Build problem for echo client sample with (D)TLS
I am trying to compile the sample
  zephyr/samples/net/sockets/echo_client
from the v2.3.0-rc1 version for the Thingy91, with TLS support:
$ west build -b thingy91_nrf9160_ns -- -DOVERLAY_CONFIG=overlay-tls.conf
This does not build, see below for the output. When omitting the overlay for TLS, the build works. What do I have to change to make it work?
Thanks, Thomas
-- Application: /home/tludwig/ncs/v2.3.0-rc1/zephyr/samples/net/sockets/echo_client
-- Using NCS Toolchain 2.2.0 for building. (/home/tludwig/ncs/toolchains/v2.2.0/cmake)
-- Found Python3: /home/tludwig/ncs/toolchains/v2.2.0/usr/local/bin/python3 (found suitable exact version "3.8.10") found components: Interpreter
-- Cache files will be written to: /home/tludwig/.cache/zephyr
-- Zephyr version: 3.2.99 (/home/tludwig/ncs/v2.3.0-rc1/zephyr)
-- Found west (found suitable version "0.13.1", minimum required is "0.7.1")
-- Board: thingy91_nrf9160_ns
-- Found host-tools: zephyr 0.15.2 (/home/tludwig/ncs/toolchains/v2.3.0-rc1/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.15.2 (/home/tludwig/ncs/toolchains/v2.3.0-rc1/opt/zephyr-sdk)
-- Found Dtc: /home/tludwig/ncs/toolchains/v2.2.0/usr/local/bin/dtc (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: /home/tludwig/ncs/v2.3.0-rc1/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_ns.dts
-- Generated zephyr.dts: /home/tludwig/ncs/v2.3.0-rc1/zephyr/samples/net/sockets/echo_client/build/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /home/tludwig/ncs/v2.3.0-rc1/zephyr/samples/net/sockets/echo_client/build/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: /home/tludwig/ncs/v2.3.0-rc1/zephyr/samples/net/sockets/echo_client/build/zephyr/dts.cmake
warning: MBEDTLS_SSL_MAX_CONTENT_LEN (defined at modules/mbedtls/Kconfig:69,
modules/mbedtls/Kconfig:69) was assigned the value '2048' but got the value ''. Check these
unsatisfied dependencies: ((MBEDTLS_BUILTIN && MBEDTLS) || (MBEDTLS_BUILTIN && MBEDTLS && 0)) (=n).
See docs.zephyrproject.org/.../kconfig.html and/or look
up MBEDTLS_SSL_MAX_CONTENT_LEN in the menuconfig/guiconfig interface. The Application Development
Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
might be helpful too.
warning: TEST_RANDOM_GENERATOR (defined at subsys/random/Kconfig:8) was assigned the value 'y' but
got the value 'n'. Check these unsatisfied dependencies: (!ENTROPY_HAS_DRIVER) (=n). See
docs.zephyrproject.org/.../kconfig.html and/or look up
TEST_RANDOM_GENERATOR in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
warning: The choice symbol MBEDTLS_BUILTIN (defined at modules/mbedtls/Kconfig:27,
modules/mbedtls/Kconfig:27) was selected (set =y), but MBEDTLS_LIBRARY_NRF_SECURITY (defined at
/home/tludwig/ncs/v2.3.0-rc1/nrf/Kconfig.nrf:31) ended up as the choice selection. See
MBEDTLS_BUILTIN in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
warning: Experimental symbol NET_SOCKETS_SOCKOPT_TLS is enabled.
warning: Experimental symbol NET_SOCKETS_ENABLE_DTLS is enabled.
warning: Experimental symbol NET_CONNECTION_MANAGER is enabled.
warning: MBEDTLS_DTLS (defined at modules/mbedtls/Kconfig.tls-generic:34, /home/tludwig/ncs/v2.3.0-rc1/nrfxlib/nrf_security/Kconfig:120, modules/mbedtls/Kconfig.tls-generic:34) has direct dependencies ((MBEDTLS_TLS_VERSION_1_1 || MBEDTLS_TLS_VERSION_1_2) && !(NRF_SECURITY || NORDIC_SECURITY_BACKEND) && MBEDTLS_BUILTIN && MBEDTLS_CFG_FILE = "config-tls-generic.h" && MBEDTLS) || ((MBEDTLS_TLS_VERSION_1_2 || MBEDTLS_SSL_PROTO_TLS1_2) && !MBEDTLS_BUILTIN) || ((MBEDTLS_TLS_VERSION_1_1 || MBEDTLS_TLS_VERSION_1_2) && !(NRF_SECURITY || NORDIC_SECURITY_BACKEND) && MBEDTLS_BUILTIN && MBEDTLS_CFG_FILE = "config-tls-generic.h" && MBEDTLS && 0) with value n, but is currently being y-selected by the following symbols:
- NET_SOCKETS_ENABLE_DTLS (defined at subsys/net/lib/sockets/Kconfig:99), with value y, direct dependencies NET_SOCKETS_SOCKOPT_TLS && NET_SOCKETS && NETWORKING (value: y), and select condition NET_NATIVE && NET_SOCKETS_SOCKOPT_TLS && NET_SOCKETS && NETWORKING (value: y)
Parsing /home/tludwig/ncs/v2.3.0-rc1/zephyr/samples/net/sockets/echo_client/Kconfig
Loaded configuration '/home/tludwig/ncs/v2.3.0-rc1/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_ns_defconfig'
Merged configuration '/home/tludwig/ncs/v2.3.0-rc1/zephyr/samples/net/sockets/echo_client/prj.conf'
Merged configuration '/home/tludwig/ncs/v2.3.0-rc1/zephyr/samples/net/sockets/echo_client/overlay-tls.conf'
error: Aborting due to Kconfig warnings
CMake Error at /home/tludwig/ncs/v2.3.0-rc1/zephyr/cmake/modules/kconfig.cmake:328 (message):
command failed with return code: 1
/home/tludwig/ncs/v2.3.0-rc1/nrf/cmake/modules/kconfig.cmake:29 (include)
/home/tludwig/ncs/v2.3.0-rc1/zephyr/cmake/modules/zephyr_default.cmake:108 (include)
/home/tludwig/ncs/v2.3.0-rc1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
/home/tludwig/ncs/v2.3.0-rc1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
CMakeLists.txt:5 (find_package)
FATAL ERROR: command exited with status 1: /home/tludwig/ncs/toolchains/v2.3.0-rc1/usr/local/bin/cmake -DWEST_PYTHON=/home/tludwig/ncs/toolchains/v2.3.0-rc1/usr/local/bin/python3.8 -B/home/tludwig/ncs/v2.3.0-rc1/zephyr/samples/net/sockets/echo_client/build -GNinja -DBOARD=thingy91_nrf9160_ns -DOVERLAY_CONFIG=overlay-tls.conf -S/home/tludwig/ncs/v2.3.0-rc1/zephyr/samples/net/sockets/echo_client
  • you may also try to ask about the zephyr/mbedtls setup in https://github.com/zephyrproject-rtos/zephyr/issues maybe you can get some hints there.
  • Hi Achim,
    Thanks for your help. I tried to disable renegotiation on the openssl s_server but had no success. Actually I now think the problem might not be related to renegotiation (I think a saw this once but I am not sure anymore). Below is the trace output.
    The OpenSSL version is 3.0.2.
    If you think it might help I can pare down my test project, convert it from C++ to C, and provide it.
    Thomas
    openssl s_server -dtls1_2 -accept 8741 -nocert -psk "01020304050607080901020304050607" --psk_identity "urn:imei:352656100832081" --psk_hint "My server" -state -trace
    Using default temp DH parameters
    ACCEPT
    SSL_accept:before SSL initialization
    Received Record
    Header:
      Version = DTLS 1.0 (0xfeff)
      epoch=0, sequence_number=000000000000
      Content Type = Handshake (22)
      Length = 102
        ClientHello, Length=90
        message_seq=0, fragment_offset=0, fragment_length=90
          client_version=0xfefd (DTLS 1.2)
          Random:
            gmt_unix_time=0x64105599
            random_bytes (len=28): 6D78E360223007C254431787FE1BEBEFBB5B9CD4985A9F22E1E41E8F
          session_id (len=0):
          cookie (len=0):
          cipher_suites (len=10)
            {0x00, 0x8D} TLS_PSK_WITH_AES_256_CBC_SHA
            {0x00, 0xAE} TLS_PSK_WITH_AES_128_CBC_SHA256
            {0x00, 0x8C} TLS_PSK_WITH_AES_128_CBC_SHA
            {0xC0, 0xA8} TLS_PSK_WITH_AES_128_CCM_8
            {0x00, 0xFF} TLS_EMPTY_RENEGOTIATION_INFO_SCSV
          compression_methods (len=1)
            No Compression (0x00)
          extensions, length = 38
            extension_type=server_name(0), length=8
              0000 - 00 06 00 00 03 4d 79 20-                       .....My
            extension_type=signature_algorithms(13), length=22
              ecdsa_secp521r1_sha512 (0x0603)
              rsa_pkcs1_sha512 (0x0601)
              ecdsa_secp384r1_sha384 (0x0503)
              rsa_pkcs1_sha384 (0x0501)
              ecdsa_secp256r1_sha256 (0x0403)
              rsa_pkcs1_sha256 (0x0401)
              ecdsa_sha224 (0x0303)
              rsa_pkcs1_sha224 (0x0301)
              ecdsa_sha1 (0x0203)
              rsa_pkcs1_sha1 (0x0201)
    SSL_accept:SSLv3/TLS read client hello
    Sent Record
    Header:
      Length = 35
        HelloVerifyRequest, Length=23
        message_seq=0, fragment_offset=0, fragment_length=23
          server_version=0xfeff (DTLS 1.0)
          cookie (len=20): 23807D2FEDC49B40CB389470DEE8B94C6D4DCDE4
    SSL_accept:DTLS1 write hello verify request
    Received Record
    Header:
      epoch=0, sequence_number=000000000001
      Length = 122
        ClientHello, Length=110
        message_seq=1, fragment_offset=0, fragment_length=110
          Random:
          session_id (len=0):
              ecdsa_sha1 (0x0203)
    Sent Record
    Header:
      Version = DTLS 1.2 (0xfefd)
      Length = 89
        ServerHello, Length=77
        message_seq=1, fragment_offset=0, fragment_length=77
          server_version=0xfefd (DTLS 1.2)
          Random:
            gmt_unix_time=0xD18BFE20
            random_bytes (len=28): CD6A0BB158AAA933CD71A6969BF3E4FB911BBCA829B92E2EAAC03C8F
          session_id (len=32): 7538C692C87FE845B2CFEE4FCB8283371242EC1CAB5DA00DD97B5ECB48A6C9B8
          cipher_suite {0x00, 0x8D} TLS_PSK_WITH_AES_256_CBC_SHA
          compression_method: No Compression (0x00)
          extensions, length = 5
            extension_type=renegotiate(65281), length=1
                <EMPTY>
    SSL_accept:SSLv3/TLS write server hello
    Sent Record
    Header:
      epoch=0, sequence_number=000000000002
      Length = 23
        ServerKeyExchange, Length=11
        message_seq=2, fragment_offset=0, fragment_length=11
          KeyExchangeAlgorithm=PSK
            psk_identity_hint (len=9): 4D7920736572766572
    SSL_accept:SSLv3/TLS write key exchange
    Sent Record
    Header:
      epoch=0, sequence_number=000000000003
      Length = 12
        ServerHelloDone, Length=0
        message_seq=3, fragment_offset=0, fragment_length=0
    SSL_accept:SSLv3/TLS write server done
    Received Record
    Header:
      Length = 38
        ClientKeyExchange, Length=26
        message_seq=2, fragment_offset=0, fragment_length=26
            psk_identity (len=24): 75726E3A696D65693A333532363536313030383332303831
    Received Record
    Header:
      Content Type = ChangeCipherSpec (20)
      Length = 1
        change_cipher_spec (1)
    SSL_accept:SSLv3/TLS read client key exchange
    Received Record
    Header:
      epoch=1, sequence_number=000000000000
      Length = 64
    Sent Record
    Header:
      epoch=0, sequence_number=000000000004
      Length = 89
          Random:
                <EMPTY>
    Sent Record
    Header:
      epoch=0, sequence_number=000000000005
      Length = 23
    Sent Record
    Header:
      epoch=0, sequence_number=000000000006
      Length = 12
    Received Record
    Header:
      Length = 38
    Received Record
    Header:
      Length = 1
    Received Record
    Header:
      epoch=1, sequence_number=000000000001
      Length = 64
    Received Record
    Header:
      Length = 38
    Received Record
    Header:
      epoch=0, sequence_number=000000000007
      Length = 1
    Received Record
    Header:
      epoch=1, sequence_number=000000000002
      Length = 64
    Sent Record
    Header:
      Length = 89
          Random:
                <EMPTY>
    Sent Record
    Header:
      epoch=0, sequence_number=000000000008
      Length = 23
    Sent Record
    Header:
      epoch=0, sequence_number=000000000009
      Length = 12
    Received Record
    Header:
      Length = 38
    Received Record
    Header:
      Length = 1
    Received Record
    Header:
      epoch=1, sequence_number=000000000003
      Length = 64
    Received Record
    Header:
      epoch=0, sequence_number=00000000000a
      Length = 38
    Received Record
    Header:
      epoch=0, sequence_number=00000000000b
      Length = 1
    Received Record
    Header:
      epoch=1, sequence_number=000000000004
      Length = 64
    Sent Record
    Header:
      Length = 89
          Random:
                <EMPTY>
    Sent Record
    Header:
      Length = 23
    Sent Record
    Header:
      epoch=0, sequence_number=00000000000c
      Length = 12
    Received Record
    Header:
      Length = 38
    Received Record
    Header:
      epoch=0, sequence_number=00000000000d
      Length = 1
    Received Record
    Header:
      epoch=1, sequence_number=000000000005
      Length = 64
    Received Record
    Header:
      epoch=0, sequence_number=00000000000e
      Length = 38
    Received Record
    Header:
      epoch=0, sequence_number=00000000000f
      Length = 1
    Received Record
    Header:
      epoch=1, sequence_number=000000000006
      Length = 64
    Sent Record
    Header:
      Length = 89
          Random:
                <EMPTY>
    Sent Record
    Header:
      Length = 23
    Sent Record
    Header:
      Length = 12
    Received Record
    Header:
      epoch=0, sequence_number=000000000010
      Length = 38
    Received Record
    Header:
      epoch=0, sequence_number=000000000011
      Length = 1
    Received Record
    Header:
      epoch=1, sequence_number=000000000007
      Length = 64
  • My guess: transmission timeout issue.
    The server retransmits the server_hello on receiving the clients flight.
    It's easier to check "wireshark captures". Some time ago I write a guide for that, see https://github.com/eclipse-californium/californium/wiki/Logs-and-IP-Capturing-%E2%80%90-How-To-Provide-The-Right-Information#ip-capturing
    My hint about RFC5746 is more based on my "long years experience" with PSK issues (I'm one developer of Eclispe/Californium and Eclispe/tinydtls, and so I handled a couple of "PSK is not working issues :-). The last was RFC 5746.
  • ClientHello
    With that the client is RFC5746 compliant, so no need to use -legacy_renegotiation.
  • I appreciate your longtime experience with DTLS; it is a complicated subject indeed.
    Concerning the timeouts, here is the wireshark output.
    No.     Time            Source         Destination    Protocol   Length  Info
    23146   25.438375165    modem_iaddr    server_iaddr   DTLSv1.2   145     Client Hello
    23147   25.439115290    server_iaddr   modem_iaddr    DTLSv1.2   90      Hello Verify Request
    23251   25.592824864    modem_iaddr    server_iaddr   DTLSv1.2   165     Client Hello
    23252   25.593403772    server_iaddr   modem_iaddr    DTLSv1.2   205     Server Hello, Server Key Exchange, Server Hello Done
    23261   25.847556073    modem_iaddr    server_iaddr   DTLSv1.2   184     Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    25047   26.614250327    server_iaddr   modem_iaddr    DTLSv1.2   144     Server Hello
    25048   26.614379464    server_iaddr   modem_iaddr    DTLSv1.2   78      Server Key Exchange
    25049   26.614466025    server_iaddr   modem_iaddr    DTLSv1.2   67      Server Hello Done
    32985   27.519012708    modem_iaddr    server_iaddr   DTLSv1.2   184     Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    36243   28.180647865    modem_iaddr    server_iaddr   DTLSv1.2   184     Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    36246   28.630243159    server_iaddr   modem_iaddr    DTLSv1.2   144     Server Hello
    36247   28.630322557    server_iaddr   modem_iaddr    DTLSv1.2   78      Server Key Exchange
    36248   28.630371468    server_iaddr   modem_iaddr    DTLSv1.2   67      Server Hello Done
    37892   28.999876157    modem_iaddr    server_iaddr   DTLSv1.2   184     Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    40162   32.854262859    server_iaddr   modem_iaddr    DTLSv1.2   144     Server Hello
    40163   32.854323677    server_iaddr   modem_iaddr    DTLSv1.2   78      Server Key Exchange
    40164   32.854371348    server_iaddr   modem_iaddr    DTLSv1.2   67      Server Hello Done
    42164   35.101685272    modem_iaddr    server_iaddr   DTLSv1.2   184     Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    44148   37.007838038    modem_iaddr    server_iaddr   DTLSv1.2   184     Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    46465   41.046292415    server_iaddr   modem_iaddr    DTLSv1.2   144     Server Hello
    46466   41.046395467    server_iaddr   modem_iaddr    DTLSv1.2   78      Server Key Exchange
    46467   41.046472979    server_iaddr   modem_iaddr    DTLSv1.2   67      Server Hello Done
    48953   46.229800699    modem_iaddr    server_iaddr   DTLSv1.2   184     Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    50963   48.541785982    modem_iaddr    server_iaddr   DTLSv1.2   184     Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
    53974   57.174280969    server_iaddr   modem_iaddr    DTLSv1.2   144     Server Hello
    53975   57.174368081    server_iaddr   modem_iaddr    DTLSv1.2   78      Server Key Exchange
    53976   57.174413149    server_iaddr   modem_iaddr    DTLSv1.2   67      Server Hello Done
    54135   57.803507632    modem_iaddr    server_iaddr   DTLSv1.2   184     Client Key Exchange, Change Cipher Spec, Encrypted Handshake Message
