LE Audio timeout behaviour (0x08) interfacing with third party devices.
Hi, I'm currently developing a device that acts as an LE Audio client. Everything works as expected when interfacing with an LE Audio server counterpart on a 5340 Audio DK, also using the Zephyr BLE Audio API.
However I recently attempted to interface my client with a third party pair of LE Audio headphones, specifically the Earfun Air Pro 3s, and upon enabling the streams (bt_audio_stream_enable) the device receives no response callback and supposedly hits the supervisory timeout (disconnect reason 0x08.) At first I suspected this may be an issue with the headphones, and I haven't ruled out this possibility.
But then I decided to test the nrF5340 audio application (unmodified) with the Android LE Audio framework in the developer settings, which seems to work decently well with the Earfun Air Pro 3s. I found that the 5340 headset application was successfully receiving and playing back the stream for 4s, but then receives a timeout event and immediately stops playing.
There's a chance these are unrelated issues but seeing as they both involve supervision timeouts, there's the possibility something is not being handled correctly on the 5340? Can something about the LE Audio framework cause it to stop sending packets to the peer device? Has the audio application been tested with any third party devices?
I have tried changing the clock source with:
CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH=y
As I heard this has been related to other timeout issues, but that doesn't seem to be the cause here as it has no effect.
Log from headset:
HL [00:01:04.268,341] <inf> cis_headset: Connected: 0C:C4:13:2F:AD:44 (public)
HL [00:01:09.610,137] <inf> ble_audio_services: Volume = 10, mute state = 0
HL [00:08:10.497,955] <dbg> bt_audio_stream: bt_audio_stream_attach: conn 0x20002db8 stream 0x2000a728 ep 0x2000ba34 codec 0x2000ba44
HL [00:08:10.587,951] <dbg> bt_audio_stream: bt_audio_stream_iso_listen: stream 0x2000a728 conn 0x20002db8
HL [00:08:10.683,288] <wrn> audio_datapath: I2S RX continuing stream
HL [00:08:10.691,284] <wrn> audio_datapath: I2S RX overrun. Single msg
HL [00:08:10.704,315] <inf> audio_datapath: Drft comp state: INIT
HL [00:08:11.243,072] <dbg> bt_audio_stream: bt_audio_stream_iso_accept: acl 0x20002db8
HL [00:08:11.243,072] <dbg> bt_audio_stream: bt_audio_stream_iso_accept: iso_chan 0x2000bb20
HL [00:08:11.440,124] <inf> audio_datapath: Drft comp state: CALIB
HL [00:08:11.441,101] <wrn> audio_datapath: Data received, total underruns: 755
HL [00:08:11.492,218] <wrn> audio_datapath: Data received, total underruns: 756
HL [00:08:11.540,344] <inf> audio_datapath: Drft comp state: OFFSET
HL [00:08:12.021,820] <inf> audio_datapath: Drft comp state: LOCKED
HL [00:08:12.029,510] <inf> audio_datapath: Pres comp state: MEAS
HL [00:08:12.139,495] <inf> audio_datapath: Pres comp state: WAIT
HL [00:08:12.239,501] <inf> audio_datapath: Pres comp state: INIT
HL [00:08:12.249,511] <inf> audio_datapath: Pres comp state: MEAS
HL [00:08:12.359,497] <inf> audio_datapath: Pres comp state: LOCKED
HL [00:08:16.800,872] <inf> cis_headset: Stream stopped
HL [00:08:16.800,903] <dbg> bt_audio_stream: bt_audio_stream_iso_listen: stream 0x2000a728 conn 0x20002db8
HL [00:08:16.801,727] <inf> cis_headset: Disconnected: 0C:C4:13:2F:AD:44 (public) (reason 0x08)
HL [00:08:16.802,673] <inf> cis_headset: Direct advertising to 0C:C4:13:2F:AD:44 (public) started
