NRF5340 AUDIO DK: WALKIE_TALKIE no bidirectional
Walkie-Talkie example works (add CONFIG_WALKIE_TALKIE_DEMO=y to prj.conf), but it is not bidirectional. I can only hear sounds from gateway's OB microphone.
I also tried with:
CONFIG_STREAM_BIDIRECTIONAL=y
but still it cannot work.
SDK version: 2.3.0 and application is updated to the latest found in github: 3330
  • Could you clarify what you mean when you say 'latest version' - does that mean you are working on the v2.2.0, or on the main branch?
    i use v2.3.0-rc1 SDK version, and 3330 version of nrf5340 audio dk app (found in /bin/manifest.yaml file)
    Yes, you can indeed use the button 4, or something else, to implement a switch that changes which of the received streams that are output on the Headphones jack.
    I see. So, in a nutshell NRF5340 AUDIO DK in walkie-talkie example successfully receives the (mono) stream from both headsets, but in order to choose which headset i listen (as listening the left headset DK is the default), i have to implement some kind of switching myself.
    Thank you for clarifying.
    Not quite - the Walkie-talkie demo is made for communication between 2 devices. The TWS bidirectional PR you referenced is made for 3 devices. Your statement here is correct if you substitute 'walkie talkie example' with 'the application in the PR'. If you add some kind of switch to the TWS Bidirectional PR you will achieve the functionality you describe :)
    Karl
  • if you substitute 'walkie talkie example' with 'the application in the PR'.
    What is the application in the PR here if not the 'nRF5340_audio' application and specifically the walkie-talkie demo portion of this application? Under the referenced PR there were changes made to the readme in the walkie-talkie demo section, notably:
    "The walkie-talkie demo uses one or two bidirectional streams from the gateway to one or two headsets"
    Is there a separate demo/setup of the nRF5340_audio application for True Wireless Stereo (TWS) or is it the same as the walkie-talkie demo?
    Also I would like to note that, for the walkie-talkie demo, without any mention of the gateway only outputting audio from one headset it sounds as though the audio received from each headset would be mixed and output together, otherwise the 'bidirectional' part of this doesn't feel complete.
    All of this in reference to nRF Connect SDK v2.3.0.
  • Looking further and thinking about this more it makes a little more sense that only one stream would be output, since you wouldn't want to use both mics when they're adjacent to one another (in theory as if these were two ear buds); however, it looks as though it is hardcoded to only be output audio from the Left headset, so in the event that only the right headset is connected here will be no audio on the Gateway. Please correct me if my understanding is flawed.
