nrf53 USB as mass storage with SDCARD enable ok but doesn't work
I am here, again! I am trying to use the USB of nfr5340dk or my custom board as mass storage with SDCard.
I am sure the SDCard works... in the same project I can read and write files without problems, but when I enable the usb, the USB_enable() function returns that there is not a problem, but from the PC I can't see the device, and no enumeration too.
The first question is: How does USB bind with SDCard? I saw that for internal flash, the overlay file contains these rows that I don't have:
/delete-node/ &storage_partition;
&mx25r64 {
	partitions {
		#address-cells = <1>;
		#size-cells = <1>;
		storage_partition: partition@0 {
			label = "storage";
			reg = <0x00000000 0x00020000>;
	msc_disk0 {
		compatible = "zephyr,flash-disk";
		partition = <&storage_partition>;
		disk-name = "NAND";
		cache-size = <4096>;
second question: The application must exit from the main to works like in this other post?
Thank
Marco
  • Hi Marco
    Any chance you could try to build the sample in nRF Connect SDK v2.2.0 instead?
    I just tested the mass sample in v2.2.0, and here MASS_STORAGE_STACK_SIZE should be configurable.
    Alternatively, it is possible to add this configuration to the project Kconfig file, in order to make it user configurable and set a different default value.
    To do this simply copy the text from the Kconfig.msg file into the project Kconfig file, and alter the default value to fit your application:
    config MASS_STORAGE_STACK_SIZE
    	int "Set stack size for mass storage thread"
    	default 8192
    	help
    	  Stack size for mass storage disk operations thread
    Best regards
    Torbjørn
