External Flash W25Q64 with USBD_MSC example on NRF52840
Hi All,
        I have an external flash W25Q64 on which I have to mount a file system. I am using USBD_MSC example of NRF52840. My main goal is to create a file inside the flash memory chip. And when USB is plugged into the device it should be seen as a drive on laptop/desktop and I should be able to access the file which was created in the flash chip.I have made the connections on the NRF52840 using the pin configurations below:-
#define SDC_SCK_PIN     (25)
#define SDC_MOSI_PIN   (23)
#define SDC_MISO_PIN   (24)
#define SDC_CS_PIN       (15)
I have also configured the details in nrf_serial_flash_params.c file.
static const nrf_serial_flash_params_t m_sflash_params[] = {
        .read_id = { 0xEF,0x40,0x17 },
        .capabilities = 0x00,
        .size = 8 * 1024 * 1024,
        .erase_size = 2 * 1024,
        .program_size = 256,
nrf_serial_flash_params_t const * nrf_serial_flash_params_get(const uint8_t * p_read_id)
    size_t i;
    for (i = 0; i < ARRAY_SIZE(m_sflash_params); ++i)
        if (memcmp(m_sflash_params[i].read_id, p_read_id, sizeof(m_sflash_params[i].read_id)) == 0)
            return &m_sflash_params[i];
    return NULL;
When I run the example , i get the following error:-
<info> app: Initializing disk 0 (QSPI)...
 <error> app: Disk initialization failed.
1) Will this example run for W25Q64 IC??
2) This example also includes FATfs files. Will it automatically create a file system on the external SPI W25Q64 flash memory??
3) Why am I getting "Disk initialization failed." error?
4) Inside sdk_config.h do I also need to enable pin configurations for Qspi??
5) How to test this application? Currently I am using NRF52840 DK and then connecting external spi flash to it. But for USB detection how will it work?
I have attached few files here to check for the configurations
04162.sdk_config.h
5287.W25Q64BV.PDF
Please help me to solve this issue. I need to solve this issue on an urgent basis. Your help will be appreciated. I have also attached W25Q64 datasheet for your reference.
Thanks & Regards,
Snehal
    Since you did not provide an event handler to nrf_drv_spi_init(), the call to nrf_drv_spi_transfer() is performed in blocking mode, which means that this function returns when the transfer is finished.
    I would assume you are stuck in spi_xfer(), waiting for NRF_SPI_EVENT_READY event. But you should debug, and confirm this,
    As mentioned by Kenneth in e.g. this similar post, make sure that CLK toggle as expected (and is not forced low externally by some electrical issues)
