PStorage Event Handler Problems
Hello!
I have been experiencing some trouble with the PStorage API. I have browsed every example and similar question I can find and none seem to match the continuing issues that I am having.
I have been very sure to register the pstorage event handler:
    static void sys_evt_dispatch(uint32_t sys_evt)
    if ((sys_evt == NRF_EVT_FLASH_OPERATION_SUCCESS) ||
            (sys_evt == NRF_EVT_FLASH_OPERATION_ERROR)) {
        pstorage_sys_event_handler(sys_evt);
When I call on my functions to store or clear in pstorage, the pstorage events handler is never called, and as such no callback is sent and the queue element is not eliminated. As a temporary workaround, for the purposes of testing further, I made a small function to be called after my first store operation had actually written to memory.
 void cheap_trick(void){
	pstorage_sys_event_handler(NRF_EVT_FLASH_OPERATION_SUCCESS);
This allowed me, after having checked the write actually completed with a quick load operation, to simulate the event that the handler should be getting passed and remove it from the queue as it should be on completion, this was confirmed by running pstorage_access_status_get() showing 0 operations left in the queue.
However, the subsequent store operation is queued but fails to even write to the memory, even though in debugging I can see that it calls sd_flash_write() and returns NRF_SUCCESS there.
In addition I have called sd_flash_write()directly twice in a row to the first 4 then second 4 bytes of the pstorage block area, the first write succeeds and the second does not and using sd_evt_get() neither of these operation appears to be giving the NRF_EVT_FLASH_OPERATION_SUCCESS event on completion.
Is there somthing I could have missed in the setup of PStorage or could there be a problem in the Softdevice itself? I welcome all suggestions regarding solving this problem!
Chris
