External Flash W25Q64 with USBD_MSC example on NRF52840
Hi All,
        I have an external flash W25Q64 on which I have to mount a file system. I am using USBD_MSC example of NRF52840. My main goal is to create a file inside the flash memory chip. And when USB is plugged into the device it should be seen as a drive on laptop/desktop and I should be able to access the file which was created in the flash chip.I have made the connections on the NRF52840 using the pin configurations below:-
#define SDC_SCK_PIN     (25)
#define SDC_MOSI_PIN   (23)
#define SDC_MISO_PIN   (24)
#define SDC_CS_PIN       (15)
I have also configured the details in nrf_serial_flash_params.c file.
static const nrf_serial_flash_params_t m_sflash_params[] = {
        .read_id = { 0xEF,0x40,0x17 },
        .capabilities = 0x00,
        .size = 8 * 1024 * 1024,
        .erase_size = 2 * 1024,
        .program_size = 256,
nrf_serial_flash_params_t const * nrf_serial_flash_params_get(const uint8_t * p_read_id)
    size_t i;
    for (i = 0; i < ARRAY_SIZE(m_sflash_params); ++i)
        if (memcmp(m_sflash_params[i].read_id, p_read_id, sizeof(m_sflash_params[i].read_id)) == 0)
            return &m_sflash_params[i];
    return NULL;
When I run the example , i get the following error:-
<info> app: Initializing disk 0 (QSPI)...
 <error> app: Disk initialization failed.
1) Will this example run for W25Q64 IC??
2) This example also includes FATfs files. Will it automatically create a file system on the external SPI W25Q64 flash memory??
3) Why am I getting "Disk initialization failed." error?
4) Inside sdk_config.h do I also need to enable pin configurations for Qspi??
5) How to test this application? Currently I am using NRF52840 DK and then connecting external spi flash to it. But for USB detection how will it work?
I have attached few files here to check for the configurations
04162.sdk_config.h
5287.W25Q64BV.PDF
Please help me to solve this issue. I need to solve this issue on an urgent basis. Your help will be appreciated. I have also attached W25Q64 datasheet for your reference.
Thanks & Regards,
Snehal
  • You could e.g. start by replacing QSPI read/write operations with SPI read/write operations.  We don't have any guides for this. You just have to use the other implementations as a reference.
  • Hi Sigurd, Thanks for the suggestion. I will try converting it.
    One the same SPI lines I have one more chip MAX3421e. SS pin is different for both flash chip and MAX3421. Will it conflict if I implement block drivers for flash chip SPI??
    Just don't want to get in any trouble later. So confirming from you.
    P0.22 SPI_SS
    P0.23 SPI_MOSI
    P0.24 SPI_MISO
    P0.25 SPI_CLK
    P0.26 SPI_WP
    P0.27
    SPI_HOLD
    P0.15 SPI_SS_FLSH
    P0.22 SPI_SS_MAX3421
    Thanks & Regards,
    Snehal.
    As long as you use SS, and have different SS-line for each SPI device, it should be okay.
  • Okay, Thank you.
    According to your suggestion I have tried converting qspi to spi drivers.I am not sure if my conversion is right. I have uploaded 2 files here. Can you please check if the conversion is okay??
    Also one thing is left to convert in the file which is regarding "nrf_qspi_cinstr_conf_t" which is custom configuration structure for QSPI and "nrf_drv_qspi_cinstr_xfer" . How do I convert this part for SPI??
    nrf_qspi_cinstr_conf_t cinstr_cfg = {
    .opcode = QSPI_STD_CMD_RSTEN,
    .length = NRF_QSPI_CINSTR_LEN_1B,
    .io2_level = true,
    .io3_level = true,
    .wipwait = true,
    .wren = true
    /* Send reset enable */
    ret = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, NULL, NULL);
    /* Send reset command */
    cinstr_cfg.opcode = QSPI_STD_CMD_RST;
    /* Get 3 byte identification value */
    uint8_t rdid_buf[3] = {0, 0, 0};
    cinstr_cfg.opcode = QSPI_STD_CMD_READ_ID;
    cinstr_cfg.length = NRF_QSPI_CINSTR_LEN_4B;
    ret = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, NULL, rdid_buf);
     * Copyright (c) 2016 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
    #include "sdk_common.h"
    #if NRF_MODULE_ENABLED(NRF_BLOCK_DEV_SPI)
    #include "nrf_serial_flash_params.h"
    #include "nrf_block_dev_spi.h"
    #include "spi.h"
    #include <inttypes.h>
    /**@file
     * @ingroup nrf_block_dev_spi
     * @brief This module implements block device API. It should be used as a reference block device.
    #if NRF_BLOCK_DEV_SPI_CONFIG_LOG_ENABLED
    #define NRF_LOG_LEVEL       NRF_BLOCK_DEV_SPI_CONFIG_LOG_LEVEL
    #define NRF_LOG_INFO_COLOR  NRF_BLOCK_DEV_SPI_CONFIG_INFO_COLOR
    #define NRF_LOG_DEBUG_COLOR NRF_BLOCK_DEV_SPI_CONFIG_DEBUG_COLOR
    #else
    #define NRF_LOG_LEVEL       0
    #include "nrf_log.h"
    #define SPI_STD_CMD_WRSR    0x01   /**< Write status register command*/
    #define SPI_STD_CMD_RSTEN   0x66   /**< Reset enable command*/
    #define SPI_STD_CMD_RST     0x99   /**< Reset command*/
    #define SPI_STD_CMD_READ_ID 0x9F   /**< Read ID command*/
    #define BD_PAGE_PROGRAM_SIZE 256    /**< Page program size (minimum block size)*/
    #define BD_ERASE_UNIT_INVALID_ID   0xFFFFFFFF /**< Invalid erase unit number*/
    #define BD_ERASE_UNIT_ERASE_VAL    0xFFFFFFFF /**< Erased memory value*/
    const nrf_drv_spi_t m_spi = NRF_DRV_SPI_INSTANCE(1);
     * @brief Block to erase unit translation
     * @param blk_id    Block index
     * @param blk_size  Block size
    #define BD_BLOCK_TO_ERASEUNIT(blk_id, blk_size)   \
        ((blk_id) * (blk_size)) / (NRF_BLOCK_DEV_SPI_ERASE_UNIT_SIZE)
     * @brief Blocks per erase unit
    #define BD_BLOCKS_PER_ERASEUNIT(blk_size)         \
        (NRF_BLOCK_DEV_SPI_ERASE_UNIT_SIZE / (blk_size))
    static ret_code_t block_dev_spi_eunit_write(nrf_block_dev_spi_t const * p_spi_dev,
                                                 nrf_block_req_t * p_blk_left);
    nrfx_err_t nrf_drv_spi_read(void *   p_rx_buffer,
                              size_t   rx_buffer_length,
                              uint32_t src_address);
    nrfx_err_t nrf_drv_spi_write(void const * p_tx_buffer,size_t tx_buffer_length,uint32_t dst_address);
    static void block_dev_spi_read_from_eunit(nrf_block_dev_spi_t const * p_spi_dev)
        nrf_block_dev_spi_work_t const * p_work = p_spi_dev->p_work;
        /*In write-back mode data that we read might not be the same as in erase unit buffer*/
        uint32_t eunit_start = BD_BLOCK_TO_ERASEUNIT(p_work->req.blk_id,
                                                     p_work->geometry.blk_size);
        uint32_t eunit_end = BD_BLOCK_TO_ERASEUNIT(p_work->req.blk_id + p_work->req.blk_count,
        if ((eunit_start > p_work->erase_unit_idx) || (eunit_end < p_work->erase_unit_idx))
            /*Do nothing. Read request doesn't hit current cached erase unit*/
            return;
        /*Case 1: Copy data from start erase unit*/
        if (eunit_start == p_work->erase_unit_idx)
             size_t blk = p_work->req.blk_id %
                          BD_BLOCKS_PER_ERASEUNIT(p_work->geometry.blk_size);
             size_t cnt = BD_BLOCKS_PER_ERASEUNIT(p_work->geometry.blk_size) - blk;
             size_t off = p_work->geometry.blk_size * blk;
             if (cnt > p_work->req.blk_count)
                 cnt = p_work->req.blk_count;
             memcpy(p_work->req.p_buff,
                    p_work->p_erase_unit_buff + off,
                    cnt * p_work->geometry.blk_size);
             return;
        /*Case 2: Copy data from end erase unit*/
        if (eunit_end == p_work->erase_unit_idx)
             size_t cnt = (p_work->req.blk_id + p_work->req.blk_count) %
             size_t off = (p_work->erase_unit_idx * BD_BLOCKS_PER_ERASEUNIT(p_work->geometry.blk_size) -
                           p_work->req.blk_id) * p_work->geometry.blk_size;
             memcpy((uint8_t *)p_work->req.p_buff + off,
                    p_work->p_erase_unit_buff,
             return;
        /*Case 3: Copy data from  eunit_start < p_work->erase_unit_idx < eunit_end*/
               NRF_BLOCK_DEV_SPI_ERASE_UNIT_SIZE);
     * @brief Active SPI block device handle. Only one instance.
    static nrf_block_dev_spi_t const * m_active_spi_dev;
    static void spi_handler(nrf_drv_spi_evt_t event, void * p_context)
        if (m_active_spi_dev != p_context)
            return;
        nrf_block_dev_spi_t const * p_spi_dev = p_context;
        nrf_block_dev_spi_work_t *  p_work = p_spi_dev->p_work;
        nrf_block_req_t * p_blk_left = &p_work->left_req;
        switch (p_work->state)
            case NRF_BLOCK_DEV_SPI_STATE_READ_EXEC:
                if (p_work->writeback_mode)
                    block_dev_spi_read_from_eunit(p_spi_dev);
                p_work->state = NRF_BLOCK_DEV_SPI_STATE_IDLE;
                if (p_work->ev_handler)
                    const nrf_block_dev_event_t ev = {
                            NRF_BLOCK_DEV_EVT_BLK_READ_DONE,
                            NRF_BLOCK_DEV_RESULT_SUCCESS,
                            &p_work->req,
                            p_work->p_context
                    p_work->ev_handler(&p_spi_dev->block_dev, &ev);
            case NRF_BLOCK_DEV_SPI_STATE_EUNIT_LOAD:
                ret_code_t ret;
                uint32_t erase_unit = BD_BLOCK_TO_ERASEUNIT(p_blk_left->blk_id,
                UNUSED_VARIABLE(erase_unit);
                ASSERT(erase_unit == p_work->erase_unit_idx);
                /* Check if block is in erase unit buffer*/
                ret = block_dev_spi_eunit_write(p_spi_dev, p_blk_left);
                ASSERT(ret == NRF_SUCCESS);
                UNUSED_VARIABLE(ret);
            case NRF_BLOCK_DEV_SPI_STATE_WRITE_ERASE:
            case NRF_BLOCK_DEV_SPI_STATE_WRITE_EXEC:
                /*Clear last programmed block*/
                uint32_t block_to_program = __CLZ(__RBIT(p_work->erase_unit_dirty_blocks));
                if (p_work->state == NRF_BLOCK_DEV_SPI_STATE_WRITE_EXEC)
                    p_work->erase_unit_dirty_blocks ^= 1u << block_to_program;
                if (p_work->erase_unit_dirty_blocks == 0)
                    if (p_work->left_req.blk_count)
                        /*Load next erase unit*/
                        ret_code_t ret;
                        uint32_t eunit = BD_BLOCK_TO_ERASEUNIT(p_blk_left->blk_id,
                        p_work->erase_unit_idx = eunit;
                        p_work->state = NRF_BLOCK_DEV_SPI_STATE_EUNIT_LOAD;
                        ret = nrf_drv_spi_read(p_work->p_erase_unit_buff,
                                                NRF_BLOCK_DEV_SPI_ERASE_UNIT_SIZE,
                    /*All blocks are programmed. Call event handler if required.*/
                    if (p_work->ev_handler && !p_work->cache_flushing)
                                NRF_BLOCK_DEV_EVT_BLK_WRITE_DONE,
                                &p_work->req,
                                p_work->p_context
                    p_work->cache_flushing = false;
                /*Get next block to program from program mask*/
                uint32_t dst_address = (p_work->erase_unit_idx * NRF_BLOCK_DEV_SPI_ERASE_UNIT_SIZE) +
                                       (block_to_program * p_work->geometry.blk_size);
                const void * p_src_address = p_work->p_erase_unit_buff +
                                             block_to_program * p_work->geometry.blk_size;
                p_work->state = NRF_BLOCK_DEV_SPI_STATE_WRITE_EXEC;
                ret_code_t ret = nrf_drv_spi_write(p_src_address,
                                                    p_work->geometry.blk_size,
                                                    dst_address);
                ASSERT(0);
    static void wait_for_idle(nrf_block_dev_spi_t const * p_spi_dev)
        while (p_work->state != NRF_BLOCK_DEV_SPI_STATE_IDLE)
            __WFI();
    static ret_code_t block_dev_spi_init(nrf_block_dev_t const * p_blk_dev,
                                          nrf_block_dev_ev_handler ev_handler,
                                          void const * p_context)
        ASSERT(p_blk_dev);
                                      CONTAINER_OF(p_blk_dev, nrf_block_dev_spi_t, block_dev);
        nrf_drv_spi_config_t const * p_spi_cfg = &p_spi_dev->spi_bdev_config.spi_config;
        ret_code_t ret = NRF_SUCCESS;
        NRF_LOG_INST_DEBUG(p_spi_dev->p_log, "Init");
        if (p_spi_dev->spi_bdev_config.block_size % BD_PAGE_PROGRAM_SIZE)
            /*Unsupported block size*/
            NRF_LOG_INST_ERROR(p_spi_dev->p_log, "Unsupported block size because of program page size");
            return NRF_ERROR_NOT_SUPPORTED;
        if (NRF_BLOCK_DEV_SPI_ERASE_UNIT_SIZE % p_spi_dev->spi_bdev_config.block_size)
            NRF_LOG_INST_ERROR(p_spi_dev->p_log, "Unsupported block size because of erase unit size");
        if (m_active_spi_dev)
            /* SPI instance is BUSY*/
            NRF_LOG_INST_ERROR(p_spi_dev->p_log, "Cannot init because SPI is busy");
            return NRF_ERROR_BUSY;
        ret = nrf_drv_spi_init(&m_spi,p_spi_cfg, spi_handler, (void *)p_blk_dev);
        if (ret != NRF_SUCCESS)
            NRF_LOG_INST_ERROR(p_spi_dev->p_log, "SPI init error: %"PRIu32"", ret);
            return ret;
        nrf_spi_cinstr_conf_t cinstr_cfg = {
            .opcode    = SPI_STD_CMD_RSTEN,
            .length    = NRF_SPI_CINSTR_LEN_1B,
            .io2_level = true,
            .io3_level = true,
            .wipwait   = true,
            .wren      = true
        ret = nrf_drv_spi_cinstr_xfer(&cinstr_cfg, NULL, NULL);
            NRF_LOG_INST_ERROR(p_spi_dev->p_log, "SPI reset enable command error: %"PRIu32"", ret);
            return ret;
        cinstr_cfg.opcode = SPI_STD_CMD_RST;
            NRF_LOG_INST_ERROR(p_spi_dev->p_log, "SPI reset command error: %"PRIu32"", ret);
            return ret;
        cinstr_cfg.opcode = SPI_STD_CMD_READ_ID;
        cinstr_cfg.length = NRF_SPI_CINSTR_LEN_4B;
        ret = nrf_drv_spi_cinstr_xfer(&cinstr_cfg, NULL, rdid_buf);
            NRF_LOG_INST_ERROR(p_spi_dev->p_log, "SPI get 3 byte id error: %"PRIu32"", ret);
            return ret;
        nrf_serial_flash_params_t const * serial_flash_id = nrf_serial_flash_params_get(rdid_buf);
        if (!serial_flash_id)
            NRF_LOG_INST_ERROR(p_spi_dev->p_log, "SPI FLASH not supported");
        if (serial_flash_id->erase_size != NRF_BLOCK_DEV_SPI_ERASE_UNIT_SIZE)
            NRF_LOG_INST_ERROR(p_spi_dev->p_log, "SPI FLASH erase unit size not supported");
        /* Calculate block device geometry.... */
        uint32_t blk_size = p_spi_dev->spi_bdev_config.block_size;
        uint32_t blk_count = serial_flash_id->size / p_spi_dev->spi_bdev_config.block_size;
        if (!blk_count || (blk_count % BD_BLOCKS_PER_ERASEUNIT(blk_size)))
            NRF_LOG_INST_ERROR(p_spi_dev->p_log, "SPI FLASH block size not supported");
        p_work->geometry.blk_size = blk_size;
        p_work->geometry.blk_count = blk_count;
        p_work->p_context = p_context;
        p_work->ev_handler = ev_handler;
        p_work->erase_unit_idx = BD_ERASE_UNIT_INVALID_ID;
        p_work->writeback_mode =  (p_spi_dev->spi_bdev_config.flags &
                                   NRF_BLOCK_DEV_SPI_FLAG_CACHE_WRITEBACK) != 0;
        m_active_spi_dev = p_spi_dev;
            /*Asynchronous operation (simulation)*/
                    NRF_BLOCK_DEV_EVT_INIT,
                    NULL,
                    p_work->p_context
            p_work->ev_handler(p_blk_dev, &ev);
        return NRF_SUCCESS;
    static ret_code_t block_dev_spi_uninit(nrf_block_dev_t const * p_blk_dev)
        ASSERT(p_blk_dev);
        NRF_LOG_INST_DEBUG(p_spi_dev->p_log, "Uninit");
        if (m_active_spi_dev != p_spi_dev)
        if (p_work->state != NRF_BLOCK_DEV_SPI_STATE_IDLE)
            /* Previous asynchronous operation in progress*/
            NRF_LOG_INST_ERROR(p_spi_dev->p_log, "Cannot uninit because SPI is busy");
            /*Asynchronous operation*/
                    NRF_BLOCK_DEV_EVT_UNINIT,
                    NULL,
                    p_work->p_context
        p_work->state = NRF_BLOCK_DEV_SPI_STATE_DISABLED;
        nrf_drv_spi_uninit(&m_spi);
        memset(p_work, 0, sizeof(nrf_block_dev_spi_work_t));
        m_active_spi_dev = NULL;
        return NRF_SUCCESS;
    static ret_code_t block_dev_spi_read_req(nrf_block_dev_t const * p_blk_dev,
                                              nrf_block_req_t const * p_blk)
        ASSERT(p_blk_dev);
        ASSERT(p_blk);
        NRF_LOG_INST_DEBUG(
            p_spi_dev->p_log,
            "Read req from block %"PRIu32" size %"PRIu32"(x%"PRIu32") to %"PRIXPTR,
            p_blk->blk_id,
            p_blk->blk_count,
            p_blk_dev->p_ops->geometry(p_blk_dev)->blk_size,
            p_blk->p_buff);
        if ((p_blk->blk_id + p_blk->blk_count) > p_work->geometry.blk_count)
           NRF_LOG_INST_ERROR(
               p_spi_dev->p_log,
               "Out of range read req block %"PRIu32" count %"PRIu32" while max is %"PRIu32,
               p_blk->blk_id,
               p_blk->blk_count,
               p_blk_dev->p_ops->geometry(p_blk_dev)->blk_count);
           return NRF_ERROR_INVALID_ADDR;
            NRF_LOG_INST_ERROR(p_spi_dev->p_log, "Cannot read because SPI is busy");
            NRF_LOG_INST_ERROR(p_spi_dev->p_log, "Cannot read because of ongoing previous operation");
        p_work->left_req = *p_blk;
        p_work->req = *p_blk;
        p_work->state = NRF_BLOCK_DEV_SPI_STATE_READ_EXEC;
        ret = nrf_drv_spi_read(p_blk_left->p_buff,
                                p_blk_left->blk_count * p_work->geometry.blk_size,
                                p_blk_left->blk_id * p_work->geometry.blk_size);
            NRF_LOG_INST_ERROR(p_spi_dev->p_log, "SPI read error: %"PRIu32"", ret);
            return ret;
        p_blk_left->p_buff = NULL;
        p_blk_left->blk_count = 0;
        if (!p_work->ev_handler && (p_work->state != NRF_BLOCK_DEV_SPI_STATE_IDLE))
            /*Synchronous operation*/
            wait_for_idle(p_spi_dev);
        return ret;
    static bool block_dev_spi_update_eunit(nrf_block_dev_spi_t const * p_spi_dev,
                                            size_t off,
                                            const void * p_src,
                                            size_t len)
        ASSERT((len % sizeof(uint32_t)) == 0)
        uint32_t *       p_dst32 = (uint32_t *)(p_work->p_erase_unit_buff + off);
        const uint32_t * p_src32 = p_src;
        bool erase_required = false;
        len /= sizeof(uint32_t);
        /*Do normal copying until erase unit is not required*/
        do
            if (*p_dst32 != *p_src32)
                if (*p_dst32 != BD_ERASE_UNIT_ERASE_VAL)
                    erase_required = true;
                /*Mark block as dirty*/
                p_work->erase_unit_dirty_blocks |= 1u << (off / p_work->geometry.blk_size);
            *p_dst32++ = *p_src32++;
            off += sizeof(uint32_t);
        } while (--len);
        return erase_required;
    static ret_code_t block_dev_spi_write_start(nrf_block_dev_spi_t const * p_spi_dev)
        if (!p_work->erase_required)
            /*Get first block to program from program mask*/
            return nrf_drv_spi_write(p_src_address,
                                      dst_address);
        /*Erase is required*/
        uint32_t address = (p_work->erase_unit_idx * NRF_BLOCK_DEV_SPI_ERASE_UNIT_SIZE);
        p_work->state = NRF_BLOCK_DEV_SPI_STATE_WRITE_ERASE;
        p_work->erase_required = false;
        return nrf_drv_spi_erase(NRF_SPI_ERASE_LEN_4KB, address);
        size_t blk = p_blk_left->blk_id %
        if (cnt > p_blk_left->blk_count)
            cnt = p_blk_left->blk_count;
        bool erase_required = block_dev_spi_update_eunit(p_spi_dev,
                                                          off,
                                                          p_blk_left->p_buff,
        if (erase_required)
            p_work->erase_required = true;
        p_blk_left->blk_count -= cnt;
        p_blk_left->blk_id += cnt;
        p_blk_left->p_buff = (uint8_t *)p_blk_left->p_buff + cnt * p_work->geometry.blk_size;
        if (p_work->erase_required)
            uint32_t blk_size = p_work->geometry.blk_size;
            p_work->erase_unit_dirty_blocks |= (1u << BD_BLOCKS_PER_ERASEUNIT(blk_size)) - 1;
        if (p_work->erase_unit_dirty_blocks == 0 || p_work->writeback_mode)
            /*No dirty blocks detected. Write end.*/
            if (p_work->ev_handler && p_blk_left->blk_count == 0)
                        &p_work->req,
                        p_work->p_context
                return NRF_SUCCESS;
        return block_dev_spi_write_start(p_spi_dev);
    static ret_code_t block_dev_spi_write_req(nrf_block_dev_t const * p_blk_dev,
        ASSERT(p_blk_dev);
        ASSERT(p_blk);
        NRF_LOG_INST_DEBUG(
            p_spi_dev->p_log,
            "Write req to block %"PRIu32" size %"PRIu32"(x%"PRIu32") from %"PRIXPTR,
            p_blk->blk_id,
            p_blk->blk_count,
            p_blk->p_buff);
           NRF_LOG_INST_ERROR(
               p_spi_dev->p_log,
               "Out of range write req block %"PRIu32" count %"PRIu32" while max is %"PRIu32,
               p_blk->blk_id,
               p_blk->blk_count,
            NRF_LOG_INST_ERROR(p_spi_dev->p_log, "Cannot write because SPI is busy");
            NRF_LOG_INST_ERROR(p_spi_dev->p_log, "Cannot write because of ongoing previous operation");
        if (erase_unit == p_work->erase_unit_idx)
                ret = block_dev_spi_write_start(p_spi_dev);
                p_work->erase_unit_idx = erase_unit;
                        erase_unit * NRF_BLOCK_DEV_SPI_ERASE_UNIT_SIZE);
            NRF_LOG_INST_ERROR(p_spi_dev->p_log, "SPI write error: %"PRIu32"", ret);
            return ret;
        return ret;
    static ret_code_t block_dev_spi_ioctl(nrf_block_dev_t const * p_blk_dev,
                                           nrf_block_dev_ioctl_req_t req,
                                           void * p_data)
        ASSERT(p_blk_dev);
        switch (req)
            case NRF_BLOCK_DEV_IOCTL_REQ_CACHE_FLUSH:
                bool * p_flushing = p_data;
                NRF_LOG_INST_DEBUG(p_spi_dev->p_log, "IOCtl: Cache flush");
                if (!p_work->writeback_mode || p_work->erase_unit_dirty_blocks == 0)
                    if (p_flushing)
                        *p_flushing = false;
                    return NRF_SUCCESS;
                ret_code_t ret =  block_dev_spi_write_start(p_spi_dev);
                if (ret == NRF_SUCCESS)
                    if (p_flushing)
                        *p_flushing = true;
                    p_work->cache_flushing = true;
                return ret;
            case NRF_BLOCK_DEV_IOCTL_REQ_INFO_STRINGS:
                if (p_data == NULL)
                    return NRF_ERROR_INVALID_PARAM;
                nrf_block_dev_info_strings_t const * * pp_strings = p_data;
                *pp_strings = &p_spi_dev->info_strings;
                return NRF_SUCCESS;
    static nrf_block_dev_geometry_t const * block_dev_spi_geometry(nrf_block_dev_t const * p_blk_dev)
        ASSERT(p_blk_dev);
        return &p_work->geometry;
    const nrf_block_dev_ops_t nrf_block_device_spi_ops = {
            .init = block_dev_spi_init,
            .uninit = block_dev_spi_uninit,
            .read_req = block_dev_spi_read_req,
            .write_req = block_dev_spi_write_req,
            .ioctl = block_dev_spi_ioctl,
            .geometry = block_dev_spi_geometry,
    uint8_t   spi_tx_buf[8]; // spi tx buffer
    uint8_t   spi_rx_buf[8]; // spi tx buffer
    static volatile bool spi_xfer_done;  /* Flag used to indicate that SPI instance completed the transfer. */
    volatile  uint8_t   SPIReadLength, SPIWriteLength; // variables to hold read and write lengths
       spi_tx_buf[0] = (src_address);
       spi_xfer_done = false;
       APP_ERROR_CHECK(nrf_drv_spi_transfer(&m_spi,spi_tx_buf,2,p_rx_buffer,2));
       while(spi_xfer_done == false){};
       return spi_rx_buf[1];
    /* A function to write into LIS3DSH Internal Register */
        SPIWriteLength = 2; // set the spi write length to 2 bytes
        SPIReadLength = 0; // set the read length
        spi_tx_buf[0] = SET_WRITE_SINGLE_CMD(dst_address); // set the first byte which is a write command
        spi_tx_buf[1] = p_tx_buffer; // A byte of data to be sent
        /* set the transfer flag to false to indicate data transfer has not yet started */
        /* transfer the data by calling the spi transfer function and call it in app error check so if
           any error occurs it will catch it and sends it on debug port */
        APP_ERROR_CHECK(nrf_drv_spi_transfer(&m_spi, spi_tx_buf, tx_buffer_length, spi_rx_buf, SPIReadLength));
        /* wait until the transfer is completed */
        while(!spi_xfer_done); // this flag will be set to true in the spi interrupt handler function
    #endif // NRF_MODULE_ENABLED(NRF_BLOCK_DEV_SPI)
    nrf_block_dev_spi.h
    I will be glad if you please verify my changes. Waiting for your reply.
    Thanks & Regards,
    Snehal.
