Failing to connect Connecting Light Bulb sample to HomePod Mini, possibly due to 46336 [SVR]Cannot load binding table
I'm able to build and deploy my app to the nRF52840 board.
On start-up the QR code link is listed and the pairing code and on my Android phone, under Bluetooth, I can see the board listed
But the logs then says...
533 [DL]CHIP task running
I: 536 [DIS]Updating services using commissioning mode 0
D: 541 [DL]Using Thread extended MAC for hostname.
D: 545 [DL]Using Thread extended MAC for hostname.
I: 550 [DIS]Advertise commission parameter vendorID=65521 productID=32772 discriminator=3840/15 cm=0
E: 559 [DIS]Failed to advertise extended commissionable node: 3
E: 565 [DIS]Failed to finalize service update: 1c
***** BUS FAULT *****
E: Imprecise data bus error
E: r0/a1: 0x00001000 r1/a2: 0x40010604 r2/a3: 0x6e524635
E: r3/a4: 0x00000001 r12/ip: 0x00000000 r14/lr: 0x2000041f
E: xpsr: 0x01000000
E: s[ 0]: 0x00000000 s[ 1]: 0x00000000 s[ 2]: 0x00000000 s[ 3]: 0x00000000
E: s[ 4]: 0x00000000 s[ 5]: 0x00000000 s[ 6]: 0x00000000 s[ 7]: 0x00000000
E: s[ 8]: 0x00000000 s[ 9]: 0x00000000 s[10]: 0x00000000 s[11]: 0x00000000
E: s[12]: 0x00000000 s[13]: 0x00000000 s[14]: 0x00000000 s[15]: 0x00000000
E: fpscr: 0x00000000
E: Faulting instruction address (r15/pc): 0x20000430
E: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0
E: Current thread: 0x20011ed8 (CHIP)
E: Halting system
I: Initialize binding Handler
I: 46336 [SVR]Cannot load binding table: a0
In short I just want to recreate this demo ( have a nanoleaf lightbulb).
https://www.youtube.com/watch?v=yLkkeVM0Guo
I'm new to working with this board, so unsure if I'm doing something wrong or if I need to do something else (setup wise) for the demos (created from SDK v2.2.0) to work. and be detected by HomePod mini etc.
So any help in pointing me in the right direction, would be greatly appreciated!
  • Hi
    I cleaned out the /opt/nordic/ncs/v2.2.0/modules/lib/matter/third_party/zap/repo directory re-ran the run_zaptool.sh on our zap file and got the attached error.
    There could be a error in there, but as I mentioned the contents were copied from the post you linked to earlier.
    So 2 questions.
    1. What is the timeframe for nordic to update their samples to include one that (just) works with Google/Apple Home out of the box? This would greatly help, I think, newbie devs like me who just want a working, end to end, Matter starting point, to then hack from.
    2. I have sent an email to your sales team last week about getting in contact with a nordic consultant to help us get a working Google/Apple Home Matter sample up and running, but I've heard absolutely nothing since. Is there something else I need to do?
    Dominique.
     2023-03-13T10_05_48_889Z-debug-0.log
  • Dear marte:
    I would like to ask you a question about the above mentioned "use zap tool to add generic type switches", is all the operation under windows or linux, because I failed to operate under windows.
    chuck
  • Hi Dominique,
    Thank you for your patience, I have been out of the office and unable to respond to tickets.
    Our samples should work with Google/Apple Home out of the box. In the blog post I linked to earlier,  Matter: Testing the nRF Connect platform with Apple, Google and Samsung ecosystems, the developers are using the out-of-the-box Light Bulb sample. We have seen cases of people having issues with Google/Apple home, but after looking into the issues, the developers have found that the issues are not in our SDK or samples, but rather on Google's/Apple's side.
    Please send me a direct message with the contact information you used and where you are located, and I will help you get in contact with our regional sales manager in your area.
    Can you try with nRF Connect SDK v2.3.0 and see if you have the same issue? Please be aware that there are some changes to the steps of running the ZAP tool in this version. See Adding clusters to Matter application - v2.3.0.
    Marte
  • Hi Chuck,
    The instructions are written for Linux and MAC. On Windows you need to use the following command:
    bash scripts/tools/zap/run_zaptool.sh ../../../nrf/samples/matter/sensor/src/template.zap
    Marte
