Buttonless Ble DFU update via Esp32
Hello
I want to put nordic device into dfu mode via esp32. I reviewed the documents. I put the nordic device in dfu mode from the phone.
Likewise, I am sending the data over Esp32, but I could not succeed.
Could you help?
Best regards,Esp32(Master)_Nrf(Slave) dfu.pcapng
  • Sorry, I do not understand your question. What offset are you referring to?
  • NRF_DFU_OP_OBJECT_CREATE (data)
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00026000, len=1 pages), queue usage: 0
    00>
    00> <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00000000, CRC: 0x00000000
    it's the same on every create object
  • You are right, I did not notice that. The problem is that you are not sending the Execute command after every object. If you skip the execute request and call 'object create' again after an object is written, you will start over overwriting that object again instead of starting on the next.
  • thanks, I'm getting an error while writing the last package. The file I am trying to send is the original update package.
    00> <info> app: Inside main
    00>
    00> <debug> app: In nrf_bootloader_init
    00>
    00> <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
    00>
    00> <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    00>
    00> <debug> nrf_dfu_settings: Using settings page.
    00>
    00> <debug> nrf_dfu_settings: Copying forbidden parts from backup page.
    00>
    00> <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
    00>
    00> <info> nrf_dfu_settings: Backing up settings page to address 0x7E000.
    00>
    00>
    00> <debug> app: Enter nrf_bootloader_fw_activate
    00>
    00> <info> app: No firmware to activate.
    00>
    00> <info> app: Boot validation failed. No valid app to boot.
    00>
    00> <debug> app: DFU mode because app is not valid.
    00>
    00> <info> nrf_bootloader_wdt: WDT is not enabled
    00>
    00> <debug> app: in weak nrf_dfu_init_user
    00>
    00> <debug> app: timer_stop (0x20005968)
    00>
    00> <debug> app: timer_activate (0x20005968)
    00>
    00> <info> app: Entering DFU mode.
    00>
    00> <debug> app: Initializing transports (found: 1)
    00>
    00> <debug> nrf_dfu_ble: Initializing BLE DFU transport
    00>
    00> <debug> nrf_dfu_ble: Setting up vector table: 0x00071000
    00>
    00> <debug> nrf_dfu_ble: Enabling SoftDevice.
    00>
    00> <debug> nrf_dfu_ble: Configuring BLE stack.
    00>
    00> <debug> nrf_dfu_ble: Enabling the BLE stack.
    00>
    00> <debug> nrf_dfu_ble: No advertising name found
    00>
    00> <debug> nrf_dfu_ble: Using default advertising name
    00>
    00> <debug> nrf_dfu_ble: Advertising...
    00>
    00> <debug> nrf_dfu_ble: BLE DFU transport initialized.
    00>
    00> <debug> nrf_dfu_flash: Initializing nrf_fstorage_sd backend.
    00>
    00> <debug> nrf_dfu_validation: PB: Init packet data len: 64
    00>
    00> <debug> app: Enter main loop
    00>
    00> <debug> nrf_dfu_ble: Connected
    00>
    00> <debug> nrf_dfu_ble: Received BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST.
    00>
    00> <debug> nrf_dfu_ble: Received BLE_GAP_EVT_DATA_LENGTH_UPDATE (251, max_rx_time 2120).
    00>
    00> <debug> nrf_dfu_ble: Received BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST (request: 247, reply: 247).
    00>
    00> <debug> app: Shutting down transports (found: 1)
    00>
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (command)
    00>
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    00>
    00> <debug> nrf_dfu_ble: Buffer 0x200076B8 acquired, len 141 (244)
    00>
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (command)
    00>
    00> <debug> nrf_dfu_ble: Freeing buffer 0x200076B8
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (command)
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (command)
    00>
    00>
    00> <info> nrf_dfu_validation: Signature required. Checking signature.
    00>
    00> <info> nrf_dfu_validation: Calculating hash (len: 64)
    00>
    00> <info> nrf_dfu_validation: Verify signature
    00>
    00> <info> nrf_dfu_validation: Image verified
    00>
    00> <debug> app: Enter nrf_dfu_cache_prepare()
    00>
    00> <debug> app: required_size: 0x9EC0.
    00>
    00> <debug> app: single_bank: false.
    00>
    00> <debug> app: keep_app: false.
    00>
    00> <debug> app: keep_softdevice: true.
    00>
    00> <debug> app: SD_PRESENT: true.
    00>
    00> <debug> app: Bank contents:
    00>
    00> <debug> app: Bank 0 code: 0x00: Size: 0x0
    00>
    00> <debug> app: Bank 1 code: 0x00: Size: 0x0
    00>
    00> <debug> app: pass: 0.
    00>
    00> <debug> app: cache_address: 0x26000.
    00>
    00> <debug> app: cache_too_small: false.
    00>
    00> <debug> app: keep_firmware: false.
    00>
    00> <debug> app: delete_more: false.
    00>
    00> <debug> nrf_dfu_validation: Write address set to 0x00026000
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Writing valid init command to flash.
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (data)
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash erase success: addr=0x00026000, pending 0
    00>
    00> <debug> nrf_dfu_ble: Buffer 0x200076B8 acquired, len 240 (244)
    00>
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026000, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00026000, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000260F0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000260F0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000261E0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000261E0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000262D0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000262D0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000263C0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000263C0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000264B0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000264B0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000265A0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000265A0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026690, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00026690, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026780, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00026780, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026870, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00026870, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026960, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00026960, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026A50, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00026A50, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026B40, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00026B40, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026C30, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00026C30, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026D20, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00026D20, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026E10, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00026E10, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026F00, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00026F00, pending 0
    00>
    00>
    00> <debug> nrf_dfu_ble: Buffer 0x200076B8 acquired, len 16 (244)
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026FF0, src=0x200076B8, len=16 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00026FF0, pending 0
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (data)
    00>
    00> <debug> nrf_dfu_req_handler: Offset:4096, CRC:0x49969564
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (data)
    00>
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00027000, len=1 pages), queue usage: 0
    00>
    00> <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00001000, CRC: 0x49969564
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash erase success: addr=0x00027000, pending 0
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027000, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027000, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000270F0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000270F0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000271E0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000271E0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000272D0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000272D0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000273C0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000273C0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000274B0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000274B0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000275A0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000275A0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027690, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027690, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027780, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027780, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027870, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027870, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027960, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027960, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027A50, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027A50, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027B40, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027B40, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027C30, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027C30, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027D20, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027D20, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027E10, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027E10, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027F00, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027F00, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027FF0, src=0x200076B8, len=16 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027FF0, pending 0
    00>
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Offset:8192, CRC:0x5FE6EA20
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00028000, len=1 pages), queue usage: 0
    00>
    00> <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00002000, CRC: 0x5FE6EA20
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash erase success: addr=0x00028000, pending 0
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028000, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028000, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000280F0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000280F0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000281E0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000281E0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000282D0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000282D0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000283C0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000283C0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000284B0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000284B0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000285A0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000285A0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028690, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028690, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028780, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028780, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028870, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028870, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028960, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028960, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028A50, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028A50, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028B40, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028B40, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028C30, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028C30, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028D20, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028D20, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028E10, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028E10, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028F00, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028F00, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028FF0, src=0x200076B8, len=16 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028FF0, pending 0
    00>
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Offset:12288, CRC:0x304CCC1B
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00029000, len=1 pages), queue usage: 0
    00>
    00> <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00003000, CRC: 0x304CCC1B
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash erase success: addr=0x00029000, pending 0
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029000, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029000, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000290F0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000290F0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000291E0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000291E0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000292D0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000292D0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000293C0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000293C0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000294B0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000294B0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000295A0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000295A0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029690, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029690, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029780, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029780, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029870, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029870, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029960, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029960, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029A50, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029A50, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029B40, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029B40, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029C30, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029C30, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029D20, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029D20, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029E10, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029E10, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029F00, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029F00, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029FF0, src=0x200076B8, len=16 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029FF0, pending 0
    00>
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Offset:16384, CRC:0xF63514D0
    00>
    00>
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_ble: Received BLE_GAP_EVT_CONN_PARAM_UPDATE
    00>
    00> <debug> nrf_dfu_ble: max_conn_interval: 12
    00>
    00> <debug> nrf_dfu_ble: min_conn_interval: 12
    00>
    00> <debug> nrf_dfu_ble: slave_latency: 0
    00>
    00> <debug> nrf_dfu_ble: conn_sup_timeout: 600
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0002A000, len=1 pages), queue usage: 0
    00>
    00> <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00004000, CRC: 0xF63514D0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash erase success: addr=0x0002A000, pending 0
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A000, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002A000, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A0F0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002A0F0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A1E0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002A1E0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A2D0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002A2D0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A3C0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002A3C0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A4B0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002A4B0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A5A0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002A5A0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A690, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002A690, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A780, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002A780, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A870, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002A870, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A960, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002A960, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AA50, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002AA50, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AB40, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002AB40, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AC30, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002AC30, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AD20, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002AD20, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AE10, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002AE10, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AF00, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002AF00, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AFF0, src=0x200076B8, len=16 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002AFF0, pending 0
    00>
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Offset:20480, CRC:0xA4C36119
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0002B000, len=1 pages), queue usage: 0
    00>
    00> <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00005000, CRC: 0xA4C36119
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash erase success: addr=0x0002B000, pending 0
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B000, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002B000, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B0F0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002B0F0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B1E0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002B1E0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B2D0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002B2D0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B3C0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002B3C0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B4B0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002B4B0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B5A0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002B5A0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B690, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002B690, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B780, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002B780, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B870, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002B870, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B960, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002B960, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BA50, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002BA50, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BB40, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002BB40, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BC30, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002BC30, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BD20, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002BD20, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BE10, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002BE10, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BF00, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002BF00, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BFF0, src=0x200076B8, len=16 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002BFF0, pending 0
    00>
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Offset:24576, CRC:0xB9224599
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0002C000, len=1 pages), queue usage: 0
    00>
    00> <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00006000, CRC: 0xB9224599
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash erase success: addr=0x0002C000, pending 0
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C000, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002C000, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C0F0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002C0F0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C1E0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002C1E0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C2D0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002C2D0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C3C0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002C3C0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C4B0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002C4B0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C5A0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002C5A0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C690, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002C690, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C780, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002C780, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C870, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002C870, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C960, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002C960, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CA50, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002CA50, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CB40, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002CB40, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CC30, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002CC30, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CD20, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002CD20, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CE10, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002CE10, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CF00, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002CF00, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CFF0, src=0x200076B8, len=16 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002CFF0, pending 0
    00>
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Offset:28672, CRC:0x00A72C15
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0002D000, len=1 pages), queue usage: 0
    00>
    00> <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00007000, CRC: 0x00A72C15
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash erase success: addr=0x0002D000, pending 0
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D000, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002D000, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D0F0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002D0F0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D1E0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002D1E0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D2D0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002D2D0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D3C0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002D3C0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D4B0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002D4B0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D5A0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002D5A0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D690, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002D690, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D780, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002D780, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D870, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002D870, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D960, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002D960, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DA50, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002DA50, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DB40, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002DB40, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DC30, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002DC30, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DD20, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002DD20, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DE10, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002DE10, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DF00, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002DF00, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DFF0, src=0x200076B8, len=16 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002DFF0, pending 0
    00>
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Offset:32768, CRC:0xA2A8F1AA
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0002E000, len=1 pages), queue usage: 0
    00>
    00> <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00008000, CRC: 0xA2A8F1AA
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash erase success: addr=0x0002E000, pending 0
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E000, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002E000, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E0F0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002E0F0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E1E0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002E1E0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E2D0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002E2D0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E3C0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002E3C0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E4B0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002E4B0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E5A0, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002E5A0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E690, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002E690, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E780, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002E780, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E870, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002E870, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E960, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002E960, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EA50, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002EA50, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EB40, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002EB40, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EC30, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002EC30, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002ED20, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002ED20, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EE10, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002EE10, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EF00, src=0x200076B8, len=240 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002EF00, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EFF0, src=0x200076B8, len=16 bytes), queue usage: 0
    00>
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0002EFF0, pending 0
    00>
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Offset:36864, CRC:0x59CFC349
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00> <error> nrf_dfu_req_handler: Creating the object with size 0x00001000 would overflow firmware size. Offset is 0x00009000 and firmware size is 0x00009EC0.
    00>
    00> <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x8
    00>
    00> <warning> nrf_dfu_ble: DFU request 1 failed with error: 0x8
    00>
    00>
    00>
    00> <error> nrf_dfu_req_handler: Write request too long
    00>
    00> <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x3
    00>
    00> <debug> nrf_dfu_ble: Buffer 0x200077AC acquired, len 240 (244)
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_ble: Buffer 0x200078A0 acquired, len 240 (244)
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_ble: Buffer 0x20007994 acquired, len 240 (244)
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_ble: Buffer 0x20007A88 acquired, len 240 (244)
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_ble: Buffer 0x20007B7C acquired, len 240 (244)
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_ble: Buffer 0x20007C70 acquired, len 240 (244)
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_ble: Buffer 0x20007D64 acquired, len 240 (244)
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_ble: Buffer 0x20007E58 acquired, len 240 (244)
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_ble: Buffer 0x20007F4C acquired, len 240 (244)
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_ble: Buffer 0x20008040 acquired, len 240 (244)
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_ble: Buffer 0x20008134 acquired, len 240 (244)
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_ble: Buffer 0x20008228 acquired, len 240 (244)
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_ble: Buffer 0x2000831C acquired, len 240 (244)
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_ble: Buffer 0x20008410 acquired, len 240 (244)
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_ble: Buffer 0x20008504 acquired, len 240 (244)
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_ble: Buffer 0x200085F8 acquired, len 240 (244)
    00>
    00>
    00>
    00>
    00> <warning> nrf_dfu_ble: cannot allocate memory buffer!
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
