TLS Socket connection request return with error number -22(EINVAL)
Hi All,
I am trying to setup a thread network to send  RPC message to a remote http server:https://mainnet.incubed.net). I took http_client sample(sdk-zephyr) and modified slightly to adapt to my application. .
I was successful in sending RPC message to the server via TCP socket connection but I am really struggling to open secure channel(TLS) for communicating with the server. When my application tries to connect using TLS socket it throws an error with error number -22(EINVAL). I am not quite sure why and what mistake I did with respect to config options.
[00:00:58.561,645] <dbg> http_client: in3_register_https_client: in3 register https
[00:00:58.594,177] <dbg> http_client: setup_socket: Server address: fd97:6739:93e:2:0:0:A756:5EF8
[00:00:58.594,360] <dbg> net_sock_tls: tls_alloc: (main): Allocated TLS context, 0x20003478
[00:00:58.594,665] <dbg> net_tcp: tcp_conn_ref: (main): conn: 0x2002d320, ref_count: 1
[00:00:58.594,696] <dbg> net_tcp: tcp_conn_alloc: (main): conn: 0x2002d320
[00:00:58.594,757] <dbg> net_sock: zsock_socket_internal: (main): socket: ctx=0x2001031c, fd=1
[00:00:58.594,940] <dbg> net_ctx: net_context_bind: (main): Context 0x2001031c binding to TCP [::]:41215 iface 1 (0x20000a98)
[00:00:58.595,031] <dbg> net_tcp: net_tcp_connect: (main): context: 0x2001031c, local: ::, remote: fd97:6739:93e:2::a756:5ef8
[00:00:58.595,214] <dbg> net_tcp: net_tcp_connect: (main): conn: 0x2002d320 src: fd97:6739:93e:1:649e:fad5:e7ab:366d, dst: fd97:6739:93e:2::a756:5ef8
[00:00:58.595,336] <dbg> net_conn: conn_register_debug: (main): [0x200107b8/6/2/0x3f] remote fd97:6739:93e:2::a756:5ef8/443
[00:00:58.595,397] <dbg> net_conn: conn_register_debug: (main):   local ::/41215 cb 0x16fc9 ud 0x2001031c
[00:00:58.595,520] <dbg> net_tcp: tcp_in: (main):  [LISTEN Seq=548241854 Ack=0]
[00:00:58.595,764] <dbg> net_tcp: tcp_out_ext: (main): SYN Seq=548241854 Len=0
[00:00:58.595,947] <dbg> net_tcp: tcp_send_process_no_lock: (main): SYN Seq=548241854 Len=0
[00:00:58.596,160] <dbg> net_tcp: tcp_send: (main): SYN Seq=548241854 Len=0
[00:00:58.596,862] <dbg> net_tcp: tcp_in: (main): LISTEN->SYN_SENT
[00:00:58.648,925] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002c6d0 src port 443 dst port 41215 family 2
[00:00:58.648,956] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x200107b8] match found cb 0x16fc9 ud 0x2001031c rank 0x3f
[00:00:58.649,261] <dbg> net_tcp: tcp_in: (rx_q[0]): SYN,ACK Seq=3167820546 Ack=548241855 Len=0 [SYN_SENT Seq=548241855 Ack=0]
[00:00:58.649,322] <dbg> net_tcp: tcp_options_check: (rx_q[0]): len=4
[00:00:58.649,353] <dbg> net_tcp: tcp_options_check: (rx_q[0]): opt: 2, opt_len: 4
[00:00:58.649,353] <dbg> net_tcp: tcp_options_check: (rx_q[0]): MSS=1460
[00:00:58.649,383] <dbg> net_tcp: tcp_in: (rx_q[0]): Lowering send window from 64240 to 3413
[00:00:58.649,414] <dbg> net_tcp: tcp_window_full: (rx_q[0]): conn: 0x2002d320 window_full=0
[00:00:58.649,597] <dbg> net_tcp: tcp_send_timer_cancel: (rx_q[0]): SYN Seq=548241854 Len=0
[00:00:58.649,902] <dbg> net_tcp: tcp_out_ext: (rx_q[0]): ACK Seq=548241855 Ack=3167820547 Len=0
[00:00:58.650,085] <dbg> net_tcp: tcp_send_process_no_lock: (rx_q[0]): ACK Seq=548241855 Ack=3167820547 Len=0
[00:00:58.650,268] <dbg> net_tcp: tcp_send: (rx_q[0]): ACK Seq=548241855 Ack=3167820547 Len=0
[00:00:58.650,390] <dbg> net_tcp: tcp_in: (rx_q[0]): SYN_SENT->ESTABLISHED
[00:00:58.650,604] <dbg> net_tcp: net_tcp_connect: (main): conn: 0x2002d320, ret=0
[00:00:58.650,665] <dbg> net_tcp: net_tcp_recv: (main): context: 0x2001031c, cb: 0x8ce1, user_data: (nil)
[00:00:58.662,567] <err> http_client: Cannot connect to IPv6 remote (-22)
[00:00:58.662,597] <err> http_client: Failed to connect to socket
[00:00:58.662,597] <dbg> http_client: run_https_post: starting tcp failed
[00:00:58.718,750] <dbg> main: main: Error sending rpc request: The request could not be send!
[00:01:06.033,477] <inf> net_l2_openthread: State changed! Flags: 0x00000064 Current role: router
#Socket settings
CONFIG_NET_SOCKETS_SOCKOPT_TLS=n
CONFIG_POSIX_MAX_FDS=8
CONFIG_NET_SOCKETS_TLS_MAX_CONTEXTS=10
#MBEDTLS and security configuration
CONFIG_MBEDTLS_CFG_FILE="config-tls-generic.h"
CONFIG_OPENTHREAD_MBEDTLS_CHOICE=y
#CONFIG_MBEDTLS_TLS_VERSION_1_2=y
#CONFIG_MBEDTLS_TLS_LIBRARY=y
#CONFIG_MBEDTLS_SSL_PROTO_TLS1_2=y
# TLS configuration
CONFIG_MBEDTLS=y
CONFIG_MBEDTLS_BUILTIN=y
CONFIG_MBEDTLS_ENABLE_HEAP=y
CONFIG_MBEDTLS_HEAP_SIZE=32768
CONFIG_MBEDTLS_X509_LIBRARY=y
CONFIG_MBEDTLS_PEM_CERTIFICATE_FORMAT=y
# certificate must fit into one message, fragmenting is not supported
CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=4096
Can someone tell me what should I try to resolve this problem.
Regards
Vipin Das
  • Hi Jørgen,
    Any comments on my last question.
    Regards
    Vipin Das
    Sorry for the slow response. I see that you marked the previous answer as verified answer, does this mean that you managed to resolve the issue? If so, can you post the solution for other users looking for the same thing?
    Jørgen
    The TLS handshake issue with error code -7780 got fixed after changing the PEM(cert) with PEM(chain) certificate and also enabled some MBEDTLS security config options.
    CONFIG_MBEDTLS_KEY_EXCHANGE_RSA_ENABLED=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_RSA_ENABLED=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA_ENABLED=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_RSA_ENABLED=y
    CONFIG_MBEDTLS_MAC_SHA256_ENABLED=y
    CONFIG_MBEDTLS_HASH_SHA256_ENABLED=y
    CONFIG_MBEDTLS_CIPHER_AES_ENABLED=y
    CONFIG_MBEDTLS_CIPHER_GCM_ENABLED=y
    CONFIG_MBEDTLS_CIPHER_MODE_CBC=y
    CONFIG_MBEDTLS_CIPHER_MODE_CBC_ENABLED=y
    But again I am back to my previous error state. By the way did you find any problem with my code snippet I shared? If you can comment on that I could find some clue on the issue.
    [00:01:07.141,326] <dbg> net_sock: zsock_socket_internal: (main): socket: ctx=0x20010ae0, fd=1
    [00:01:07.141,326] <dbg> http_client: establish_connection_ipv6: TLS Socket fd: 0
    [00:01:07.141,510] <dbg> net_ctx: net_context_bind: (main): Context 0x20010ae0 binding to TCP [::]:33530 iface 1 (0x20000ac0)
    [00:01:07.141,601] <dbg> net_tcp: net_tcp_connect: (main): context: 0x20010ae0, local: ::, remote: fd97:6739:93e:2::808:808
    [00:01:07.141,784] <dbg> net_tcp: net_tcp_connect: (main): conn: 0x2002fe28 src: fd97:6739:93e:1:4ea8:498f:5004:da95, dst: fd97:6739:93e:2::808:808
    [00:01:07.141,906] <dbg> net_conn: conn_register_debug: (main): [0x2001108c/6/2/0x3f] remote fd97:6739:93e:2::808:808/443
    [00:01:07.141,967] <dbg> net_conn: conn_register_debug: (main):   local ::/33530 cb 0x17e51 ud 0x20010ae0
    [00:01:07.142,089] <dbg> net_tcp: tcp_in: (main):  [LISTEN Seq=384814854 Ack=0]
    [00:01:07.142,364] <dbg> net_tcp: tcp_out_ext: (main): SYN Seq=384814854 Len=0
    [00:01:07.142,517] <dbg> net_tcp: tcp_send_process_no_lock: (main): SYN Seq=384814854 Len=0
    [00:01:07.142,730] <dbg> net_tcp: tcp_send: (main): SYN Seq=384814854 Len=0
    [00:01:07.143,096] <dbg> net_tcp: tcp_in: (main): LISTEN->SYN_SENT
    [00:01:07.190,002] <dbg> in3_ot: pingResponseCallback: Ping reply
    [00:01:07.190,032] <dbg> in3_ot: printIpv6Address: Mesh Local EID Address: fd97.6739.093e.0002.0000.0000.0808.0808
    [00:01:07.196,014] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002f1d8 src port 443 dst port 33530 family 2
    [00:01:07.196,044] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2001108c] match found cb 0x17e51 ud 0x20010ae0 rank 0x3f
    [00:01:07.196,380] <dbg> net_tcp: tcp_in: (rx_q[0]): SYN,ACK Seq=1435167008 Ack=384814855 Len=0 [SYN_SENT Seq=384814855 Ack=0]
    [00:01:07.196,441] <dbg> net_tcp: tcp_options_check: (rx_q[0]): len=4
    [00:01:07.196,441] <dbg> net_tcp: tcp_options_check: (rx_q[0]): opt: 2, opt_len: 4
    [00:01:07.196,472] <dbg> net_tcp: tcp_options_check: (rx_q[0]): MSS=1412
    [00:01:07.196,502] <dbg> net_tcp: tcp_in: (rx_q[0]): Lowering send window from 65535 to 1280
    [00:01:07.196,533] <dbg> net_tcp: tcp_window_full: (rx_q[0]): conn: 0x2002fe28 window_full=0
    [00:01:07.196,685] <dbg> net_tcp: tcp_send_timer_cancel: (rx_q[0]): SYN Seq=384814854 Len=0
    [00:01:07.196,990] <dbg> net_tcp: tcp_out_ext: (rx_q[0]): ACK Seq=384814855 Ack=1435167009 Len=0
    [00:01:07.197,204] <dbg> net_tcp: tcp_send_process_no_lock: (rx_q[0]): ACK Seq=384814855 Ack=1435167009 Len=0
    [00:01:07.197,387] <dbg> net_tcp: tcp_send: (rx_q[0]): ACK Seq=384814855 Ack=1435167009 Len=0
    [00:01:07.197,509] <dbg> net_tcp: tcp_in: (rx_q[0]): SYN_SENT->ESTABLISHED
    [00:01:07.197,723] <dbg> net_tcp: net_tcp_connect: (main): conn: 0x2002fe28, ret=0
    [00:01:07.197,784] <dbg> net_tcp: net_tcp_recv: (main): context: 0x20010ae0, cb: 0x8d45, user_data: (nil)
    [00:01:07.262,359] <err> http_client: Cannot connect to ipv6 remote (-22)
    [00:01:07.262,390] <err> http_client: Establishing socket connection failed
    [00:01:07.262,390] <err> http_client: Setup socket connection failed
    Thanks
    Vipin Das
    I can't see any obvious problem in your code. Can you have a look at the code in the https_client sample in the sdk-nrf repo, to see if this works for you? This is written for nRF9160, but it uses sockets like the example you already based on, so it should be similar modifications needed to make it work with OpenThread.
    Also, if you can retry setup of the Sniffer, that will probably help figure out what is failing. I recommend using the nRF52840 Dongle with the sniffer (or nRF52840 DK connected through the NRF_USB port). Make sure you program the sniffer firmware before opening Wireshark, and run the Python command as described in step 3 in the installation guide to make sure no errors are reported from Python, and that the interface is detected correctly.
    Jørgen
    Honestly speaking, I had tried both the implementation. The good thing is that both gives the same error.
    One interesting thing that I noticed now is when I try to open a socket as below throws error for setsockopt()
    *sock = socket(res->ai_family, res->ai_socktype, res->ai_protocol);
    [00:00:33.839,416] <dbg> net_sock: zsock_socket_internal: (main): socket: ctx=0x20010ae4, fd=0
    [00:00:33.839,447] <err> http_client: Failed to setup peer verification, err -109
    [00:00:33.839,477] <err> http_client: Establishing socket connection failed
    [00:00:33.839,477] <err> http_client: Setup socket connection failed
    [00:00:33.839,508] <dbg> net_sock: z_impl_zsock_close: (main): close: ctx=0x20010ae4, fd=0
    But when I use *sock = socket(res->ai_family, res->ai_socktype,IPPROTO_TLS_1_2), then I can see socket is opening but network connection fails with -22. Right now I am trying to connect to google.com.
    Could you please check that socket(res->ai_family(AF_INET6), res->ai_socktype(SOCK_STREAM), res->ai_socktype(IPPROTO_TLS_1_2)) works fine or should I have to handle differently.
    I will try again for sniffer as you mentioned. I am using nRF52840 dongle.
    Regards
    Vipin Das
