MCUBoot SPI Flash Image
I cannot get MCUBoot to create a image on external spi flash. Using the spi_flash sample I can read/write/erase fine with spi flash configuration in my device tree.
I am creating a child_image for mcuboot which contains mcuboot.conf and the board.overlay file.
Relevant details:
Version: Nordic Connect SDK v2.0.0
Board: Custom NRF52832 - Using nrf52dk_nrf52832.overlay
partitions.yml:
app:
  address: 0xc200
  end_address: 0x80000
  region: flash_primary
external_flash:
  address: 0x74000
  region: external_flash
mcuboot:
  address: 0x0
  end_address: 0xc000
  placement:
    before:
    - mcuboot_primary
mcuboot_pad:
  address: 0xc000
  end_address: 0xc200
  placement:
    align:
      start: 0x1000
    before:
    - mcuboot_primary_app
mcuboot_primary:
  address: 0xc000
  orig_span: &id001
  - app
  - mcuboot_pad
  span: *id001
mcuboot_primary_app:
  address: 0xc200
  orig_span: &id002
  - app
  span: *id002
mcuboot_secondary:
  address: 0x0
  device: /soc/spi@40003000/at25df041b@0
  end_address: 0x74000
  placement:
    align:
      start: 0x4
  share_size:
  - mcuboot_primary
sram_primary:
  address: 0x20000000
  end_address: 0x20010000
  region: sram_primary
.overlay: Used for both MCUBoot and main.
	chosen {
		nordic,pm-ext-flash = &at25df041b;
 &pinctrl {
 spi0_default_alt: spi0_default_alt {
		group1 {
			psels = <NRF_PSEL(SPIM_SCK, 0, 9)>,
				<NRF_PSEL(SPIM_MOSI, 0, 10)>,
				<NRF_PSEL(SPIM_MISO, 0, 8)>;
	spi0_sleep_alt: spi0_sleep_alt {
		group1 {
			low-power-enable;
		uart0_default: uart0_default {
		group1 {
			psels = <NRF_PSEL(UART_TX, 0, 20)>,
				<NRF_PSEL(UART_RX, 0, 19)>,
				<NRF_PSEL(UART_RTS, 0, 5)>,
				<NRF_PSEL(UART_CTS, 0, 24)>;
	uart0_sleep: uart0_sleep {
		group1 {
			low-power-enable;
&spi0 {
	status = "okay";
	label = "SPI_0";
	pinctrl-0 = <&spi0_default_alt>;
	pinctrl-1 = <&spi0_sleep_alt>;
	cs-gpios = <&gpio0 6 GPIO_ACTIVE_LOW>;
	at25df041b: at25df041b@0 {
		compatible = "jedec,spi-nor";
		label = "AT25DF041B";
		spi-max-frequency = <1000000>;
		reg = <0>;
		jedec-id = [ 1F 44 02 ];
		size = <0x400000>;
		has-dpd;
		t-enter-dpd = <10000>;
		t-exit-dpd = <35000>;
		wp-gpios = <&gpio0 7 GPIO_ACTIVE_LOW>;
		hold-gpios = <&gpio0 11 GPIO_ACTIVE_LOW>;
		has-lock = <0xff>;
&pwm0 {
	status = "disabled";
prj.conf:
CONFIG_SPI=y
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_NFCT_PINS_AS_GPIOS=y
CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
mcuboot.conf:
CONFIG_MAIN_STACK_SIZE=10240
CONFIG_SPI=y
CONFIG_FLASH=y
CONFIG_BOOT_MAX_IMG_SECTORS=1024
CONFIG_LOG=y
CONFIG_LOG_MODE_IMMEDIATE=y
CONFIG_LOG_DEFAULT_LEVEL=4
CONFIG_PRINTK=y
CONFIG_LOG_MODE_MINIMAL=n
CONFIG_UART_CONSOLE=y
CONFIG_RTT_CONSOLE=n
CONFIG_CONSOLE_HANDLER=y
# If you don't add this when setting CONFIG_SPI=y, you'll get a lot of undefined references from the nrfx spim driver
# E.G. "undefined reference to `z_impl_k_sleep'"
CONFIG_MULTITHREADING=y
CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
Output:
I can't seem to understand why this configuration would work for the main program but mcuboot doesn't work.
I have tried almost every prj.conf, mcuboot.conf and pm_static.yml configurations I can think of with no luck.
Any ideas on what might be causing this? Changing CONFIG_BOOT_MAX_IMG_SECTORS doesn't seem to change anything.
Thanks for any help you can provide.
