DFU Mesh serial not working
I'm trying to use mesh_bootloader_serial_gccarmemb_nrf52832_xxAA.hex with my custom app based on light switch example.
I'm working with nrf_mesh_sdk 5.0. nRF52832 and devkit.
I'm programming with :
nrfjprog --eraseall
mergehex --merge "nrf5_SDK_for_Mesh_v5/bin/softdevice/s132_nrf52_7.2.0_softdevice.hex" "nrf5_SDK_for_Mesh_v5/mesh/bootloader/build/mesh_bootloader_serial_gccarmemb_nrf52832_xxAA_Debug/mesh_bootloader_serial_gccarmemb_nrf52832_xxAA.hex" --output "SD_BL.hex"
mergehex --merge "SD_BL.hex" "myapp_nrf52832_xxAA_s132_7.2.0.hex" --output "SD_BL_APP.hex"
nrfjprog --program "SD_BL_APP.hex" --family NRF52 --chiperase
nrfjprog --reset
My app is working but the bootloader is not started.
I tried and read all your documentations. The application starts but the bootloader does not. The start address for the application flash is 0x26000 and the bootloader starts at 0x78000.
I don't have any programming errors except when I try to program the setting.hex that I generate with nrfutil settings generate.
Why is my bootloader never called? I put logs and a delay without success.
Thank you
  • Yes I tried the dfu_no_serial and dfu_serial example from your folder and it works. But when I copy paste the code I embed in light_switch it doesn't work. My goal is to integrate the DFU background mesh code into the light_switch code.
    Besides, the bootloader_verify.py script does not return a positive return.
    Is something stuck?
    nrfjprog --eraseall
    python bootloader_verify.py <myserialnumber> <myserialport>
    nrfjprog --program "device_page_nrf52832_xxAA_s132_7.2.0.hex"
    nrfjprog --program "nrf5_SDK_for_Mesh_v5/bin/softdevice/s132_nrf52_7.2.0_softdevice.hex"
    nrfjprog --program "nrf5_SDK_for_Mesh_v5/mesh/bootloader/build/mesh_bootloader_serial_gccarmemb_nrf52832_xxAA_Debug/mesh_bootloader_serial_gccarmemb_nrf52832_xxAA.hex"
    nrfjprog --program "light_switch_server_nrf52832_xxAA_s132_7.2.0_Debug/light_switch_server_nrf52832_xxAA_s132_7.2.0.hex"
    nrfjprog --reset
    I copied and pasted the DFU functions from the dfu_serial code into the light_switch code.
    The application works but the DFU does not start. And the bootloader obviously does not work
    Thank you in advance !
  • Hi Nabil,
    Please clarify that by using dfu_serial  you have managed to update the mesh node and other nodes in the network.
    How did you modify the light_switch example ? Have you included all the functions called in mesh_evt_handler() ? If you plan to receive the update via serial , in the preprocessor symbol you need to define NRF_MESH_SERIAL_ENABLE. You will also need to include serial library nrf_mesh_serial.c  . Please refer to the dfu example.
    When you say it doesn't work, what exactly didn't work ? Which error you receive ?
  • Thank you,
    I don't need the serial connexion. In my case I have a mesh network and I want to do a DFU update via wireless connectivity. I say it doesn't work because my devkit connected to my pc is receiving dfu packets and segments fine but the remote devkit are not moving.
    If I don't use the serial what are the steps to integrate correctly in light switch? To be sure everything is done correctly
    in my case the "mesh_evt_handler" function is added in light_switch but something doesn't works
    Thanks for your help !
    In the code I have on the remote DEVKIT I have an error while initializing DFU commands. So that is exactly why I ask you my question. The way I program doesn't work for the bootloader. The app is ok but the bootloader is not. How can I program both app and booloader : light_switch example and nrf5_SDK_for_Mesh_v5/mesh/bootloader/build/mesh_bootloader_serial_gccarmemb_nrf52832_xxAA_Debug/
    I got this error :
    if (BOOTLOADERADDR() == 0xFFFFFFFF)
            /* No bootloader present. */
             __LOG(LOG_SRC_DFU, LOG_LEVEL_ERROR, "dfu_cmd_handler_set : NRF_ERROR_NOT_SUPPORTED!\n");
            return NRF_ERROR_NOT_SUPPORTED;
    Thank you for your help
  • Hi Nabil,
    Before moving any further, please clarify if you have managed to do a DFU with the dfu_no_serial and dfu_serial example ?
    Please use one board with serial that receive the image, and one board with dfu_no_serial and then confirm that the dfu_no_serial get updated to a new firmware.
    When you program the hex files, please use the command one by one , don't use the script. And check the result of nrfjprog. please copy the full log here.
