I am using the nrf connect SDK.
I want to switch multiple BDADDRs in one AdvertiseSet.
BDADDR does not change even if bt_le_adv_param.id is changed in bt_le_ext_adv_update_param().
Is there any way?
Is there any way?
Inside the bt_le_ext_adv_cb.sent() callback function, we are calling bt_le_ext_adv_update_param().
Is this a problem?
If you are doing something wrong when calling bluetooth api's you will get an error message. As long as there is no error message you are fine.
Kenneth
Apparently, bt_id can only be set during adv_create and cannot be changed with update_param.
I would like to use bt_id_reset() instead.
However, if the id is associated with adv_create(), calling bt_id_reset() will return an error (-120).
What are the limitations of bt_id_reset()?
loquat said:Apparently, bt_id can only be set during adv_create and cannot be changed with update_param.
So it's the same as old nRF5 SDK then.
loquat said:What are the limitations of bt_id_reset()?
* @brief Reset/reclaim an identity for reuse.
* The semantics of the @a addr and @a irk parameters of this function
* are the same as with bt_id_create(). The difference is the first
* @a id parameter that needs to be an existing identity (if it doesn't
* exist this function will return an error). When given an existing
* identity this function will disconnect any connections created using it,
* remove any pairing keys or other data associated with it, and then create
* a new identity in the same slot, based on the @a addr and @a irk
* parameters.
* @note the default identity (BT_ID_DEFAULT) cannot be reset, i.e. this
* API will return an error if asked to do that.
* @param id Existing identity identifier.
* @param addr Address to use for the new identity. If NULL or initialized
* to BT_ADDR_LE_ANY the stack will generate a new static
* random address for the identity and copy it to the given
* parameter upon return from this function (in case the
* parameter was non-NULL).
* @param irk Identity Resolving Key (16 bytes) to be used with this
* identity. If set to all zeroes or NULL, the stack will
* generate a random IRK for the identity and copy it back
* to the parameter upon return from this function (in case
* the parameter was non-NULL). If privacy
* @kconfig{CONFIG_BT_PRIVACY} is not enabled this parameter must
* be NULL.
* @return Identity identifier (>= 0) in case of success, or a negative
* error code on failure.
int bt_id_reset(uint8_t id, bt_addr_le_t *addr, uint8_t *irk);
Is it possible to set a different addr for bt_id_reset?
Is it possible during advertising?
