getting errors while building from https://devzone.nordicsemi.com/guides/nrf-connect-sdk-guides/b/software/posts/ncs-dfu
i'm using a nrf52833-DK board and trying to perform DFU exactly as mentioned in  https://devzone.nordicsemi.com/guides/nrf-connect-sdk-guides/b/software/posts/ncs-dfu
i'm getting the following errors can u please help me resolve it
* Executing task: nRF Connect: Generate config nrf52833dk_nrf52820 for mesh_samples/ble_dfu_peripheral_lbs
Building ble_dfu_peripheral_lbs
west build --build-dir d:\ncs\mesh_samples\ble_dfu_peripheral_lbs\build d:\ncs\mesh_samples\ble_dfu_peripheral_lbs --pristine --board nrf52833dk_nrf52820 -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="d:/ncs/mesh_samples/light_switch;d:/ncs/mesh_samples/ble_dfu_peripheral_lbs;d:/ncs/mesh_samples/peripheral_lbs"
-- Application: D:/ncs/mesh_samples/ble_dfu_peripheral_lbs
-- Found Python3: C:/ncs/toolchains/v2.2.0/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.2.0/zephyr/.cache
-- Zephyr version: 3.2.99 (C:/ncs/v2.2.0/zephyr)
-- Board: nrf52833dk_nrf52820
-- Found host-tools: zephyr 0.15.1 (C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.15.1 (C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/v2.2.0/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/ncs/v2.2.0/zephyr/boards/arm/nrf52833dk_nrf52820/nrf52833dk_nrf52820.dts
-- Generated zephyr.dts: D:/ncs/mesh_samples/ble_dfu_peripheral_lbs/build/zephyr/zephyr.dts
-- Generated devicetree_generated.h: D:/ncs/mesh_samples/ble_dfu_peripheral_lbs/build/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: D:/ncs/mesh_samples/ble_dfu_peripheral_lbs/build/zephyr/dts.cmake
Parsing D:/ncs/mesh_samples/ble_dfu_peripheral_lbs/Kconfig
Loaded configuration 'C:/ncs/v2.2.0/zephyr/boards/arm/nrf52833dk_nrf52820/nrf52833dk_nrf52820_defconfig'
Merged configuration 'D:/ncs/mesh_samples/ble_dfu_peripheral_lbs/prj.conf'
Configuration saved to 'D:/ncs/mesh_samples/ble_dfu_peripheral_lbs/build/zephyr/.config'
Kconfig header saved to 'D:/ncs/mesh_samples/ble_dfu_peripheral_lbs/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 12.1.0
-- The CXX compiler identification is GNU 12.1.0
-- Found assembler: C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
-- Found Python3: C:/ncs/toolchains/v2.2.0/opt/bin/python.exe (found version "3.8.2") found components: Interpreter
=== child image mcuboot - begin ===
loading initial cache file D:/ncs/mesh_samples/ble_dfu_peripheral_lbs/build/mcuboot/child_image_preload.cmake
-- Application: C:/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr
-- Found devicetree overlay: C:/ncs/v2.2.0/nrf/modules/mcuboot/usb.overlay
-- Found devicetree overlay: C:/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr/dts.overlay
-- Generated zephyr.dts: D:/ncs/mesh_samples/ble_dfu_peripheral_lbs/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_generated.h: D:/ncs/mesh_samples/ble_dfu_peripheral_lbs/build/mcuboot/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: D:/ncs/mesh_samples/ble_dfu_peripheral_lbs/build/mcuboot/zephyr/dts.cmake
Parsing C:/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr/Kconfig
Merged configuration 'C:/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration 'C:/ncs/v2.2.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration 'D:/ncs/mesh_samples/ble_dfu_peripheral_lbs/build/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'D:/ncs/mesh_samples/ble_dfu_peripheral_lbs/build/mcuboot/zephyr/.config'
Kconfig header saved to 'D:/ncs/mesh_samples/ble_dfu_peripheral_lbs/build/mcuboot/zephyr/include/generated/autoconf.h'
MCUBoot bootloader key file: C:/ncs/v2.2.0/bootloader/mcuboot/root-rsa-2048.pem
-- Configuring done
-- Generating done
-- Build files have been written to: D:/ncs/mesh_samples/ble_dfu_peripheral_lbs/build/mcuboot
=== child image mcuboot - end ===
CMake Warning at C:/ncs/v2.2.0/nrf/modules/mcuboot/CMakeLists.txt:286 (message):
--- WARNING: Using default MCUBoot key, it should not ---
--- be used for production. ---
CMake Warning at C:/ncs/v2.2.0/zephyr/CMakeLists.txt:1833 (message):
-- Configuring done
-- Generating done
[1/270] Generating include/generated/version.h
-- Zephyr version: 3.2.99 (C:/ncs/v2.2.0/zephyr), build: v3.2.99-ncs1
[2/270] Creating directories for 'mcuboot_subimage'
[3/270] No download step for 'mcuboot_subimage'
[4/270] No update step for 'mcuboot_subimage'
[5/270] No patch step for 'mcuboot_subimage'
[6/270] No configure step for 'mcuboot_subimage'
[6/270] Performing build step for 'mcuboot_subimage'
[1/275] Generating include/generated/version.h
[2/275] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[3/275] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[4/275] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[5/275] Generating include/generated/driver-validation.h
[6/275] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[7/275] Generating include/generated/offsets.h
[8/275] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[9/275] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[10/275] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
[11/275] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[12/275] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
[13/275] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[14/275] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
[15/275] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[16/275] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[17/275] Generating linker_zephyr_pre1.cmd
[18/275] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[19/275] Generating linker_zephyr_pre0.cmd
[20/275] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[21/275] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[22/275] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[23/275] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[24/275] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[25/275] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[26/275] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[27/275] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[28/275] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[29/275] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[30/275] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[31/275] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[32/275] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[33/275] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[34/275] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.2.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
[35/275] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[36/275] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[37/275] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[38/275] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[39/275] Linking C static library zephyr\arch\common\libisr_tables.a
[40/275] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/mdk/system_nrf52820.c.obj
[41/275] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[42/275] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[43/275] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
[44/275] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
[45/275] Building C object modules/segger/CMakeFiles/modules__segger.dir/SEGGER_RTT_zephyr.c.obj
[46/275] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_wdt.c.obj
[47/275] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[48/275] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[49/275] Building C object modules/segger/CMakeFiles/modules__segger.dir/C_/ncs/v2.2.0/modules/debug/segger/SEGGER/SEGGER_RTT.c.obj
[50/275] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_ppi.c.obj
[51/275] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
[52/275] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
[53/275] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
[54/275] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[55/275] Linking C static library zephyr\arch\common\libarch__common.a
[56/275] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[57/275] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[58/275] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[59/275] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[60/275] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[61/275] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[62/275] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[63/275] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[64/275] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[65/275] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[66/275] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[67/275] Linking C static library modules\segger\libmodules__segger.a
[68/275] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[69/275] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[70/275] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[71/275] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[72/275] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
[73/275] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[74/275] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[75/275] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[76/275] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[77/275] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[78/275] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[79/275] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[80/275] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[81/275] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[82/275] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[83/275] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[84/275] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[85/275] Generating zephyr/autogen-pubkey.c
[86/275] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[87/275] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
[88/275] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[89/275] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[90/275] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[91/275] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[92/275] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_nano.c.obj
[93/275] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
[94/275] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[95/275] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[96/275] Linking C static library zephyr\kernel\libkernel.a
[97/275] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[98/275] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
[99/275] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
[100/275] Building C object CMakeFiles/app.dir/main.c.obj
[101/275] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
[102/275] Building C object CMakeFiles/app.dir/os.c.obj
[103/275] Building C object CMakeFiles/app.dir/keys.c.obj
[104/275] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj
[105/275] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj
[106/275] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_ed25519.c.obj
[107/275] Building C object CMakeFiles/app.dir/zephyr/autogen-pubkey.c.obj
[108/275] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_ec256.c.obj
[109/275] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/fault_injection_hardening.c.obj
[110/275] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj
[111/275] Generating ../../../include/generated/libc/minimal/strerror_table.h
[112/275] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj
[113/275] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/caps.c.obj
[114/275] Building C object CMakeFiles/app.dir/nrf_cleanup.c.obj
[115/275] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/swap_scratch.c.obj
[116/275] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj
[117/275] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
[118/275] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
[119/275] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj
[120/275] Linking C static library zephyr\libzephyr.a
[121/275] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/soc.c.obj
[122/275] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[123/275] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[124/275] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
[125/275] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
[126/275] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[127/275] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
[128/275] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
[129/275] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[130/275] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
[131/275] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
[132/275] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
[133/275] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[134/275] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
[135/275] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[136/275] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[137/275] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[138/275] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[139/275] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[140/275] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
[141/275] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[142/275] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[143/275] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
[144/275] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[145/275] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[146/275] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[147/275] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
[148/275] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
[149/275] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
[150/275] Linking C static library app\libapp.a
[151/275] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
[152/275] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[153/275] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
[154/275] Linking C static library zephyr\soc\arm\nordic_nrf\nrf52\libsoc__arm__nordic_nrf__nrf52.a
[155/275] Linking C static library zephyr\drivers\console\libdrivers__console.a
[156/275] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
[157/275] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
[158/275] Building C object modules/nrf/lib/fprotect/CMakeFiles/..__nrf__lib__fprotect.dir/fprotect_acl.c.obj
[159/275] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
[160/275] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[161/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/aria.c.obj
[162/275] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
[163/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/asn1write.c.obj
[164/275] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
[165/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/zephyr_init.c.obj
[166/275] Linking C static library zephyr\drivers\flash\libdrivers__flash.a
[167/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/aes.c.obj
[168/275] Linking C static library modules\nrf\lib\fprotect\lib..__nrf__lib__fprotect.a
[169/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/asn1parse.c.obj
[170/275] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
[171/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/base64.c.obj
[172/275] Linking C static library zephyr\drivers\pinctrl\libdrivers__pinctrl.a
[173/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/camellia.c.obj
[174/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/chacha20.c.obj
[175/275] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
[176/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/chachapoly.c.obj
[177/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ccm.c.obj
[178/275] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
[179/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/cmac.c.obj
[180/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/aesni.c.obj
[181/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/dhm.c.obj
[182/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/cipher.c.obj
[183/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/des.c.obj
[184/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ecdh.c.obj
[185/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/cipher_wrap.c.obj
[186/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/constant_time.c.obj
[187/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/debug.c.obj
[188/275] Linking C static library modules\mcuboot\boot\bootutil\zephyr\libmcuboot_util.a
[189/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ctr_drbg.c.obj
[190/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ecjpake.c.obj
[191/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/entropy.c.obj
[192/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ecdsa.c.obj
[193/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/gcm.c.obj
[194/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ecp_curves.c.obj
[195/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/hmac_drbg.c.obj
[196/275] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
[197/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ecp.c.obj
[198/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/entropy_poll.c.obj
[199/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/error.c.obj
[200/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/hkdf.c.obj
[201/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/bignum.c.obj
[202/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/md.c.obj
[203/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/mps_reader.c.obj
[204/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/net_sockets.c.obj
[205/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/md5.c.obj
[206/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/nist_kw.c.obj
[207/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/mps_trace.c.obj
[208/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/pkparse.c.obj
[209/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/pk_wrap.c.obj
[210/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/oid.c.obj
[211/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/pem.c.obj
[212/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/pkcs5.c.obj
[213/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/pk.c.obj
[214/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/padlock.c.obj
[215/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/memory_buffer_alloc.c.obj
[216/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/poly1305.c.obj
[217/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/pkwrite.c.obj
[218/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto.c.obj
[219/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/pkcs12.c.obj
[220/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/platform.c.obj
[221/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/platform_util.c.obj
[222/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_client.c.obj
[223/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_ecp.c.obj
[224/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_aead.c.obj
[225/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_cipher.c.obj
[226/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_se.c.obj
[227/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_driver_wrappers.c.obj
[228/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_hash.c.obj
[229/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_slot_management.c.obj
[230/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_mac.c.obj
[231/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_rsa.c.obj
[232/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ripemd160.c.obj
[233/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_its_file.c.obj
[234/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/sha1.c.obj
[235/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/sha512.c.obj
[236/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_ciphersuites.c.obj
[237/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/rsa_alt_helpers.c.obj
[238/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/sha256.c.obj
[239/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_tls13_keys.c.obj
[240/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_msg.c.obj
[241/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_srv.c.obj
[242/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_cli.c.obj
[243/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_cache.c.obj
[244/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_cookie.c.obj
[245/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_storage.c.obj
[246/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_tls13_generic.c.obj
[247/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_debug_helpers_generated.c.obj
[248/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_tls.c.obj
[249/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_tls13_client.c.obj
[250/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/version.c.obj
[251/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_ticket.c.obj
[252/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/threading.c.obj
[253/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/timing.c.obj
[254/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/rsa.c.obj
[255/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_tls13_server.c.obj
[256/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/version_features.c.obj
[257/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/x509_csr.c.obj
[258/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/x509_crl.c.obj
[259/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/x509.c.obj
[260/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/x509_crt.c.obj
[261/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/x509write_crt.c.obj
[262/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/x509_create.c.obj
[263/275] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/x509write_csr.c.obj
[264/275] Linking C static library modules\mbedtls\libmodules__mbedtls.a
[265/275] Linking C executable zephyr\zephyr_pre0.elf
[266/275] Generating dev_handles.c
[267/275] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj
[268/275] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
[269/275] Linking C executable zephyr\zephyr_pre1.elf
[270/275] Generating linker.cmd
[271/275] Generating isr_tables.c, isrList.bin
[272/275] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
[273/275] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
[274/275] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
[275/275] Linking C executable zephyr\zephyr.elf
FAILED: zephyr/zephyr.elf zephyr/zephyr.map zephyr/zephyr.hex zephyr/zephyr.bin zephyr/zephyr.meta zephyr/zephyr.lst zephyr/zephyr.stat
cmd.exe /C "cd . && C:\ncs\toolchains\v2.2.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -gdwarf-4 zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj -o zephyr\zephyr.elf -Wl,-T zephyr/linker.cmd -Wl,-Map=D:/ncs/mesh_samples/ble_dfu_peripheral_lbs/build/mcuboot/zephyr/zephyr_final.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a zephyr/lib/libc/minimal/liblib__libc__minimal.a zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a zephyr/drivers/clock_control/libdrivers__clock_control.a zephyr/drivers/console/libdrivers__console.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/flash/libdrivers__flash.a zephyr/drivers/serial/libdrivers__serial.a zephyr/drivers/timer/libdrivers__timer.a zephyr/drivers/pinctrl/libdrivers__pinctrl.a modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a modules/mbedtls/libmodules__mbedtls.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a modules/segger/libmodules__segger.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -L"c:/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/thumb/v7e-m/nofp" -LD:/ncs/mesh_samples/ble_dfu_peripheral_lbs/build/mcuboot/zephyr -lgcc -Wl,--print-memory-usage zephyr/arch/common/libisr_tables.a -no-pie -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -Wl,-X -Wl,-N -Wl,--orphan-handling=warn && cmd.exe /C "cd /D D:\ncs\mesh_samples\ble_dfu_peripheral_lbs\build\mcuboot\zephyr && C:\ncs\toolchains\v2.2.0\opt\bin\cmake.exe -E copy zephyr_final.map zephyr.map && C:\ncs\toolchains\v2.2.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-objcopy.exe --gap-fill 0xff --output-target=ihex --remove-section=.comment --remove-section=COMMON --remove-section=.eh_frame zephyr.elf zephyr.hex && C:\ncs\toolchains\v2.2.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-objcopy.exe --gap-fill 0xff --output-target=binary --remove-section=.comment --remove-section=COMMON --remove-section=.eh_frame zephyr.elf zephyr.bin && C:\ncs\toolchains\v2.2.0\opt\bin\python.exe C:/ncs/v2.2.0/zephyr/scripts/zephyr_module.py --zephyr-base C:/ncs/v2.2.0/zephyr --meta-out zephyr.meta && C:\ncs\toolchains\v2.2.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-objdump.exe -d -S zephyr.elf > zephyr.lst && C:\ncs\toolchains\v2.2.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-readelf.exe -e zephyr.elf > zephyr.stat""
Memory region Used Size Region Size %age Used
FLASH: 33320 B 48 KB 67.79%
RAM: 23744 B 32 KB 72.46%
IDT_LIST: 0 GB 2 KB 0.00%
File "C:/ncs/v2.2.0/zephyr/scripts/zephyr_module.py", line 624, in <module>
main()
File "C:/ncs/v2.2.0/zephyr/scripts/zephyr_module.py", line 616, in main
meta = process_meta(args.zephyr_base, west_projs, modules,
File "C:/ncs/v2.2.0/zephyr/scripts/zephyr_module.py", line 392, in process_meta
if project.sha(MANIFEST_REV_BRANCH) != revision:
File "c:\ncs\toolchains\v2.2.0\opt\bin\Lib\site-packages\west\manifest.py", line 861, in sha
cp = self.git(f'rev-parse {rev}^{{commit}}', capture_stdout=True,
File "c:\ncs\toolchains\v2.2.0\opt\bin\Lib\site-packages\west\manifest.py", line 845, in git
raise subprocess.CalledProcessError(popen.returncode, cmd_list,
subprocess.CalledProcessError: Command '['rev-parse', 'manifest-rev^{commit}']' returned non-zero exit status 128.
[249/270] Linking C executable zephyr\zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
cmd.exe /C "cd . && C:\ncs\toolchains\v2.2.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -gdwarf-4 @CMakeFiles\zephyr_pre0.rsp -o zephyr\zephyr_pre0.elf && cmd.exe /C "cd /D D:\ncs\mesh_samples\ble_dfu_peripheral_lbs\build\zephyr && C:\ncs\toolchains\v2.2.0\opt\bin\cmake.exe -E echo ""
c:/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.exe: zephyr\zephyr_pre0.elf section `text' will not fit in region `FLASH'
c:/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.exe: zephyr\zephyr_pre0.elf section `noinit' will not fit in region `RAM'
c:/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.exe: region `FLASH' overflowed by 87428 bytes
c:/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.exe: region `RAM' overflowed by 5116 bytes
collect2.exe: error: ld returned 1 exit status
FAILED: modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build mcuboot/zephyr/zephyr.hex mcuboot/zephyr/zephyr.elf
cmd.exe /C "cd /D D:\ncs\mesh_samples\ble_dfu_peripheral_lbs\build\mcuboot && C:\ncs\toolchains\v2.2.0\opt\bin\cmake.exe --build . --"
FATAL ERROR: command exited with status 1: 'c:\ncs\toolchains\v2.2.0\opt\bin\cmake.EXE' --build 'd:\ncs\mesh_samples\ble_dfu_peripheral_lbs\build'
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
