Run a standard Zephyr application in NRF5
I have a sample application running in standard Zephyr 3.2.99. The application is just looping doing a sleep (k_sleep(K_SECONDS(10))) and logging a line.
I tried to build it to be run in nRF with MBR, Sofdevice (disabled) and bootloader. This will not be the system definitive app, just a special purpose one that would be convenient to be a Zephyr app.
To build it I took care of different memory layout: flash load offset 0x26000 (then changed to 0x1000), and reserving first 0x3000 RAM addresses that could be used by Softdevice.
When started by the Nordic bootloader, it correctly loops for >= 250 seconds (regardless of k_sleep interval, e.g. 10 or 30 sec), then it stops logging.
I tried doubling and quadrupling CONFIG_PRIVILEGED_STACK_SIZE and CONFIG_MAIN_STACK_SIZE (then even CONFIG_ISR_STACK_SIZE and CONFIG_IDLE_STACK_SIZE).
I checked usage of SVC interrupts, yet they seem unused bot in nFR and in zephyr. Then I investigated debugging, it looks like the last k_sleep call is waiting for a PendSV exception in arch_swap().
It's not clear to me why the PendSV interrupts are coming fro ~4 minutes and they stop. I read the S132 SoftDevice Specification and I couldn't find a valid reason why this should happen.
I thought about a possible incompatibility with Sofdtdevice and then I moved the app from 0x26000 to 0x1000 and I was surprised that the issue is the same.
The bootloader sets the vector table address for Sofdevice and now my app is in place of SD at 0x1000, so I would expect that the interrupts are forwarded (not only for 4 minutes).
Any suggestion is welcome.
Giancarlo.
