External library compiles, but linking
I'm using Windows 11, WSL2, VSCode extension, NCS v2.
I am trying to build an application against a library which is outside the application folder.  It seems to compile correctly, but linking isn't working.  Can you tell me how to set up my build environment to get this to work?
Here is the folder structure.  The git/app/BikeControlBoard folder is the application.  The git/lib is the library root folder.  There are many sub-directories of the git/lib folder.
git
├── README.md
├── app
│   └── BikeControlBoard
│       ├── CMakeLists.txt
│       ├── app.overlay
│       ├── prj.conf
│       └── src
│           ├── main.cpp
│           └── test.h
├── lib
│   ├── Kconfig
│   ├── app
│   │   ├── App.h
│   │   ├── Application.h
│   │   └── CMakeLists.txt
│   ├── ble
│   └── zephyr
│       └── module.yml
The git/app/BikeControlBoard/CMakeLists.txt is this:
cmake_minimum_required(VERSION 3.20.0)
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
add_subdirectory(${CMAKE_CURRENT_SOURCE_DIR}/../../lib build)
project(app)
target_sources(app PRIVATE
    src/main.cpp
The git/lib/CMakeLists.txt is this:
add_subdirectory(app)
add_subdirectory(ble)
zephyr_include_directories(.)
file(GLOB lib_sources *.cpp)
if (lib_sources)
  zephyr_library()
  zephyr_library_sources(
    ${lib_sources}
endif()
The git/lib/app/CMakeLists.txt, and all other sub-directories of git/lib, is this:
if (lib_sources)
  zephyr_library()
    ${lib_sources}
endif()
The full build log is this:
 *  Executing task: nRF Connect: Build [pristine]: BikeControlBoard/build (active)
Building BikeControlBoard
west build --build-dir /home/doug/git/nRF52/app/BikeControlBoard/build /home/doug/git/nRF52/app/BikeControlBoard --pristine --board adafruit_feather_nrf52840 -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONFIG_DEBUG_OPTIMIZATIONS:STRING="y" -DCONFIG_DEBUG_THREAD_INFO:STRING="y" -DDTC_OVERLAY_FILE:STRING="/home/doug/git/nRF52/app/BikeControlBoard/app.overlay" -DCONF_FILE:STRING="/home/doug/git/nRF52/app/BikeControlBoard/prj.conf"
-- Application: /home/doug/git/nRF52/app/BikeControlBoard
-- Found Python3: /home/doug/ncs/toolchains/v2.0.0/usr/local/bin/python3.8 (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: /home/doug/.cache/zephyr
-- Zephyr version: 3.0.99 (/home/doug/ncs/v2.0.0/zephyr)
-- Found west (found suitable version "0.13.1", minimum required is "0.7.1")
-- Board: adafruit_feather_nrf52840
-- Found host-tools: zephyr 0.14.1 (/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk)
-- Found dtc: /home/doug/ncs/toolchains/v2.0.0/usr/bin/dtc (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: zephyr 0.14.1 (/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk)
-- Found BOARD.dts: /home/doug/ncs/v2.0.0/zephyr/boards/arm/adafruit_feather_nrf52840/adafruit_feather_nrf52840.dts
-- Found devicetree overlay: /home/doug/git/nRF52/app/BikeControlBoard/app.overlay
-- Generated zephyr.dts: /home/doug/git/nRF52/app/BikeControlBoard/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /home/doug/git/nRF52/app/BikeControlBoard/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: /home/doug/git/nRF52/app/BikeControlBoard/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: /home/doug/git/nRF52/app/BikeControlBoard/build/zephyr/dts.cmake
Parsing /home/doug/ncs/v2.0.0/zephyr/Kconfig
Loaded configuration '/home/doug/ncs/v2.0.0/zephyr/boards/arm/adafruit_feather_nrf52840/adafruit_feather_nrf52840_defconfig'
Merged configuration '/home/doug/git/nRF52/app/BikeControlBoard/prj.conf'
Merged configuration '/home/doug/git/nRF52/app/BikeControlBoard/build/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to '/home/doug/git/nRF52/app/BikeControlBoard/build/zephyr/.config'
Kconfig header saved to '/home/doug/git/nRF52/app/BikeControlBoard/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 10.3.0
-- The CXX compiler identification is GNU 10.3.0
-- Found assembler: /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
CMake Warning at /home/doug/ncs/v2.0.0/zephyr/subsys/bluetooth/host/CMakeLists.txt:103 (message):
  CONFIG_BT_FIXED_PASSKEY is enabled
    A fixed passkey is easy to deduce during the pairing procedure, do not use in
    production.
CMake Warning at /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/CMakeLists.txt:22 (message):
  CONFIG_USB_DEVICE_VID has default value 0x2FE3.
  This value is only for testing and MUST be configured for USB products.
CMake Warning at /home/doug/ncs/v2.0.0/zephyr/CMakeLists.txt:1803 (message):
-- Configuring done
-- Generating done
-- Build files have been written to: /home/doug/git/nRF52/app/BikeControlBoard/build
[1/282] Preparing syscall dependency handling
[2/282] Generating include/generated/version.h
-- Zephyr version: 3.0.99 (/home/doug/ncs/v2.0.0/zephyr), build: v3.0.99-ncs1
[3/282] Generating misc/generated/syscalls_subdirs.trigger
[4/282] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[5/282] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[6/282] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[7/282] Generating include/generated/driver-validation.h
[8/282] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[9/282] Generating include/generated/offsets.h
[10/282] Building CXX object build/peripheral/CMakeFiles/..__..__..__git__nRF52__lib__peripheral.dir/Pin.cpp.obj
[11/282] Building CXX object build/mpsl/CMakeFiles/..__..__..__git__nRF52__lib__mpsl.dir/MpslSession.cpp.obj
[12/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[13/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[14/282] Building CXX object CMakeFiles/app.dir/src/main.cpp.obj
[15/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[16/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[17/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[18/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[19/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[20/282] Building CXX object build/service/CMakeFiles/..__..__..__git__nRF52__lib__service.dir/Shell.cpp.obj
[21/282] Building CXX object build/mpsl/CMakeFiles/..__..__..__git__nRF52__lib__mpsl.dir/MPSL.cpp.obj
[22/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[23/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[24/282] Building CXX object build/ble/CMakeFiles/..__..__..__git__nRF52__lib__ble.dir/BleScanner.cpp.obj
[25/282] Building CXX object build/evm/CMakeFiles/..__..__..__git__nRF52__lib__evm.dir/Evm.cpp.obj
[26/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[27/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[28/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[29/282] Building CXX object build/ble/CMakeFiles/..__..__..__git__nRF52__lib__ble.dir/Ble.cpp.obj
[30/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[31/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[32/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[33/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
[34/282] Building CXX object build/evm/CMakeFiles/..__..__..__git__nRF52__lib__evm.dir/TimedEventHandler.cpp.obj
[35/282] Linking CXX static library app/libapp.a
[36/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[37/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[38/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[39/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[40/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[41/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/ring_buffer.c.obj
[42/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[43/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[44/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/util/fnmatch/fnmatch.c.obj
[45/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj
[46/282] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[47/282] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[48/282] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[49/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_list.c.obj
[50/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/debug/thread_info.c.obj
[51/282] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[52/282] Building CXX object build/service/CMakeFiles/..__..__..__git__nRF52__lib__service.dir/Log.cpp.obj
[53/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_core.c.obj
[54/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_msg.c.obj
[55/282] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[56/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_output.c.obj
[57/282] Building CXX object build/service/CMakeFiles/..__..__..__git__nRF52__lib__service.dir/Work.cpp.obj
[58/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_msg2.c.obj
[59/282] Building CXX object build/peripheral/CMakeFiles/..__..__..__git__nRF52__lib__peripheral.dir/PAL.cpp.obj
/home/doug/git/nRF52/lib/peripheral/PAL.cpp:15:13: warning: 'void approtect_hw_disable()' defined but not used [-Wunused-function]
   15 | static void approtect_hw_disable(void)
[60/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_mgmt.c.obj
[61/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/backends/shell_uart.c.obj
[62/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_backend_swo.c.obj
[63/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell.c.obj
[64/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/modules/device_service.c.obj
[65/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_cmds.c.obj
[66/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/modules/kernel_service.c.obj
[67/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/modules/devmem_service.c.obj
[68/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_fprintf.c.obj
[69/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_utils.c.obj
[70/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_ops.c.obj
[71/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_init_array.c.obj
[72/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_init.c.obj
[73/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_dtors.c.obj
[74/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_help.c.obj
[75/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_log_backend.c.obj
[76/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_cmds.c.obj
[77/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_history.c.obj
[78/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_wildcard.c.obj
[79/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_ctors.c.obj
[80/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/utils/addr_utils.c.obj
[81/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/disk/disk_access.c.obj
[82/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/nvs/nvs.c.obj
[83/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/usb_device.c.obj
[84/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/class/msc.c.obj
[85/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/usb_descriptor.c.obj
[86/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
[87/282] Building CXX object build/utl/CMakeFiles/..__..__..__git__nRF52__lib__utl.dir/Timeline.cpp.obj
[88/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/usb_transfer.c.obj
[89/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_default.c.obj
[90/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
[91/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_store.c.obj
[92/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[93/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings.c.obj
[94/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_nvs.c.obj
[95/282] Building C object zephyr/CMakeFiles/zephyr.dir/home/doug/ncs/v2.0.0/modules/crypto/tinycrypt/lib/source/aes_decrypt.c.obj
[96/282] Building C object zephyr/CMakeFiles/zephyr.dir/home/doug/ncs/v2.0.0/modules/crypto/tinycrypt/lib/source/utils.c.obj
[97/282] Building C object zephyr/CMakeFiles/zephyr.dir/home/doug/ncs/v2.0.0/modules/crypto/tinycrypt/lib/source/aes_encrypt.c.obj
[98/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_init.c.obj
[99/282] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_line.c.obj
[100/282] Building C object zephyr/CMakeFiles/zephyr.dir/home/doug/ncs/v2.0.0/modules/crypto/tinycrypt/lib/source/cmac_mode.c.obj
[101/282] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[102/282] Building C object zephyr/CMakeFiles/zephyr.dir/home/doug/ncs/v2.0.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
[103/282] Building C object zephyr/CMakeFiles/zephyr.dir/home/doug/ncs/v2.0.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
[104/282] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[105/282] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[106/282] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[107/282] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[108/282] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[109/282] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[110/282] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[111/282] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[112/282] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[113/282] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[114/282] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[115/282] Linking C static library zephyr/arch/common/libisr_tables.a
[116/282] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/__aeabi_atexit.c.obj
[117/282] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[118/282] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[119/282] Generating linker_zephyr_pre0.cmd
[120/282] Generating linker_zephyr_pre1.cmd
[121/282] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[122/282] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[123/282] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[124/282] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[125/282] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[126/282] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[127/282] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[128/282] Linking C static library zephyr/libzephyr.a
[129/282] Linking C static library zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a
[130/282] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
[131/282] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
[132/282] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
[133/282] Linking C static library zephyr/arch/common/libarch__common.a
[134/282] Building C object zephyr/lib/libc/newlib/CMakeFiles/lib__libc__newlib.dir/libc-hooks.c.obj
[135/282] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
[136/282] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
[137/282] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/soc.c.obj
[138/282] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/dummy.c.obj
[139/282] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/uuid.c.obj
[140/282] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
[141/282] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/log.c.obj
[142/282] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/addr.c.obj
[143/282] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[144/282] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/rpa.c.obj
[145/282] Linking C static library zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a
[146/282] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a
[147/282] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/settings.c.obj
[148/282] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_core.c.obj
[149/282] Linking C static library zephyr/lib/libc/newlib/liblib__libc__newlib.a
[150/282] Linking C static library zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a
[151/282] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/buf.c.obj
[152/282] Linking C static library zephyr/lib/posix/liblib__posix.a
[153/282] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_common.c.obj
[154/282] Linking C static library zephyr/drivers/console/libdrivers__console.a
[155/282] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/id.c.obj
[156/282] Linking C static library zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a
[157/282] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/adv.c.obj
[158/282] Linking C static library zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a
[159/282] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/scan.c.obj
[160/282] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/conn.c.obj
[161/282] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/l2cap.c.obj
[162/282] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/att.c.obj
[163/282] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/ecc.c.obj
[164/282] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/gatt.c.obj
[165/282] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/smp.c.obj
[166/282] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/keys.c.obj
[167/282] Building C object zephyr/subsys/fs/CMakeFiles/subsys__fs.dir/fat_fs.c.obj
[168/282] Building C object zephyr/subsys/fs/CMakeFiles/subsys__fs.dir/fs.c.obj
[169/282] Building C object zephyr/subsys/fs/CMakeFiles/subsys__fs.dir/fs_impl.c.obj
[170/282] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/buf.c.obj
[171/282] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
[172/282] Building C object zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/ramdisk.c.obj
[173/282] Building C object zephyr/drivers/usb/device/CMakeFiles/drivers__usb__device.dir/usb_dc_nrfx.c.obj
[174/282] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
[175/282] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
[176/282] Building C object zephyr/drivers/pwm/CMakeFiles/drivers__pwm.dir/pwm_nrfx.c.obj
[177/282] Building C object zephyr/drivers/pwm/CMakeFiles/drivers__pwm.dir/pwm_shell.c.obj
[178/282] Building C object zephyr/drivers/hwinfo/CMakeFiles/drivers__hwinfo.dir/hwinfo_weak_impl.c.obj
[179/282] Building C object zephyr/drivers/hwinfo/CMakeFiles/drivers__hwinfo.dir/hwinfo_shell.c.obj
[180/282] Linking C static library zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a
[181/282] Building C object zephyr/drivers/hwinfo/CMakeFiles/drivers__hwinfo.dir/hwinfo_nrf.c.obj
[182/282] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
[183/282] Linking C static library zephyr/subsys/random/libsubsys__random.a
[184/282] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
[185/282] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uart.c.obj
[186/282] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_shell.c.obj
[187/282] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[188/282] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/entropy_nrf5.c.obj
[189/282] Linking C static library zephyr/drivers/usb/device/libdrivers__usb__device.a
[190/282] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
[191/282] Linking C static library zephyr/subsys/net/libsubsys__net.a
[192/282] Linking C static library zephyr/drivers/disk/libdrivers__disk.a
[193/282] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
[194/282] Linking C static library zephyr/subsys/fs/libsubsys__fs.a
[195/282] Linking C static library zephyr/drivers/pwm/libdrivers__pwm.a
[196/282] Building C object modules/nrf/lib/multithreading_lock/CMakeFiles/..__nrf__lib__multithreading_lock.dir/multithreading_lock.c.obj
[197/282] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
[198/282] Linking C static library zephyr/drivers/hwinfo/libdrivers__hwinfo.a
[199/282] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/home/doug/ncs/v2.0.0/nrf/drivers/entropy/entropy_cc3xx.c.obj
[200/282] Linking C static library zephyr/drivers/flash/libdrivers__flash.a
[201/282] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
[202/282] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a
[203/282] Linking C static library zephyr/drivers/serial/libdrivers__serial.a
[204/282] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
[205/282] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/crypto.c.obj
[206/282] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_driver.c.obj
[207/282] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
[208/282] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_internal.c.obj
[209/282] Building C object modules/nrf/subsys/esb/CMakeFiles/..__nrf__subsys__esb.dir/esb.c.obj
[210/282] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/ecdh.c.obj
[211/282] Linking C static library modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a
[212/282] Building C object modules/nrf/subsys/mpsl/init/CMakeFiles/..__nrf__subsys__mpsl__init.dir/mpsl_init.c.obj
[213/282] Linking C static library zephyr/drivers/entropy/libdrivers__entropy.a
[214/282] Building C object modules/nrf/drivers/mpsl/clock_control/CMakeFiles/..__nrf__drivers__mpsl__clock_control.dir/nrfx_clock_mpsl.c.obj
[215/282] Building C object modules/fatfs/CMakeFiles/..__modules__fs__fatfs.dir/ff.c.obj
[216/282] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/doug/ncs/v2.0.0/modules/hal/nordic/nrfx/mdk/system_nrf52840.c.obj
[217/282] Building C object modules/nrf/drivers/mpsl/flash_sync/CMakeFiles/..__nrf__drivers__mpsl__flash_sync.dir/flash_sync_mpsl.c.obj
[218/282] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
[219/282] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a
[220/282] Building C object modules/fatfs/CMakeFiles/..__modules__fs__fatfs.dir/zfs_diskio.c.obj
[221/282] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[222/282] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/doug/ncs/v2.0.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
[223/282] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/doug/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
[224/282] Linking C static library modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a
[225/282] Linking C static library modules/nrf/subsys/esb/lib..__nrf__subsys__esb.a
[226/282] Linking C static library modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a
[227/282] Linking C static library modules/nrf/subsys/mpsl/init/lib..__nrf__subsys__mpsl__init.a
[228/282] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/doug/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
[229/282] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/doug/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_power.c.obj
[230/282] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/doug/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_ppi.c.obj
[231/282] Linking C static library modules/nrf/drivers/mpsl/flash_sync/lib..__nrf__drivers__mpsl__flash_sync.a
[232/282] Linking C static library modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a
[233/282] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/doug/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_pwm.c.obj
[234/282] Linking C static library modules/fatfs/lib..__modules__fs__fatfs.a
[235/282] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/doug/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_usbd.c.obj
[236/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
[237/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[238/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[239/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[240/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[241/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[242/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[243/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[244/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[245/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[246/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
[247/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
[248/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
[249/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
[250/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
[251/282] Linking C static library modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
[252/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
[253/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
[254/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
[255/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
[256/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
[257/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
[258/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
[259/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[260/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[261/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/poll.c.obj
[262/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/usage.c.obj
[263/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[264/282] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[265/282] Linking CXX static library build/evm/lib..__..__..__git__nRF52__lib__evm.a
[266/282] Linking CXX static library build/peripheral/lib..__..__..__git__nRF52__lib__peripheral.a
[267/282] Linking CXX static library build/utl/lib..__..__..__git__nRF52__lib__utl.a
[268/282] Linking CXX static library build/ble/lib..__..__..__git__nRF52__lib__ble.a
[269/282] Linking CXX static library build/service/lib..__..__..__git__nRF52__lib__service.a
[270/282] Linking CXX static library build/mpsl/lib..__..__..__git__nRF52__lib__mpsl.a
[271/282] Linking C static library zephyr/kernel/libkernel.a
[272/282] Linking CXX executable zephyr/zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
: && ccache /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-g++   zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  -fuse-ld=bfd  -Wl,-T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/home/doug/git/nRF52/app/BikeControlBoard/build/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a  zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a  zephyr/lib/libc/newlib/liblib__libc__newlib.a  zephyr/lib/posix/liblib__posix.a  zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a  zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a  zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a  zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a  zephyr/subsys/fs/libsubsys__fs.a  zephyr/subsys/net/libsubsys__net.a  zephyr/subsys/random/libsubsys__random.a  zephyr/drivers/disk/libdrivers__disk.a  zephyr/drivers/usb/device/libdrivers__usb__device.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/pwm/libdrivers__pwm.a  zephyr/drivers/hwinfo/libdrivers__hwinfo.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/entropy/libdrivers__entropy.a  zephyr/drivers/timer/libdrivers__timer.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a  modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a  modules/nrf/subsys/esb/lib..__nrf__subsys__esb.a  modules/nrf/subsys/mpsl/init/lib..__nrf__subsys__mpsl__init.a  modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a  modules/nrf/drivers/mpsl/flash_sync/lib..__nrf__drivers__mpsl__flash_sync.a  modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a  modules/fatfs/lib..__modules__fs__fatfs.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -L"/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/thumb/v7e-m/nofp"  -L/home/doug/git/nRF52/app/BikeControlBoard/build/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  /home/doug/ncs/v2.0.0/nrfxlib/crypto/nrf_oberon/lib/cortex-m4/soft-float/liboberon_3.0.11.a  -no-pie  -mcpu=cortex-m4  -mthumb  -mabi=aapcs  -mfp16-format=ieee  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -lstdc++  -lm  -Wl,-lc  -L"/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi"/lib/thumb/v7e-m/nofp  -u_printf_float  -Wl,-lgcc  -lc  -specs=nano.specs  /home/doug/ncs/v2.0.0/nrfxlib/mpsl/lib/cortex-m4/soft-float/libmpsl.a  /home/doug/ncs/v2.0.0/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m4/soft-float/no-interrupts/libnrf_cc310_platform_0.9.14.a  -lc  /home/doug/ncs/v2.0.0/nrfxlib/softdevice_controller/lib/cortex-m4/soft-float/libsoftdevice_controller_multirole.a && cd /home/doug/git/nRF52/app/BikeControlBoard/build/zephyr && /home/doug/ncs/toolchains/v2.0.0/usr/local/lib/python3.8/site-packages/cmake/data/bin/cmake -E echo
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::Start()::{lambda()#3}::operator()() const':
/home/doug/git/nRF52/lib/esb/Esb.h:306: undefined reference to `Log(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::Init()::{lambda()#4}::operator()() const':
/home/doug/git/nRF52/lib/esb/Esb.h:1055: undefined reference to `TimedEventHandler::DeRegisterForTimedEvent()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/esb/Esb.h:1050: undefined reference to `Log(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::Init()::{lambda()#6}::operator()() const':
/home/doug/git/nRF52/lib/esb/Esb.h:1092: undefined reference to `Timeline::ReportNow(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `__static_initialization_and_destruction_0(int, int)':
/home/doug/git/nRF52/lib/utl/Timeline.h:61: undefined reference to `Timeline::Timeline(char const*)'
/home/doug/git/nRF52/lib/mpsl/MPSL.h:121: undefined reference to `Timeline::Timeline(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::Init()::{lambda(std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >)#12}::operator()(std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >) const':
/home/doug/git/nRF52/lib/esb/Esb.h:1129: undefined reference to `Log(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::Stop()':
/home/doug/git/nRF52/lib/esb/Esb.h:323: undefined reference to `Timeline::Event(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/esb/Esb.h:329: undefined reference to `MpslSession::CloseSession()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `TimedEventHandler::~TimedEventHandler()':
/home/doug/git/nRF52/lib/evm/TimedEventHandler.h:41: undefined reference to `TimedEventHandler::DeRegisterForTimedEvent()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/evm/TimedEventHandler.h:41: undefined reference to `TimedEventHandler::DeRegisterForTimedEvent()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::~Esb()':
/home/doug/git/nRF52/lib/esb/Esb.h:68: undefined reference to `MpslSession::~MpslSession()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `RgbLedEffectsController::StopSampler()':
/home/doug/git/nRF52/lib/led/RgbLedEffectsController.h:384: undefined reference to `TimedEventHandler::DeRegisterForTimedEvent()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::OnMpslTimeslotEnd()':
/home/doug/git/nRF52/lib/esb/Esb.h:463: undefined reference to `Timeline::Event(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::StopModeRx()':
/home/doug/git/nRF52/lib/esb/Esb.h:493: undefined reference to `Timeline::Event(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::StopModeTx()':
/home/doug/git/nRF52/lib/esb/Esb.h:505: undefined reference to `Timeline::Event(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [2], int&>(char const (&) [2], int&)':
/home/doug/git/nRF52/lib/service/Log.h:132: undefined reference to `LogNNL(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/service/Log.h:133: undefined reference to `LogNNL(int)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/service/Log.h:134: undefined reference to `LogNNL()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::Init()::{lambda(std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >)#7}::operator()(std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >) const':
/home/doug/git/nRF52/lib/esb/Esb.h:1098: undefined reference to `Log(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::EnableTimeslotExtensions()':
/home/doug/git/nRF52/lib/esb/Esb.h:278: undefined reference to `MpslSession::EnableTimeslotExtensions()'
/home/doug/git/nRF52/lib/esb/Esb.h:1103: undefined reference to `Log(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::DisableTimeslotExtensions()':
/home/doug/git/nRF52/lib/esb/Esb.h:283: undefined reference to `MpslSession::DisableTimeslotExtensions()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [13], char const*&>(char const (&) [13], char const*&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/service/Log.h:133: undefined reference to `LogNNL(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [13], char const*>(char const (&) [13], char const*&&)':
/home/doug/git/nRF52/lib/service/Log.h:141: undefined reference to `LogNL()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [13], unsigned short&>(char const (&) [13], unsigned short&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/service/Log.h:133: undefined reference to `LogNNL(unsigned short)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [13], unsigned short&>(char const (&) [13], unsigned short&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [13], unsigned char&, char const (&) [2]>(char const (&) [13], unsigned char&, char const (&) [2])':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/service/Log.h:133: undefined reference to `LogNNL(unsigned char)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/service/Log.h:134: undefined reference to `LogNNL(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [13], unsigned char&, char const (&) [2]>(char const (&) [13], unsigned char&, char const (&) [2])':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [13], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&>(char const (&) [13], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/service/Log.h:133: undefined reference to `LogNNL(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [13], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >>(char const (&) [13], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [13], unsigned char&>(char const (&) [13], unsigned char&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [13], unsigned char&>(char const (&) [13], unsigned char&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [17], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&>(char const (&) [17], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [17], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >>(char const (&) [17], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [26], int&>(char const (&) [26], int&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [26], int&>(char const (&) [26], int&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [37], int&>(char const (&) [37], int&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [37], int&>(char const (&) [37], int&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [34], int&>(char const (&) [34], int&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [34], int&>(char const (&) [34], int&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [22], int&>(char const (&) [22], int&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [22], int&>(char const (&) [22], int&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::Init()::{lambda(std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >)#13}::operator()(std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >) const':
/home/doug/git/nRF52/lib/esb/Esb.h:1136: undefined reference to `Log(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::LiveModeChangeFromTxToRx()':
/home/doug/git/nRF52/lib/esb/Esb.h:510: undefined reference to `Timeline::Event(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::StartModeRx()':
/home/doug/git/nRF52/lib/esb/Esb.h:486: undefined reference to `Timeline::Event(char const*)'
/home/doug/git/nRF52/lib/esb/Esb.h:1141: undefined reference to `Log(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::LiveModeChangeFromRxToTx()':
/home/doug/git/nRF52/lib/esb/Esb.h:519: undefined reference to `Timeline::Event(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::StartModeTx()':
/home/doug/git/nRF52/lib/esb/Esb.h:499: undefined reference to `Timeline::Event(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::Send(Esb::Message&)':
/home/doug/git/nRF52/lib/esb/Esb.h:345: undefined reference to `Timeline::Event(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/esb/Esb.h:377: undefined reference to `Timeline::Event(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj):/home/doug/git/nRF52/lib/esb/Esb.h:356: more undefined references to `Timeline::Event(char const*)' follow
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [4], bool&, char const (&) [2]>(char const (&) [4], bool&, char const (&) [2])':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [4], bool&, char const (&) [2]>(char const (&) [4], bool&, char const (&) [2])':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [14], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, char const (&) [9]>(char const (&) [14], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, char const (&) [9])':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [14], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, char const (&) [9]>(char const (&) [14], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&&, char const (&) [9])':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [11], unsigned int&>(char const (&) [11], unsigned int&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/service/Log.h:133: undefined reference to `LogNNL(unsigned int)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [11], unsigned int&>(char const (&) [11], unsigned int&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [5], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&>(char const (&) [5], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [5], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >>(char const (&) [5], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [16], char const*&>(char const (&) [16], char const*&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [16], char const*>(char const (&) [16], char const*&&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [14], char const*&>(char const (&) [14], char const*&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [14], char const*>(char const (&) [14], char const*&&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [12], unsigned short&>(char const (&) [12], unsigned short&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [12], unsigned short&>(char const (&) [12], unsigned short&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [9], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&>(char const (&) [9], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [9], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >>(char const (&) [9], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [10], unsigned char&>(char const (&) [10], unsigned char&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [5], unsigned char&, char const (&) [10], unsigned char&>(char const (&) [5], unsigned char&, char const (&) [10], unsigned char&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [5], unsigned char, char const (&) [10], unsigned char>(char const (&) [5], unsigned char&&, char const (&) [10], unsigned char&&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [10], unsigned char&>(char const (&) [10], unsigned char&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [15], unsigned int&>(char const (&) [15], unsigned int&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [15], unsigned int&>(char const (&) [15], unsigned int&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [10], unsigned int&>(char const (&) [10], unsigned int&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [10], unsigned int&>(char const (&) [10], unsigned int&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::Init()::{lambda(std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >)#20}::operator()(std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >) const':
/home/doug/git/nRF52/lib/esb/Esb.h:1194: undefined reference to `PlatformAbstractionLayer::Micros()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/esb/Esb.h:1196: undefined reference to `TimedEventHandler::RegisterForTimedEvent(unsigned int)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [23], unsigned int&>(char const (&) [23], unsigned int&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [23], unsigned int>(char const (&) [23], unsigned int&&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [10], int&>(char const (&) [10], int&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [10], int>(char const (&) [10], int&&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::Init()::{lambda()#3}::operator()() const':
/home/doug/git/nRF52/lib/esb/Esb.h:1041: undefined reference to `TimedEventHandler::RegisterForTimedEvent(unsigned int)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::Start()':
/home/doug/git/nRF52/lib/esb/Esb.h:288: undefined reference to `Timeline::Event(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/esb/Esb.h:292: undefined reference to `Log(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/esb/Esb.h:302: undefined reference to `MpslSession::SetCbOnStart(std::function<void ()>)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/esb/Esb.h:303: undefined reference to `MpslSession::SetCbOnEnd(std::function<void ()>)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/esb/Esb.h:306: undefined reference to `MpslSession::SetCbOnNoMoreComing(std::function<void ()>)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/esb/Esb.h:308: undefined reference to `MpslSession::OpenSession()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/esb/Esb.h:315: undefined reference to `MpslSession::RequestTimeslots(unsigned int, unsigned int, bool)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::Init()::{lambda(std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >)#11}::operator()(std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >) const':
/home/doug/git/nRF52/lib/esb/Esb.h:1124: undefined reference to `Log(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/esb/Esb.h:323: undefined reference to `Timeline::Event(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::Report()':
/home/doug/git/nRF52/lib/esb/Esb.h:408: undefined reference to `Timeline::Report(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::EsbIsrEventHandler(esb_evt const*)':
/home/doug/git/nRF52/lib/esb/Esb.h:813: undefined reference to `Timeline::Event(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/esb/Esb.h:820: undefined reference to `Timeline::Event(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/esb/Esb.h:827: undefined reference to `Timeline::Event(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/esb/Esb.h:875: undefined reference to `Timeline::Event(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::OnEsbRx(esb_payload*)':
/home/doug/git/nRF52/lib/esb/Esb.h:533: undefined reference to `Evm::QueueWork(char const*, std::function<void ()>&&)'
/home/doug/git/nRF52/lib/esb/Esb.h:858: undefined reference to `Timeline::Event(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::OnMpslTimeslotStart()':
/home/doug/git/nRF52/lib/esb/Esb.h:439: undefined reference to `Timeline::Event(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<esb_payload>(esb_payload*)':
/home/doug/git/nRF52/lib/service/Log.h:119: undefined reference to `LogNNL(unsigned int)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [6], esb_payload*&>(char const (&) [6], esb_payload*&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [6], esb_payload*>(char const (&) [6], esb_payload*&&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [6], esb_payload*&>(char const (&) [6], esb_payload*&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<unsigned char [252]>(unsigned char (*) [252])':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [6], unsigned char (*&) [252]>(char const (&) [6], unsigned char (*&) [252])':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [6], unsigned char (*) [252]>(char const (&) [6], unsigned char (*&&) [252])':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<unsigned char>(unsigned char*)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [6], unsigned char (&) [252]>(char const (&) [6], unsigned char (&) [252])':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [6], unsigned char (&) [252]>(char const (&) [6], unsigned char (&) [252])':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Application::Run()':
/home/doug/git/nRF52/lib/app/Application.h:67: undefined reference to `Timeline::EnableCcGlobal()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/app/Application.h:68: undefined reference to `Timeline::Global()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/app/Application.h:68: undefined reference to `Timeline::SetMaxEvents(unsigned short)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/app/Application.h:70: undefined reference to `UartSelect(int)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/app/Application.h:71: undefined reference to `UartOut(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/app/Application.h:72: undefined reference to `UartSelect(int)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/app/Application.h:73: undefined reference to `UartOut(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/app/Application.h:75: undefined reference to `Log(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/app/Application.h:78: undefined reference to `PlatformAbstractionLayer::Delay(unsigned int)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::SetCbOnAssert(std::function<void ()>)':
/home/doug/git/nRF52/lib/esb/Esb.h:217: undefined reference to `MpslSession::SetCbOnAssert(std::function<void ()>)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::Init()':
/home/doug/git/nRF52/lib/esb/Esb.h:1095: undefined reference to `Shell::AddCommand(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::function<void (std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >)>, Shell::CmdOptions)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/esb/Esb.h:1108: undefined reference to `Shell::AddCommand(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::function<void (std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >)>, Shell::CmdOptions)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/esb/Esb.h:1113: undefined reference to `Shell::AddCommand(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::function<void (std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >)>, Shell::CmdOptions)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/esb/Esb.h:1118: undefined reference to `Shell::AddCommand(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::function<void (std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >)>, Shell::CmdOptions)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/esb/Esb.h:1123: undefined reference to `Shell::AddCommand(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::function<void (std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >)>, Shell::CmdOptions)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj):/home/doug/git/nRF52/lib/esb/Esb.h:1128: more undefined references to `Shell::AddCommand(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::function<void (std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >)>, Shell::CmdOptions)' follow
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::Esb()':
/home/doug/git/nRF52/lib/esb/Esb.h:166: undefined reference to `Timeline::Timeline(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/esb/Esb.h:167: undefined reference to `MpslSession::EnableTimeslotExtensions()'
/home/doug/git/nRF52/lib/esb/Esb.h:950: undefined reference to `vtable for MpslSession'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `App::App()':
/home/doug/git/nRF52/lib/app/App.h:27: undefined reference to `LogNL(unsigned char)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `App::SetThreadPriority()':
/home/doug/git/nRF52/lib/app/App.h:63: undefined reference to `PlatformAbstractionLayer::SetThreadPriority(int)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `App::SetupPin()':
/home/doug/git/nRF52/lib/app/App.h:68: undefined reference to `Pin::Init()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `App::SetupPAL()':
/home/doug/git/nRF52/lib/app/App.h:73: undefined reference to `PlatformAbstractionLayer::Init()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `App::SetupLog()':
/home/doug/git/nRF52/lib/app/App.h:78: undefined reference to `LogInit()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `App::SetupTimeline()':
/home/doug/git/nRF52/lib/app/App.h:83: undefined reference to `Timeline::Init()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/app/App.h:84: undefined reference to `Timeline::Global()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/app/App.h:84: undefined reference to `Timeline::SetMaxEvents(unsigned short)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `App::SetupEvm()':
/home/doug/git/nRF52/lib/app/App.h:89: undefined reference to `Evm::Init()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `App::SetupWork()':
/home/doug/git/nRF52/lib/app/App.h:94: undefined reference to `Work::Init()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `App::SetupBle()':
/home/doug/git/nRF52/lib/app/App.h:99: undefined reference to `Ble::Init()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `App::SetupMPSL()':
/home/doug/git/nRF52/lib/app/App.h:104: undefined reference to `MPSL::Init()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `App::SetupMpslSession()':
/home/doug/git/nRF52/lib/app/App.h:109: undefined reference to `MpslSession::Init()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Application::Application()':
/home/doug/git/nRF52/lib/app/Application.h:60: undefined reference to `Ble::CreateObserver()'
/home/doug/git/nRF52/lib/app/Application.h:63: undefined reference to `vtable for MpslSession'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [16], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, char const (&) [4]>(char const (&) [16], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, char const (&) [4])':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [7], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, char const (&) [16], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, char const (&) [4]>(char const (&) [7], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, char const (&) [16], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, char const (&) [4])':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [8], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, char const (&) [7], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, char const (&) [16], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, char const (&) [4]>(char const (&) [8], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, char const (&) [7], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, char const (&) [16], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, char const (&) [4])':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [8], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, char const (&) [7], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, char const (&) [16], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, char const (&) [4]>(char const (&) [8], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&&, char const (&) [7], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&&, char const (&) [16], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&&, char const (&) [4])':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::Init()::{lambda()#2}::operator()() const':
/home/doug/git/nRF52/lib/esb/Esb.h:995: undefined reference to `TimedEventHandler::RegisterForTimedEvent(unsigned int)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/esb/Esb.h:999: undefined reference to `PlatformAbstractionLayer::Micros()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/esb/Esb.h:1021: undefined reference to `TimedEventHandler::RegisterForTimedEvent(unsigned int)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/esb/Esb.h:1011: undefined reference to `LogNNL(char const*)'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/esb/Esb.h:1016: undefined reference to `LogNL()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [3], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&>(char const (&) [3], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [3], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, char const (&) [3], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&>(char const (&) [3], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, char const (&) [3], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void LogNNL<char const (&) [8], unsigned int&, char const (&) [3], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, char const (&) [3], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&>(char const (&) [8], unsigned int&, char const (&) [3], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, char const (&) [3], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `void Log<char const (&) [8], unsigned int, char const (&) [3], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, char const (&) [3], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >(char const (&) [8], unsigned int&&, char const (&) [3], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&&, char const (&) [3], std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&&)':
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.cpp.obj): in function `Esb::Init()::{lambda(Esb::Message)#5}::operator()(Esb::Message) const':
/home/doug/git/nRF52/lib/esb/Esb.h:1072: undefined reference to `LogNL()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/git/nRF52/lib/esb/Esb.h:1075: undefined reference to `LogNL()'
/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: modules/nrf/subsys/mpsl/init/lib..__nrf__subsys__mpsl__init.a(mpsl_init.c.obj): in function `m_assert_handler':
/home/doug/ncs/v2.0.0/nrf/subsys/mpsl/init/mpsl_init.c:116: undefined reference to `mpsl_assert_handle'
collect2: error: ld returned 1 exit status
FATAL ERROR: command exited with status 1: /home/doug/ncs/toolchains/v2.0.0/usr/local/bin/cmake --build /home/doug/git/nRF52/app/BikeControlBoard/build
 *  The terminal process terminated with exit code: 1.
I'm unclear on whether I should be using the add_subdirectory() cmake command in the application, or trying to call the library an ZEPHYR_EXTRA_MODULES.
The requirement for the library is:
  • The library is a mix of .h and .cpp files in each sub-folder
  • Any .h or .cpp file may try to include another .h file from that folder, or another sub-folder of lib
  • The application code may try to include any .h file from any sub-folder of lib
  • The whole thing has to compile at once and link together
Thanks.
