Clarifications for sdc_default_tx_power_set() and CONFIG_BT_CTLR_TX_PWR in NCS 2.2
1. Can I assume that if I set CONFIG_MPSL_FEM_POWER_MODEL=n, then the value I set with sdc_default_tx_power_set() is just the radio tx power level and not necessarily the power level fed to the antenna?
  • The documentation for sdc_default_tx_power_set(int8_t requested_power_level) says:
requested_power_level represents the actual power level fed to the antenna. When a Front-End Module is used, gain values for the SoC and FEM are calculated automatically to guarantee the closest possible match to the value requested by the user at the RF output.
The reason I bring this up is that I can still have an FEM that I control outside of the SDC. In this case, with CONFIG_MPSL_FEM_POWER_MODEL=n, the requested_power_level is not the power level fed to the antenna, contrary to the description. right?  If so, then perhaps the description could be clarified by adding what's in bold:  “When a Front-End Module is used and CONFIG_MPSL_FEM_POWER_MODEL=y, gain values for …”
2. If CONFIG_MPSL_FEM_POWER_MODEL=n, then what is the difference between CONFIG_BT_CTLR_TX_PWR and sdc_default_tx_power_set()?  Do they both achieve the same result, except one is a build-time setting and the other is a run-time setting, and the latter can override the former?
3. Why don’t the possible values of CONFIG_BT_CTLR_TX_PWR allow all possible nRF5340 radio transmit power levels?  For example, -6 dBm is a valid nRF5340 radio tx power (see TXPOWER register) but no such choice exists for CONFIG_BT_CTRL_TX_PWR.  The closest choices are CONFIG_BT_CTLR_TX_PWR_MINUS_4 and CONFIG_BT_CTLR_TX_PWR_MINUS_8.
4. Again with CONFIG_MPSL_FEM_POWER_MODEL=n:  From my understanding, the beginning of a transmit for a BLE connection or for BLE advertising begins with the radio transmit power value in CONFIG_BT_CTRL_TX_PWR, unless overridden by sdc_default_tx_power_set() having been called before calling sdc_enable().  If, for example, I change the transmit power during a BLE connection by using the HCI command BT_HCI_OP_VS_WRITE_TX_POWER_LEVEL, the radio transmit power level will change to that HCI command value, but the radio transmit power level will return to the default value at the start of the next BLE connection or if I start advertising again.  Is that correct?
Thanks in advance.
  • Hi Torbjørn,
    The gain of the connected PA is set to -10 dBm.
    I updated my model init and fetch routines to look like this.
    static int8_t gFemGain = 0;
    static void model_init(const mpsl_fem_calibration_data_t *p_calibration_data)
       gFemGain = p_calibration_data->simple_gpio.gain;
    static void model_fetch(int8_t                        requested_power,
                            uint16_t                       freq_mhz,
                            mpsl_fem_power_model_output_t *p_output)
          (void) freq_mhz;
          p_output->soc_pwr      = mpsl_tx_power_radio_supported_power_adjust(requested_power);
          p_output->fem.gain_db  = gFemGain;
          p_output->achieved_pwr = requested_power;
    Setting the p_output->fem.gain_db to the same value that's in the device tree does fix the network core reset issue.
    The following table shows the Radio Power values with their corresponding TXPOWER register value:
    Radio Tx Power TXPOWEER register
    3 0xFE => -2 dBm w/VREGRADIO.VREQH=1
    2 0xFE => -2 dBm w/VREGRADIO.VREQH=1
    1 0xFE => -2 dBm w/VREGRADIO.VREQH=1
    0 0x00 => 0 dBm
    -1 0xFF => -1 dBm
    -2 0xFE => -2 dBm
    -3 0xFD => -3 dBm
    -4 0xFC => -4 dBm
    -5 0xFB => -5 dBm
    -6 0xFA => -6 dBm
    -7 0xF9 => -7 dBm
    -8 0xF8 => -8 dBm
    -12 0xF4 => -12 dBm
    -16 0xF0 => -16 dBm
    Everything looks good except for the 1st two rows. The 1st two rows should look like this:
    Radio Tx Power TXPOWER Register
    3 0x00 => 0 dBm w/VREGRADIO.VREQH=1
    2 0xFF => -1 dBm w/VREGRADIO.VREQH=1
    because if VREGADIO.VREQH=1, there's a +3 dBm TX power that's added on the radio.
    In NCS 2.0, we got the right TXPOWER register values for Radio Tx Power 2 &3.
    ronbo999
  • Hi Ron,
    I'm taking over the case when Torbjørn is on vacation.
    I have forwarded your question to our R&D team and got some feedback:
    - `mpsl_tx_power_radio_supported_power_adjust` should properly return 2 and 3 as SoC output power, so the problem might be connected to a protocol driver and not to the FEM driver
    - maybe the customer could check if the value p_output->soc_pwr is set appropriately (or in other words does mpsl_tx_power_radio_supported_power_adjust) return the correct value - if it does, then this is connected rather to SDC then to MPSL.
    I assume mpsl_tx_power_radio_supported_power_adjust() return the correct value but what you find in the RADIO's TXPOWER was not should be expected ?
  • Hi Hung,
    It looks like the issue is not with the mpsl_tx_power_radio_supported_power_adjust().It returns the expected value for radio TX power of 1, 2 or 3.
    When the app core sets the radio tx power to 2 dBm or 3 dBm, the requested_power value in the model_fetch() is always set to 1. It's never set to 2 or 3. That's why the TXPOWER register is always set to 0xFE.
  • Hi Ronald,
    Just want to double check, the txpower is only changed by using sdc_default_tx_power_set() ? correct ?
  • Hi Hung,
    I'm not calling the sdc_default_tx_set(). The API for that function says that I can only call the sdc_default_tx_set() before sdc_enable() is called.
    Return values:
    • 0 – Success
    • -NRF_EPERM – This API must be called before sdc_enable().
    I'm sending a BT_HCI_OP_VS_WRITE_TX_POWER_LEVEL msg to the net core to change the transmit power level.
