LTE connected but cannot able nto connect AWS.
we are using nrf9160 custom board. Modem connected to LTE network but it is not connected to AWS cloud service. It's giving the -111 error, means connection refused. But with same esim card connected to AWS modem version of 1.2.3.
  • Hi charlie,
    i have upgraded the modem firmware but still issue was not resolved its not connecting to AWS in our custom board.
    And my nrf9160 development kit MFW is 1.3.2 Our aws_iot code is working in my development kit and i have another nrf9169 custom board with MFW is 1.3.2 in this also aws_iot code is working
    As previous reply i said our aws_iot code is working in development kit and another custom board too
    but not working in our new custom board
    thank you
  • Hi Jagadish,
    1) Did you require HW require for your new custom board? what is the link to this case?
    2) Can you share the modem trace recording?
    Charlie
  • Hello charlie,
    we have updated Modem firmware 1.3.2 to 1.3.4 and SDK version  is 2.2.0
    Please find the below log for your reference aws_iot in  nrf9160  example giving this below logs. I have  tested same code in nrf9160dk board its working fine.
    when i run same code in our nrf9160 custom board its not working and below is the log
    *** Booting Zephyr OS build v3.2.99-ncs1 ***
    The AWS IoT sample started, version: v1.0.0
    LTE cell changed: Cell ID: 26892034, Tracking area: 1500
    RRC mode: Connected
    RRC mode: Idle
    LTE cell changed: Cell ID: -1, Tracking area: -1
    LTE cell changed: Cell ID: 2840579, Tracking area: 49200
    RRC mode: Connected
    Network registration status: Connected - roaming
    PSM parameter update: TAU: 3240, Active time: -1
    Date time obtained
    Next connection retry in 30 seconds
    AWS_IOT_EVT_CONNECTING
    RRC mode: Idle
    RRC mode: Connected
    W: sntp_query, error: -116
    E: mqtt_connect, error: -111
    Awaiting for your response
    Thank you
  • Hi Jagadish,
    Can you provide the information I requested in the former reply?
    The two error codes show the connection may be bad and not stable. Have you checked the signal quality through %CESQ notification?
    #define ECONNREFUSED 111 /* Connection refused */
    #define ETIMEDOUT 116 /* Connection timed out */
    Charlie
