When I connect on tera term and try sending AT commands, the device doesn't identify them,
My prj.conf file looks like this:
I don't want to use AT_SHELL, so can u please suggest:
# Copyright (c) 2020 Nordic Semiconductor ASA
# General config
# Firmware version string v<major>.<minor>.<build>
CONFIG_FIRMWARE_VERSION="v0.200.01"
# Enable Zephyr application to be booted by MCUboot
# MCUBOOT
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_MCUBOOT_IMG_MANAGER=y
CONFIG_DEBUG=y
CONFIG_REBOOT=y
# RESET_ON_FATAL_ERROR is y by default if !DEBUG
CONFIG_RESET_ON_FATAL_ERROR=y
# CONFIG_DEBUG_OPTIMIZATIONS=y
# CONFIG_DEBUG_THREAD_INFO=y
# Image manager
CONFIG_IMG_MANAGER=y
CONFIG_FLASH=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
# Provisioning mode
CONFIG_PROD_TEST=y
# Shell configurations
CONFIG_PRINTK=y
CONFIG_SHELL=y
# CONFIG_SHELL_BACKENDS=y
CONFIG_SHELL_BACKEND_SERIAL=y
CONFIG_SHELL_MINIMAL=y
# CONFIG_SHELL_STACK_SIZE=4096
# CONFIG_USE_SEGGER_RTT=y
# CONFIG_SHELL_CMDS=y
# CONFIG_SHELL_CMDS_RESIZE=y
# CONFIG_SHELL_TAB=y
# CONFIG_SHELL_HISTORY=y
# AT Shell
# CONFIG_AT_SHELL=y
# disable * and ? wildcards for at commands
CONFIG_SHELL_WILDCARD=n
# CONFIG_RING_BUFFER=n
# logging configurations
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=4
CONFIG_LOG_BACKEND_UART=y
CONFIG_LOG_MODE_IMMEDIATE=y
# NEWLIB C
CONFIG_NEWLIB_LIBC=y
# Modem library
# CONFIG_NRF_MODEM_LIB=y
# Modem
CONFIG_MODEM_INFO=y
# AT Host
# CONFIG_AT_HOST_LIBRARY=y
# CONFIG_AT_HOST_UART_0=y
# Modbus
CONFIG_MODBUS=y
CONFIG_MODBUS_SERIAL=y
CONFIG_MODBUS_ROLE_CLIENT=y
# Network
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
# LTE link control
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
CONFIG_LTE_NETWORK_TIMEOUT=120
# LTE Mode
CONFIG_LTE_NETWORK_MODE_LTE_M=y
# CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT=y
# CONFIG_LTE_NETWORK_USE_FALLBACK=y
# CONFIG_LTE_MODE_PREFERENCE_LTE_M=y
# CONFIG_LTE_MODE_PREFERENCE_NBIOT=y
# Only enable bands: 2,4,12,13 This will provide coverage for the USA and Canada (Rogers, Telus, AT&T and Verizon).
# The rational: Limiting the bands will allow the modem to find a suitable network faster the first time.
# After running for a few days, the modem writes it's band history to NV and will remember
# the previous bands used which shortens the registration time. We can also remove this capability if
# are ok with long registration times for the first power up. Depending on our final unit
# test process, removing this logic would likely increase our test times. I am putting in for now.
# First enable modem to disable the extra/unused frequency bands.
CONFIG_LTE_LOCK_BANDS=y
# Then only enable bands 2, 4, 12, 13 (it's a bitmask starting at Band #1 in the LSB)
CONFIG_LTE_LOCK_BAND_MASK="1100000001010"
# Set the PDP Context - for Rogers OR Eseye SIM cards. Change the default APN setting below for Rogers or Eseye
CONFIG_PDN=y
CONFIG_PDN_DEFAULTS_OVERRIDE=y
CONFIG_PDN_SYS_INIT=y
CONFIG_PDN_DEFAULT_APN="\"m2minternet.apn\""
# CONFIG_PDN_DEFAULT_APN="\"eseye1\""
CONFIG_PDN_DEFAULT_FAM_IPV4V6=y
CONFIG_TELEMETRY_PAYLOAD_BUFFER_SIZE=1024
CONFIG_BASE64=y
CONFIG_MQTT_LIB=y
CONFIG_MQTT_LIB_TLS=y # For aws MQTT TLS
# AWS IoT library
CONFIG_AWS_IOT=y
CONFIG_AWS_IOT_CLIENT_ID_APP=y
CONFIG_AWS_IOT_BROKER_HOST_NAME="a1hxntjfjh5450-ats.iot.ca-central-1.amazonaws.com"
CONFIG_AWS_IOT_SEC_TAG=12345678
CONFIG_AWS_IOT_LOG_LEVEL_DBG=y
CONFIG_AWS_IOT_AUTO_DEVICE_SHADOW_REQUEST=n
CONFIG_AWS_IOT_APP_SUBSCRIPTION_LIST_COUNT=2
CONFIG_AWS_IOT_TOPIC_UPDATE_DELTA_SUBSCRIBE=y
CONFIG_AWS_IOT_LAST_WILL=y
CONFIG_AWS_IOT_TOPIC_GET_ACCEPTED_SUBSCRIBE=y
CONFIG_AWS_IOT_TOPIC_GET_REJECTED_SUBSCRIBE=y
#CONFIG_AWS_IOT_MQTT_PAYLOAD_BUFFER_LEN=2048
# CONFIG_AWS_IOT_APP_SUBSCRIPTION_LIST_COUNT=2
# CONFIG_AWS_IOT_TOPIC_UPDATE_DELTA_SUBSCRIBE=y
# CONFIG_AWS_IOT_TOPIC_UPDATE_ACCEPTED_SUBSCRIBE=y
# CONFIG_AWS_IOT_TOPIC_UPDATE_REJECTED_SUBSCRIBE=y
CONFIG_AWS_IOT_CLIENT_ID_MAX_LEN=50
# MQTT - Maximum MQTT keepalive timeout specified by AWS IoT Core
CONFIG_MQTT_KEEPALIVE=1200
CONFIG_SNTP=y
# Date Time library
CONFIG_DATE_TIME=y
CONFIG_DATE_TIME_NTP=n
CONFIG_DATE_TIME_MODEM=y
# Heap and stacks
CONFIG_HEAP_MEM_POOL_SIZE=8192
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_FPU=y
CONFIG_FPU_SHARING=y
# AWS FOTA
CONFIG_AWS_FOTA=y
CONFIG_AWS_FOTA_DOWNLOAD_SECURITY_TAG=12345678
CONFIG_FOTA_DOWNLOAD=y
CONFIG_DFU_TARGET=y
CONFIG_DFU_TARGET_STREAM_SAVE_PROGRESS=y
# Settings
CONFIG_SETTINGS=y
CONFIG_SETTINGS_NVS=y
# Non-volatile Storage
CONFIG_NVS=y
# CJSON
CONFIG_CJSON_LIB=y
# Download client (needed by AWS FOTA)
CONFIG_DOWNLOAD_CLIENT=y
CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
####### THUNDER
CONFIG_THREAD_NAME=y
CONFIG_CMSIS_DSP=y
CONFIG_CMSIS_DSP_SUPPORT=y
CONFIG_CMSIS_DSP_FASTMATH=y
CONFIG_CMSIS_DSP_COMPLEXMATH=y
CONFIG_CMSIS_DSP_STATISTICS=y
CONFIG_CMSIS_DSP_TRANSFORM=y
CONFIG_CMSIS_DSP_TABLES_ALL_FFT=n
CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F32_1024=y
# CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F32_2048=y
# Filesystem
CONFIG_SPI=y
CONFIG_SPI_ASYNC=y
CONFIG_SPI_NOR=y
CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
CONFIG_DISK_ACCESS=y
CONFIG_DISK_DRIVER_SDMMC=y
CONFIG_SDMMC_OVER_SPI=y
# Enable flash operations.
CONFIG_FLASH_MAP=y
CONFIG_FLASH_PAGE_LAYOUT=y
# Enable the LittleFS file system.
CONFIG_FILE_SYSTEM=y
CONFIG_FILE_SYSTEM_LITTLEFS=y
# CONFIG_FILE_SYSTEM_SHELL=y
# Partition manager settings
CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=n
CONFIG_LOG=y
CONFIG_NRF_CLOUD_LOG_LEVEL_DBG=y
# logging configurations when debugging
# CONFIG_LOG_BACKEND_UART=y
CONFIG_LOG_PRINTK=y
CONFIG_I2C=y
CONFIG_SENSOR=y
# Temp, Pressure, Humidity and gas sensor
CONFIG_BME688=y
# CONFIG_BME688_TEMP_OVER_4X=y
# Accelerometer
# CONFIG_BMA280=y
# CONFIG_BMA280_TRIGGER_GLOBAL_THREAD=y
# CONFIG_BMA280_PMU_RANGE_2G=y
# # 15.63Hz
# CONFIG_BMA280_PMU_BW_2=y
# battery / VSYS
CONFIG_ADC=y
CONFIG_STATS=y
CONFIG_STATS_SHELL=y
# Zephyr Device Power Management
CONFIG_PM=y
# Required to disable default behavior of deep sleep on timeout
CONFIG_PM_DEVICE=y
# configure to Enable Modem sleep notifications
CONFIG_LTE_LC_MODEM_SLEEP_NOTIFICATIONS=y # see if this is working
## PSM
# CONFIG_UDP_PSM_ENABLE=y
CONFIG_LTE_PSM_REQ_RPTAU="00000110"
CONFIG_LTE_PSM_REQ_RAT="00000101"
#PDM
CONFIG_NRFX_PDM=y
