BLE diagnostics API in nCS
Can you please help me with any API available in nRF Connect SDK, which will tell me if the BLE communication / BLE hardware on my nRF52833 is faulty or functional..?
    I do not think I completely understand what you are asking for. Can you please try to explain in other words what you want to check for, and for what purpose?
    Do you want to know if BLE has been disabled, or do you want to know if the node is hanging, or do you want to know something else?
    If what you look for is an alert when "some unknown error has happened on the device which makes BLE not work any more" then I am afraid that is not something it will be possible to self-test for. The only available option then is to try to communicate over BLE. If you get successful communication, then you can conclude that BLE is working. If you do not get any communication, it may either be that something is wrong locally on the device, or there are no BLE devices within range, but there is no way to know which one of the two it is. Most likely however the device does not suddenly stop working.
    Terje
  • Hello Terje,
    Apologies, let me rephrase
    My device is a BLE-mesh device I am developing firmware for it over nCS.
    Now, my device working fine and supposing that I perform a DFU over BLE  on my device and post DFU, I lost the device from the BLE-Mesh.
    with the previous image BLE-Mesh was functional in the device, now with the DFU updated image, device is not on scannable or detectable on BLE-Mesh.
    Here I just need to understand if my device's BLE hardware is functional or it is an issue with my updated image. Hence, I need to diagnose if BLE controller is healthy or not..?
    In the scenario that you describe, you have upgraded from a functioning Bluetooth mesh application to a malfunctioning Bluetooth mesh application. The error would be in the application itself.
    The DFU solution already have safeguards for switching permanently to the new application only if the new application is valid and functional.
    Basically, the DFU process is as follows: Using two slots, the existing image is in the first slot and the new image is uploaded to the second slot. The slots are then swapped and the device runs the new image. After the next reset the slots are swapped back, leaving you back with the old (known to be working) image. In order to stay on the new image, the new image must actively confirm the swap. This is done from the application itself. You can for instance do the confirmation after confirmed BLE reception. Returning to the previous application can be done for instance through watchdog timer, or trigger reset after a timeout if no BLE activity has happened, or manually repowering the device, or a number of other methods.
    Terje
  • Hello Terje,
    I have enabled the test upgrade only from mcuboot which is fine.
    My problem lies with this, if BLE is not functional, I cannot connect to the device.
    How will I find out if no BLE activity has happened..?
    This could be anything, really, but one simple way would be to extend the DFU functionality so that after the device has been upgraded, the DFU controller must send a message (over BLE) to tell the device to confirm the upgrade. When receiving such a message, the device confirms the upprade. If not receiving such a message, the device will automatically revert to the older firmware after the next reset, since the upgrade has not been confirmed.
    Terje
