Only BLE sleep and wake-up sequence control in a nRF52832, while CPU running in normal mode
For the development of a new device I am using a custom hardware with a nRF52832 chip. I am working over the nRF5_SDK_17.1.0 using the SES IDE environment.
As a controller, the nRF52832 manages a state machine for acquiring some data from an SPI sensor and storing this data in a SPI flash. I only need to connect the device by BLE during some specific moments.
So, for increasing the autonomy of the small battery the device has, I would need that the CPU could run in normal mode while the BLE should be sleep. And wake-up the BLE in a controlled way in those specific moments. And after having transmitted the information, I should put the BLE services to sleep again.
Do you know of any example that could help me for managing this?
Thank you very much in advance.
Joel
  • Hi Einar,
    Thank you for your answer. I will check it.
    Joel
  • Hello Einar,
    At the beginning of the main() function I call the next initializations:
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        advertising_start();
        ble_gap_addr_t my_addr;
        err_code = sd_ble_gap_addr_get(&my_addr);
        NRF_LOG_INFO("addr %02x:%02x:%02x:%02x:%02x:%02x", my_addr.addr[0],
                                                          my_addr.addr[1],
                                                          my_addr.addr[2],
                                                          my_addr.addr[3],
                                                          my_addr.addr[4],
                                                          my_addr.addr[5]);
    In the services_init() function I initiate the NUS and the DFU services:
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
        // Initialize the DFU service
        ble_dfu_buttonless_init_t dfus_init =
            .evt_handler =  ble_dfu_buttonless_evt_handler
        err_code = ble_dfu_buttonless_init(&dfus_init);
    For selectively stopping all these tasks and stop all the BLE tasks (for maximum consumption reduction) what would be the best way/,method/codesequence that you would suggest to use?
    For reset them again I understand i should reinitiate them according to the same code I have shared. Is this ok?
    Joel
  • Hi Joel,
    There is no need to uninitialize anything Bluetooth related, but you should stop advertising, scanning (if relevant) etc if needed, or reduce the advertising interval etc if needed. This may not be as important as you could think, as the Bluetooth stack itself will not significantly contribute to the current consumption except during advertising events or connection events (or in scan windows). That is highly power optimized. You can see how this works on the current consumption by playing wth the online power profiler.
    Yes. For the other libraries etc. you use, it varies both on what you do and how you use it. Only NUS will not cause any issues, as that is just bluetooth. But do you also use UART? And is that always enabled? If so, the current consumption will be significant. So you should disable UART when you don't need it, and re-enable when you do. And logging you should disable for your production builds, as logging over UART will keep a UART instance the HW clock always running.
  • Hi Einar,
    I have not initialized the UART, but I still have the NRF_LOG_INFO messages and the logs are still enabled in the sdk_config.h file.
    Joel
  • I see. Then I would expect that you should get a low power consumption, comparable with what you see in the online power profiler. Have you checked to see if that is the case?
