I'm using nRF Connect v2.0.2 and running in Zephyr.
When scanning by filtering for UUID, I find the matching devices, and the scan filter match callback gets called. However, when I try to parse the advertising data, I can only see one type.
Example: If I filter on UUID, the advertising data parse only contains UUID type
BT_SCAN_CB_INIT(scan_cbhs, scan_filter_match, NULL, NULL, NULL);
start_scanning_function()
struct bt_scan_init_param scan_init = {
.connect_if_match = 0,
.scan_param = BT_LE_SCAN_ACTIVE, // can this be passive?
.conn_param = BT_LE_CONN_PARAM_DEFAULT
bt_scan_init(&scan_init);
bt_scan_cb_register(&scan_cbhs);
bt_scan_filter_add(BT_SCAN_FILTER_TYPE_UUID, BT_UUID_DECLARE_128(BLE_UUID128_ENCODE(K_BLE_UUID_FILTER_VAL)));
bt_scan_filter_enable(BT_SCAN_UUID_FILTER, false);
bt_scan_start(BT_SCAN_TYPE_SCAN_ACTIVE);
static void scan_filter_match(struct bt_scan_device_info *device_info,
struct bt_scan_filter_match *filter_match,
bool connectable)
bt_data_parse(device_info->adv_data, find_adv_data, NULL);
bool find_adv_data(struct bt_data *data, void *user_data)
printk("Data type is %u \n", data->type);
return true; // keep parsing
In the code example above, the only print is
Parse type 7
which is I think is BT_DATA_UUID128_ALL, but not other calls to the parser callback
Similarly if I filter on device name instead of UUID, then I only get
Parse type 1
which I think is BT_DATA_FLAGS and that's it.
If I scan and filter based on UUID, how do I access the advertised device name, manufacturer data, or other data from the device's advertisement?
Thanks
