Debuggen of BLE Applications based on Connect SDK 2.2.0 not possible -> Faulting instruction address (r15/pc)
I have the problem that I am currently unable to debug any of my Bluetooth applications.
I'm sure that I was able to do this without any problems during the original development with SDK v1.9.1.
The firmware works fine without a debugger.
However, when used with debugger, the firmware crashes shortly after bt_le_adv_start with the following output:
ASSERTION FAIL [0] @ WEST_TOPDIR/zephyr/subsys/bluetooth/controller/ll_sw/nordic/lll/lll.c:473
lll_preempt_calc: Actual EVENT_OVERHEAD_START_US = 2021270
[00:00:04.303,894] <err> os: r0/a1: 0x00000003 r1/a2: 0x00000002 r2/a3: 0x00000001
[00:00:04.303,894] <err> os: r3/a4: 0x00000000 r12/ip: 0x0000d796 r14/lr: 0x00000fb9
[00:00:04.303,924] <err> os: xpsr: 0x41000028
[00:00:04.303,924] <err> os: Faulting instruction address (r15/pc): 0x00000fc4
[00:00:04.303,955] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
[00:00:04.303,985] <err> os: Fault during interrupt handling[00:00:04.304,016] <err> os: Current thread: 0x20002150 (main)
[00:00:04.556,945] <err> fatal_error: Resetting system
After various investigations in my own projects, I tested older (v2.0.0) and newer (v2.2.99-dev3) SDK's. Unfortunately without success!
VSCode was also uninstalled (+ .vscode deleted in the user folder) and completely reinstalled. Also without success!
I then tried to debug the sample samples/bluetooth/peripheral (built with Connect SDK v2.2.0).
But here the firmware also crashes with the following output:
[00:00:03.346,[00:00:03.346,435] <inf> fs_nvs: nvs_mount: alloc wra: 0, fb8
[00:00:03.346,435] <inf> fs_nvs: nvs_mount: data wra: 0, 4c
[00:00:03.346,588] <inf> sdc_hci_driver: hci_driver_open: SoftDevice Controller build revision:
6d 90 41 2a 38 e8 ad 17 29 a5 03 38 39 27 d7 85 |m.A*8... )..89'..
1f 85 d8 e1 |....
[00:00:03.349,853] <inf> bt_hci_core: hci_vs_init: HW Platform: Nordic Semiconductor (0x0002)
[00:00:03.349,884] <inf> bt_hci_core: hci_vs_init: HW Variant: nRF52x (0x0002)
[00:00:03.349,914] <inf> bt_hci_core: hci_vs_init: Firmware: Standard Bluetooth controller (0x00) Version 109.16784 Build 2917677098
[00:00:03.350,402] <inf> bt_hci_core: bt_init: No ID address. App must call settings_load()
[00:00:03.353,149] <inf> bt_hci_core: bt_dev_show_info: Identity: E7:BF:32:EE:30:C4 (random)
[00:00:03.353,179] <inf> bt_hci_core: bt_dev_show_info: HCI: version 5.3 (0x0c) revision 0x11fa, manufacturer 0x0059
[00:00:03.353,210] <inf> bt_hci_core: bt_dev_show_info: LMP: version 5.3 (0x0c) subver 0x11fa
[00:00:12.012,115] <err> mpsl_init: m_assert_handler: MPSL ASSERT: 112, 2195
[00:00:12.012,115] <err> os: hard_fault: HARD FAULT
[00:00:12.012,145] <err> os: hard_fault: Fault escalation (see below)
[00:00:12.012,145] <err> os: hard_fault: ARCH_EXCEPT with reason 3
[00:00:12.012,176] <err> os: esf_dump: r0/a1: 0x00000003 r1/a2: 0x00000000 r2/a3: 0x00000018
[00:00:12.012,176] <err> os: esf_dump: r3/a4: 0x0002d80f r12/ip: 0x00000000 r14/lr: 0x0002aad9
[00:00:12.012,207] <err> os: esf_dump: xpsr: 0x61000018
[00:00:12.012,207] <err> os: esf_dump: Faulting instruction address (r15/pc): 0x00029088[0m
[00:00:12.012,237] <err> os: z_fatal_error: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
[00:00:12.012,268] <err> os: z_fatal_error: Fault during interrupt handling
The crash occurs in bt_ready at line:
printk("Advertising successfully started\n");
If the line with bt_le_adv_start is commented out, you can debug without any problems!
Information about the environment:
  • Windows 10 22H2
  • nRF Connect SDK: v2.2.0 (v2.0.0, v2.2.99-dev3)
  • Visual Studio Code: Version: 1.75.0 (system setup)
  • nRF Connect for VS Code: v2023.1.44
  • Board: nRF52 DK NRF52832
