ADXL362 registers writing
Hi
I am using ADXL362 moving sensor in my nrf5340 custom board. In a previous ticket I could achieve to read its registers by modifying the overlay file
according to my hardware design. Now  I want to know how can I write to its registers by SPI commands. For example I want to increase its g measurement
range from 1g to 8g. For your information I am using nRF connect for Desktop software for writing and programing my custom board.
Thank you in advance for your support.
Best Regards
Saeed Mahvis
  • Hi Naeem
    Below is my main code:
    * Copyright (c) 2018 Nordic Semiconductor ASA
    /** @file
    * @brief Nordic UART Bridge Service (NUS) sample
    #include <zephyr/types.h>
    #include <zephyr.h>
    #include <drivers/uart.h>
    #include <drivers/gpio.h>
    #include <device.h>
    #include <soc.h>
    #include <drivers/sensor.h>
    //#include <bluetooth/bluetooth.h>
    //#include <bluetooth/uuid.h>
    //#include <bluetooth/gatt.h>
    //#include <bluetooth/hci.h>
    //#include <bluetooth/services/nus.h>
    #include <dk_buttons_and_leds.h>
    #include <settings/settings.h>
    #include <stdio.h>
    #include <logging/log.h>
    #include <stdlib.h>
    #include <kernel.h>
    #include <devicetree.h>
    #include <math.h>
    #include <string.h>
    #include <init.h>
    #include <sys/byteorder.h>
    #include <sys/__assert.h>
    #include <drivers/spi.h>
    // #include <pm/device.h>
    #define LOG_MODULE_NAME peripheral_uart
    LOG_MODULE_REGISTER(LOG_MODULE_NAME);
    #define STACKSIZE CONFIG_BT_NUS_THREAD_STACK_SIZE
    #define PRIORITY 7
    //#define DEVICE_NAME CONFIG_BT_DEVICE_NAME
    //#define DEVICE_NAME_LEN (sizeof(DEVICE_NAME) - 1)
    //#define RUN_STATUS_LED1 DK_LED1
    //#define RUN_STATUS_LED2 DK_LED2
    //#define RUN_STATUS_LED3 DK_LED3
    //#define RUN_STATUS_LED4 DK_LED4
    static uint8_t led1flg;
    #define led5 28 // pin number for led5
    #define rscon 12 // pin number for rscon
    #define pwkey 8 // pin number for pwkey of quictell
    #define gprson 7 // pin number for gprs power off command
    #define st0 15 // status0 pin of harvester
    #define st1 13 // status1 pin of harvester
    #define st2 23 // statue3 pin of harvester
    #define temp_cut 17 // pin number for temperature cut command
    #define rs0_connect_led DK_LED1
    #define UART_BUF_SIZE CONFIG_BT_NUS_UART_BUFFER_SIZE
    #define UART_WAIT_FOR_BUF_DELAY K_MSEC(50)
    #define UART_WAIT_FOR_RX CONFIG_BT_NUS_UART_RX_WAIT_TIME
    //#define baudrate38400 NRF_UARTE0->BAUDRATE = UARTE_BAUDRATE_BAUDRATE_Baud38400
    //#define baudrate9600 NRF_UARTE0->BAUDRATE = UARTE_BAUDRATE_BAUDRATE_Baud9600
    //#define baudrate115200 NRF_UARTE0->BAUDRATE = UARTE_BAUDRATE_BAUDRATE_Baud115200
    static const struct device *uart;
    uint8_t datarx[512];
    uint8_t rxupdate0 = 0;
    uint8_t rxdatalen0;
    static struct k_work_delayable uart_work;
    struct uart_data_t {
    void *fifo_reserved;
    uint8_t data[UART_BUF_SIZE];
    uint16_t len;
    // static K_FIFO_DEFINE(fifo_uart_tx_data);
    // static K_FIFO_DEFINE(fifo_uart_rx_data);
    static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
    int k;
    ARG_UNUSED(dev);
    // static uint8_t *current_buf;
    // static size_t aborted_len;
    bool buf_release;
    struct uart_data_t *buf;
    // static uint8_t *aborted_buf;
    switch (evt->type) {
    case UART_RX_RDY:
    buf = CONTAINER_OF(evt->data.rx.buf, struct uart_data_t, data);
    buf->len += evt->data.rx.len;
    buf_release = false;
    if (led1flg == 0) {
    led1flg = 1;
    dk_set_led_on(rs0_connect_led);
    } else {
    led1flg = 0;
    dk_set_led_off(rs0_connect_led);
    // dk_set_led_on(rs0_connect_led);
    rxdatalen0 = buf->len;
    for (k = 0; k < buf->len; k++) {
    datarx[k] = buf->data[k]; // buf->data[k];
    // k_fifo_put(&fifo_uart_rx_data, buf);
    buf->len = 0;
    buf_release = true;
    // uart_rx_disable(uart);
    uart_rx_enable(uart, buf->data, sizeof(buf->data), 10);
    rxupdate0 = 1;
    static void uart_work_handler(struct k_work *item)
    buf = k_malloc(sizeof(*buf));
    if (buf) {
    buf->len = 0;
    } else {
    LOG_WRN("Not able to allocate UART receive buffer");
    k_work_reschedule(&uart_work, UART_WAIT_FOR_BUF_DELAY);
    return;
    static int uart_init(void)
    uart_irq_rx_enable(uart);
    int err;
    struct uart_data_t *rx;
    uart = device_get_binding(DT_LABEL(DT_NODELABEL(uart0)));
    rx = k_malloc(256); // k_malloc(sizeof(*rx));
    if (rx) {
    rx->len = 0;
    } else {
    return -ENOMEM;
    k_work_init_delayable(&uart_work, uart_work_handler);
    err = uart_callback_set(uart, uart_cb, NULL);
    if (err) {
    return err;
    return uart_rx_enable(uart, rx->data, sizeof(rx->data), 10);
    static K_SEM_DEFINE(ble_init_ok, 0, 1); //
    static uint8_t adv_array[29] = { 0 };
    static struct bt_data ad[] = {
    BT_DATA(BT_DATA_MANUFACTURER_DATA, adv_array, sizeof(adv_array)),
    static uint8_t adv_array1[29];
    void bluetoothupdate(void)
    BT_DATA(BT_DATA_MANUFACTURER_DATA, adv_array1, sizeof(adv_array1)),
    bt_le_adv_update_data(ad, ARRAY_SIZE(ad), 0, 0); // sd, ARRAY_SIZE(sd));
    const struct uart_config uart_cfg115200 = { .baudrate = 115200,
    .parity = UART_CFG_PARITY_NONE,
    .stop_bits = UART_CFG_STOP_BITS_1,
    .data_bits = UART_CFG_DATA_BITS_8,
    .flow_ctrl = UART_CFG_FLOW_CTRL_NONE };
    uint8_t threeminute_flg = 1;
    uint8_t sch_Evt = 1;
    void schEvt_thread(void)
    while (1) {
    k_msleep(1000 * 60 * 60);
    sch_Evt = 1;
    K_THREAD_DEFINE(schEvt_id, 256, schEvt_thread, NULL, NULL, NULL, PRIORITY, 0, 0);
    void minute3_thread(void)
    // const struct device *port0 = device_get_binding("GPIO_0"); // get the device address of port0
    while (1) {
    // threeminute_flg = 1; //
    k_msleep(1000 * 60*1.5);
    threeminute_flg = 0;
    // gpio_pin_toggle(port0, led5);
    k_sleep(K_FOREVER);
    K_THREAD_DEFINE(threeminute_id, 256, minute3_thread, NULL, NULL, NULL, PRIORITY, 0, 0);
    void gprs_thread(void)
    //uint8_t data[100],qmtflg = 0,wh_end=0;
    uint64_t time_stamp;
    int64_t delta_time;
    char cmd_string[50];
    uart_init();
    uart_configure(uart, &uart_cfg115200);
    gpio_pin_set( port0,gprson,1);
    k_msleep(3000);
    while(strncmp("AT\r\r\nOK\r\n",datarx,9)){
    strcpy( cmd_string,"AT\r\n");
    uart_tx(uart,cmd_string,strlen(cmd_string), SYS_FOREVER_MS);
    k_msleep(300);
    strcpy( cmd_string,"AT+IPR=115200\r\n");
    k_msleep(1000);
    strcpy( cmd_string,"AT&W\r\n");
    k_msleep(10000);
    //gpio_pin_set( port0,gprson,0); //Quectell off
    //0x0D = \r = <CR>
    //0x0A = \n = <LF>
    //0x1A = <SUB>
    //gpio_pin_set(port0, led5,0);
    while (1) {
    NRF_UARTE0->ENABLE = 8; // uart enable
    k_msleep(100);
    NRF_UARTE0->TASKS_STARTTX = 1;
    k_msleep(100);
    NRF_UARTE0->TASKS_STARTRX = 1;
    k_msleep(100);
    gpio_pin_set(port0, gprson, 1); // Quectel on
    k_msleep(3000); // 3s delay
    time_stamp = k_uptime_get(); // time Stamp
    while((strncmp("AT\r\r\nOK\r\n",datarx,9)) && (threeminute_flg==1)&& ( k_uptime_delta(&time_stamp)<= 5000) ){ // for auto synic
    k_sleep(K_MSEC(300));
    ///////////////////////////////////AT+CPIN?
    while (threeminute_flg == 1 && ( strncmp("AT+CPIN?\r\r\n+CPIN: READY\r\n\r\nOK\r\n",datarx,31) !=0) ) { // Sim card check insert or not
    strcpy(cmd_string, "AT+CPIN?\r\n");
    uart_tx(uart, cmd_string, strlen(cmd_string), SYS_FOREVER_MS);
    k_msleep(300);
    if(k_uptime_delta(&time_stamp)>= 5000){threeminute_flg = 0;} // check for time out 5s then swich off quectel
    /////////////////////////////////AT+QIFGCNT=2
    while (threeminute_flg == 1 && ( strncmp("AT+QIFGCNT=2\r\r\nOK\r\n",datarx,19) !=0) ) { //
    strcpy(cmd_string, "AT+QIFGCNT=2\r\n");
    k_msleep(300);
    if((k_uptime_get() - time_stamp) >= 5000){threeminute_flg = 0;} // check for time out 5s then swich off quectel
    /////////////////////////////////'AT+QICSGP=1,"mtnirancell
    while (threeminute_flg == 1 && ( strncmp("AT+QICSGP=1,\"mtnirancell\"\r\r\nOK\r\n",datarx,32) !=0) ) { //
    strcpy(cmd_string,"AT+QICSGP=1,\"mtnirancell\"\r\n");
    k_msleep(200);
    /////////////////////////////////CGREG
    time_stamp = k_uptime_get(); // home register // Roaming
    while (threeminute_flg == 1 && ( strncmp("AT+CGREG?\r\r\n+CGREG: 0,1\r\n\r\nOK\r\n",datarx,31) !=0) && ( strncmp("AT+CGREG?\r\r\n+CGREG: 0,5\r\n\r\nOK\r\n",datarx,31) !=0) ) { //
    strcpy(cmd_string,"AT+CGREG?\r\n");
    k_msleep(1000);
    /////////////////////////////////CGDCONT
    while (threeminute_flg == 1 && ( strncmp("AT+CGDCONT=1,\"IP\",\"mtnirancell\",\"0.0.0.0\",0,0\r\r\nOK\r\n",datarx,52) !=0) ) { //
    strcpy(cmd_string,"AT+CGDCONT=1,\"IP\",\"mtnirancell\",\"0.0.0.0\",0,0\r\n");
    k_msleep(200);
    /////////////////////////////////AT+CGATT=1
    while (threeminute_flg == 1 && ( strncmp("AT+CGATT=1\r\r\nOK\r\n",datarx,17) !=0) ) { //
    strcpy(cmd_string,"AT+CGATT=1\r\n");
    k_msleep(200);
    /////////////////////////////////AT+CGATT?
    while (threeminute_flg == 1 && ( strncmp("AT+CGATT?\r\r\n+CGATT: 1\r\n\r\nOK\r\n",datarx,29) !=0) ) { //
    strcpy(cmd_string,"AT+CGATT?\r\n");
    k_msleep(200);
    /////////////////////////////////AT+CGACT
    do { //
    strcpy(cmd_string,"AT+CGACT=1,1\r\n");
    k_msleep(200);
    }while (threeminute_flg == 1 && ( strncmp("AT+CGACT=1,1",datarx,12) !=0) );
    //////////////////////////////////// AT+CGPADDR=1
    strcpy(cmd_string,"AT+CGPADDR=1\r\n");
    k_msleep(3000);
    ////////////////////////////////////// AT+CGDCONT?
    do { //
    strcpy(cmd_string,"AT+CGDCONT?\r\n");
    k_msleep(300);
    if(k_uptime_delta(&time_stamp)>= 10000){threeminute_flg = 0;} // check for time out 5s then swich off quectel
    }while (threeminute_flg == 1 && ( strncmp("AT+CGDCONT?\r\r\n+CGDCONT: 1,\"IP\"",datarx,30) !=0) );
    ////////////////////////////////////// AT+QGNSSTS?
    do { //
    strcpy(cmd_string,"AT+QGNSSTS?\r\n");
    k_msleep(200);
    }while (threeminute_flg == 1 && ( strncmp("AT+QGNSSTS?\r\r\n+QGNSSTS: 1\r\n\r\nOK\r\n",datarx,32) !=0) );
    // ////////////////////////////////////// AT+QCELLLOC=1
    // time_stamp = k_uptime_get();
    // strcpy(cmd_string,"AT+QCELLLOC=1\r\n");
    //uart_tx(uart, cmd_string, strlen(cmd_string), SYS_FOREVER_MS);
    //k_msleep(300); //
    //do { //
    // if( strncmp("\r\n+CME ERROR: 3826\r\n",datarx,13) ==0){
    // uart_tx(uart, cmd_string, strlen(cmd_string), SYS_FOREVER_MS);
    //}while (threeminute_flg == 1 && ( strncmp("\r\n+QCELLLOC: 51.414337,35.725136<CR><LF>",datarx,12) !=0) && k_uptime_delta(&time_stamp)<= 3000);
    /////////////////////////////////'AT+QGREFLOC=35.727047,51.410278';
    while (threeminute_flg == 1 && ( strncmp("AT+QGREFLOC=35.727047,51.410278<CR><CR><LF>OK<CR><LF",datarx,11) !=0) ) { //
    strcpy(cmd_string,"AT+QGREFLOC=35.727047,51.410278\r\n");
    k_msleep(200);
    ///////////////////////////////// AT+QGNSSEPO=1
    while (threeminute_flg == 1 && ( strncmp("AT+QGNSSEPO=1\r\r\nOK\r\n",datarx,20) !=0) ) { //
    strcpy(cmd_string,"AT+QGNSSEPO=1\r\n");
    k_msleep(200);
    ///////////////////////////////// 'AT+QGNSSC=1' GNSS on
    while (threeminute_flg == 1 && ( strncmp("AT+QGNSSC=1\r\r\nOK\r\n",datarx,18) !=0) ) { //
    strcpy(cmd_string,"AT+QGNSSC=1\r\n");
    k_msleep(200);
    // ///////////////////////////////// AT+QGNSSRD="NMEA/RMC
    // k_msleep(2000);
    // time_stamp = k_uptime_get(); //
    //while (threeminute_flg == 1 && ( strncmp("A+QGNSSC=1\r\r\nOK\r\n",datarx,18) !=0) ) { //
    // strcpy(cmd_string,"AT+QGNSSRD=\"NMEA/RMC\"\r\n");
    // k_msleep(2000);
    // if(k_uptime_delta(&time_stamp)>= 5000){threeminute_flg = 0;} // check for time out 5s then swich off quectel
    ///////////////////////////////// AT+QMTOPEN=1,"37.221.21.101",1883 tcp request
    startReconnect:
    strcpy(cmd_string,"AT+QMTOPEN=1,\"37.221.21.101\",1883\r\n");
    do {
    if(strncmp("\r\n+QMTOPEN: 1,-1\r\n",datarx,18) == 0){ // can not open tcp connection and try again
    if(strncmp("\r\n+QMTSTAT: 1,1\r\n",datarx,17) == 0){ // QMTSTAT: 1,1 TIME OUT and try again
    }while (threeminute_flg == 1 && ( strncmp("\r\n+QMTOPEN: 1,0\r\n",datarx,17) !=0) );
    ///////////////////////////////// AT+QMTCONN=1,"1111","bayat","1qaz!QAZ" mqtt connection request
    strcpy(cmd_string,"AT+QMTCONN=1,\"1111\",\"bayat\",\"1qaz!QAZ\"\r\n");
    do {
    if(strncmp("\r\n+QMTSTAT: 1,3\r\n\r\n+QMTCONN: 1,2\r\n>",datarx,34) == 0){ //time out for connectio to mqtt so shoud do tcp command again
    goto startReconnect;
    }while (threeminute_flg == 1 && ( strncmp("\r\n+QMTCONN: 1,0,0\r\n",datarx,19) !=0) );
    ///////////////////////////////// 'AT+QMTPUB=1,10,2,0,"topic/upload" publish to topic address
    strcpy(cmd_string,"AT+QMTPUB=1,10,2,0,\"topic/upload\",5\r\n");
    do {
    // if(strncmp("\r\n+QMTSTAT: 1,3\r\n\r\n+QMTCONN: 1,2\r\n>",datarx,34) == 0){ //time out for connectio to mqtt so shoud do tcp command again
    // goto startReconnect;
    k_msleep(300);
    }while (threeminute_flg == 1 && ( strncmp("AT+QMTPUB=1,10,2,0,\"topic/upload\",5\r\r\n>",datarx,39) !=0) );
    k_msleep(1000);
    strcpy(cmd_string,"bayatnasser");
    k_msleep(100);
    cmd_string[0]= 0x1a; //<sub> charcter sent
    uart_tx(uart, cmd_string, 1, SYS_FOREVER_MS);
    k_msleep(100);
    if (threeminute_flg == 1) {
    strcpy(cmd_string, "ATI\r\n");
    k_msleep(1000);
    strcpy(cmd_string, "C\r\n");
    k_msleep(1000);
    strcpy(cmd_string, "D\r\n");
    k_msleep(1000);
    strcpy(cmd_string, "E\r\n");
    k_msleep(1000);
    strcpy(cmd_string, "F\r\n");
    k_msleep(1000);
    strcpy(cmd_string, "G\r\n");
    k_msleep(1000);
    strcpy(cmd_string, "H\r\n");
    k_msleep(1000);
    strcpy(cmd_string, "I\r\n");
    k_msleep(1000);
    strcpy(cmd_string, "J\r\n");
    k_msleep(1000);
    strcpy(cmd_string, "K\r\n");
    k_msleep(1000);
    strcpy(cmd_string, "L\r\n");
    k_msleep(1000);
    k_msleep(1000);
    gpio_pin_set(port0, gprson, 0);
    gpio_pin_set(port0, led5,1);
    led1flg = 0;
    k_msleep(100);
    NRF_UARTE0->ENABLE = 0;
    k_msleep(100);
    k_sleep(K_FOREVER);
    //K_THREAD_DEFINE(quectel_id, STACKSIZE, gprs_thread, NULL, NULL, NULL, PRIORITY, 0, 0);
    void reverse(char* str, int len)
    int i = 0, j = len - 1, temp;
    while (i < j) {
    temp = str[i];
    str[i] = str[j];
    str[j] = temp;
    i++;
    j--;
    // Converts a given integer x to string str[].
    // d is the number of digits required in the output.
    // If d is more than the number of digits in x,
    // then 0s are added at the beginning.
    int intToStr(int x, char str[], int d)
    int i = 0;
    while (x) {
    str[i++] = (x % 10) + '0';
    x = x / 10;
    // If number of digits required is more, then
    // add 0s at the beginning
    while (i < d)
    str[i++] = '0';
    reverse(str, i);
    str[i] = '\0';
    return i;
    // Converts a floating-point/double number to a string.
    void ftoa(float n, char* res, int afterpoint)
    uint8_t sign_flg[52];
    uint8_t temp[52];
    if( n < 0 ){
    sign_flg[0] = '-';
    n = -n;
    else{
    sign_flg[0] = ' ';
    sign_flg[1] ='\0';
    // Extract integer part
    int ipart = (int)n;
    // Extract floating part
    float fpart = n - (float)ipart;
    // convert integer part to string
    int i = intToStr(ipart, res, 0);
    // check for display option after point
    if (afterpoint != 0) {
    res[i] = '.'; // add dot
    // Get the value of fraction part upto given no.
    // of points after dot. The third parameter
    // is needed to handle cases like 233.007
    //fpart = fpart * pow (10, afterpoint);
    for(int j = 0; j< afterpoint;++j){
    fpart = fpart * 10;
    intToStr((int)fpart, res + i + 1, afterpoint);
    if( n < 1 ){
    for ( int j = 0; j < strlen(res); ++j){
    temp[j+1] = res[j];
    temp[0] = 0x30;
    strcpy(res,temp);
    res[strlen(res) + 1] ='\0';
    strcat(sign_flg,res);
    strcpy(res,sign_flg);
    K_SEM_DEFINE(sem, 0, 1);
    static void trigger_handler(const struct device *dev,
    const struct sensor_trigger *trig)
    switch (trig->type) {
    case SENSOR_TRIG_DATA_READY:
    if (sensor_sample_fetch(dev) < 0) {
    printf("Sample fetch error\n");
    return;
    k_sem_give(&sem);
    case SENSOR_TRIG_THRESHOLD:
    printf("Threshold trigger\n");
    printf("Unknown trigger\n");
    void adxl362_thread(void)
    char res[50];
    double ax,ay,az,ambient_temp;
    struct sensor_value accel[3],temp[1];
    const struct device *dev = device_get_binding(DT_LABEL(DT_INST(0, adi_adxl362)));
    if (IS_ENABLED(CONFIG_ADXL362_TRIGGER)) {
    struct sensor_trigger trig = { .chan = SENSOR_CHAN_ACCEL_XYZ };
    trig.type = SENSOR_TRIG_THRESHOLD;
    if (sensor_trigger_set(dev, &trig, trigger_handler)) {
    printf("Trigger set error\n");
    return;
    trig.type = SENSOR_TRIG_DATA_READY;
    ///////// system reset command __NVIC_SystemReset();
    adxl362_set_range(dev,8);
    while(1) {
    k_sem_take(&sem, K_FOREVER);
    } else {
    k_msleep(1000);
    return;
    sensor_sample_fetch(dev);
    //k_msleep(100);
    sensor_channel_get(dev, SENSOR_CHAN_ACCEL_X, &accel[0]);
    ax = sensor_value_to_double(&accel[0]);
    if( ax > 12.5 ){
    strcpy(res,"Ax =");
    uart_tx(uart,res,strlen(res), SYS_FOREVER_MS);
    k_msleep(2);
    ftoa(ax,res,4);
    k_msleep(2);
    strcpy(res,"\r\n");
    k_msleep(2);
    sensor_channel_get(dev, SENSOR_CHAN_ACCEL_Y, &accel[1]);
    ay = sensor_value_to_double(&accel[1]);
    if ( ay > 12.5 ) {
    strcpy(res,"Ay =");
    k_msleep(2);
    ftoa(ay,res,4);
    k_msleep(2);
    strcpy(res,"\r\n");
    k_msleep(2);
    sensor_channel_get(dev, SENSOR_CHAN_ACCEL_Z, &accel[2]);
    az = sensor_value_to_double(&accel[2]);
    if( az > 12.5 ) {
    strcpy(res,"Az =");
    k_msleep(2);
    ftoa(az,res,4);
    k_msleep(2);
    strcpy(res,"\r\n");
    k_msleep(2);
    sensor_channel_get(dev,SENSOR_CHAN_DIE_TEMP,&temp[0]);
    ambient_temp = sensor_value_to_double(&temp[0]) + 22 ;
    strcpy(res,"Temperature = ");
    k_msleep(20);
    ftoa(ambient_temp,res,2);
    k_msleep(20);
    strcpy(res,"\r\n");
    k_msleep(20);
    // __NVIC_SystemReset();
    K_THREAD_DEFINE(adxl362_id, 1024, adxl362_thread, NULL, NULL, NULL, PRIORITY, 0, 0);
    void main()
    uint64_t j, k;
    gpio_pin_configure(port0, led5,GPIO_OUTPUT | GPIO_OUTPUT_INIT_HIGH); // set the pin for led5 as output high
    gpio_pin_configure(port0, rscon, GPIO_INPUT); // set the pin for rscon as input high z
    gpio_pin_configure(port0, pwkey,GPIO_OUTPUT | GPIO_OUTPUT_INIT_LOW); // set the pin for pwkey as output low
    gpio_pin_configure(port0, gprson,GPIO_OUTPUT| GPIO_OUTPUT_INIT_LOW); // set the pin for gprsoff as output low
    gpio_pin_configure(port0,temp_cut,GPIO_OUTPUT| GPIO_OUTPUT_INIT_LOW); // set the pin for temp_cut as output low
    gpio_pin_configure(port0, st0, GPIO_INPUT); // set the pin for st0 as input high z
    gpio_pin_configure(port0, st1, GPIO_INPUT); // set the pin for st1 as input high z
    gpio_pin_configure(port0, st2, GPIO_INPUT); // set the pin for st2 as input high z
    dk_leds_init();
    //k_msleep(1000 * 60);
    uart_init();
    while (1) {
    if (sch_Evt == 1) {
    k_wakeup(quectel_id);
    k_wakeup(threeminute_id);
    sch_Evt = 0;
    //gpio_pin_set(port0,led5,0);
    k_msleep(500);
    B.R.
    Saeed
  • Dear Saeed,
    Which SDK version you are using?
    What problem you are getting with that function? What is the error?
    Please send the minimal project in the zip file, as I am not able to build based on your code and produce the error related to the said function.
    Please mention what error you are getting and how you are building the project.
    In your proj.conf you have "CONFIG_BT_NUS_UART_BUFFER_SIZE=512"
    but there is no such KCONFIG option available with nCS.
    Regards
  • Hi Naeem
    Please tell me how can I send you a Zip file sample of my project.
    I tried to send it via Email but it has been blocked.
    The SDK version which I am using is v.1.8.0.
    B.R.
  • Please click on Insert--> Image/video/file and then on the "Upload" under the File/URL bar.
    This will allow you to browse, select and upload your zip file.
    Please also mention:
    What error you are getting?
    And how to reproduce the error.
    Please send the minimal project.
