Test scripts are in python. Running on version 2.1.0 and older nRF52-DK boards; but not on the new version 3.0.0 boards that have the new MCU.
Hi Simon,
I figured it out. The boards are shipped with Flash in protected mode. So the python scripts could update the FW. But I was able to use the RSSI Viewer to reset the protection mode. Using the lower com port worked!
Thanks for your help!
Best Regards,
Raymond Yen
That only worked on one board :-( There's still a problem!
Okay, the Readback protection on the device is enabled, causing the problem. Is there a way to disable this?
Hi
Please try doing calling nrfjprog --recover in your command line. This should do erase the flash of the SoC on the nRF52 DK, and also disable the readback protection.
Simon
Hi Simon,
Thanks! But it is not permanent. Do you have to do it every time after power on?
Best Regards,
Raymond
