OK, I see you are getting a permission error when it tries to open COM8 (10-Jan-2023 12:48:38 (+0100) ERROR: Error opening UART could not open port 'COM8': PermissionError(13, 'Acceso denegado.', None, 5)). Any chance this port may be kept open by another program like a serial terminal emulator?
Apparently not, I don't have any serial port terminal opened
OK, can you clear the log and check if you get the same permission error after a reboot of your PC?
1673363398.5505974
10-Jan-2023 16:09:58 (+0100) INFO: --------------------------------------------------------
10-Jan-2023 16:09:58 (+0100) INFO: Software version: 4.1.0
10-Jan-2023 16:09:58 (+0100) INFO: Software version: 4.1.1
10-Jan-2023 16:09:58 (+0100) INFO: Started PID 11356
10-Jan-2023 16:09:58 (+0100) INFO: Namespace(capture=False, extcap_interfaces=True, extcap_interface=None, extcap_dlts=False, extcap_config=False, extcap_capture_filter=None, fifo=None, extcap_control_in=None, extcap_control_out=None, extcap_version='4.0', device='', baudrate=None, only_advertising=False, only_legacy_advertising=False, scan_follow_rsp=False, scan_follow_aux=False, coded=False)
10-Jan-2023 16:09:58 (+0100) INFO: Opening serial port COM8
10-Jan-2023 16:09:58 (+0100) INFO: Started PID 11200
10-Jan-2023 16:09:58 (+0100) ERROR: Error opening UART could not open port 'COM8': PermissionError(13, 'Acceso denegado.', None, 5)
File "C:\Program Files\Wireshark\extcap\SnifferAPI\Packet.py", line 74, in __init__
self.uart = UART.Uart(portnum, baudrate)
File "C:\Program Files\Wireshark\extcap\SnifferAPI\UART.py", line 124, in __init__
self.ser = serial.Serial(
File "C:\Users\Laura\AppData\Local\Programs\Python\Python311\Lib\site-packages\pyserial-3.5-py3.11.egg\serial\serialwin32.py", line 33, in __init__
super(Serial, self).__init__(*args, **kwargs)
File "C:\Users\Laura\AppData\Local\Programs\Python\Python311\Lib\site-packages\pyserial-3.5-py3.11.egg\serial\serialutil.py", line 244, in __init__
self.open()
File "C:\Users\Laura\AppData\Local\Programs\Python\Python311\Lib\site-packages\pyserial-3.5-py3.11.egg\serial\serialwin32.py", line 64, in open
raise SerialException("could not open port {!r}: {!r}".format(self.portstr, ctypes.WinError()))
serial.serialutil.SerialException: could not open port 'COM8': PermissionError(13, 'Acceso denegado.', None, 5)
10-Jan-2023 16:09:58 (+0100) INFO: Opening serial port None
self.open()
10-Jan-2023 16:09:58 (+0100) INFO: Opening serial port COM1
10-Jan-2023 16:09:58 (+0100) ERROR: Error opening UART Cannot configure port, something went wrong. Original message: OSError(22, 'El par�metro no es correcto.', None, 87)
File "C:\Program Files\Wireshark\extcap\SnifferAPI\UART.py", line 130, in __init__
self.ser.baudrate = baudrate
File "C:\Users\Laura\AppData\Local\Programs\Python\Python311\Lib\site-packages\pyserial-3.5-py3.11.egg\serial\serialutil.py", line 299, in baudrate
self._reconfigure_port()
File "C:\Users\Laura\AppData\Local\Programs\Python\Python311\Lib\site-packages\pyserial-3.5-py3.11.egg\serial\serialwin32.py", line 222, in _reconfigure_port
serial.serialutil.SerialException: Cannot configure port, something went wrong. Original message: OSError(22, 'El par�metro no es correcto.', None, 87)
10-Jan-2023 16:09:58 (+0100) INFO: Exiting PID 11200
10-Jan-2023 16:09:58 (+0100) INFO: closing UART
10-Jan-2023 16:09:59 (+0100) INFO: closing UART
10-Jan-2023 16:09:59 (+0100) INFO: Opening serial port COM1
10-Jan-2023 16:09:59 (+0100) ERROR: Error opening UART Cannot configure port, something went wrong. Original message: OSError(22, 'El par�metro no es correcto.', None, 87)
File "C:\Users\Laura\AppData\Roaming\Wireshark\extcap\SnifferAPI\Packet.py", line 74, in __init__
File "C:\Users\Laura\AppData\Roaming\Wireshark\extcap\SnifferAPI\UART.py", line 130, in __init__
10-Jan-2023 16:09:59 (+0100) INFO: Opening serial port None
10-Jan-2023 16:09:59 (+0100) INFO: Exiting PID 11356
Have you tried to see if you are able to open COM8 from another application such as TeraTerm, etc?
