Reading magnetometer LIS2MDL via SPI
using segger v5.66, SDK 17.1
My hardware has 4 wire SPI lines running to magnetometer, Initially I was unable to read the WHO_AM_I(4F)  register. After going through the datasheet I came across this
so I was suspecting this was actual problem because of which I was unable to read register
The information given in datasheet I don't understand completely what to be done, Here is my current code
#define ADD_REG_WHO_AM_I          0x4F
#define WHO_AM_I_DEFAULTvalue     0x40  //reserved register
#define SPI_BUFFER    8
#define SPI_INSTANCE  0
#define SET_READ_SINGLE_CMD(x)  (x | 0x80)
uint8_t spi_tx_buf[SPI_BUFFER];
uint8_t spi_rx_buf[SPI_BUFFER];
static volatile bool spi_xfer_done;
//create an instance
static const nrf_drv_spi_t m_spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);
void spi_event_handler(nrf_drv_spi_evt_t const * p_event, void * p_context)
    spi_xfer_done = true;
void spi_init(void)
    nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
    spi_config.ss_pin     = 27;
    spi_config.miso_pin   = 05;
    spi_config.mosi_pin   = 17;
    spi_config.sck_pin    = 26;
    spi_config.frequency  = NRF_DRV_SPI_FREQ_4M;
    APP_ERROR_CHECK(nrf_drv_spi_init(&m_spi, &spi_config, spi_event_handler, NULL));
int lsm2_read_reg(char reg)
    spi_tx_buf[0] = SET_READ_SINGLE_CMD(reg); //creat read comd
    spi_xfer_done = false;
    APP_ERROR_CHECK(nrf_drv_spi_transfer(&m_spi, spi_tx_buf, 2, spi_rx_buf, 2));
    while(spi_xfer_done == false){}
    return spi_rx_buf[1];
    int interRegValue;
    spi_init();
    NRF_LOG_INFO("Spi application started");
    interRegValue = lsm2_read_reg(ADD_REG_WHO_AM_I);
    if(interRegValue == WHO_AM_I_DEFAULTvalue)
        NRF_LOG_INFO("WHO AM I value is correct");
    while (1)
So now, I dont understand how do we interface this
this is what I though initially
1. initialize, config, read the register
btw, any help from community shall help, Thanks
