Problem establishing LTE connection
I'm trying to establish a connection to the nrf cloud with LTE-M for the nrf9160, but I'm having a problem. I had already managed to connect the devkit a couple weeks ago, but I changed of virtual machine (my PC is under windows, and I use a linux VM) and can't establish a connection since. I'm using the provided eSIM.  I'm in France, wich should support both LTE-M and NB IoT. I'm barely beginning with the nordic components.
Since I retried to establish the connection, I updated the certificate, and deleted my previous device on the nrf cloud as told here.
I then uploaded the modem firmware 1.3.3, and the application firmware asset_tracket_v2_2022_12_08, which according to the CONTENTS.txt supports both LTE-M and NB IoT. Now is the problem. From the nrf cloud, I can't add a new LTE device, because no connection is established. Led1 blinks continuously.
From the LTE Link Monitor, I can see that the modem and UICC are enabled, but the UART ad LTE are blinking in yellow/red and the PDN is constantly off. Please see the log file below.
Thank you for your help.
Armand
EDIT : I uploaded the application firmware at_client, and followed the testing lines given here. The results to the commands seem coherent, except for AT%XMONITOR. It returns : 4, wich according to the AT documentation is 'Unknown'. I guess that's a problem, but I don't know how to use this information.
2023-02-09T16:15:53.325Z DEBUG Application data folder: /home/devnordicconnect/.config/nrfconnect/pc-nrfconnect-linkmonitor
2023-02-09T16:15:53.837Z INFO Using nrf-device-lib-js version: 0.4.13
2023-02-09T16:15:53.840Z INFO Using nrf-device-lib version: 0.12.8
2023-02-09T16:15:53.844Z INFO Using nrfjprog DLL version: 10.16.0
2023-02-09T16:15:53.846Z INFO Using JLink version: JLink_V7.84a
2023-02-09T16:15:53.942Z DEBUG App pc-nrfconnect-linkmonitor v2.0.2 official
2023-02-09T16:15:53.943Z DEBUG App path: /home/devnordicconnect/.nrfconnect-apps/node_modules/pc-nrfconnect-linkmonitor
2023-02-09T16:15:53.943Z DEBUG nRFConnect 3.12.0, required by the app is (^3.12.0)
2023-02-09T16:15:53.943Z DEBUG nRFConnect path: /tmp/.mount_nrfconFZntmj/resources/app.asar
2023-02-09T16:15:53.943Z DEBUG HomeDir: /home/devnordicconnect
2023-02-09T16:15:53.943Z DEBUG TmpDir: /tmp
2023-02-09T16:15:53.948Z INFO Installed JLink version does not match the provided version (V7.66a)
2023-02-09T16:16:01.970Z INFO Modem port is opened
2023-02-09T16:16:02.045Z DEBUG modem >> AT+CFUN?
2023-02-09T16:16:02.191Z DEBUG modem << ERROR
2023-02-09T16:16:15.875Z DEBUG modem << [00:02:01.512,603] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
2023-02-09T16:16:15.958Z DEBUG modem << [00:02:01.513,244] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, MOD_STAT, LOCATION)[0m
2023-02-09T16:16:15.998Z DEBUG modem << [00:02:01.513,885] [0m<inf> app_event_manager: LOCATION_MODULE_EVT_ACTIVE[0m
2023-02-09T16:16:16.011Z DEBUG modem << [00:02:01.514,892] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_NOT_SUPPORTED[0m
2023-02-09T16:16:16.024Z DEBUG modem << [00:02:01.520,385] [0m<inf> app_event_manager: LOCATION_MODULE_EVT_AGPS_NEEDED[0m
2023-02-09T16:16:16.034Z DEBUG modem << [00:02:01.521,820] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
2023-02-09T16:16:16.041Z DEBUG modem << [00:02:01.521,850] [1;31m<err> modem_module: modem_info_params_get, error: -22[0m
2023-02-09T16:16:16.049Z DEBUG modem << [00:02:01.521,942] [0m<inf> app_event_manager: MODEM_EVT_MODEM_STATIC_DATA_NOT_READY[0m
2023-02-09T16:16:16.074Z DEBUG modem << [00:02:01.524,932] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
2023-02-09T16:16:16.086Z DEBUG modem << [00:02:01.524,963] [1;31m<err> modem_module: modem_info_params_get, error: -22[0m
2023-02-09T16:16:16.095Z DEBUG modem << [00:02:01.525,024] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2023-02-09T16:16:16.955Z DEBUG modem << [00:02:01.614,746] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
2023-02-09T16:16:17.009Z DEBUG modem << [00:02:01.614,776] [1;31m<err> modem_module: modem_info_params_get, error: -22[0m
2023-02-09T16:16:17.037Z DEBUG modem << [00:02:01.614,837] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_NOT_READY[0m
2023-02-09T16:16:20.723Z DEBUG modem >> AT+CFUN?
2023-02-09T16:16:20.774Z DEBUG modem << +CFUN: 1
2023-02-09T16:16:20.840Z DEBUG modem << OK
2023-02-09T16:16:20.858Z DEBUG modem >> AT+CGSN=1
2023-02-09T16:16:20.898Z DEBUG modem << +CGSN: "350457791992116"
2023-02-09T16:16:20.912Z DEBUG modem << OK
2023-02-09T16:16:20.978Z DEBUG modem >> AT+CGMI
2023-02-09T16:16:21.022Z DEBUG modem << Nordic Semiconductor ASA
2023-02-09T16:16:21.033Z DEBUG modem << OK
2023-02-09T16:16:21.107Z DEBUG modem >> AT+CGMM
2023-02-09T16:16:21.155Z DEBUG modem << nRF9160-SICA
2023-02-09T16:16:21.177Z DEBUG modem << OK
2023-02-09T16:16:21.206Z DEBUG modem >> AT+CGMR
2023-02-09T16:16:21.247Z DEBUG modem << mfw_nrf9160_1.3.3
2023-02-09T16:16:21.253Z DEBUG modem << OK
2023-02-09T16:16:21.261Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.3.3] SerNr: 350457791992116
2023-02-09T16:16:21.281Z DEBUG modem >> AT+CEMODE?
2023-02-09T16:16:21.315Z DEBUG modem << +CEMODE: 0
2023-02-09T16:16:21.329Z DEBUG modem << OK
2023-02-09T16:16:21.410Z DEBUG modem >> AT%XCBAND=?
2023-02-09T16:16:21.440Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)
2023-02-09T16:16:21.452Z DEBUG modem << OK
2023-02-09T16:16:21.514Z DEBUG modem >> AT+CMEE?
2023-02-09T16:16:21.565Z DEBUG modem << +CMEE: 0
2023-02-09T16:16:21.581Z DEBUG modem << OK
2023-02-09T16:16:21.622Z DEBUG modem >> AT+CMEE=1
2023-02-09T16:16:21.682Z DEBUG modem << OK
2023-02-09T16:16:21.710Z DEBUG modem >> AT+CNEC?
2023-02-09T16:16:21.758Z DEBUG modem << +CNEC: 16
2023-02-09T16:16:21.771Z DEBUG modem << OK
2023-02-09T16:16:21.798Z DEBUG modem >> AT+CNEC=24
2023-02-09T16:16:21.849Z DEBUG modem << OK
2023-02-09T16:16:21.878Z DEBUG modem >> AT+CGEREP?
2023-02-09T16:16:21.916Z DEBUG modem << +CGEREP: 1,0
2023-02-09T16:16:21.926Z DEBUG modem << OK
2023-02-09T16:16:21.963Z DEBUG modem >> AT+CIND=1,1,1
2023-02-09T16:16:21.998Z DEBUG modem << OK
2023-02-09T16:16:22.047Z DEBUG modem >> AT+CEREG=5
2023-02-09T16:16:22.093Z DEBUG modem << OK
2023-02-09T16:16:22.143Z DEBUG modem >> AT+CEREG?
2023-02-09T16:16:22.188Z DEBUG modem << +CEREG: 5,4
2023-02-09T16:16:22.212Z DEBUG modem << OK
2023-02-09T16:16:22.281Z DEBUG modem >> AT%CESQ=1
2023-02-09T16:16:22.330Z DEBUG modem << OK
2023-02-09T16:16:22.363Z DEBUG modem >> AT+CESQ
2023-02-09T16:16:22.436Z DEBUG modem << +CESQ: 99,99,255,255,255,255
2023-02-09T16:16:22.459Z DEBUG modem << OK
2023-02-09T16:16:22.530Z DEBUG modem >> AT%XSIM=1
2023-02-09T16:16:22.575Z DEBUG modem << OK
2023-02-09T16:16:22.618Z DEBUG modem >> AT%XSIM?
2023-02-09T16:16:22.656Z DEBUG modem << %XSIM: 1
2023-02-09T16:16:22.674Z DEBUG modem << OK
2023-02-09T16:16:22.752Z DEBUG modem >> AT+CPIN?
2023-02-09T16:16:22.795Z DEBUG modem << +CPIN: READY
2023-02-09T16:16:22.807Z DEBUG modem << OK
2023-02-09T16:16:22.875Z DEBUG modem >> AT+CPINR="SIM PIN"
2023-02-09T16:16:22.925Z DEBUG modem << +CPINR: "SIM PIN",3
2023-02-09T16:16:22.938Z DEBUG modem << OK
2023-02-09T16:16:23.006Z DEBUG modem >> AT+CIMI
2023-02-09T16:16:23.063Z DEBUG modem << 204080813691384
2023-02-09T16:16:23.075Z DEBUG modem << OK
2023-02-09T16:16:23.082Z INFO IMSIdentity: 204080813691384
2023-02-09T16:16:23.362Z DEBUG modem << +CEREG: 2
2023-02-09T16:16:24.362Z DEBUG modem << [00:02:09.021,087] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
2023-02-09T16:16:54.111Z DEBUG modem >> AT+CFUN?
2023-02-09T16:16:54.180Z DEBUG modem << +CFUN: 1
2023-02-09T16:16:54.229Z DEBUG modem << OK
2023-02-09T16:16:54.260Z DEBUG modem >> AT+CGSN=1
2023-02-09T16:16:54.295Z DEBUG modem << +CGSN: "350457791992116"
2023-02-09T16:16:54.307Z DEBUG modem << OK
2023-02-09T16:16:54.347Z DEBUG modem >> AT+CGMI
2023-02-09T16:16:54.395Z DEBUG modem << Nordic Semiconductor ASA
2023-02-09T16:16:54.411Z DEBUG modem << OK
2023-02-09T16:16:54.446Z DEBUG modem >> AT+CGMM
2023-02-09T16:16:54.493Z DEBUG modem << nRF9160-SICA
2023-02-09T16:16:54.507Z DEBUG modem << OK
2023-02-09T16:16:54.560Z DEBUG modem >> AT+CGMR
2023-02-09T16:16:54.599Z DEBUG modem << mfw_nrf9160_1.3.3
2023-02-09T16:16:54.610Z DEBUG modem << OK
2023-02-09T16:16:54.618Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.3.3] SerNr: 350457791992116
2023-02-09T16:16:54.667Z DEBUG modem >> AT+CEMODE?
2023-02-09T16:16:54.793Z DEBUG modem << +CEMODE: 0
2023-02-09T16:16:54.804Z DEBUG modem << OK
2023-02-09T16:16:54.883Z DEBUG modem >> AT%XCBAND=?
2023-02-09T16:16:54.916Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)
2023-02-09T16:16:54.952Z DEBUG modem << OK
2023-02-09T16:16:55.047Z DEBUG modem >> AT+CMEE?
2023-02-09T16:16:55.085Z DEBUG modem << +CMEE: 1
2023-02-09T16:16:55.096Z DEBUG modem << OK
2023-02-09T16:16:55.136Z DEBUG modem >> AT+CNEC?
2023-02-09T16:16:55.188Z DEBUG modem << +CNEC: 24
2023-02-09T16:16:55.209Z DEBUG modem << OK
2023-02-09T16:16:55.248Z DEBUG modem >> AT+CGEREP?
2023-02-09T16:16:55.308Z DEBUG modem << +CGEREP: 1,0
2023-02-09T16:16:55.317Z DEBUG modem << OK
2023-02-09T16:16:55.348Z DEBUG modem >> AT+CIND=1,1,1
2023-02-09T16:16:55.400Z DEBUG modem << OK
2023-02-09T16:16:55.430Z DEBUG modem >> AT+CEREG=5
2023-02-09T16:16:55.465Z DEBUG modem << OK
2023-02-09T16:16:55.508Z DEBUG modem >> AT+CEREG?
2023-02-09T16:16:55.563Z DEBUG modem << +CEREG: 5,2
2023-02-09T16:16:55.573Z DEBUG modem << OK
2023-02-09T16:16:55.624Z DEBUG modem >> AT%CESQ=1
2023-02-09T16:16:55.663Z DEBUG modem << OK
2023-02-09T16:16:55.713Z DEBUG modem >> AT+CESQ
2023-02-09T16:16:55.771Z DEBUG modem << +CESQ: 99,99,255,255,255,255
2023-02-09T16:16:55.786Z DEBUG modem << OK
2023-02-09T16:16:55.824Z DEBUG modem >> AT%XSIM=1
2023-02-09T16:16:55.864Z DEBUG modem << OK
2023-02-09T16:16:55.896Z DEBUG modem >> AT%XSIM?
2023-02-09T16:16:55.941Z DEBUG modem << %XSIM: 1
2023-02-09T16:16:55.946Z DEBUG modem << OK
2023-02-09T16:16:55.987Z DEBUG modem >> AT+CPIN?
2023-02-09T16:16:56.024Z DEBUG modem << +CPIN: READY
2023-02-09T16:16:56.038Z DEBUG modem << OK
2023-02-09T16:16:56.103Z DEBUG modem >> AT+CPINR="SIM PIN"
2023-02-09T16:16:56.178Z DEBUG modem << +CPINR: "SIM PIN",3
2023-02-09T16:16:56.186Z DEBUG modem << OK
2023-02-09T16:16:56.241Z DEBUG modem >> AT+CIMI
2023-02-09T16:16:56.272Z DEBUG modem << 204080813691384
2023-02-09T16:16:56.279Z DEBUG modem << OK
2023-02-09T16:16:56.284Z INFO IMSIdentity: 204080813691384
