NRF52840 as USB peripheral and USB host.
Hi Everyone,
                 I am using NRF52840 in my project and working on sdk 17.0.2. My application includes the following:-
1) Send aquired data from sensors to the desktop via USB.
2) Receive data from the desktop application via USB.
We are also using MAX3421E IC which is connected to NRF52840 via SPI interface. This IC is basically a USB Interface IC which can be configured as USB Peripheral/Host Controller with SPI Interface.
I am new to this USB development. I know I will have to include libraries of MAX3421e IC and configure it via SPI through the NRF52840. I am confused on the part of how will the data be sent from nrf52840 to the desktop application and vice versa. Do I need to add any peripheral libraries for nrf52840 so that it can send the data???
Or MAX342 will do the sending part. I am reading the documentation also but quite confused on the working.
Can anyone please help?
Thank you,
Snehal.
  • The section placement macros you posted earlier appear to be for the nRF52833, not the nRF52840 which has 256K of RAM and 1MB of flash. Please use the 'pca10056' configuration for the ble_app_hrs_freertos example as a reference for what values to use.
  • Hi Vidar,
               I changed the values according to the ble_app_hrs_freertos example.
    FLASH_PH_START=0x0
    FLASH_PH_SIZE=0x100000
    RAM_PH_START=0x20000000
    RAM_PH_SIZE=0x40000
    FLASH_START=0x27000
    FLASH_SIZE=0xd9000
    RAM_START=0x20005978
    RAM_SIZE=0x3a688
    FLASH RX 0x0 0x100000;RAM1 RWX 0x20000000 0x40000
    But still it is giving me the same errors. I guess the issue is in usb file attached below.
    The RAM_BLOCK_DEVICE_SIZE is defined as (380 * 512) which is taking a lot of space I assume.
    When I change it to (100*100) I am able to compile the code.
    But the code says Windows fails to format volumes smaller than 190KB.
    Can you suggest something?
    #include <stdint.h>
    #include <stdbool.h>
    #include <stddef.h>
    #include <inttypes.h>
    #include <stdlib.h>
    #include "nrf.h"
    #include "nrf_block_dev.h"
    #include "nrf_block_dev_ram.h"
    #include "nrf_block_dev_empty.h"
    #include "nrf_block_dev_qspi.h"
    #include "nrf_block_dev_sdc.h"
    #include "nrf_drv_usbd.h"
    #include "nrf_drv_clock.h"
    #include "nrf_gpio.h"
    #include "nrf_atomic.h"
    #include "nrf_drv_power.h"
    #include "ff.h"
    #include "diskio_blkdev.h"
    #include "app_usbd.h"
    #include "app_usbd_core.h"
    #include "app_usbd_string_desc.h"
    #include "app_usbd_msc.h"
    #include "app_error.h"
    #include "app_timer.h"
    #include "bsp.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define BTN_RANDOM_FILE  0
    #define BTN_LIST_DIR     1
    #define BTN_MKFS         2
    #define KEY_EV_RANDOM_FILE_MSK (1U << BTN_RANDOM_FILE)
    #define KEY_EV_LIST_DIR_MSK    (1U << BTN_LIST_DIR   )
    #define KEY_EV_MKFS_MSK        (1U << BTN_MKFS       )
     * @brief Enable power USB detection
     * Configure if example supports USB port connection
    #ifndef USBD_POWER_DETECTION
    #define USBD_POWER_DETECTION true
     * @brief SD card enable/disable
    #define USE_SD_CARD       1
     * @brief FatFS for QPSI enable/disable
    #define USE_FATFS_QSPI    1
     * @brief Mass storage class user event handler
    static void msc_user_ev_handler(app_usbd_class_inst_t const * p_inst,
                                    app_usbd_msc_user_event_t     event);
     * @brief Ram block device size
     * @note Windows fails to format volumes smaller than 190KB
    #define RAM_BLOCK_DEVICE_SIZE (380 * 512)
    //#define RAM_BLOCK_DEVICE_SIZE (100 * 100)
     * @brief  RAM block device work buffer
    static uint8_t m_block_dev_ram_buff[RAM_BLOCK_DEVICE_SIZE];
     * @brief  RAM block device definition
    NRF_BLOCK_DEV_RAM_DEFINE(
        m_block_dev_ram,
        NRF_BLOCK_DEV_RAM_CONFIG(512, m_block_dev_ram_buff, sizeof(m_block_dev_ram_buff)),
        NFR_BLOCK_DEV_INFO_CONFIG("Nordic", "RAM", "1.00")
     * @brief Empty block device definition
    NRF_BLOCK_DEV_EMPTY_DEFINE(
        m_block_dev_empty,
        NRF_BLOCK_DEV_EMPTY_CONFIG(512, 1024 * 1024),
        NFR_BLOCK_DEV_INFO_CONFIG("Nordic", "EMPTY", "1.00")
     * @brief  QSPI block device definition
    NRF_BLOCK_DEV_QSPI_DEFINE(
        m_block_dev_qspi,
        NRF_BLOCK_DEV_QSPI_CONFIG(
            512,
            NRF_BLOCK_DEV_QSPI_FLAG_CACHE_WRITEBACK,
            NRF_DRV_QSPI_DEFAULT_CONFIG
         NFR_BLOCK_DEV_INFO_CONFIG("Nordic", "QSPI", "1.00")
    #if USE_SD_CARD
    #define SDC_SCK_PIN     (25)        //(27)        ///< SDC serial clock (SCK) pin.
    #define SDC_MOSI_PIN    (23)        //(26)        ///< SDC serial data in (DI) pin.
    #define SDC_MISO_PIN    (24)        //(2)         ///< SDC serial data out (DO) pin.
    #define SDC_CS_PIN      (15)        //(32 + 15)   ///< SDC chip select (CS) pin.
     * @brief  SDC block device definition
    NRF_BLOCK_DEV_SDC_DEFINE(
        m_block_dev_sdc,
        NRF_BLOCK_DEV_SDC_CONFIG(
            SDC_SECTOR_SIZE,
            APP_SDCARD_CONFIG(SDC_MOSI_PIN, SDC_MISO_PIN, SDC_SCK_PIN, SDC_CS_PIN)
         NFR_BLOCK_DEV_INFO_CONFIG("Nordic", "SDC", "1.00")
     * @brief Block devices list passed to @ref APP_USBD_MSC_GLOBAL_DEF
    #define BLOCKDEV_LIST() (                                   \
        NRF_BLOCKDEV_BASE_ADDR(m_block_dev_ram, block_dev),     \
        NRF_BLOCKDEV_BASE_ADDR(m_block_dev_empty, block_dev),   \
        NRF_BLOCKDEV_BASE_ADDR(m_block_dev_qspi, block_dev),    \
        NRF_BLOCKDEV_BASE_ADDR(m_block_dev_sdc, block_dev)      \
    #else
        NRF_BLOCKDEV_BASE_ADDR(m_block_dev_qspi, block_dev)     \
     * @brief Endpoint list passed to @ref APP_USBD_MSC_GLOBAL_DEF
    #define ENDPOINT_LIST() APP_USBD_MSC_ENDPOINT_LIST(1, 1)
     * @brief Mass storage class work buffer size
    #define MSC_WORKBUFFER_SIZE (1024)
    /*lint -save -e26 -e64 -e123 -e505 -e651*/
     * @brief Mass storage class instance
    APP_USBD_MSC_GLOBAL_DEF(m_app_msc,
                            0,
                            msc_user_ev_handler,
                            ENDPOINT_LIST(),
                            BLOCKDEV_LIST(),
                            MSC_WORKBUFFER_SIZE);
    /*lint -restore*/
     * @brief Events from keys
    static nrf_atomic_u32_t m_key_events;
     * @brief  USB connection status
    static bool m_usb_connected = false;
    #if USE_FATFS_QSPI
    static FATFS m_filesystem;
    static bool fatfs_init(void)
        FRESULT ff_result;
        DSTATUS disk_state = STA_NOINIT;
        memset(&m_filesystem, 0, sizeof(FATFS));
        // Initialize FATFS disk I/O interface by providing the block device.
        static diskio_blkdev_t drives[] =
            DISKIO_BLOCKDEV_CONFIG(NRF_BLOCKDEV_BASE_ADDR(m_block_dev_qspi, block_dev), NULL)
        diskio_blockdev_register(drives, ARRAY_SIZE(drives));
        NRF_LOG_INFO("Initializing disk 0 (QSPI)...");
        disk_state = disk_initialize(0);
        if (disk_state)
            NRF_LOG_ERROR("Disk initialization failed.");
            return false;
        NRF_LOG_INFO("Mounting volume...");
        ff_result = f_mount(&m_filesystem, "", 1);
        if (ff_result != FR_OK)
            if (ff_result == FR_NO_FILESYSTEM)
                NRF_LOG_ERROR("Mount failed. Filesystem not found. Please format device.");
                NRF_LOG_ERROR("Mount failed: %u", ff_result);
            return false;
        return true;
    static void fatfs_mkfs(void)
        FRESULT ff_result;
        if (m_usb_connected)
            NRF_LOG_ERROR("Unable to operate on filesystem while USB is connected");
            return;
        NRF_LOG_INFO("\r\nCreating filesystem...");
        static uint8_t buf[512];
        ff_result = f_mkfs("", FM_FAT, 1024, buf, sizeof(buf));
            NRF_LOG_ERROR("Mkfs failed.");
            return;
            NRF_LOG_ERROR("Mount failed.");
            return;
        NRF_LOG_INFO("Done");
    static void fatfs_ls(void)
        DIR dir;
        FRESULT ff_result;
        FILINFO fno;
            return;
        NRF_LOG_INFO("\r\nListing directory: /");
        ff_result = f_opendir(&dir, "/");
            NRF_LOG_ERROR("Directory listing failed: %u", ff_result);
            return;
        uint32_t entries_count = 0;
        do
            ff_result = f_readdir(&dir, &fno);
                NRF_LOG_ERROR("Directory read failed: %u", ff_result);
                return;
            if (fno.fname[0])
                if (fno.fattrib & AM_DIR)
                    NRF_LOG_RAW_INFO("   <DIR>   %s\r\n",(uint32_t)fno.fname);
                    NRF_LOG_RAW_INFO("%9lu  %s\r\n", fno.fsize, (uint32_t)fno.fname);
            ++entries_count;
            NRF_LOG_FLUSH();
        } while (fno.fname[0]);
        NRF_LOG_RAW_INFO("Entries count: %u\r\n", entries_count);
    static void fatfs_file_create(void)
        FRESULT ff_result;
        FIL file;
        char filename[16];
            return;
        (void)snprintf(filename, sizeof(filename), "%08x.txt", rand());
        NRF_LOG_RAW_INFO("Creating random file: %s ...", (uint32_t)filename);
        NRF_LOG_FLUSH();
        ff_result = f_open(&file, filename, FA_CREATE_ALWAYS | FA_WRITE);
            NRF_LOG_ERROR("\r\nUnable to open or create file: %u", ff_result);
            NRF_LOG_FLUSH();
            return;
        ff_result = f_close(&file);
            NRF_LOG_ERROR("\r\nUnable to close file: %u", ff_result);
            NRF_LOG_FLUSH();
            return;
        NRF_LOG_RAW_INFO("done\r\n");
    static void fatfs_uninit(void)
        NRF_LOG_INFO("Un-initializing disk 0 (QSPI)...");
        UNUSED_RETURN_VALUE(disk_uninitialize(0));
    #else //USE_FATFS_QSPI
    #define fatfs_init()        false
    #define fatfs_mkfs()        do { } while (0)
    #define fatfs_ls()          do { } while (0)
    #define fatfs_file_create() do { } while (0)
    #define fatfs_uninit()      do { } while (0)
     * @brief Class specific event handler.
     * @param p_inst    Class instance.
     * @param event     Class specific event.
        UNUSED_PARAMETER(p_inst);
        UNUSED_PARAMETER(event);
     * @brief USBD library specific event handler.
     * @param event     USBD library event.
    static void usbd_user_ev_handler(app_usbd_event_type_t event)
        switch (event)
            case APP_USBD_EVT_DRV_SUSPEND:
                NRF_LOG_INFO("APP_USBD_EVT_DRV_SUSPEND");
            case APP_USBD_EVT_DRV_RESUME:
                NRF_LOG_INFO("APP_USBD_EVT_DRV_RESUME");
            case APP_USBD_EVT_STARTED:
                NRF_LOG_INFO("APP_USBD_EVT_STARTED");
            case APP_USBD_EVT_STOPPED:
                UNUSED_RETURN_VALUE(fatfs_init());
                app_usbd_disable();
               // bsp_board_leds_off();
            case APP_USBD_EVT_POWER_DETECTED:
                NRF_LOG_INFO("USB power detected");
                if (!nrf_drv_usbd_is_enabled())
                    fatfs_uninit();
                    app_usbd_enable();
            case APP_USBD_EVT_POWER_REMOVED:
                NRF_LOG_INFO("USB power removed");
                app_usbd_stop();
            case APP_USBD_EVT_POWER_READY:
                NRF_LOG_INFO("USB ready");
                app_usbd_start();
                m_usb_connected = true;
    static void bsp_event_callback(bsp_event_t ev)
        switch (ev)
            /* Just set a flag to be processed in the main loop */
            case CONCAT_2(BSP_EVENT_KEY_, BTN_RANDOM_FILE):
                UNUSED_RETURN_VALUE(nrf_atomic_u32_or(&m_key_events, KEY_EV_RANDOM_FILE_MSK));
            case CONCAT_2(BSP_EVENT_KEY_, BTN_LIST_DIR):
                UNUSED_RETURN_VALUE(nrf_atomic_u32_or(&m_key_events, KEY_EV_LIST_DIR_MSK));
            case CONCAT_2(BSP_EVENT_KEY_, BTN_MKFS):
                UNUSED_RETURN_VALUE(nrf_atomic_u32_or(&m_key_events, KEY_EV_MKFS_MSK));
                return; // no implementation needed
    void usbd_msc_task(void)
        ret_code_t ret;
        static const app_usbd_config_t usbd_config = {
            .ev_state_proc = usbd_user_ev_handler
        ret = NRF_LOG_INIT(app_usbd_sof_timestamp_get);
        APP_ERROR_CHECK(ret);
        /* Fill whole RAM block device buffer */
        for (size_t i = 0; i < sizeof(m_block_dev_ram_buff); ++i)
            m_block_dev_ram_buff[i] = i;
        /* Configure LEDs and buttons */
        //ret = bsp_init(BSP_INIT_BUTTONS, bsp_event_callback);
        //APP_ERROR_CHECK(ret);
        //bsp_board_init(BSP_INIT_LEDS);
        if (fatfs_init())
            fatfs_ls();
            fatfs_file_create();
        ret = app_usbd_init(&usbd_config);
        app_usbd_class_inst_t const * class_inst_msc = app_usbd_msc_class_inst_get(&m_app_msc);
        ret = app_usbd_class_append(class_inst_msc);
        NRF_LOG_INFO("USBD MSC example started.");
        if (USBD_POWER_DETECTION)
            ret = app_usbd_power_events_enable();
            NRF_LOG_INFO("No USB power detection enabled\r\nStarting USB now");
            app_usbd_enable();
            app_usbd_start();
        while (true)
            while (app_usbd_event_queue_process())
                /* Nothing to do */
            /* Process BSP key events flags.*/
            uint32_t events = nrf_atomic_u32_fetch_store(&m_key_events, 0);
            if (events & KEY_EV_RANDOM_FILE_MSK)
            if (events & KEY_EV_LIST_DIR_MSK)
                fatfs_ls();
            if (events & KEY_EV_MKFS_MSK)
                fatfs_mkfs();
            UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
            /* Sleep CPU only if there was no interrupt since last loop processing */
            __WFE();
    Thanks & Regards,
    Snehal.
  • Hi Snehal,
    What is the RAM disk going to be used for?
    Vidar
  • Hi Vidar,
                My goal is to create a file inside the flash memory chip. And when USB is plugged into the device it should be seen as a drive on laptop/desktop and I should be able to access the file which was created in the flash chip.
    Snehal
