BLE DFU build fails
I can successfully build and run the DFU as described here:  Add DFU support to your application
Now I'm trying to take the same steps with my own application and it fails in a weird way. I had to change /zephyr/subsys/mgmt/mcumgr/lib/cmd/img_mgmt/include/image.h a bit just to get anything to compile. Had to change __packed at the end of each struct to __attribute__ ((__packed__)). I'm not sure why this is - I suspected some compiler version thing or something but I don't know how to even check that. This error doesn't seem to be related to that however.
All this error tells me is that something is going wrong in the assembler. Unfortunately that is as far as I can go with this. Can you please help me? If I can't get help from here I will have to start again from the working DFU LBS sample and try to add everything my application needs on top of that. That would be very time consuming to do.
* Executing task: nRF Connect: Build: blindy_v3/build (active)
Building blindy_v3
west build --build-dir /home/tiit/code/blindy_v3/build /home/tiit/code/blindy_v3
[0/1] Re-running CMake...
Loading Zephyr default modules (Zephyr base (cached)).
-- Application: /home/tiit/code/blindy_v3
-- Cache files will be written to: /home/tiit/.cache/zephyr
-- Zephyr version: 3.2.99 (/home/tiit/ncs/v2.2.0-rc1/zephyr)
-- Board: blindy_v4
-- Found host-tools: zephyr 0.15.1 (/home/tiit/ncs/toolchains/v2.2.0-rc1/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.15.1 (/home/tiit/ncs/toolchains/v2.2.0-rc1/opt/zephyr-sdk)
-- Found BOARD.dts: /home/tiit/code/blindy_v3/boards/arm/blindy_v4/blindy_v4.dts
-- Generated zephyr.dts: /home/tiit/code/blindy_v3/build/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /home/tiit/code/blindy_v3/build/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: /home/tiit/code/blindy_v3/build/zephyr/dts.cmake
Parsing /home/tiit/ncs/v2.2.0-rc1/zephyr/Kconfig
Loaded configuration '/home/tiit/code/blindy_v3/boards/arm/blindy_v4/blindy_v4_defconfig'
Merged configuration '/home/tiit/code/blindy_v3/prj.conf'
Configuration saved to '/home/tiit/code/blindy_v3/build/zephyr/.config'
Kconfig header saved to '/home/tiit/code/blindy_v3/build/zephyr/include/generated/autoconf.h'
CMake Warning at /home/tiit/ncs/v2.2.0-rc1/zephyr/subsys/usb/device/CMakeLists.txt:22 (message):
CONFIG_USB_DEVICE_VID has default value 0x2FE3.
This value is only for testing and MUST be configured for USB products.
-- Found Python3: /home/tiit/ncs/toolchains/v2.2.0-rc1/usr/local/bin/python3.8 (found version "3.8.2") found components: Interpreter
=== child image mcuboot - begin ===
loading initial cache file /home/tiit/code/blindy_v3/build/mcuboot/child_image_preload.cmake
-- Application: /home/tiit/ncs/v2.2.0-rc1/bootloader/mcuboot/boot/zephyr
-- Found Python3: /home/tiit/ncs/toolchains/v2.2.0-rc1/usr/local/bin/python3.8 (found suitable exact version "3.8.2") found components: Interpreter
-- Board: blindy_v4
-- Found Dtc: /home/tiit/ncs/toolchains/v2.2.0-rc1/usr/bin/dtc (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found devicetree overlay: /home/tiit/ncs/v2.2.0-rc1/nrf/modules/mcuboot/usb.overlay
-- Found devicetree overlay: /home/tiit/ncs/v2.2.0-rc1/bootloader/mcuboot/boot/zephyr/dts.overlay
-- Generated zephyr.dts: /home/tiit/code/blindy_v3/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /home/tiit/code/blindy_v3/build/mcuboot/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: /home/tiit/code/blindy_v3/build/mcuboot/zephyr/dts.cmake
Parsing /home/tiit/ncs/v2.2.0-rc1/bootloader/mcuboot/boot/zephyr/Kconfig
Merged configuration '/home/tiit/ncs/v2.2.0-rc1/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration '/home/tiit/ncs/v2.2.0-rc1/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration '/home/tiit/code/blindy_v3/build/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to '/home/tiit/code/blindy_v3/build/mcuboot/zephyr/.config'
Kconfig header saved to '/home/tiit/code/blindy_v3/build/mcuboot/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 12.1.0
-- The CXX compiler identification is GNU 12.1.0
-- Found assembler: /home/tiit/ncs/toolchains/v2.2.0-rc1/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
CMake Warning at /home/tiit/ncs/v2.2.0-rc1/nrf/lib/flash_patch/CMakeLists.txt:8 (message):
--- WARNING: To maintain the integrity of secure boot, ---
--- enable CONFIG_DISABLE_FLASH_PATCH in production. ---
MCUBoot bootloader key file: /home/tiit/ncs/v2.2.0-rc1/bootloader/mcuboot/root-ec-p256.pem
-- Configuring done
-- Generating done
-- Build files have been written to: /home/tiit/code/blindy_v3/build/mcuboot
=== child image mcuboot - end ===
CMake Warning at /home/tiit/ncs/v2.2.0-rc1/nrf/modules/mcuboot/CMakeLists.txt:286 (message):
--- WARNING: Using default MCUBoot key, it should not ---
--- be used for production. ---
-- Configuring done
-- Generating done
[1/293] Creating directories for 'mcuboot_subimage'
[2/293] No download step for 'mcuboot_subimage'
[3/293] No update step for 'mcuboot_subimage'
[4/293] No patch step for 'mcuboot_subimage'
[5/293] No configure step for 'mcuboot_subimage'
[5/293] Performing build step for 'mcuboot_subimage'
[1/176] Preparing syscall dependency handling
[2/176] Generating include/generated/version.h
-- Zephyr version: 3.2.99 (/home/tiit/ncs/v2.2.0-rc1/zephyr), build: v3.2.99-ncs1-rc1
[3/176] Generating misc/generated/syscalls_subdirs.trigger
[4/176] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[5/176] Generating include/generated/driver-validation.h
[6/176] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[7/176] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[8/176] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[9/176] Generating include/generated/offsets.h
[10/176] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[11/176] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[12/176] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[13/176] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[14/176] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[15/176] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[16/176] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[17/176] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[18/176] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[19/176] Generating zephyr/autogen-pubkey.c
[20/176] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[21/176] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[22/176] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[23/176] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[24/176] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[25/176] Building C object CMakeFiles/app.dir/os.c.obj
[26/176] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[27/176] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[28/176] Building C object CMakeFiles/app.dir/home/tiit/ncs/v2.2.0-rc1/bootloader/mcuboot/boot/bootutil/src/fault_injection_hardening.c.obj
[29/176] Building C object CMakeFiles/app.dir/keys.c.obj
[30/176] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[31/176] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[32/176] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
[33/176] Building C object CMakeFiles/app.dir/home/tiit/ncs/v2.2.0-rc1/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
[34/176] Building C object CMakeFiles/app.dir/home/tiit/ncs/v2.2.0-rc1/bootloader/mcuboot/ext/mbedtls-asn1/src/platform_util.c.obj
[35/176] Building C object CMakeFiles/app.dir/main.c.obj
[36/176] Building C object CMakeFiles/app.dir/home/tiit/ncs/v2.2.0-rc1/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj
[37/176] Building C object CMakeFiles/app.dir/home/tiit/ncs/v2.2.0-rc1/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj
[38/176] Building C object CMakeFiles/app.dir/home/tiit/ncs/v2.2.0-rc1/bootloader/mcuboot/boot/bootutil/src/image_ed25519.c.obj
[39/176] Building C object CMakeFiles/app.dir/home/tiit/ncs/v2.2.0-rc1/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj
[40/176] Building C object CMakeFiles/app.dir/home/tiit/ncs/v2.2.0-rc1/bootloader/mcuboot/boot/bootutil/src/image_ec256.c.obj
[41/176] Building C object CMakeFiles/app.dir/zephyr/autogen-pubkey.c.obj
[42/176] Building C object CMakeFiles/app.dir/home/tiit/ncs/v2.2.0-rc1/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj
[43/176] Building C object CMakeFiles/app.dir/home/tiit/ncs/v2.2.0-rc1/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj
[44/176] Building C object CMakeFiles/app.dir/home/tiit/ncs/v2.2.0-rc1/bootloader/mcuboot/boot/bootutil/src/caps.c.obj
[45/176] Building C object CMakeFiles/app.dir/home/tiit/ncs/v2.2.0-rc1/bootloader/mcuboot/ext/mbedtls-asn1/src/asn1parse.c.obj
[46/176] Building C object CMakeFiles/app.dir/home/tiit/ncs/v2.2.0-rc1/bootloader/mcuboot/ext/nrf/cc310_glue.c.obj
[47/176] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
[48/176] Building C object CMakeFiles/app.dir/home/tiit/ncs/v2.2.0-rc1/bootloader/mcuboot/boot/bootutil/src/swap_scratch.c.obj
[49/176] Building C object CMakeFiles/app.dir/nrf_cleanup.c.obj
[50/176] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
FAILED: zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
ccache /home/tiit/ncs/toolchains/v2.2.0-rc1/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DKERNEL -DNRF52840_XXAA -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I/home/tiit/ncs/v2.2.0-rc1/zephyr/kernel/include -I/home/tiit/ncs/v2.2.0-rc1/zephyr/arch/arm/include -I/home/tiit/ncs/v2.2.0-rc1/zephyr/include -Izephyr/include/generated -I/home/tiit/ncs/v2.2.0-rc1/zephyr/soc/arm/nordic_nrf/nrf52 -I/home/tiit/ncs/v2.2.0-rc1/zephyr/soc/arm/nordic_nrf/common/. -I/home/tiit/ncs/v2.2.0-rc1/nrf/include -I/home/tiit/ncs/v2.2.0-rc1/modules/hal/cmsis/CMSIS/Core/Include -I/home/tiit/ncs/v2.2.0-rc1/modules/hal/nordic/nrfx -I/home/tiit/ncs/v2.2.0-rc1/modules/hal/nordic/nrfx/drivers/include -I/home/tiit/ncs/v2.2.0-rc1/modules/hal/nordic/nrfx/mdk -I/home/tiit/ncs/v2.2.0-rc1/zephyr/modules/hal_nordic/nrfx/. -I/home/tiit/ncs/v2.2.0-rc1/bootloader/mcuboot/boot/bootutil/zephyr/.. -I/home/tiit/ncs/v2.2.0-rc1/bootloader/mcuboot/boot/bootutil/zephyr/../include -I/home/tiit/ncs/v2.2.0-rc1/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -I/home/tiit/ncs/v2.2.0-rc1/nrfxlib/crypto/nrf_cc310_bl/include -isystem /home/tiit/ncs/v2.2.0-rc1/zephyr/lib/libc/minimal/include -isystem /home/tiit/ncs/toolchains/v2.2.0-rc1/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/include -isystem /home/tiit/ncs/toolchains/v2.2.0-rc1/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/include-fixed -isystem /home/tiit/ncs/v2.2.0-rc1/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -Os -imacros /home/tiit/code/blindy_v3/build/mcuboot/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfpu=fpv4-sp-d16 -mfloat-abi=hard -mfp16-format=ieee --sysroot=/home/tiit/ncs/toolchains/v2.2.0-rc1/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros /home/tiit/ncs/v2.2.0-rc1/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/home/tiit/ncs/v2.2.0-rc1/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=/home/tiit/ncs/v2.2.0-rc1/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/home/tiit/ncs/v2.2.0-rc1=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj -MF zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj.d -o zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj -c zephyr/misc/generated/configs.c
/tmp/ccetOlIq.s: Assembler messages:
/tmp/ccetOlIq.s:213: Error: missing expression
[51/176] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[52/176] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[53/176] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_nano.c.obj
[54/176] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[55/176] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[56/176] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[57/176] Building C object CMakeFiles/app.dir/home/tiit/ncs/v2.2.0-rc1/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
[58/176] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
[59/176] Building C object CMakeFiles/app.dir/home/tiit/ncs/v2.2.0-rc1/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj
[141/293] Linking C static library zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a
FAILED: modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build mcuboot/zephyr/zephyr.hex mcuboot/zephyr/zephyr.elf
cd /home/tiit/code/blindy_v3/build/mcuboot && /home/tiit/ncs/toolchains/v2.2.0-rc1/usr/local/lib/python3.8/site-packages/cmake/data/bin/cmake --build . --
[143/293] Linking C static library zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a
[144/293] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_common.c.obj
[145/293] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/buf.c.obj
[146/293] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/ecc.c.obj
[147/293] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/settings.c.obj
[148/293] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/adv.c.obj
[149/293] Building C object CMakeFiles/app.dir/src/main.c.obj
../src/main.c: In function 'main':
/home/tiit/code/blindy_v3/src/main.c:274:17: warning: unused variable 'dir' [-Wunused-variable]
274 | uint8_t dir = 1U;
/home/tiit/code/blindy_v3/src/main.c:273:18: warning: unused variable 'step' [-Wunused-variable]
273 | uint32_t step = 0;
[150/293] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/id.c.obj
[151/293] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_core.c.obj
FATAL ERROR: command exited with status 1: /home/tiit/ncs/toolchains/v2.2.0-rc1/usr/local/bin/cmake --build /home/tiit/code/blindy_v3/build
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
  • Hi Tiit,
    Tiit said:
    I can send you the entire project
    Yes please. As you said that the DFU with LBS sample is working but not with your custom board. So please make no / minimal changes to the sample project + your custom board files. Do mention if there is anything special to consider.
    We can look for upgrading to the latest version once it compiles successfully.
    Naeem
  • After installing the SDK v2.0.0 I can't open anything in VSCode any more. I'm getting this error:
    Error loading webview: Error: Could not register service workers: InvalidStateError: Failed to register a ServiceWorker: The document is in an invalid state..
    VSCode itself seems to be fine but all the Nordic parts are broken now.
  • I uninstalled everything and reinstalled v2.0.0. That doesn't work well with my dts file (something in the ADC config part). But removing offending parts of the dts file I got the HR sample to compile with my board file.
    I then installed v2.2.0 and again modified the HR sample to have DFU. That compiled fine. Added my own DTS file and that also compiled now. So I just copied all the sources from my project into this new one and now it seems to work. I have no idea what in the project configuration is causing this error but it still fails in the old folder and works in the new one.
    I guess we can close this as I have a working solution now. During all this testing VSCode broke several times and I had to uninstall and reinstall the Nordic extension to get it to work again. I'm coming from the very old nrf-51 SDK and all the new configuration files are really confusing me still. The code part is easy but gettign all the dts and conf and yaml and CMake file working has been a hassle.
    Tiit
