Hello everyone,
I am using a nRF52840 as a central device to scan and connect to peripherals using the whitelist. I have a peripheral that doesn't support pairing (it's a pulse oximeter), but since I am using the whitelist to scan and filter the other devices I am working with, I decided to manually add the address of this pulse oximeter to the whitelist. For the record, I have done this with another peripheral and checked that the procedure works.
Anyways, I add the peripheral address to the whitelist and print all the addresses stored in the whitelist to make sure I am scanning for the peripherals correctly.
This is where my problem happens: Even thought the address of the pulse oximeter shows up in the whitelist, when I turn on the device, it doesn't get connected to the central.
This is the code I am using to store the address in the whitelist. manually. It is not mine, I got it from another forum a long time ago but I lost the link .-.
static void onWhitelistRequest(void) {
ret_code_t err_code;
BondedDeviceInfo_t bonded_devices_info[ADDRESSES_IN_WHITELIST] = {0};
uint16_t bonded_devices_count = 0;
uint8_t i, j;
uint64_t aux_konsung_mac = 0;
uint64_t aux_berry_mac = 0;
ble_gap_addr_t konsung_mac = {0};
ble_gap_addr_t berry_mac = {0};
// Extract info from FLASH
getDevices(bonded_devices_info, &bonded_devices_count);
for(j = 0; j < bonded_devices_count; j++) {
if(strcmp(bonded_devices_info[j].tag, "pleth sonosat") == 0) {
aux_konsung_mac = bonded_devices_info[j].mac_address;
} else if (strcmp(bonded_devices_info[j].tag, "pleth bm1000") == 0) {
aux_berry_mac = bonded_devices_info[j].mac_address;
for (j = 0; j < 6; j++) {
konsung_mac.addr[j] = (aux_konsung_mac >> (j*8)) & 0xFF;
berry_mac.addr[j] = (aux_berry_mac >> (j*8)) & 0xFF;
konsung_mac.addr_type = BLE_UUID_TYPE_UNKNOWN;
berry_mac.addr_type = BLE_UUID_TYPE_UNKNOWN;
// Whitelist buffers.
ble_gap_addr_t whitelist_addrs[ADDRESSES_IN_WHITELIST];
ble_gap_irk_t whitelist_irks[ADDRESSES_IN_WHITELIST];
memset(whitelist_addrs, 0x00, sizeof(whitelist_addrs));
memset(whitelist_irks, 0x00, sizeof(whitelist_irks));
uint32_t addr_cnt = (sizeof(whitelist_addrs) / sizeof(ble_gap_addr_t));
uint32_t irk_cnt = (sizeof(whitelist_irks) / sizeof(ble_gap_irk_t));
// Reload the whitelist and whitelist all peers.
whitelistLoad();
// Get the whitelist previously set using pm_whitelist_set().
err_code =
pm_whitelist_get(whitelist_addrs, &addr_cnt, whitelist_irks, &irk_cnt);
/* Check if the pulse oximeter has been already detected, if so,
add to the whitelist if necessary. */
// add Konsung manually to whitelist
bool bPresent = false;
if (aux_konsung_mac) {
for(uint8_t i = 0; i < addr_cnt; i++) {
// Loop through all addresses in the whitelist table.
if(strcmp(whitelist_addrs[i].addr, konsung_mac.addr) == 0) {
// Address is present in whitelist.
PRINT_INFO("Konsung already in whitelist\n");
bPresent = true;
if(bPresent == false) {
whitelist_addrs[addr_cnt] = konsung_mac;
addr_cnt++;
ble_gap_addr_t const * p_addr[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
for (uint32_t i = 0; i < BLE_GAP_WHITELIST_ADDR_MAX_COUNT; i++)
p_addr[i] = &whitelist_addrs[i];
err_code = sd_ble_gap_whitelist_set(p_addr, addr_cnt);
// add Berry manually to whitelist **PROBLEM HERE**
bPresent = false;
if (aux_berry_mac) {
if(strcmp(whitelist_addrs[i].addr, berry_mac.addr) == 0) {
PRINT_INFO("Berry already in whitelist\n");
bPresent = true;
whitelist_addrs[addr_cnt] = berry_mac;
addr_cnt++;
PRINT_DEBUG("Address count: %d, IRK count: %d\n", addr_cnt, irk_cnt);
for (int i = 0; i < addr_cnt; i++) {
PRINT_DEBUG("Scanning for address: %02X %X %X %X %X %X \n", whitelist_addrs[i].addr[5],
whitelist_addrs[i].addr[4], whitelist_addrs[i].addr[3], whitelist_addrs[i].addr[2],
whitelist_addrs[i].addr[1], whitelist_addrs[i].addr[0]);
if (((addr_cnt == 0) && (irk_cnt == 0)) || (g_whitelist_disabled)) {
// Don't use whitelist.
err_code = nrf_ble_scan_params_set(&m_scan, NULL);
}NOTE: The strategy to manually add an address to the whitelist works for the Konsung peripheral (already tested in another firmware). However, it doesn't work for the Berry peripheral.
Thank you very much for your help,
PD: I am using SDK v17.1
