Modem FW 1.3.4 Error 0x10
Hey,
we're currently testing our devices with Modem FW 1.3.4 / nRF Connect SDK 2.2.0 and have observed the following error:
00:01:37.478 <inf> app_event_manager: e:modem_module_event REQ_DISCONNECT (timeout = 30, lte_lc = offline)
00:01:38.236 <err> nrf_modem: Modem error: 0x10, PC: 0x7ce68
00:01:38.236 <err> lte_lc: Failed to set functional mode. Please check XSYSTEMMODE.
00:01:38.239 <inf> nrf_modem: Modem has faulted, re-initializing
  • LTE-M
  • Connection was successful before, no other issues
  • Data was transferred
  • GPS was used in-between
  • No PSM/eDRX
  • State before error: RRC connected
Does this information help you in any way?
If not, what details will help you further?
Kind regards
Markus
  • Sure, in case you have the nRF91 connected to a PC you can use the desktop tools to flash any modem firmware version you want.
  • Thanks!
    So no "left overs" in the flash config, a factory reset will not clean up?
    And no mechanisms, which prevents from downgrade with the 1.3.x line?
    we may have a similar issue. Can you please detail what was the issue here and is there any related issue/commit in the git?
    Marco
  • Hey,
    We seem to have the same problem . I would like to report an error that is happening with devices that have very low sleep time intervals ( 3 min or 5 min). After a while of normaly working those devices are crashing with an error shown in screen shot below (UART Logs). I also attached the UART logs in a file, the devices were working fine an after a while they crash ( all cases are with devices with very low sleep time). Once we reset the device it works again. The devices with very low sleep time intervals( 3 to 5minutes) are crashing again. Could you help us here please? we are currently in series production
    I: Modem library successfully shut down
    I: new sleep time in seconds : 130 (-49 Elapsed Time in seconds)
    I: Alarm set for 130 seconds.
    I: Going to deep sleep
    uart:~$ *** Booting nRF Connect SDK v2.5.0 ***
    W: Reset cause: 163
    W: RESET BY PIN
    I: Firmware VERSION 3.2.8
    I: 2 Sectors of 4096 bytes
    I: alloc wra: 0, ea0
    I: data wra: 0, 418
    I: No Bottle type is selected
    W: Please Select Bottle type for accurate Filling Level.
    I: Calibration data SLOP [0.000000] OFFSET [0]
    I: Display Language is ENGLISH
    I: Measured Weight: 0 grams
    I: Filling Level: 0
    I: Voltage: 3958
    I:  Battery Percentage: 78%
    I: HS4013_ID : -1475241472  |  Temperature is : 21   |   Humidity is : 36
    I: Modem FW version: mfw_nrf9160_1.3.5
    I: Using LTE LC neighbor search type GCI extended complete for 2 cells
    I: Extracted IMEI: [ 359746167113302 ] Device ID : [ gasvisor-ID359746167113302 ]
    I: Waiting for network..
    +CEREG: 2,"C936","018D3017",7
    W: LTE Searching
    +CSCON: 1
    I: RRC mode: connected
    +CGEV: ME PDN ACT 0,0
    +CNEC_ESM: 50,0
    +CEREG: 5,"C936","018D3017",7,,,"00000000","11100000"
    I: Network registration status: Connected - roaming
    I: C%XTIME: "40","52309210727240","00"
    onnected to Network
    I: Waiting for modem to acquire network time...
    I: Network time obtained %CCLK: "25/03/29,01:27:30+04",0
    OK
    I: Current UNIX time: 1743211650013
    I: Stored Time in NVS (UNIX)  1743178781995
    I: Difference in days: 0.38
    I: Not enough time has passed. No location sent.
    I: Current RSRP: -93 dBm
    I: Current RSRQ: -8 dB
    I: Current SNR (Signal to Noise ratio):  35 dB
    I: Current Network Band: 20
    I: Signal Strength: Fair
    I: Signal Quality: Excellent
    I: Initializing Iot Connect Init
    I: Start IoTConnect_Init
    I: Get URL address ...
    I: Resolved 52.179.195.5 (AF_INET)
    I: Connecting to discovery.iotconnect.io:443
    I:   .. OK
    I: This is json format
    I: Connecting to euagent.iotconnect.io
    I:   .. OK
    I: Device : 359746167113302 Status :
    I:   .. OK
    I: Sync_Response_Data Saved
    I: Init IoTConnect sdk SUCCESS
    I: IPv4 Address found 20.50.65.137
    I: MQTT_Init SUCCESS
    I: [mqtt_evt_handler:207] MQTT client connected!
    I: [mqtt_evt_handler:279] SUBACK packet id: 1234
    I: Sensor data is [{"uniqueId":"359746167113302","time":"2025-03-29T01:27:37.000Z","data":{"weightGrams":0,"voltageMillivolts":3958,"fillingLevelPercentage":0,"batteryPercentage
    ":78,"signalStrengthDbm":-93,"temperatureCelsius":21,"humidityPercentage":36,"cylinderCapacity":0,"cylinderChangedEvent":0,"latitude":0,"longitude":0,"uncertaintyMeters":0,"firm
    wareVersion":"3.2.8","hardwareVersion":"7.0"}}]
    I: Time Diff : 1743211657
    I: Publishing data...
    I: getAllTwins Publish
    I: [mqtt_evt_handler:270] PUBACK packet id: 1
    I: [mqtt_evt_handler:270] PUBACK packet id: 3
    I: [mqtt_evt_handler:230] MQTT PUBLISH result=0 len=112
    I: Twin_Update_Data Publish
    I: [mqtt_evt_handler:230] MQTT PUBLISH result=0 len=0
    I: :: sdk is Disconnected From IoTConnect ::
    I: [mqtt_evt_handler:214] MQTT client disconnected 0
    I: disconnection 0
    I: Powering off LTE modem...
    +CGEV: ME PDN DEACT 0
    +CEREG: 0
    I: Network disconnected..!
    +CGEV: ME DETACH
    +CSCON: 0
    I: RRC mode: idle
    I: LTE modem is powered off.
    I: Deinitializing LTE link controller...
    I: LTE link controller deinitialized
    I: new sleep time in seconds : 129 (-50 Elapsed Time in seconds)
    I: Alarm set for 129 seconds.
    W: Reset cause: 163
    W: RESET BY PIN
    I: data wra: 0, 418
    I: Filling Level: 0
    I: Voltage: 3958
    W: LTE Searching
    +CSCON: 1
    +CNEC_ESM: 50,0
    I: C%XTIME: "40","52309210039240","00"
    onnected to Network
    I: Network time obtained %CCLK: "25/03/29,01:30:32+04",0
    OK
    I: Current UNIX time: 1743211832013
    I: Current SNR (Signal to Noise ratio):  34 dB
    I:   .. OK
    I:   .. OK
    I:   .. OK
    I: Sensor data is [{"uniqueId":"359746167113302","time":"2025-03-29T01:30:40.000Z","data":{"weightGrams":0,"voltageMillivolts":3958,"fillingLevelPercentage":0,"batteryPercentage
    I: Time Diff : 1743211840
    I: [mqtt_evt_handler:214] MQTT client disconnected -128
    E: Cmmand send failed
    E: getAllTwins Publish Failed
    +CSCON: 0
    I: RRC mode: idle
    E: ERROR: mqtt_live -128
    I: disconnection -128
    +CSCON: 1
    +CEREG: 0
    +CGEV: ME DETACH
    +CSCON: 0
    I: RRC mode: idle
    W: LTE Searching
    +CSCON: 1
    +CNEC_ESM: 50,0
    I: C%XTIME: "40","52309210133240","00"
    onnected to Network
    I: Current RSRQ: -7 dB
    I:   .. OK
    I:   .. OK
    I:   .. OK
    I: Sensor data is
    W: Reset cause: 163
    W: RESET BY PIN
    I: data wra: 0, 418
    I: Filling Level: 0
    I: Voltage: 3957
    I:  Battery Percentage: 77%
    I: HS4013_ID : -1475241472  |  Temperature is : 22   |   Humidity is : 35
    W: LTE Searching
    +CSCON: 1
    +CNEC_ESM: 50,0
    I: C%XTIME: "40","52309210130540","00"
    onnected to Network
    I: Network time obtained %CCLK: "25/03/29,01:31:53+04",0
    OK
    I: Current UNIX time: 1743211913013
    I: Current RSRP: -91 dBm
    I: Current SNR (Signal to Noise ratio):  37 dB
    I:   .. OK
    I:   .. OK
    I:   .. OK
    E: MQTT connect failed 5
    I: [mqtt_evt_handler:214] MQTT client disconnected -111
    E: ERROR: mqtt_input -111
    E: Error : IoTConnect_Connect Fail
    +CSCON: 0
    I: RRC mode: idle
    E: MQTT Connection Failed
    I: Trying to reinit IotConnect MQTT Connection
    +CSCON: 1
    +CEREG: 0
    +CGEV: ME DETACH
    +CSCON: 0
    I: RRC mode: idle
    W: LTE Searching
    +CSCON: 1
    +CNEC_ESM: 50,0
    I: Co%XTIME: "40","52309210233440","00"
    nnected to Network
    I: Current RSRP: -90 dBm
    I:   .. OK
    I:   .. OK
    I:   .. OK
    I: Sensor data is [{"uniqueId":"359746167113302","time":"2025-03-29T01:32:51.000Z","data":{"weightGrams":0,"voltageMillivolts":3957,"fillingLevelPercentage":0,"batteryPercentage
    ":77,"signalStrengthDbm":-90,"temperatureCelsius":22,"humidityPercentage":35,"cylinderCapacity":0,"cylinderChangedEvent":0,"latitude":0,"longitude":0,"uncertaintyMeters":0,"firm
    I: Time Diff : 1743211971
    W: Reset cause: 163
    W: RESET BY PIN
    I: data wra: 0, 418
    I: Filling Level: 0
    I: Voltage: 3957
    W: LTE Searching
    +CSCON: 1
    +CNEC_ESM: 50,0
    I: Co%XTIME: "40","52309210337040","00"
    nnected to Network
    I: Network time obtained %CCLK: "25/03/29,01:33:10+04",0
    OK
    I: Current UNIX time: 1743211990012
    I:   .. OK
    I:   .. OK
    I:   .. OK
    I: Sensor data is [{"uniqueId":"359746167113302","time":"2025-03-29T01:33:17.000Z","data":{"weightGrams":0,"voltageMillivolts":3957,"fillingLevelPercentage":0,"batteryPercentage
    ":77,"signalStrengthDbm":-93,"temperatureCelsius":22,"humidityPercentage":35,"cylinderCapacity":0,"cylinderChangedEvent":0,"latitude":0,"longitude":0,"uncertaintyMeters":0,"firm
    I: Time Diff : 1743211997
    I: disconnection 0
    +CEREG: 0
    +CGEV: ME DETACH
    +CSCON: 0
    I: RRC mode: idle
    I: new sleep time in seconds : 133 (-46 Elapsed Time in seconds)
    I: Alarm set for 133 seconds.
    W: Reset cause: 163
    W: RESET BY PIN
    I: data wra: 0, 418
    I: Filling Level: 0
    I: Voltage: 3957
    W: LTE Searching
    +CSCON: 1
    +CNEC_ESM: 50,0
    I: C%XTIME: "40","52309210631140","00"
    onnected to Network
    I: Network time obtained %CCLK: "25/03/29,01:36:14+04",0
    OK
    I: Current UNIX time: 1743212174013
    I: Difference in days: 0.39
    E: connect() failed, err: 116  |  -1    FD   0
    E: Base_url is NULL
    E: Failed to Init IoTConnect sdk
    +CEREG: 0
    +CGEV: ME DETACH
    +CSCON: 0
    I: RRC mode: idle
    I: Retrying ----------
    W: LTE Searching
    +CSCON: 1
    +CNEC_ESM: 50,0
    I: Con%XTIME: "40","52309210636340","00"
    nected to Network
    I:   .. OK
    I:   .. OK
    I:   .. OK
    I: Sensor data is [{"uniqueId":"359746167113302","time":"2025-03-29T01:36:43.000Z","data":{"weightGrams":0,"voltageMillivolts":3957,"fillingLevelPercentage":0,"batteryPercentage
    ":77,"signalStrengthDbm":-93,"temperatureCelsius":21,"humidityPercentage":36,"cylinderCapacity":0,"cylinderChangedEvent":0,"latitude":0,"longitude":0,"uncertaintyMeters":0,"firm
    I: Time Diff : 1743212203
    I: disconnection 0
    +CEREG: 0
    +CGEV: ME DETACH
    +CSCON: 0
    I: RRC mode: idle
    I: new sleep time in seconds : 107 (-72 Elapsed Time in seconds)
    I: Alarm set for 107 seconds.
    W: Reset cause: 163
    W: RESET BY PIN
    I: data wra: 0, 418
    I: Filling Level: 0
    I: Voltage: 3958
    W: LTE Searching
    +CSCON: 1
    +CNEC_ESM: 50,0
    I: Co%XTIME: "40","52309210931140","00"
    nnected to Network
    I: Network time obtained %CCLK: "25/03/29,01:39:14+04",0
    OK
    I: Current UNIX time: 1743212354013
    I: Current SNR (Signal to Noise ratio):  36 dB
    I:   .. OK
    I:   .. OK
    I:   .. OK
    I: Sensor data is [{"uniqueId":"359746167113302","time":"2025-03-29T01:39:21.000Z","data":{"weightGrams":0,"voltageMillivolts":3958,"fillingLevelPercentage":0,"batteryPercentage
    ":78,"signalStrengthDbm":-91,"temperatureCelsius":21,"humidityPercentage":36,"cylinderCapacity":0,"cylinderChangedEvent":0,"latitude":0,"longitude":0,"uncertaintyMeters":0,"firm
    I: Time Diff : 1743212361
    I: disconnection 0
    +CEREG: 0
    +CGEV: ME DETACH
    +CSCON: 0
    I: RRC mode: idle
    W: Reset cause: 163
    W: RESET BY PIN
    I: data wra: 0, 418
    I: Filling Level: 0
    I: Voltage: 3958
    W: LTE Searching
    +CSCON: 1
    +CNEC_ESM: 50,0
    I: Connec%XTIME: "40","52309210241140","00"
    ted to Network
    I: Network time obtained %CCLK: "25/03/29,01:42:14+04",0
    OK
    I: Current UNIX time: 1743212534012
    I: Current SNR (Signal to Noise ratio):  33 dB
    I:   .. OK
    I:   .. OK
    I:   .. OK
    I: Sensor data is [{"uniqueId":"359746167113302","time":"2025-03-29T01:42:21.000Z","data":{"weightGrams":0,"voltageMillivolts":3958,"fillingLevelPercentage":0,"batteryPercentage
    I: Time Diff : 1743212541
    I: disconnection 0
    +CEREG: 0
    +CGEV: ME DETACH
    +CSCON: 0
    I: RRC mode: idle
    W: Reset cause: 163
    W: RESET BY PIN
    I: data wra: 0, 418
    I: Filling Level: 0
    I: Voltage: 3958
    E: Modem has crashed, reason 0x10, PC: 0x9a776
    I: Modem has crashed, re-initializing
    E: Failed to set functional mode. Please check XSYSTEMMODE.
  • Hi  ,
    This ticket is quite old. Please open new ticket and provide all relevant information (including logs) there. In addition, please provide modem trace for investigating the issue.
    Dejan
