Central uart on thingy91:nrf52840 unstabile ble_data_received
I am running central_uart example on thingy91:nrf52840 it is paired up with Thingy52 running peripheral_uart example.
everything seems to run fine i send and receive msg every 5 sec.
my problem is that the ble_data_received is toggling with triggered when buffer is full (40 bytes) and end of msg that is normaly 15-20 bytes.
how can i controll this? is there any time settings or end of msg character i can use
Rune
 * Copyright (c) 2018 Nordic Semiconductor ASA
 *modifyed by rv
/** @file
 *  @brief Nordic UART Service Client sample
#include <errno.h>
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/sys/byteorder.h>
#include <zephyr/bluetooth/hci.h>
#include <zephyr/bluetooth/conn.h>
#include <zephyr/bluetooth/uuid.h>
#include <zephyr/bluetooth/gatt.h>
#include <bluetooth/services/nus.h>
#include <bluetooth/services/nus_client.h>
#include <bluetooth/gatt_dm.h>
#include <bluetooth/scan.h>
#include <zephyr/settings/settings.h>
#include <zephyr/drivers/uart.h>
#define LOG_MODULE_NAME central_uart
LOG_MODULE_REGISTER(LOG_MODULE_NAME);
/* UART payload buffer element size. */
#define UART_BUF_SIZE 40
#define KEY_PASSKEY_ACCEPT DK_BTN1_MSK
#define KEY_PASSKEY_REJECT DK_BTN2_MSK
#define NUS_WRITE_TIMEOUT K_MSEC(150)
#define UART_WAIT_FOR_BUF_DELAY K_MSEC(50)
#define UART_RX_TIMEOUT 500
static const struct device *uart = DEVICE_DT_GET(DT_NODELABEL(uart1));
static struct k_work_delayable uart_work;
K_SEM_DEFINE(nus_write_sem, 0, 1);
struct uart_data_t {
	void *fifo_reserved;
	uint8_t  data[UART_BUF_SIZE];
	uint16_t len;
struct uart_data_t *uart_rx_buf;
uint8_t  uart_tx_buf[UART_BUF_SIZE];
static K_FIFO_DEFINE(fifo_uart_tx_data);
static K_FIFO_DEFINE(fifo_uart_rx_data);
static struct bt_conn *default_conn;
static struct bt_nus_client nus_client;
bool btcon=false;
static void ble_data_sent(struct bt_nus_client *nus, uint8_t err,
					const uint8_t *const data, uint16_t len)
	ARG_UNUSED(nus);
	struct uart_data_t *buf;
	// Retrieve buffer context.
	buf = CONTAINER_OF(data, struct uart_data_t, data);
	k_free(buf);
	k_sem_give(&nus_write_sem);
	if (err) {
		LOG_WRN("ATT error code: 0x%02X", err);
static uint8_t ble_data_received(struct bt_nus_client *nus,
						const uint8_t *data, uint16_t len)
	ARG_UNUSED(nus);
		int err;
		LOG_INF("BLE data received!  %d,:%s",len,data);
		for (uint16_t x=0;x<len;x++){
			if ( data[x]=='\n' || x==len-1 ){
				uart_tx_buf[x]=data[x];
				uart_tx_buf[x+1]='\0';
				err = uart_tx(uart,uart_tx_buf, x+1, SYS_FOREVER_MS);
				if (err) {
				LOG_INF("Error Sending data over UART");
				}else{
					LOG_INF("Sending data over UART to nrf91! %d,%s",x,uart_tx_buf);
	return BT_GATT_ITER_CONTINUE;
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
	ARG_UNUSED(dev);
	int err;
	switch (evt->type) {
	case UART_RX_RDY:
		uart_rx_buf = CONTAINER_OF(evt->data.rx.buf, struct uart_data_t, data);
		uart_rx_buf->len=evt->data.rx.len;
		if (evt->data.rx.buf[uart_rx_buf->len - 1] == '\n') { // removed or '\r'
			k_fifo_put(&fifo_uart_rx_data, uart_rx_buf);
			uart_rx_disable(uart);
	case UART_RX_DISABLED:
		LOG_DBG("UART_RX_DISABLED");
		uart_rx_enable(uart, uart_rx_buf->data, sizeof(uart_rx_buf->data),
			       UART_RX_TIMEOUT);
static int uart_init(void)
	int err;
	struct uart_data_t *rx;
	if (!device_is_ready(uart)) {
		LOG_ERR("UART device not ready");
		return -ENODEV;
	rx = k_malloc(sizeof(*rx));
	if (rx) {
		rx->len = 0;
	} else {
		return -ENOMEM;
	err = uart_callback_set(uart, uart_cb, NULL);
	if (err) {
		return err;
	return uart_rx_enable(uart, rx->data, sizeof(rx->data),
			      UART_RX_TIMEOUT);
static void discovery_complete(struct bt_gatt_dm *dm,
			       void *context)
	struct bt_nus_client *nus = context;
	LOG_INF("Service discovery completed");
	bt_gatt_dm_data_print(dm);
	bt_nus_handles_assign(dm, nus);
	bt_nus_subscribe_receive(nus);
	bt_gatt_dm_data_release(dm);
static void discovery_service_not_found(struct bt_conn *conn,
					void *context)
	LOG_INF("Service not found");
static void discovery_error(struct bt_conn *conn,
			    int err,
			    void *context)
	LOG_WRN("Error while discovering GATT database: (%d)", err);
struct bt_gatt_dm_cb discovery_cb = {
	.completed         = discovery_complete,
	.service_not_found = discovery_service_not_found,
	.error_found       = discovery_error,
static void gatt_discover(struct bt_conn *conn)
	int err;
	if (conn != default_conn) {
		return;
	err = bt_gatt_dm_start(conn,
			       BT_UUID_NUS_SERVICE,
			       &discovery_cb,
			       &nus_client);
	if (err) {
		LOG_ERR("could not start the discovery procedure, error "
			"code: %d", err);
static void exchange_func(struct bt_conn *conn, uint8_t err, struct bt_gatt_exchange_params *params)
	if (!err) {
		LOG_INF("MTU exchange done");
	} else {
		LOG_WRN("MTU exchange failed (err %" PRIu8 ")", err);
static void connected(struct bt_conn *conn, uint8_t conn_err)
	int err;
	if (conn_err) {
		LOG_INF("Failed to connect to %s (%d)", log_strdup(addr),
			conn_err);
		if (default_conn == conn) {
			bt_conn_unref(default_conn);
			default_conn = NULL;
			err = bt_scan_start(BT_SCAN_TYPE_SCAN_ACTIVE);
			if (err) {
				LOG_ERR("Scanning failed to start (err %d)",
					err);
		return;
	LOG_INF("Connected: %s", log_strdup(addr));
	static struct bt_gatt_exchange_params exchange_params;
	exchange_params.func = exchange_func;
	err = bt_gatt_exchange_mtu(conn, &exchange_params);
	if (err) {
		LOG_WRN("MTU exchange failed (err %d)", err);
	err = bt_conn_set_security(conn, BT_SECURITY_L2);
	if (err) {
		LOG_WRN("Failed to set security: %d", err);
		gatt_discover(conn);
	err = bt_scan_stop();
	if ((!err) && (err != -EALREADY)) {
		LOG_ERR("Stop LE scan failed (err %d)", err);
	int err;
	LOG_INF("Disconnected: %s (reason %u)", log_strdup(addr),
		reason);
	btcon=false;
	if (default_conn != conn) {
		return;
	if (err) {
			err);
static void security_changed(struct bt_conn *conn, bt_security_t level,
			     enum bt_security_err err)
	if (!err) {
		LOG_INF("Security changed: %s level %u", log_strdup(addr),
			level);
	} else {
		LOG_WRN("Security failed: %s level %u err %d", log_strdup(addr),
			level, err);
BT_CONN_CB_DEFINE(conn_callbacks) = {
	.connected = connected,
	.disconnected = disconnected,
	.security_changed = security_changed
static void scan_filter_match(struct bt_scan_device_info *device_info,
			      struct bt_scan_filter_match *filter_match,
			      bool connectable)
	bt_addr_le_to_str(device_info->recv_info->addr, addr, sizeof(addr));
	LOG_INF("Filters matched. Address: %s connectable: %d",
		log_strdup(addr), connectable);
	btcon=true;
static void scan_connecting_error(struct bt_scan_device_info *device_info)
	LOG_WRN("Connecting failed");
static void scan_connecting(struct bt_scan_device_info *device_info,
	default_conn = bt_conn_ref(conn);
static int nus_client_init(void)
	int err;
	struct bt_nus_client_init_param init = {
		.cb = {
			.received = ble_data_received,
			.sent = ble_data_sent,
	err = bt_nus_client_init(&nus_client, &init);
	if (err) {
		LOG_ERR("NUS Client initialization failed (err %d)", err);
		return err;
	LOG_INF("NUS Client module initialized");
	return err;
BT_SCAN_CB_INIT(scan_cb, scan_filter_match, NULL,
		scan_connecting_error, scan_connecting);
static int scan_init(void)
	int err;
	struct bt_scan_init_param scan_init = {
		.connect_if_match = 1,
	bt_scan_init(&scan_init);
	bt_scan_cb_register(&scan_cb);
	//static uint8_t cname[] = "CriticAlert";
	err = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_UUID, BT_UUID_NUS_SERVICE);
	//err = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_NAME,*cname);
	if (err) {
		LOG_ERR("Scanning filters cannot be set (err %d)", err);
		return err;
	err = bt_scan_filter_enable(BT_SCAN_UUID_FILTER, false);
	//err = bt_scan_filter_enable(BT_SCAN_NAME_FILTER, false);
	if (err) {
		LOG_ERR("Filters cannot be turned on (err %d)", err);
		return err;
	LOG_INF("Scan module initialized");
	return err;
static void auth_cancel(struct bt_conn *conn)
	LOG_INF("Pairing cancelled: %s", log_strdup(addr));
static void pairing_complete(struct bt_conn *conn, bool bonded)
	LOG_INF("Pairing completed: %s, bonded: %d", log_strdup(addr),
		bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
	LOG_WRN("Pairing failed conn: %s, reason %d", log_strdup(addr),
		reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
	.cancel = auth_cancel,
static struct bt_conn_auth_info_cb conn_auth_info_callbacks = {
	.pairing_complete = pairing_complete,
	.pairing_failed = pairing_failed
void main(void)
	int err;
	err = bt_conn_auth_cb_register(&conn_auth_callbacks);
	if (err) {
		LOG_ERR("Failed to register authorization callbacks.");
		return;
	err = bt_conn_auth_info_cb_register(&conn_auth_info_callbacks);
	if (err) {
		printk("Failed to register authorization info callbacks.\n");
		return;
	err = bt_enable(NULL);
	if (err) {
		LOG_ERR("Bluetooth init failed (err %d)", err);
		return;
	LOG_INF("Bluetooth initialized");
	if (IS_ENABLED(CONFIG_SETTINGS)) {
		settings_load();
	int (*module_init[])(void) = {uart_init, scan_init, nus_client_init};
	for (size_t i = 0; i < ARRAY_SIZE(module_init); i++) {
		err = (*module_init[i])();
		if (err) {
			return;
	printk("Starting Bluetooth Central UART example\n");
	if (err) {
		LOG_ERR("Scanning failed to start (err %d)", err);
		return;
	LOG_INF("Scanning successfully started");
	for (;;) {
		/* Wait indefinitely for data to be sent over Bluetooth */
		struct uart_data_t *nusbuf = k_fifo_get(&fifo_uart_rx_data,
						     K_FOREVER);
		err = bt_nus_client_send(&nus_client, nusbuf->data, nusbuf->len);
		if (err) {
			LOG_WRN("Failed to send data over BLE connection"
				"(err %d)", err);
			LOG_INF("Sent data over BLE from nrf52: %d:%s", nusbuf->len,nusbuf->data);
		err = k_sem_take(&nus_write_sem, NUS_WRITE_TIMEOUT);
		if (err) {
			LOG_WRN("NUS send timeout");
		k_msleep(5);
  • Hi Vidar,
    When i use the default value of 50 i get data back only when buffer is full. see log:
    [00:00:13.628,753] <inf> peripheral_uart: Security changed: D2:82:88:82:11:26 (random) level 2
    [00:00:18.527,282] <inf> peripheral_uart: bt_data_received: 13:MES,0,10000
    [00:00:18.527,679] <inf> peripheral_uart: TX_DATA:13,MES,0,10000
    ic UART service example
    [00:00:18.528,869] <dbg> peripheral_uart: uart_cb: UART_TX_DONE
    [00:00:28.574,310] <inf> peripheral_uart: bt_data_received: 12:MES,1,2000
    [00:00:28.574,523] <inf> peripheral_uart: TX_DATA:12,MES,1,2000
    [00:00:28.575,592] <dbg> peripheral_uart: uart_cb: UART_TX_DONE
    [00:00:38.621,826] <inf> peripheral_uart: bt_data_received: 11:PPG,2,200
    [00:00:38.622,039] <inf> peripheral_uart: TX_DATA:11,PPG,2,200
    [00:00:38.623,016] <dbg> peripheral_uart: uart_cb: UART_TX_DONE
    [00:00:53.618,164] <inf> peripheral_uart: bt_data_received: 13:MES,0,10000
    [00:00:53.618,347] <inf> peripheral_uart: TX_DATA:13,MES,0,10000
    [00:00:53.619,506] <dbg> peripheral_uart: uart_cb: UART_TX_DONE
    [00:00:53.858,856] <dbg> peripheral_uart: uart_cb: UART_RX_RDY
    [00:00:53.858,886] <dbg> peripheral_uart: uart_cb: UART_RX_BUF_RELEASED
    [00:00:53.858,917] <dbg> peripheral_uart: uart_cb: UART_RX_BUF_REQUEST
    [00:00:53.859,008] <inf> peripheral_uart: bt_send:40:mes,01,22.90
    ppg,0.0,0.0,0.0
    mes,00,35(
    [00:00:58.666,900] <inf> peripheral_uart: bt_data_received: 12:MES,1,2000
    [00:00:58.667,114] <inf> peripheral_uart: TX_DATA:12,MES,1,2000
    ppg,0.0,0.0,0.0
    mes,00,35
    [00:00:58.668,182] <dbg> peripheral_uart: uart_cb: UART_TX_DONE
    [00:01:08.714,447] <inf> peripheral_uart: bt_data_received: 11:PPG,2,200
    [00:01:08.714,630] <inf> peripheral_uart: TX_DATA:11,PPG,2,200
    ppg,0.0,0.0,0.0
    mes,00,35
    [00:01:08.715,606] <dbg> peripheral_uart: uart_cb: UART_TX_DONE
    [00:01:23.760,742] <inf> peripheral_uart: bt_data_received: 13:MES,0,10000
    [00:01:23.760,955] <inf> peripheral_uart: TX_DATA:13,MES,0,10000
    ppg,0.0,0.0,0.0
    mes,00,35
    [00:01:23.762,084] <dbg> peripheral_uart: uart_cb: UART_TX_DONE
    [00:01:24.023,956] <dbg> peripheral_uart: uart_cb: UART_RX_RDY
    [00:01:24.023,956] <dbg> peripheral_uart: uart_cb: UART_RX_BUF_RELEASED
    [00:01:24.024,017] <dbg> peripheral_uart: uart_cb: UART_RX_BUF_REQUEST
    [00:01:24.024,108] <inf> peripheral_uart: bt_send:40:.38
    mes,01,22.92
    ppg,0.0,0.0,0.0
    mes,(
    [00:01:28.809,509] <inf> peripheral_uart: bt_data_received: 12:MES,1,2000
    [00:01:28.809,722] <inf> peripheral_uart: TX_DATA:12,MES,1,2000
    22.92
    ppg,0.0,0.0,0.0
    mes,
    [00:01:28.810,791] <dbg> peripheral_uart: uart_cb: UART_TX_DONE
    [00:01:38.857,025] <inf> peripheral_uart: bt_data_received: 11:PPG,2,200
    [00:01:38.857,238] <inf> peripheral_uart: TX_DATA:11,PPG,2,200
    22.92
    ppg,0.0,0.0,0.0
    mes,
    [00:01:38.858,215] <dbg> peripheral_uart: uart_cb: UART_TX_DONE
    [00:01:43.170,074] <dbg> peripheral_uart: uart_cb: UART_RX_RDY
    [00:01:43.170,074] <dbg> peripheral_uart: uart_cb: UART_RX_BUF_RELEASED
    [00:01:43.170,104] <dbg> peripheral_uart: uart_cb: UART_RX_BUF_REQUEST
    [00:01:43.170,227] <inf> peripheral_uart: bt_send:40:00,35.42
    mes,01,22.94
    (pg,0.0,0.0,0.0
    When I use 50000 as equal to 50 ms i got normal behavior for a while (aprox 6 min) and then it starts to return when buffer is full se log:
    [00:04:51.485,961] <inf> peripheral_uart: bt_data_received: 13:MES,0,10000
    [00:04:51.486,175] <inf> peripheral_uart: TX_DATA:13,MES,0,10000
    .0
    /���ȁķ���W
    �xG��
    [00:04:51.487,335] <dbg> peripheral_uart: uart_cb: UART_TX_DONE
    [00:04:51.778,991] <dbg> peripheral_uart: uart_cb: UART_RX_RDY
    [00:04:51.779,541] <dbg> peripheral_uart: uart_cb: UART_RX_BUF_RELEASED
    [00:04:51.779,571] <dbg> peripheral_uart: uart_cb: UART_RX_BUF_RELEASED
    [00:04:51.779,602] <dbg> peripheral_uart: uart_cb: UART_RX_DISABLED
    [00:04:51.779,632] <dbg> peripheral_uart: uart_cb: UART_RX_BUF_REQUEST
    [00:04:51.779,754] <inf> peripheral_uart: bt_send:14:mes,00,35.42
    0
    ART service example
    [00:04:56.534,790] <inf> peripheral_uart: bt_data_received: 12:MES,1,2000
    [00:04:56.535,003] <inf> peripheral_uart: TX_DATA:12,MES,1,2000
    0
    ART service example
    [00:04:56.536,071] <dbg> peripheral_uart: uart_cb: UART_TX_DONE
    [00:04:56.904,693] <dbg> peripheral_uart: uart_cb: UART_RX_RDY
    [00:04:56.905,242] <dbg> peripheral_uart: uart_cb: UART_RX_BUF_RELEASED
    [00:04:56.905,273] <dbg> peripheral_uart: uart_cb: UART_RX_BUF_RELEASED
    [00:04:56.905,303] <dbg> peripheral_uart: uart_cb: UART_RX_DISABLED
    [00:04:56.905,334] <dbg> peripheral_uart: uart_cb: UART_RX_BUF_REQUEST
    [00:04:56.905,456] <inf> peripheral_uart: bt_send:14:mes,01,22.92
    0
    /���ȁķ���W
    �xG��
    [00:05:01.583,496] <inf> peripheral_uart: bt_data_received: 11:PPG,2,200
    [00:05:01.583,709] <inf> peripheral_uart: TX_DATA:11,PPG,2,200
    2
    0
    /���ȁķ���W
    �xG��
    [00:05:01.584,686] <dbg> peripheral_uart: uart_cb: UART_TX_DONE
    [00:05:05.834,136] <dbg> peripheral_uart: uart_cb: UART_RX_RDY
    [00:05:05.834,686] <dbg> peripheral_uart: uart_cb: UART_RX_BUF_RELEASED
    [00:05:05.834,716] <dbg> peripheral_uart: uart_cb: UART_RX_BUF_RELEASED
    [00:05:05.834,747] <dbg> peripheral_uart: uart_cb: UART_RX_DISABLED
    [00:05:05.834,808] <dbg> peripheral_uart: uart_cb: UART_RX_BUF_REQUEST
    [00:05:05.834,899] <inf> peripheral_uart: bt_send:17:ppg,0.0,0.0,0.0
    ART service example
    [00:05:11.631,042] <inf> peripheral_uart: bt_data_received: 13:MES,0,10000
    [00:05:11.631,256] <inf> peripheral_uart: TX_DATA:13,MES,0,10000
    .0
    ART service example
    [00:05:11.632,415] <dbg> peripheral_uart: uart_cb: UART_TX_DONE
    [00:05:11.960,845] <dbg> peripheral_uart: uart_cb: UART_RX_RDY
    [00:05:11.961,395] <dbg> peripheral_uart: uart_cb: UART_RX_BUF_RELEASED
    [00:05:11.961,425] <dbg> peripheral_uart: uart_cb: UART_RX_BUF_RELEASED
    [00:05:11.961,456] <dbg> peripheral_uart: uart_cb: UART_RX_DISABLED
    [00:05:11.961,486] <dbg> peripheral_uart: uart_cb: UART_RX_BUF_REQUEST
    [00:05:11.961,608] <inf> peripheral_uart: bt_send:14:mes,00,35.43
    0
    /���ȁķ���W
    �xG��
    [00:05:16.679,779] <inf> peripheral_uart: bt_data_received: 12:MES,1,2000
    [00:05:16.679,992] <inf> peripheral_uart: TX_DATA:12,MES,1,2000
    0
    /���ȁķ���W
    �xG��
    [00:05:16.681,060] <dbg> peripheral_uart: uart_cb: UART_TX_DONE
    [00:05:16.986,480] <dbg> peripheral_uart: uart_cb: UART_RX_RDY
    [00:05:26.727,294] <inf> peripheral_uart: bt_data_received: 11:PPG,2,200
    [00:05:26.727,508] <inf> peripheral_uart: TX_DATA:11,PPG,2,200
    0
    /���ȁķ���W
    �xG��
    [00:05:26.728,515] <dbg> peripheral_uart: uart_cb: UART_TX_DONE
    [00:05:31.000,152] <dbg> peripheral_uart: uart_cb: UART_RX_RDY
    [00:05:41.773,620] <inf> peripheral_uart: bt_data_received: 13:MES,0,10000
    [00:05:41.773,834] <inf> peripheral_uart: TX_DATA:13,MES,0,10000
    0
    /���ȁķ���W
    �xG��
    [00:05:41.774,993] <dbg> peripheral_uart: uart_cb: UART_TX_DONE
    [00:05:42.054,565] <dbg> peripheral_uart: uart_cb: UART_RX_RDY
    [00:05:42.054,565] <dbg> peripheral_uart: uart_cb: UART_RX_BUF_RELEASED
    [00:05:42.054,595] <dbg> peripheral_uart: uart_cb: UART_RX_BUF_REQUEST
    [00:05:42.054,718] <inf> peripheral_uart: bt_send:40:mes,01,22.92
    ppg,0.0,0.0,0.0
    mes,00,35(
    In normal conditions it triggers UART_RX_BUF_REQUEST why?
    In fault conditions why UART_RX_BUF_RELEASED without UART_RX_DISABLED?
    Br
    Rune
  • Hi Rune,
    Thank you for the debugging logs. It is not clear whether the UART_RX_BUF_RELEASED event is lost or simply not triggered. I have reported this as a bug internally to allow the developers to investigate further.
    I suspect the issue may be related to the UART async adapter which is enabled when USB CDC is used as I have been unable to reproduce this with the UART driver.
    BR
    Vidar
  • Hi Vidar,
    I see in the log that UART_RX_RDY vas triggered but no UART_RX_BUF_RELEASED followed.
    Meaning that the last character in msg was not  ‘\n’.
    Then I replaced this code in case UART_RX_RDY:
    if (evt->data.rx.buf[buf->len - 1] == '\n') {
                disable_req = true;
    With this code to check on the entire msg for end of msg:
    for (int i=0; i<evt->data.rx.len;i++){
                if (evt->data.rx.buf[i] == '\n') {
                disable_req = true;
    That make the code not working at all, way?
    Then I replaced evt->data.rx.data with buf->data:
    for (int i=0; i<buf->len;i++){
                if (buf->data[i] == '\n') {
                disable_req = true;
    Now it looks like it runs ok without any buffer full fault.
    Br
    Rune
  • Hi Vidar,
    When i flash another device i got this error:
    [00:00:00.004,760] <dbg> peripheral_uart: uart_cb: UART_RX_BUF_REQUEST
    [00:00:00.008,056] <dbg> peripheral_uart: uart_cb: UART_TX_DONE
    [00:00:00.017,822] <err> os: ***** MPU FAULT *****
    [00:00:00.017,852] <err> os:   Stacking error (context area might be not valid)
    [00:00:00.017,852] <err> os:   Data Access Violation
    [00:00:00.017,883] <err> os:   MMFAR Address: 0x20006ef8
    [00:00:00.017,913] <err> os: r0/a1:  0x0002f736  r1/a2:  0x01000000  r2/a3:  0xcfbdb380
    [00:00:00.017,913] <err> os: r3/a4:  0x3e0aa44c r12/ip:  0x857e7f62 r14/lr:  0x86a02161
    [00:00:00.017,944] <err> os:  xpsr:  0x6a58c000
    [00:00:00.017,944] <err> os: Faulting instruction address (r15/pc): 0xe51528b3
    [00:00:00.018,005] <err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0
    [00:00:00.018,035] <err> os: Current thread: 0x200026b0 (main)
    [00:00:00.348,754] <err> fatal_error: Resetting system
    there is no code change from te first device.
    Please advice
    Br
    Rune
  • Hi Rune,
    The log shows you have a stack overflow in your main thread. This can be fixed by increasing the stack size (CONFIG_MAIN_STACK_SIZE). But it does not make sense that you get this on one board and not the other if you are running the same FW build and the same boards.
    I notice you have debug options enabled now; this will lead to some increase in stack usage. Do you also get a stack overflow if you uncheck the "enable debug options" checkbox in your project configuration?
    With regards to the original problem you reported, I am still waiting for the developers to have a look at it and find a root cause.
    Vidar
