Error "failed to connect to target"
Error: "Failed to connect to target" nRF52832
Hello
I have a problem. I was making a program for a counter. I managed to upload it to the card and communicate with PUTTY through COM3. Then I tried to load another program and it didn't work.
Currently it throws me this error. I tried changing the cable, turning off the device, trying to restart it but nothing worked. Also, it happened to me that I tried to do a reboot by holding down the RESET button to load the boot loader but it didn't work either.
I would greatly appreciate your help to recover the device
This is the program:
#include <stdbool.h>
#include <stdint.h>
#include "nrf.h"
#include "nordic_common.h"
#include "boards.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
* @brief Function for application main entry.
NRF_LOG_INFO("This is log data from nordic device..");
uint32_t count = 0; //creacion de un contador
while (true)
NRF_LOG_INFO("Counter Value: %d", count); //funcion similar al printf
nrf_delay_ms(500);
count++; //incrementa el valor del contador
  • As you can see in nRFutil you have the "log output" command. If you select file, you can upload the logs here.
    Joakim
  • Hello Joakim
    I try to use the following command nrfutil device --log-output=file but, nothing happened, I don't know if I misspelled the command.
    C:\>nrfutil device --log-output=file
    nrfutil-device
    USAGE:
        nrfutil device [OPTIONS] [SUBCOMMAND]
    OPTIONS:
        -h, --help                       Print help information
            --help-extended              Show comprehensive documentation
            --json                       Print output as JSON
            --json-pretty                Print output as formatted JSON
            --license                    Show license information for in-built dependencies
            --log-level <LOG_LEVEL>      Set the maximum log level [possible values: off, error, warn, info, debug, trace]
            --log-output <LOG_OUTPUT>    Set log output type: --log-output=stdout --log-output=file ... [possible values: file, stdout]
            --skip-overhead              Skip all message overhead when in JSON output mode, outputting only the data part of "info" messages and ignoring the rest
        -V, --version
    SUBCOMMANDS:
        core-info         Get core info on devices
        erase             Erase firmware on devices
        fw-info           Get firmware info from devices
        fw-verify         Verify firmware on devices
        help              Show comprehensive documentation
        list              List devices
        mcu-state-set     Set mcu state on devices
        program           Program devices
        protection-get    Get readback protection status from devices
        protection-set    Enable readback protection on devices
        recover           Erase all user available non-volatile memory and disable readback protection if enabled
        reset             Reset devices
    C:\>
  • I was try to use this command but it doesn't work again :)
  • That is the same command with the same arguments I typed and I get the same error message. See my post here:  RE: nRF52-DK "Failed to connect to target" and "Access protection is enabled, can't read device version"
    I am waiting for an answer from Nordic.
  • C:\>nrfutil device recover --log-level trace --log-output=stdout --serial-number 1050301640 --traits jlink
    error: The following required arguments were not provided:
        <--json|--json-pretty>
    USAGE:
        nrfutil device recover --log-level <LOG_LEVEL> --log-output <LOG_OUTPUT> <--serial-number <SERIAL_NUMBERS>|--traits <TRAITS>> <--json|--json-pretty>
    For more information try --help
    C:\>nrfutil device recover --log-level trace --log-output=stdout --serial-number 1050301640 --traits jlink --json
    {"type":"log","data":{"level":"INFO","message":"nrfutil-device (version = 1.0.1, platform = x86_64-pc-windows-msvc) invoked with recover --log-level trace --log-output=stdout --serial-number 1050301640 --traits jlink --json "}}
    {"type":"log","data":{"level":"DEBUG","message":"cargo = false, force_libnrfdl_lookup = false, force_nrfutil_libdir = false"}}
    {"type":"log","data":{"level":"DEBUG","message":"Creating the nrfdl context via nrfdl_create_context_with_config: Plugin location is assumed to be C:\\Users\\amolina\\.nrfutil\\lib\\nrfutil-device"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] No SEGGER instance provided"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][HighLevel][] dll_version"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG] [SeggerBackend] [Debug] Logger sink registered in Segger backend logger"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG] [JLink] [Debug] Logger sink registered in JLink logger"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG] [nRFXX] [Debug] open"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG] [nRFXX] [Debug] just_check_family"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG] [SeggerBackend] [Debug] open_dll"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG] [SeggerBackend] [Debug] No J-Link DLL path was provided. Attempting to auto detect."}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG] [SeggerBackend] [Info] Load library at C:\\Program Files\\SEGGER\\JLink\\JLink_x64.dll."}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG] [SeggerBackend] [Info] Library loaded, loading member functions."}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG] [SeggerBackend] [Info] Member functions succesfully loaded."}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG] [SeggerBackend] [Debug] dll_version"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG] [SeggerBackend] [Info] Segger dll version 7.84.d loaded."}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG] [nRFXX] [Debug] dll_version"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG] [SeggerBackend] [Debug] is_connected_to_emu"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG] [nRFXX] [Debug] close"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG] [SeggerBackend] [Debug] close"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG] [SeggerBackend] [Debug] disconnect_from_emu"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG] [SeggerBackend] [Debug] Segger Backend closed."}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG] [nRFXX] [Debug] nRF family DLL closed"}}
    {"type":"log","data":{"level":"WARN","message":"[JlinkARM] JlinkARM version non expected one found: JLink_V7.84d, expected: JLink_V7.66a"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Checking future_status of enumerate_task_status"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Waiting for enumerate task to complete"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate::enumerate_task: Start"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate::enumerate_task: Before async_lister->enumerate"}}
    {"type":"log","data":{"level":"DEBUG","message":"[->] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB"}}
    {"type":"log","data":{"level":"DEBUG","message":"Hub device path: \\\\?\\USB#ROOT_HUB30#4&19B1FD93&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {D4513256-A0C7-11ED-9603-AC675D2527E9}"}}
    {"type":"log","data":{"level":"DEBUG","message":"Starting DeviceIoControl"}}
    {"type":"log","data":{"level":"DEBUG","message":"Getting config descriptor"}}
    {"type":"log","data":{"level":"DEBUG","message":"Iterating descriptors."}}
    {"type":"log","data":{"level":"DEBUG","message":"[<-] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB [took 0ms]"}}
    {"type":"log","data":{"level":"DEBUG","message":"Hub device path: \\\\?\\USB#ROOT_HUB30#4&19B1FD93&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 6, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}"}}
    {"type":"log","data":{"level":"DEBUG","message":"Hub device path: \\\\?\\USB#ROOT_HUB30#4&19B1FD93&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 4, origin: {793477B5-A17C-11ED-9604-AC675D2527E9}"}}
    {"type":"log","data":{"level":"DEBUG","message":"[<-] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB [took 5ms]"}}
    {"type":"log","data":{"level":"DEBUG","message":"Hub device path: \\\\?\\USB#ROOT_HUB30#4&19B1FD93&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {560A81CE-20E9-5DB4-B7FF-92E21C3E4515}"}}
    {"type":"log","data":{"level":"DEBUG","message":"Hub device path: \\\\?\\USB#ROOT_HUB30#4&19B1FD93&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 10, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding device with serial number: {D4513256-A0C7-11ED-9603-AC675D2527E9}"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding device with serial number: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding device with serial number: 001050301640"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding device with serial number: {793477B5-A17C-11ED-9604-AC675D2527E9}"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate::enumerate_task: After async_lister->enumerate"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] JLinkPlugin::enumerate"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [->] NRFDL::UniversalPlatform::JLinkHW::enumerate"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] JLinkHW::enumerate all devices"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][HighLevel][] get_connected_probes"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][HighLevel][] probe_init"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][DebugProbe][] User set clock_speed == 0, setting default clock speed to default value 2000."}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][DebugProbe][] initialize"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][] open"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][] start"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][] Command open executed for 57 milliseconds with result 0"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][] connect_to_emu_with_snr"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] Logger sink registered in Segger backend logger"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][JLink][] Logger sink registered in JLink logger"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][] open"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][] just_check_family"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] open_dll"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] No J-Link DLL path was provided. Attempting to auto detect."}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] dll_version"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][] Command open executed for 8 milliseconds with result 0"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][] connect_to_emu_with_snr"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] is_connected_to_emu"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] connect_to_emu_with_snr"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] ---just_enum_emu_snr"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] ---just_get_num_emus"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] ---just_connect_to_emu_with_snr"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] ---just_connect_to_emu_without_snr"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] Segger logging enabled."}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] Firmware: J-Link OB-nRF5340-NordicSemi compiled Nov  7 2022 16:22:01"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] Hardware: V1.00"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] S/N: 1050301640"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] OEM: SEGGER"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] USB speed mode: Full speed (12 MBit/s)"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] TELNET listener socket opened on port 19021"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] WEBSRV WEBSRV_Init(): Starting webserver thread(s)"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] WEBSRV Webserver running on local port 19080"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][] Command connect_to_emu_with_snr executed for 76 milliseconds with result 0"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][] read_device_family"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 37.795ms returns \"O.K.\"  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_HasError()  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_Lock()  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_ExecCommand(\"SetRestartOnClose = 0\", ...).   "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.003ms returns 0x01  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_ExecCommand(\"DisableFlashDL\", ...).   "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.003ms returns 0x00  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_ExecCommand(\"ExcludeFlashCacheRange 0x0-0xFFFFFFFF\", ...).   "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_SetHookUnsecureDialog  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_SetHookUnsecureDialog(...)"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.012ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_TIF_Select(JLINKARM_TIF_SWD)  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.887ms returns 0x00  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_GetSpeedInfo()  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] 128000000 Hz / n, n >= 64"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.015ms  "}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] Connected emulator supports SWD speeds up to 2000kHz"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_SetSpeed(2000)  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.096ms  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_GetSpeed()  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.008ms returns 2000  "}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] SWD clock set to 2000kHz"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_GetSN()  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.010ms returns 1050301640  "}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] read_debug_port_idr"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] read_debug_port_register"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] ---just_read_debug_port_register"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] coresight_configure"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_GetHWStatus(...)  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.300ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_CORESIGHT_Configure()  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.470ms returns 0  "}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] ---just_select_debug_port_register"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] Select AP 255, DP Bank 0, AP Bank 255"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.323ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x00)  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] Value=0x2BA01477"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.287ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.006ms  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][] Command connect_to_emu_with_snr executed for 63 milliseconds with result 0"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][] read_device_family"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_IsOpen()  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.017ms returns 0x01  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][] Command read_device_family executed for 15 milliseconds with result 0"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][] select_family"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.294ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.369ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.014ms  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][] Command read_device_family executed for 0 milliseconds with result 0"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][] Command select_family executed for 15 milliseconds with result 0"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][DebugProbe][] readDeviceInfo"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][] read_device_info"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] set_core_data"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][] Command read_device_info executed for 14 milliseconds with result -90"}}
    {"type":"log","data":{"level":"ERROR","message":"[jlink] [NRFJPROG][DebugProbe][] Failed reading device info."}}
    {"type":"log","data":{"level":"WARN","message":"[jlink] [NRFJPROG][DebugProbe][] Warning: Could not read device info because the device is locked."}}
    {"type":"log","data":{"level":"WARN","message":"[jlink] [NRFJPROG][DebugProbe][] Warning: No actions other than recover will be available."}}
    {"type":"log","data":{"level":"WARN","message":"[jlink] [NRFJPROG][DebugProbe][] Warning: Try recovering the device if you want to unlock it."}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][HighLevel][] get_device_info"}}
    {"type":"log","data":{"level":"WARN","message":"[jlink] [NRFJPROG][DebugProbe][] Device info is blank. Attempting to reread."}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][] Command read_device_info executed for 15 milliseconds with result -90"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] Set core data:"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][]   Device ID: nRF52"}}
    {"type":"log","data":{"level":"ERROR","message":"[jlink] [NRFJPROG][HighLevel][] Failed to read device info from the device."}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] Got partial JLink device info because device has app protect enabled."}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][]   Expected core: 234881279"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][HighLevel][] get_probe_info"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][]   Existing Expected core: 4294967295"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][DebugProbe][] getProbeInfo"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][]   Coprocessor: APPLICATION"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][] enum_emu_com"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][]   AHB AP index: 0"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][]   Core base address: 4294967295"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] ---set_coresight_ahb_ap_index"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_ExecCommand(\"CORESIGHT_SetIndexAHBAPToUse = 0\", ...).   "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.005ms returns 0x00  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_ExecCommand(\"device = nRF52\", ...).   "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] Device \"NRF52\" selected."}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.968ms returns 0x00  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][] Command select_family executed for 1 milliseconds with result 0"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF52][] read_device_info"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.015ms returns 0x01  "}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF52][] Just_read_device_version"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF52][] Just_readback_status"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF52][] Just_is_ctrl_ap_available"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] read_access_port_register"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] ---just_read_access_port_register"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] ---just_is_debug_region_powered"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.224ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] Value=0xF0000000"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.203ms returns 0  "}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] ---just_select_access_port_register"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] Select AP 1, DP Bank 0, AP Bank 15"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.238ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] Value=0x02880000"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.209ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.197ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.220ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.225ms returns 0  "}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] Select AP 1, DP Bank 0, AP Bank 0"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.180ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] Value=0x00000000"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.217ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.265ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][] Command enum_emu_com, executed for 14 milliseconds with result 0"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][] read_connected_emu_fwstr"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.251ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][] Command read_connected_emu_fwstr executed for 14 milliseconds with result 0"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][HighLevel][] get_readback_protection"}}
    {"type":"log","data":{"level":"ERROR","message":"[jlink] [NRFJPROG][nRF52][] Access protection is enabled, can't read device version."}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][DebugProbe][] getReadbackProtectionStatus"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.007ms  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][] Command read_device_info executed for 2 milliseconds with result -90"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][] readback_status"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.014ms returns 0x01  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.218ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] Value=0xF0000040"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.198ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.204ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.205ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.202ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.207ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.219ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.233ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.253ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.258ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.359ms returns 0  "}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF52][] enum_emu_com"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.011ms returns 0x01  "}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] enum_emu_com"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][SeggerBackend][] Create serialport listener"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][SeggerBackend][] Enumerate ports"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] Evaluating com port."}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] Com port is a Segger device."}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] Com port serial number matches target serial number."}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] Found COM port:"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] \tPath   = COM3"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] \tPNP ID = USB\\VID_1366&PID_1051&MI_00\\6&1e663f31&0&0000"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] \tVCOM   = USB\\VID_1366&PID_1051&MI_00\\6&1e663f31&0&0000"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] \tSnr    = 001050301640"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] \tUSB ID = {560A81CE-20E9-5DB4-B7FF-92E21C3E4515}"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] \tVCOM_D = 0"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] \tPath   = COM4"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] \tPNP ID = USB\\VID_1366&PID_1051&MI_02\\6&1e663f31&0&0002"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] \tVCOM   = USB\\VID_1366&PID_1051&MI_02\\6&1e663f31&0&0002"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] \tVCOM_D = 1"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 2.311ms  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][] Command enum_emu_com, executed for 2 milliseconds with result 0"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF52][] read_connected_emu_fwstr"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] read_connected_emu_fwstr"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] ---just_connected_emu_fwstr"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_GetFirmwareString(...)  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.005ms  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][] Command read_connected_emu_fwstr executed for 0 milliseconds with result 0"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][] Command readback_status executed for 15 milliseconds with result 0"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][HighLevel][] probe_uninit"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][HighLevel][] internal_probe_uninit"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF52][] readback_status"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.013ms returns 0x01  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.226ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.187ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.179ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.297ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.343ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.291ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.332ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.234ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.320ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.402ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.335ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][] Command readback_status executed for 3 milliseconds with result 0"}}
    {"type":"task_begin","data":{"task":{"id":"836c898fd913478da93779263bc3ec7a","description":"Recover 1050301640","name":"recover"}}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF52][] close"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] close"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] disconnect_from_emu"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] ---just_disconnect_from_emu"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] is_connected_to_device"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.262ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.282ms returns 0  "}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] unpower_debug_and_system_regions"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] ---just_write_debug_port_register"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x01, 0x00000000)  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.237ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] Value=0x00000040"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.281ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_Close()  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][] Command close executed for 59 milliseconds with result 0"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][] terminate"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][] Command terminate executed for 0 milliseconds with result 0"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] Segger Backend closed."}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF52][] nRF family DLL closed"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][] Command close executed for 57 milliseconds with result 0"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][] Command terminate executed for 0 milliseconds with result 0"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][] Executed 11 commands for 138 milliseconds"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][] Worker process exited with code: 0"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][] Child process terminated with result 0"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][] Executed 11 commands for 294 milliseconds"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][DebugProbe][] uninitialize"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [<-] NRFDL::UniversalPlatform::JLinkHW::enumerate [took 1102ms]"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serialport enumerate update device: 001050301640"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Found device with serial number: {D4513256-A0C7-11ED-9603-AC675D2527E9}"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Found device with serial number: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Found device with serial number: 001050301640"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: device registered to device list"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Found device with serial number: {793477B5-A17C-11ED-9604-AC675D2527E9}"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Completed waiting for enumerate task"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: done"}}
    {"type":"log","data":{"level":"INFO","message":"Loaded plugin C:\\Users\\amolina\\.nrfutil\\lib\\nrfutil-device\\nrfdl-jlink-plugin.nrfdl, starting to resolve symbols"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] Log message from highlevel dll has level info, is supposed to be a progress document, but a progress callback is not provided. See comment in C:\\agents\\2.211.1\\vcpkg\\buildtrees\\nrf-device-lib\\src\\0.12.8-1-2cd3acb624.clean\\src\\jlink\\jlink_plugin.cpp about broken highleveldll API design."}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][] Command open executed for 67 milliseconds with result 0"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][] Command open executed for 9 milliseconds with result 0"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][] Command connect_to_emu_with_snr executed for 62 milliseconds with result 0"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 29.547ms returns \"O.K.\"  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.002ms returns 0x01  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.011ms returns 0x00  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.013ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.841ms returns 0x00  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.011ms  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.142ms  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.006ms returns 2000  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.005ms returns 1050301640  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.240ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.459ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.435ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.310ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][] Command connect_to_emu_with_snr executed for 54 milliseconds with result 0"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.010ms returns 0x01  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.275ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.374ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.034ms  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.006ms returns 0x00  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 1.190ms returns 0x00  "}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][HighLevel][] recover"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][DebugProbe][] recover"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][] recover"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.269ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.243ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.190ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.223ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.227ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.228ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.283ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.195ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.008ms  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][] Command read_device_info executed for 3 milliseconds with result -90"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF52][] recover"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.009ms returns 0x01  "}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF52][] Just_recover"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.372ms returns 0  "}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] write_access_port_register"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][] ---just_write_access_port_register"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000001)  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] Value=0x00000001"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.594ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.635ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.502ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.568ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.705ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.563ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.520ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.489ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.432ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.463ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.584ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.606ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.634ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.539ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.501ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.350ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.824ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.588ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.551ms returns 0  "}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF52][] Just_debug_reset"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.547ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.662ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.582ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.560ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.613ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.464ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000001)  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.507ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000000)  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.538ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000000)  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.480ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.552ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.504ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.493ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.607ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.628ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.443ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.794ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.572ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.721ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.391ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.602ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.603ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.389ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.741ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.511ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.422ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.687ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.556ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.858ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.678ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.537ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.586ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.639ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.605ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.609ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.393ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.702ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.771ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.409ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.381ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.445ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.406ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.448ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.336ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.364ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.452ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.304ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.308ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.368ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.352ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.289ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.331ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.367ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.271ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.382ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.259ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.525ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.743ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.693ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.499ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.585ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.933ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.513ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.412ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.633ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.707ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.654ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.418ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.730ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.799ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.725ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.611ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.782ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.473ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.620ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.533ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.558ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.622ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.561ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.659ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.587ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.608ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.590ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.583ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][] Command recover executed for 30185 milliseconds with result -21"}}
    {"type":"log","data":{"level":"ERROR","message":"[jlink] [NRFJPROG][DebugProbe][] Failed while performing recovery."}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.478ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.571ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.476ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.581ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.375ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.426ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.481ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.362ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.553ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.460ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.491ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.040ms  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][] Command recover executed for 30177 milliseconds with result -21"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.029ms returns 0x01  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.338ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.424ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.442ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.021ms  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][] Command close executed for 45 milliseconds with result 0"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][] Command close executed for 45 milliseconds with result 0"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][] Executed 8 commands for 30289 milliseconds"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][] Executed 8 commands for 30404 milliseconds"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] Unable to recover at retry (this is not necessarily an error): 0, exception message: RECOVER_FAILED"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][] Command open executed for 60 milliseconds with result 0"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][] Command connect_to_emu_with_snr executed for 63 milliseconds with result 0"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 30.558ms returns \"O.K.\"  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.637ms returns 0x00  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.095ms  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.005ms returns 2000  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.004ms returns 1050301640  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.182ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.019ms  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][] Command connect_to_emu_with_snr executed for 55 milliseconds with result 0"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.249ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.345ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.013ms  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 1.365ms returns 0x00  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.260ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.363ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.339ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.236ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.264ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.278ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.215ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.231ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.313ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.012ms returns 0x01  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.199ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.206ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.257ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.178ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.807ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.579ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.680ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.589ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.653ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.530ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.675ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.758ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.648ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.637ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.748ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.496ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.555ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.640ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.510ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.544ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.853ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.667ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.559ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.614ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.591ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.713ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.562ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.415ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.436ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.742ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.400ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.458ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.379ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.497ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.358ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.623ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.500ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.619ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.488ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.649ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.532ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.669ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.564ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.384ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.468ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.446ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.593ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.531ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.512ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.577ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.548ms returns 0  "}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] No SEGGER instance provided"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.604ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.477ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.524ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.616ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.487ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.437ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.946ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.518ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.317ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.397ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.392ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.766ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.612ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.597ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.895ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.671ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.632ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.661ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.416ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.625ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.598ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.657ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.535ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.596ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.549ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.545ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.798ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.550ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.542ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.600ms returns 0  "}}
    {"type":"log","data":{"level":"DEBUG","message":"Task 94460892594 is already completed"}}
    {"type":"task_end","data":{"task":{"id":"836c898fd913478da93779263bc3ec7a","description":"Recover 1050301640","name":"recover"},"message":"Failed to recover 1050301640, [jlink] RECOVER_FAILED","result":"fail"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.541ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.494ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.428ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.469ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.466ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.467ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.515ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.534ms returns 0  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.114ms  "}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][] Command recover executed for 30178 milliseconds with result -21"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][] Command recover executed for 30182 milliseconds with result -21"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][] - 0.021ms returns 0x01  "}}
    Error: One or more recover tasks failed
    C:\>
    The other commands didn't work for me, but I ran this one and it returned the information from the logs
    C:\>nrfutil device recover --log-level trace --log-output=stdout --serial-number 1050301640 --traits jlink --json
