To power ON & OFF sysem using single button in nrf52810
hello everyone,
         I am designing a device which is operated with coin cell battery, I want to turn on & turn off a device using single button. when device in on mode it should read the sensor data and send to mobile over BLE. if I turn off device I don't want to perform any task and it should be completely in off mode and power consumption should be in few nano amps.
Please help me to perform this task.
thank you
    thanks for your response, and sorry for late reply.
    actually in my case a button is used to control system off and system on. in system on case, power consumption is taking 1mA after using gpiote pin interrupt, but my requirement is power consumption should less then 100uA.
    could you please suggest me
    ''in system on case, power consumption is taking 1mA after using gpiote pin interrupt, but my requirement is power consumption should less than 100uA. '' - If the nRF52 is drawing 1mA current then it is not in System OFF mode. It should be closer to 1uA.
    Do you have infinite loop after entering system off mode in the code? that could trigger to make system on again. You can look from this point of view, and also if you want can post your code here. I can make the case private.
    Thanks.
    BR
    Kazi
    in my project i used saadc, light sensor, temperature sensor, inbult temperature sensor and BLE .
    for every 30 sec i need to push sensor data to mobile app over ble, here button is used to turn on and turn off the device. for button interface i used gpiote is used. after using gpiote, power consumption is 1mA. if i remove gpiote it consume below 500ua. i enable all the sensors at that interval and update and disable.
    i have attached the code below
    #include <stdbool.h>
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "app_timer.h"
    #include "fds.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #include "bsp_btn_ble.h"
    #include "sensorsim.h"
    #include "ble_conn_state.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_temp.h"
    #include "nrf_drv_saadc.h"
    #include "nrf_drv_ppi.h"
    #include "nrf_drv_timer.h"
    #include "nrf_drv_clock.h"
    #include "nrf_drv_twi.h"
    #include "boards.h"
    #include "nrf_drv_gpiote.h"
    #include "nrf_gpio.h"
    #include "nrf_delay.h"
    #include <stdio.h>
    #include "ds18b20.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define SAMPLES_IN_BUFFER 2
    volatile uint8_t state = 1;
    static float temp = 0;
      int32_t volatile temp1;
    static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(1);
    static nrf_saadc_value_t     m_buffer_pool[2][SAMPLES_IN_BUFFER];
    static nrf_ppi_channel_t     m_ppi_channel;
    static uint32_t              m_adc_evt_counter;
    #define TWI_INSTANCE_ID     0
    //#define LM75B_ADDR          (0x46U >> 1)
    #define LM75B_ADDR          0x23
    static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
    /* Buffer for samples read from temperature sensor. */
    #define DEVICE_NAME                     "Nordic_Template"                       /**< Name of device. Will be included in the advertising data. */
    #define MANUFACTURER_NAME               "NordicSemiconductor"                   /**< Manufacturer. Will be passed to Device Information Service. */
    #define APP_ADV_INTERVAL                300                                     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
    #define APP_ADV_DURATION                0                                   /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.1 seconds). */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.2 second). */
    #define SLAVE_LATENCY                   0                                       /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory timeout (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                   /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define SEC_PARAM_BOND                  1                                       /**< Perform bonding. */
    #define SEC_PARAM_MITM                  0                                       /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC                  0                                       /**< LE Secure Connections not enabled. */
    #define SEC_PARAM_KEYPRESS              0                                       /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
    #define SEC_PARAM_OOB                   0                                       /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE          7                                       /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE          16                                      /**< Maximum encryption key size. */
    #define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
     float B_Y;
     float soil_moi;
     float soil_tem;
        uint8_t soil_moi2;
        bool flag=false;
     #define BTN 14
      #define BTN1 14
     #define RED_LED 15
     #define GREEN_LED 16
    NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                         /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                             /**< Advertising module instance. */
    APP_TIMER_DEF(m_adv_data_update_timer);                                                  /**< Advertising module instance. */
    APP_TIMER_DEF(m_adv_data_update_timer1);                                                  /**< Advertising module instance. */
    #define ADV_DATA_UPDATE_INTERVAL        APP_TIMER_TICKS(30000)
    //#define ADV_DATA_UPDATE_INTERVAL1        APP_TIMER_TICKS(10000)
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;
    static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;
    static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];                    /**< Buffer for storing an encoded advertising set. */
    static uint8_t m_enc_scan_response_data[BLE_GAP_ADV_SET_DATA_SIZE_MAX];                       /**< Handle of the current connection. */
    /* YOUR_JOB: Declare all services structure your application is using
     *  BLE_XYZ_DEF(m_xyz);
    // YOUR_JOB: Use UUIDs for service(s) used in your application.
    static ble_uuid_t m_adv_uuids[] =                                               /**< Universally unique service identifiers. */
        {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
    static void advertising_start(bool erase_bonds);
    int weather_temperature(void);
    int read_data(void);
    void saadc_sampling_event_disable(void);
    void saadc_sampling_event_enable(void);
    static void idle_state_handle(void);
    void saadc_sampling_event_init(void);
    void saadc_callback(nrf_drv_saadc_evt_t const * p_event);
    static void adv_data_update_timer_handler(void * p_context)
     bool erase_bonds;
        ret_code_t                  err_code;
        ble_advdata_manuf_data_t    manuf_data;
        static ble_advdata_t                    new_advdata;
        nrf_drv_twi_enable(&m_twi);
        err_code = nrf_drv_saadc_init(NULL, saadc_callback);
         if(soil_moi<=0.5) soil_moi2=100;
    if((0.5<soil_moi)&&(soil_moi<=1)) soil_moi2=75;
    if((1<soil_moi)&&(soil_moi<1.5)) soil_moi2=40;
    if((1.5<=soil_moi)&&(soil_moi<1.7)) soil_moi2=25;
    if((1.7<=soil_moi)) soil_moi2=0;
       temp = ds18b20_get_temp_method_2();
          temp1=weather_temperature();
        uint8_t s_T = temp;
        uint8_t S_M = soil_moi2;
        int A_T = temp1-2;
        int A_L =50;
        uint8_t B_V = B_Y;
        uint8_t data_ad[11] = {1,0,0,0,0,1,S_M,s_T,A_T,A_L,B_V};
     advertising_start(erase_bonds);
     nrf_delay_ms(100);
        new_advdata.p_manuf_specific_data = &manuf_data;
        static uint8_t payload_index = 0;
        manuf_data.company_identifier = 0x0059;
        manuf_data.data.p_data =data_ad ;
        manuf_data.data.size = sizeof(data_ad);
        err_code = ble_advertising_advdata_update(&m_advertising, &new_advdata, NULL);
        nrf_delay_ms(2000);
        saadc_sampling_event_disable();
        nrf_drv_twi_disable(&m_twi);
        err_code= sd_ble_gap_adv_stop(m_advertising.adv_handle);
    err_code= sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        nrf_gpio_pin_clear(4);
     idle_state_handle();
    //static void adv_data_update_timer1_handler(void * p_context)
    // UNUSED_PARAMETER(p_context);
    //    flag=true;
    //     //nrf_gpio_pin_toggle(RED_LED);
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in] line_num   Line number of the failing ASSERT call.
     * @param[in] file_name  File name of the failing ASSERT call.
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    static void pm_evt_handler(pm_evt_t const * p_evt)
        pm_handler_on_pm_evt(p_evt);
        pm_handler_disconnect_on_sec_failure(p_evt);
        pm_handler_flash_clean(p_evt);
        switch (p_evt->evt_id)
                advertising_start(false);
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module. This creates and starts application timers.
    static void timers_init(void)
        // Initialize timer module.
         // lfclk_config();
         err_code = app_timer_create(&m_adv_data_update_timer,
                                      APP_TIMER_MODE_REPEATED,
                                      adv_data_update_timer_handler);
        // err_code = app_timer_create(&m_adv_data_update_timer1,
        //                              APP_TIMER_MODE_REPEATED,
        //                              adv_data_update_timer1_handler);
        //APP_ERROR_CHECK(err_code);
        // Create timers.
        /* YOUR_JOB: Create any timers to be used by the application.
                     Below is an example of how to create a timer.
                     For every new timer needed, increase the value of the macro APP_TIMER_MAX_TIMERS by
                     one.
           err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
           APP_ERROR_CHECK(err_code); */
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
        /* YOUR_JOB: Use an appearance value matching the application's use case.
           err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
        APP_ERROR_HANDLER(nrf_error);
        /* YOUR_JOB: Add code to initialize the services used by the application.
           ble_xxs_init_t                     xxs_init;
           ble_yys_init_t                     yys_init;
           // Initialize XXX Service.
           memset(&xxs_init, 0, sizeof(xxs_init));
           xxs_init.evt_handler                = NULL;
           xxs_init.is_xxx_notify_supported    = true;
           xxs_init.ble_xx_initial_value.level = 100;
           err_code = ble_bas_init(&m_xxs, &xxs_init);
           // Initialize YYY Service.
           memset(&yys_init, 0, sizeof(yys_init));
           yys_init.evt_handler                  = on_yys_evt;
           yys_init.ble_yy_initial_value.counter = 0;
           err_code = ble_yy_service_init(&yys_init, &yy_init);
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module which
     *          are passed to the application.
     *          @note All this function does is to disconnect. This could have been done by simply
     *                setting the disconnect_on_fail config parameter, but instead we use the event
     *                handler mechanism to demonstrate its use.
    /**@brief Function for handling a Connection Parameters error.
    /**@brief Function for starting timers.
    static void application_timers_start(void)
        /* YOUR_JOB: Start your timers. below is an example of how to start a timer.
           err_code = app_timer_start(m_app_timer_id, TIMER_INTERVAL, NULL);
           err_code = app_timer_start(m_adv_data_update_timer,
                                        ADV_DATA_UPDATE_INTERVAL,
                                        NULL);
           // err_code = app_timer_start(m_adv_data_update_timer1,
           //                             ADV_DATA_UPDATE_INTERVAL1,
           //                             NULL);
        //// Prepare wakeup buttons.
        //err_code = bsp_btn_ble_sleep_mode_prepare();
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                NRF_LOG_INFO("Fast advertising.");
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        ret_code_t err_code = NRF_SUCCESS;
                NRF_LOG_INFO("Disconnected.");
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected.");
                //err_code = bsp_indication_set(BSP_INDICATE_CONNECTED);
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for the Peer Manager initialization.
    static void peer_manager_init(void)
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
    /**@brief Clear bond information from persistent storage.
    static void delete_bonds(void)
        NRF_LOG_INFO("Erase bonds!");
        err_code = pm_peers_delete();
     * @param[in]   event   Event generated when button is pressed.
    //static void bsp_event_handler(bsp_event_t event)
    //    ret_code_t err_code;
    //    switch (event)
    //        case BSP_EVENT_SLEEP:
    //            sleep_mode_enter();
    //            break; // BSP_EVENT_SLEEP
    //        case BSP_EVENT_DISCONNECT:
    //            err_code = sd_ble_gap_disconnect(m_conn_handle,
    //                                             BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
    //            if (err_code != NRF_ERROR_INVALID_STATE)
    //                APP_ERROR_CHECK(err_code);
    //            break; // BSP_EVENT_DISCONNECT
    //        case BSP_EVENT_WHITELIST_OFF:
    //            if (m_conn_handle == BLE_CONN_HANDLE_INVALID)
    //                err_code = ble_advertising_restart_without_whitelist(&m_advertising);
    //            break; // BSP_EVENT_KEY_0
    //        default:
    //            break;
        ble_advertising_init_t init;
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = true;
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    //static void buttons_leds_init(bool * p_erase_bonds)
    //    bsp_event_t startup_event;
    //    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    //    err_code = bsp_btn_ble_init(NULL, &startup_event);
    //    *p_erase_bonds = (startup_event == BSP_EVENT_CLEAR_BONDING_DATA);
    static void log_init(void)
            nrf_pwr_mgmt_run();
        if (erase_bonds == true)
            delete_bonds();
            // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
            ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    //static void lfclk_config(void)
    //    ret_code_t err_code = nrf_drv_clock_init();                        //Initialize the clock source specified in the nrf_drv_config.h file, i.e. the CLOCK_CONFIG_LF_SRC constant
    //    nrf_drv_clock_lfclk_request(NULL);
      void timer_handler(nrf_timer_event_t event_type, void * p_context)
        /* setup m_timer for compare event every 400ms */
        uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 400);
                                       NRF_TIMER_CC_CHANNEL0,
                                       ticks,
                                       NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                       false);
        uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
        NRF_TIMER_CC_CHANNEL0);
                                              timer_compare_event_addr,
                                              saadc_sample_task_addr);
     nrf_gpio_pin_set(4);
    { nrf_gpio_pin_clear(4);
        ret_code_t err_code = nrf_drv_ppi_channel_disable(m_ppi_channel);
            err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
            //int i;
            //NRF_LOG_INFO("ADC event number: %d", (int)m_adc_evt_counter);
           //for (int i = 0; i < SAMPLES_IN_BUFFER; i++)
              //soil_moi = (p_event->data.done.p_buffer[0]*3.6)/1024;
              // soil_tem = (p_event->data.done.p_buffer[1]*3.6)/1024;
                  soil_moi =p_event->data.done.p_buffer[0]*3.6/1024;
                   B_Y = p_event->data.done.p_buffer[1]/8.8f;
                   //printf("soil_moi1=",soil_moi1);
                   //printf(" B_Y=", B_Y);
                //soil_moi=soil_moi1*3.6/1024;
                //if(soil_moi1<1) soil_moi=100;
                //if(1<soil_moi1<1.5) soil_moi=75;
                //if(1.5<soil_moi1<2) soil_moi=45;
                //if(2<soil_moi1) soil_moi=20;
                   //soil_tem=(soil_tem1-0.5f)*100;
    NRF_LOG_INFO("VOLTAGE1 :%d\n",soil_moi);
             //NRF_LOG_INFO("VOLTAGE2 :%f\n",soil_tem1);
             NRF_LOG_INFO("Battery percentage:%d\n", B_Y);
             //NRF_LOG_INFO("soil_percentage :%d\n",soil_moi);
            //m_adc_evt_counter++;
    void saadc_init(void)
        nrf_saadc_channel_config_t channel_0_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN3);
        nrf_saadc_channel_config_t channel_1_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_VDD);
        err_code = nrf_drv_saadc_channel_init(0, &channel_0_config);
        err_code = nrf_drv_saadc_channel_init(1, &channel_1_config);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
    //while(1)
     NRF_TEMP->TASKS_START = 1; /** Start the temperature measurement. */
            /* Busy wait while temperature measurement is not finished, you can skip waiting if you enable interrupt for DATARDY event and read the result in the interrupt. */
            /*lint -e{845} // A zero has been given as right argument to operator '|'" */
            while (NRF_TEMP->EVENTS_DATARDY == 0)
                // Do nothing.
            NRF_TEMP->EVENTS_DATARDY = 0;
            /**@note Workaround for PAN_028 rev2.0A anomaly 29 - TEMP: Stop task clears the TEMP register. */
            temp1 = (nrf_temp_read() / 4);
            /**@note Workaround for PAN_028 rev2.0A anomaly 30 - TEMP: Temp module analog front end does not power down when DATARDY event occurs. */
            NRF_TEMP->TASKS_STOP = 1; /** Stop the temperature measurement. */
            NRF_LOG_INFO("Actual temperature: %d", (int)temp1);
            //nrf_delay_ms(500);
            return  temp1;
            NRF_LOG_FLUSH();
    void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
    { //int counter=0;
        _Bool repeat=0;
        //nrf_drv_gpiote_out_toggle(PIN_OUT);
      if((nrf_gpio_pin_read(BTN)==0)&&(flag==false))
                                  flag=true;
                                    //Turn off LED to indicate the nRF5x is in System-off mode
    				nrf_drv_gpiote_out_set(RED_LED);
    			nrf_delay_ms(500);
                            //NRF_POWER->SYSTEMOFF = 1;
    				//Disable power-down button to prevent System-off wakeup
    				nrf_drv_gpiote_in_uninit(BTN);
                          nrf_drv_gpiote_in_event_disable(BTN);
    				//Configure wake-up button
    				nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_HITOLO(false);     //Configure to generate interrupt and wakeup on pin signal low. "false" means that gpiote will use the PORT event, which is low power, i.e. does not add any noticable current consumption (<<1uA). Setting this to "true" will make the gpiote module use GPIOTE->IN events which add ~8uA for nRF52 and ~1mA for nRF51.
    				in_config.pull = NRF_GPIO_PIN_PULLUP;                                            //Configure pullup for input pin to prevent it from floting. Pin is pulled down when button is pressed on nRF5x-DK boards, see figure two in http://infocenter.nordicsemi.com/topic/com.nordic.infocenter.nrf52/dita/nrf52/development/dev_kit_v1.1.0/hw_btns_leds.html?cp=2_0_0_1_4
    				err_code = nrf_drv_gpiote_in_init(BTN1, &in_config, NULL);             //Initialize the wake-up pin
    				APP_ERROR_CHECK(err_code);                                                       //Check error code returned
    				nrf_drv_gpiote_in_event_enable(BTN1, true);                            //Enable event and interrupt for the wakeup pin
    			 nrf_drv_gpiote_out_clear(RED_LED);
    				//Enter System-off
    static void gpio_init(void)
        nrf_gpio_cfg_output(RED_LED);
        nrf_gpio_cfg_output(GREEN_LED);
        nrf_gpio_cfg_output(4);
        nrf_drv_gpiote_out_config_t out_config = GPIOTE_CONFIG_OUT_SIMPLE(false);
        err_code = nrf_drv_gpiote_out_init(RED_LED, &out_config);
        nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_HITOLO(true);
        err_code = nrf_drv_gpiote_in_init(BTN, &in_config, in_pin_handler);
        nrf_drv_gpiote_in_event_enable(BTN, true);
    void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
        switch (p_event->type)
            case NRF_DRV_TWI_EVT_DONE:
                if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
                      NRF_LOG_INFO("SAMPLE RECEIVED: %d.",als_data);
                       // NRF_LOG_FLUSH();
                 if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_TX)
                     printf("TRANSFERED\r\n");
    void twi_init (void)
        const nrf_drv_twi_config_t twi_als_config = {
           .scl                = 20,
           .sda                = 18,
           .frequency          = NRF_DRV_TWI_FREQ_100K,
           .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
           .clear_bus_init     = false
        err_code = nrf_drv_twi_init(&m_twi, &twi_als_config, twi_handler, NULL);
    /**@brief Function for application main entry.
    //NRF_POWER->SYSRESET =1;
       nrf_gpio_pin_set(GREEN_LED);
            nrf_delay_ms(500);
            nrf_gpio_pin_clear(GREEN_LED);
        bool erase_bonds;
        // Initialize.
        log_init();
        gpio_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        advertising_init();
        services_init();
        conn_params_init();
        peer_manager_init();
        saadc_init();
         saadc_sampling_event_init();
        twi_init ();
        nrf_temp_init();
        ds18b20_setResolution(12);
    err_code = sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);
          err_code = sd_power_mode_set(NRF_POWER_MODE_LOWPWR);
          application_timers_start();
        // Enter main loop.
         while (true)
        sd_app_evt_wait();
    				//Enter System-on idle mode
    				//__WFE();
    				//__SEV();
    				//__WFE();
    Sorry for the late reply.
    You got 500uA without the GPIOTE and 1 mA with GPIOTE. That is very high. The GPIOTE will draw approximately 20 uA when IN events are enabled and if port event is used it is nothing.
    Can you please measure the current after commenting out the code related to ADC?
  • Hi, I achieved the low power expected at 15uA.
    thank you
