Use Dongle as Client
Hi Nordic Team
I tried to get the USB Dongle PCA10049 to connect on a other device (PCA10056) over custom UUID and Custom characteristics.
I used the Example from Dev Zone Case ID 284737 as starting point.
With the serial app (Serial Bluetooth Terminal 1.40) i can connect and write on the server(PCA10056)
What i changed:
- Added the 2 vendor specific UUIDS 128bit.
- changed the Service and Characteristic UUID 0001 -> 0x498B and 0002 -> CFBB  corresponding to the UUIDS.
- changed debug level on debug 4 for more output.
What i need
Connecting to a 128bit UUID Service - done
Write/ Indicate(read) on one specific Characterisic with second 128bit UUID
Where i get stuck
the Example is searching, and connecting to the server device. but then prints primary service "UUID 498B found", then later on "not found".
When connected on the Serial Port of the dongle, i can see the Serial commands coming in, get in the queue and then sended on /cr command.
Log Print without Bootup
<debug> nrf_sdh_ble: BLE event: 0x1D.
<debug> ble_scan: Connecting
<debug> ble_scan: Connection status: 0
<debug> nrf_sdh_ble: BLE event: 0x10.
<debug> nrf_ble_gatt: Requesting to update ATT MTU to 247 bytes on connection 0x0.
<debug> nrf_ble_gatt: Updating data length to 251 on connection 0x0.
<info> app: Connecting to target F873CD9D33C7
<debug> nrf_ble_gq: Registering connection handle: 0x0000
<debug> ble_db_disc: Starting discovery of service with UUID 0x498B on connection handle 0x0.
<debug> nrf_ble_gq: Adding item to the request queue
<debug> nrf_ble_gq: GATTC Primary Services Discovery Request
<debug> nrf_ble_gq: SD is currently busy. The GATT request procedure will be attempted                       again later.
<debug> nrf_ble_gq: Processing the request queue...
<debug> nrf_ble_gq: GATTC Primary Service Discovery Request
<debug> nrf_sdh_ble: BLE event: 0x3A.
<debug> nrf_ble_gatt: ATT MTU updated to 69 bytes on connection 0x0 (response).
<info> app: ATT MTU exchange completed.
<info> app: Ble NUS max data length set to 0x42(66)
<debug> nrf_ble_gq: SD GATT procedure (2) succeeded on connection handle: 0.
<debug> nrf_sdh_ble: BLE event: 0x24.
<debug> nrf_ble_gatt: Data length updated to 73 on connection 0x0.
<debug> nrf_ble_gatt: max_rx_octets: 73
<debug> nrf_ble_gatt: max_tx_octets: 73
<debug> nrf_ble_gatt: max_rx_time: 2120
<debug> nrf_ble_gatt: max_tx_time: 2120
<debug> nrf_sdh_ble: BLE event: 0x30.
<debug> ble_db_disc: Service UUID 0x498B not found.
<debug> ble_db_disc: Starting discovery of service with UUID 0xCFBB on connection handle 0x0.
<debug> nrf_sdh_ble: BLE event: 0x1F.
<debug> ble_db_disc: Service UUID 0xCFBB not found.
<debug> nrf_sdh_ble: BLE event: 0x12.
<info> app: CDC ACM port opened
<info> app: CDC_ACM_USER_EVT_RX_DONE
<debug> app: RX: size: 1 char: 5
<debug> app: RX: size: 1 char: 0
<debug> app: RX: size: 1 char: 1
<debug> app: RX: size: 1 char: a
<debug> app: RX: size: 1 char: c
<debug> app: Ready to send data over BLE NUS
<debug> app:  35 30 31 31 61 63 0D   |5011ac.
<debug> nrf_ble_gq: GATTC Write Request
<debug> nrf_ble_gq: SD GATT procedure (1) succeeded on connection handle: 0.
<debug> app: RX: size: 1 char: <debug> nrf_sdh_ble: BLE event: 0x3C.
Kind Regards
Simon
  • Hi Simon
    I had sucess.
    I had to discover the Characteristic UUID as well right?-> Will be found and adressed automaticly by the discovery module
    Do i have to add the second UUID to the scan response telegram as well? Not needed Service UUID is sufficent.
    ble_nus_c.c
    uint32_t ble_nus_c_init(ble_nus_c_t * p_ble_nus_c, ble_nus_c_init_t * p_ble_nus_c_init)
        uint32_t      err_code;
        ble_uuid_t    uart_uuid;
        ble_uuid_t    char_uuid;
        ble_uuid128_t nus_base_uuid = NUS_BASE_UUID;//UUID for Service
        ble_uuid128_t second_char_uuid = CHAR_UUID; // UUID for Character
        VERIFY_PARAM_NOT_NULL(p_ble_nus_c);
        VERIFY_PARAM_NOT_NULL(p_ble_nus_c_init);
        VERIFY_PARAM_NOT_NULL(p_ble_nus_c_init->p_gatt_queue);
        err_code = sd_ble_uuid_vs_add(&nus_base_uuid, &p_ble_nus_c->uuid_type);
        VERIFY_SUCCESS(err_code);
        uart_uuid.type = p_ble_nus_c->uuid_type;
        uart_uuid.uuid = BLE_UUID_NUS_SERVICE;
        p_ble_nus_c->conn_handle           = BLE_CONN_HANDLE_INVALID;
        p_ble_nus_c->evt_handler           = p_ble_nus_c_init->evt_handler;
        p_ble_nus_c->error_handler         = p_ble_nus_c_init->error_handler;
        p_ble_nus_c->handles.nus_tx_handle = BLE_GATT_HANDLE_INVALID;
        p_ble_nus_c->handles.nus_rx_handle = BLE_GATT_HANDLE_INVALID;
        p_ble_nus_c->p_gatt_queue          = p_ble_nus_c_init->p_gatt_queue;
        uint8_t type;
        err_code = sd_ble_uuid_vs_add(&second_char_uuid, &type); // char UUID add
        char_uuid.type = type;
        char_uuid.uuid = BLE_UUID_NUS_RX_CHARACTERISTIC;
       // ble_db_discovery_evt_register(&char_uuid); // Do not add for dicovery only Services
        return ble_db_discovery_evt_register(&uart_uuid);
    Kind regards
    Simon
  • Hi
    We have a message sequence chart describing characteristic discovery on the GATT client here that should be helpful. You can see the characteristics_discover() function in our ble_db_discovery.c file for reference of how it's used in the discovery module.
    Simon
