Cant build zephyr battery example
I was trying to build the zephyr battery example Battery Voltage Measurement — Zephyr Project Documentation (nordicsemi.com) . But when I was building the project, it raises an error like this:
note: in expansion of macro 'DEVICE_DT_GET'
78 | .adc = DEVICE_DT_GET(DT_IO_CHANNELS_CTLR(ZEPHYR_USER)),
What should I do? Or is there any way to read/calculate/measure the input voltage to a pin?
  • I' get back to work aproximately 8 hours later due to the night comes in. :D But I' ll delete the .dts and try again.
  • Okay thank you mike but my local time is 00:00. So I can reply to you aproximately 8.5 hours later. Standby...
  • No worries. I’m GMT+10, so I’ve got my whole day ahead of me :-)
    OK, so I grabbed the example code from ...v2.2.0/zephyr/samples/boards/nrf/battery and added the overlay file as described here.
    This is what my overlay file looks like:
        zephyr,user {
           io-channels = <&adc 4>;
    That all builds without errors if I use the nrf52dk_nrf52832 as my target (that's the DK I am using)
    However, if I try and build it for the nrf52840dk_nrf52840, then I see the same error you are getting.
    However, if I add the voltage divider version of the vbatt node to my overlay file instead, like this:
        vbatt {
            compatible = "voltage-divider";
            io-channels = <&adc 0>;
            output-ohms = <47000>;
            full-ohms = <(100000 + 47000)>;
            power-gpios = <&gpio0 30 (GPIO_PULL_DOWN | GPIO_ACTIVE_HIGH)>;
    Then I can get it to build without errors for the nrf52840dk_nrf52840.
    In my application, I'm actually using a voltage divider to step the voltage down (so, I'm measuring the battery voltage across a 47K resistor, which is in series with a 100K resistor, hence the values above for ouput-ohms and full-ohm), and I'm also enabling the battery voltage to the relevant GPIO using an arrangement of MOSFETs (means I can keep quiescent current down).  I'm using P0.30 as my enable signal, hence the value for power-gpios above where I am setting this to Pin 30.  The flags indicate that I need to set it high to activate it, and that its normally pulled low when I'm not driving that GPIO via firmware.
    I've attached the code here as a .zip file so you can see what I've done
    Hope that helps sort out your issue
    Cheers,
    Mike
    battery_nordic.zip
  • Thank you for your answer Mike. I changed my overlay file as you said. But the error occured again.(note: in expansion of macro 'DEVICE_DT_GET' undefined). Then, I downloaded the zip and tried to build again. But a cmake error occured(Configuration incomplete). I' ve attached to you my code as zip.
    Thanks in advance
    battery_BehicMV.zip
  • OK, your code builds OK for me - no errors.
    Try deleting your build folder within Windows Explorer (just delete the 'build" subfolder under your project directory), then doing a pristine build in VSC, via:
    View->Command Palette->nRF Connect:Pristine Build
    Let me know if that fixes things.
