we are using nrf9160 custom board. Modem connected to LTE network but it is not connected to AWS cloud service. It's giving the -111 error, means connection refused. But with same esim card connected to AWS modem version of 1.2.3.
waiting for your reply.
Hi Jagadish,
Did you try to follow the advice in https://devzone.nordicsemi.com/support-private/support/302149#permalink=832315? Is there anything not clear?
Except for this issue, I have one more advice. I remember you did not get your HW reviewed by us before reporting this issue. This is not common if you have talked with our local sales and FAE team, keep in mind you could get advice and support alongside your project from our local team.
Anyway, please try to clarify your needs, and we will try our best to help you figure out the issue.
Charlie
Just to make sure, let's rule out these causes of errors:
You write that the connection works with a DK but does not with your custom board
Hi Markus Tacker,
do you use the same SIM card in both boards
1. Yes we used same ESIM in both custom board and developement kit board. It's working fine in developement kit but it's not working in custom board.
does the problem happen with all your custom boards (how many have you tried)?
2.we have 4 custom board in all 4 we are facing same issue.
Do you use the same firmware on the DK and the custom board?
3. Yes same firmware code used in boath custom and development board.
Hi charlie,
Please find the modem tracings.
I'm expecting to clear out soon. Since nearly one month onwards I'm trying to clear out. Any how Please tell me now how to take tracings from custom board. We are connected JTAG, by using this how can we get the tracings.
We got the hardware review from your team. They said to follow you. Hardware no issue.
Yesterday I was noted, the signal strength.
AT COMMAND is AT+CESQ and response is +CESQ: 44,2,15,2.
Please tell me in this four parameters what is best value each, to connection establish with AWS.
Jagadish
