case about nRF9160 AT cmd AT%XRFTEST=1,1,28,7480,17,0,3,12,0,0,0,0,0 failed
Why does setting this frequency fail to transmit
Thank you for all your assistance.
Peter.Min
    The error we both observed is not an actual error, but it comes up as an error when frequency values are not properly chosen. Chapter 5.7.3 of the ETSI TS 136 101 V14.22.0 Rel 14 specifies the formula for calculating the UL frequency. For example, for band 1 this would give value of 1979.9 MHz and for band 28 the value would be 747.9 MHz. Therefore, the command that you used for band 28 should not be done with value 7480, but with the value 7479 for the UL upper bound. I have tested this myself and it worked on my side. Please note that it is up to the user to correctly make limitations for the transmission frequency.
    Dejan
  • Hi dejans,
    Very clear answer
    Peter.Min
