ı am using a dwm3001c that has a nrf52833 microprocessor. I want to set communication with initiator and responder . My initiator code that is ss_twr_initiator example in API.My responder code that is ss_twr_responder example in API. My initiator work werll with BLE and SD. ı add dfu and butonless and bluetooth com. to initiator.
But my responder not work with BLE and SD. I add dfu buttonless and bluetooth like initiator but not working. However only my adding code as ble buttonless and bluetooth work well . But this has not API as responder. AND API work well when that has not BLE and buttonless and bluetooth communication.
Please help me.
My responder as like following:
#define DEVICE_NAME "FY/Havelsan/RESPFY" /**< Name of device. Will be included in the advertising data. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms; this value corresponds to 40 ms). */
#define APP_ADV_DURATION BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED /**< The advertising time-out (in units of seconds). When set to 0, we will never time out. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(100, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.5 seconds). */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(200, UNIT_1_25_MS) /**< Maximum acceptable connection interval (1 second). */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory time-out (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(20000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (15 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (5 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define MAX_TEST_DATA_BYTES (15U)
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256
#define UNIT_TEST 0
#define SAMPLES_IN_BUFFER 5
#define UART_HWFC APP_UART_FLOW_CONTROL_DISABLED
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an encoded advertising set. */
static uint8_t m_enc_scan_response_data[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an encoded scan data. */
static nrf_drv_uart_t m_uart = NRF_DRV_UART_INSTANCE(0);
static ble_gap_adv_data_t m_adv_data =
.adv_data =
.p_data = m_enc_advdata,
.len = BLE_GAP_ADV_SET_DATA_SIZE_MAX
.scan_rsp_data =
.p_data = m_enc_scan_response_data,
static nrf_saadc_value_t m_buffer_pool[2][SAMPLES_IN_BUFFER];
static nrf_ppi_channel_t m_ppi_channel;
static uint32_t m_adc_evt_counter;
void wd_event_handler(void);
void wdt_init(void);
nrfx_wdt_channel_id m_channel_id;
NRF_BLE_GATT_DEF(m_gatt);
NRF_BLE_QWR_DEF(m_qwr);
BLE_CUS_DEF(m_cus);
BLE_ESS_DEF(p_ess);
APP_TIMER_DEF(m_notification_timer_id);
APP_TIMER_DEF(m_notification_timer_id_2);
APP_TIMER_DEF(m_app_timer_id);
APP_TIMER_DEF(m_timer);
extern ble_cus_t m_cus;
extern uint32_t ble_rate;
extern ble_ess_t p_ess;
extern example_ptr example_pointer;
extern int unit_test_main(void);
extern void build_examples(void);
void uart_error_handle(app_uart_evt_t * p_event)
if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
//APP_ERROR_HANDLER(p_event->data.error_communication);
else if (p_event->evt_type == APP_UART_FIFO_ERROR)
else if (p_event->evt_type == APP_UART_DATA_READY)
//app_uart_get(&a);
UNUSED_VARIABLE(app_uart_get(&a));
//printf("%d",a);
err_code=app_uart_put(a);
/*err_code=app_uart_put(a);
APP_ERROR_CHECK(err_code);*/
else if (p_event->evt_type == APP_UART_TX_EMPTY)
//printf("always_ok...");
bool erase_bonds;
nrf_gpio_cfg_output(red_led);
nrf_gpio_cfg_output(green_led);
nrf_gpio_cfg_output(blue_led);
nrf_gpio_cfg_input(c_type_pin,NRF_GPIO_PIN_NOPULL);
nrf_gpio_cfg_input(bat_chg_v,NRF_GPIO_PIN_NOPULL);
nrf_gpio_cfg_input(user_buton, NRF_GPIO_PIN_PULLUP);
//nrf_gpio_cfg_input(ADC,NRF_GPIO_PIN_NOPULL);
nrf_gpio_pin_set(red_led);
nrf_gpio_pin_set(green_led);
nrf_gpio_pin_set(blue_led);
nrf_drv_clock_init();
wdt_init();
log_init();
// err_code = ble_dfu_buttonless_async_svci_init();
//APP_ERROR_CHECK(err_code);
timers_init();
power_management_init();
saadc_init();
ble_stack_init();
gap_params_init();
gatt_init();
qwr_init();
services_init();
advertising_init();
conn_params_init();
advertising_start();
uint32_t uart_enable;
if(!nrf_gpio_pin_read(bat_chg_v))
uart_enable= 15;
uart_enable= UART_PIN_DISCONNECTED;
const app_uart_comm_params_t comm_params =
RX_PIN_NUMBER,
TX_PIN_NUMBER,
RTS_PIN_NUMBER,
CTS_PIN_NUMBER,
UART_HWFC,
false,
#if defined (UART_PRESENT)
NRF_UART_BAUDRATE_115200
#else
NRF_UARTE_BAUDRATE_115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_error_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
build_examples();
gpio_init();
nrf52840_dk_spi_init();
dw_irq_init();
nrf_delay_ms(2);
if (UNIT_TEST)
unit_test_main();
example_pointer();
and my responder code as like following. Note this is same to original of API . I do not changed anything.
#include "deca_probe_interface.h"
#include <deca_device_api.h>
#include <deca_spi.h>
#include <example_selection.h>
#include <port.h>
#include <shared_defines.h>
#include <shared_functions.h>
#if defined(TEST_SS_TWR_RESPONDER)
extern void test_run_info(unsigned char *data);
/* Example application name */
#define APP_NAME "SS TWR RESP v1.0"
/* Default communication configuration. We use default non-STS DW mode. */
static dwt_config_t config = {
5, /* Channel number. */
DWT_PLEN_128, /* Preamble length. Used in TX only. */
DWT_PAC8, /* Preamble acquisition chunk size. Used in RX only. */
9, /* TX preamble code. Used in TX only. */
9, /* RX preamble code. Used in RX only. */
1, /* 0 to use standard 8 symbol SFD, 1 to use non-standard 8 symbol, 2 for non-standard 16 symbol SFD and 3 for 4z 8 symbol SDF type */
DWT_BR_6M8, /* Data rate. */
DWT_PHRMODE_STD, /* PHY header mode. */
DWT_PHRRATE_STD, /* PHY header rate. */
(129 + 8 - 8), /* SFD timeout (preamble length + 1 + SFD length - PAC size). Used in RX only. */
DWT_STS_MODE_OFF, /* STS disabled */
DWT_STS_LEN_64, /* STS length see allowed values in Enum dwt_sts_lengths_e */
DWT_PDOA_M0 /* PDOA mode off */
/* Default antenna delay values for 64 MHz PRF. See NOTE 2 below. */
#define TX_ANT_DLY 16385
#define RX_ANT_DLY 16385
/* Frames used in the ranging process. See NOTE 3 below. */
static uint8_t rx_poll_msg[] = { 0x41, 0x88, 0, 0xCA, 0xDE, 'W', 'A', 'V', 'E', 0xE0, 0, 0 };
static uint8_t tx_resp_msg[] = { 0x41, 0x88, 0, 0xCA, 0xDE, 'V', 'E', 'W', 'A', 0xE1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 };
/* Length of the common part of the message (up to and including the function code, see NOTE 3 below). */
#define ALL_MSG_COMMON_LEN 10
/* Index to access some of the fields in the frames involved in the process. */
#define ALL_MSG_SN_IDX 2
#define RESP_MSG_POLL_RX_TS_IDX 10
#define RESP_MSG_RESP_TX_TS_IDX 14
#define RESP_MSG_TS_LEN 4
/* Frame sequence number, incremented after each transmission. */
static uint8_t frame_seq_nb = 0;
/* Buffer to store received messages.
* Its size is adjusted to longest frame that this example code is supposed to handle. */
#define RX_BUF_LEN 12 // Must be less than FRAME_LEN_MAX_EX
static uint8_t rx_buffer[RX_BUF_LEN];
/* Hold copy of status register state here for reference so that it can be examined at a debug breakpoint. */
static uint32_t status_reg = 0;
/* Delay between frames, in UWB microseconds. See NOTE 1 below. */
#define POLL_RX_TO_RESP_TX_DLY_UUS 650
/* Timestamps of frames transmission/reception. */
static uint64_t poll_rx_ts;
static uint64_t resp_tx_ts;
/* Values for the PG_DELAY and TX_POWER registers reflect the bandwidth and power of the spectrum at the current
* temperature. These values can be calibrated prior to taking reference measurements. See NOTE 5 below. */
extern dwt_txconfig_t txconfig_options;
* @fn main()
* @brief Application entry point.
* @param none
* @return none
int ss_twr_responder(void)
/* Display application name on LCD. */
//test_run_info((unsigned char *)APP_NAME);
/* Configure SPI rate, DW3000 supports up to 36 MHz */
port_set_dw_ic_spi_fastrate();
/* Reset and initialize DW chip. */
reset_DWIC(); /* Target specific drive of RSTn line into DW3000 low for a period. */
Sleep(2); // Time needed for DW3000 to start up (transition from INIT_RC to IDLE_RC, or could wait for SPIRDY event)
/* Probe for the correct device driver. */
dwt_probe((struct dwt_probe_s *)&dw3000_probe_interf);
while (!dwt_checkidlerc()) /* Need to make sure DW IC is in IDLE_RC before proceeding */ { };
if (dwt_initialise(DWT_DW_INIT) == DWT_ERROR)
//test_run_info((unsigned char *)"INIT FAILED ");
//while (1) { };
/* Enabling LEDs here for debug so that for each TX the D1 LED will flash on DW3000 red eval-shield boards. */
dwt_setleds(DWT_LEDS_ENABLE | DWT_LEDS_INIT_BLINK);
/* Configure DW IC. See NOTE 13 below. */
/* if the dwt_configure returns DWT_ERROR either the PLL or RX calibration has failed the host should reset the device */
if (dwt_configure(&config))
// test_run_info((unsigned char *)"CONFIG FAILED ");
//while (1) { };
/* Configure the TX spectrum parameters (power, PG delay and PG count) */
dwt_configuretxrf(&txconfig_options);
/* Apply default antenna delay value. See NOTE 2 below. */
dwt_setrxantennadelay(RX_ANT_DLY);
dwt_settxantennadelay(TX_ANT_DLY);
/* Next can enable TX/RX states output on GPIOs 5 and 6 to help debug, and also TX/RX LEDs
* Note, in real low power applications the LEDs should not be used. */
dwt_setlnapamode(DWT_LNA_ENABLE | DWT_PA_ENABLE);
/* Loop forever responding to ranging requests. */
while (1)
/* Activate reception immediately. */
dwt_rxenable(DWT_START_RX_IMMEDIATE);
/* Poll for reception of a frame or error/timeout. See NOTE 6 below. */
waitforsysstatus(&status_reg, NULL, (DWT_INT_RXFCG_BIT_MASK | SYS_STATUS_ALL_RX_ERR), 0);
if (status_reg & DWT_INT_RXFCG_BIT_MASK)
uint16_t frame_len;
/* Clear good RX frame event in the DW IC status register. */
dwt_writesysstatuslo(DWT_INT_RXFCG_BIT_MASK);
/* A frame has been received, read it into the local buffer. */
frame_len = dwt_getframelength();
if (frame_len <= sizeof(rx_buffer))
dwt_readrxdata(rx_buffer, frame_len, 0);
/* Check that the frame is a poll sent by "SS TWR initiator" example.
* As the sequence number field of the frame is not relevant, it is cleared to simplify the validation of the frame. */
rx_buffer[ALL_MSG_SN_IDX] = 0;
if (memcmp(rx_buffer, rx_poll_msg, ALL_MSG_COMMON_LEN) == 0)
uint32_t resp_tx_time;
int ret;
/* Retrieve poll reception timestamp. */
poll_rx_ts = get_rx_timestamp_u64();
/* Compute response message transmission time. See NOTE 7 below. */
resp_tx_time = (poll_rx_ts + (POLL_RX_TO_RESP_TX_DLY_UUS * UUS_TO_DWT_TIME)) >> 8;
dwt_setdelayedtrxtime(resp_tx_time);
/* Response TX timestamp is the transmission time we programmed plus the antenna delay. */
resp_tx_ts = (((uint64_t)(resp_tx_time & 0xFFFFFFFEUL)) << 8) + TX_ANT_DLY;
/* Write all timestamps in the final message. See NOTE 8 below. */
resp_msg_set_ts(&tx_resp_msg[RESP_MSG_POLL_RX_TS_IDX], poll_rx_ts);
resp_msg_set_ts(&tx_resp_msg[RESP_MSG_RESP_TX_TS_IDX], resp_tx_ts);
/* Write and send the response message. See NOTE 9 below. */
tx_resp_msg[ALL_MSG_SN_IDX] = frame_seq_nb;
dwt_writetxdata(sizeof(tx_resp_msg), tx_resp_msg, 0); /* Zero offset in TX buffer. */
dwt_writetxfctrl(sizeof(tx_resp_msg), 0, 1); /* Zero offset in TX buffer, ranging. */
ret = dwt_starttx(DWT_START_TX_DELAYED);
/* If dwt_starttx() returns an error, abandon this ranging exchange and proceed to the next one. See NOTE 10 below. */
if (ret == DWT_SUCCESS)
/* Poll DW IC until TX frame sent event set. See NOTE 6 below. */
waitforsysstatus(NULL, NULL, DWT_INT_TXFRS_BIT_MASK, 0);
/* Clear TXFRS event. */
dwt_writesysstatuslo(DWT_INT_TXFRS_BIT_MASK);
/* Increment frame sequence number after transmission of the poll message (modulo 256). */
frame_seq_nb++;
/* Clear RX error events in the DW IC status register. */
dwt_writesysstatuslo(SYS_STATUS_ALL_RX_ERR);
My responder code when I download ,ıt communicate with initiator for 5 times then crash and not communicate.
but only API can full communicate.
Preprocessors definitions:
BL_SETTINGS_ACCESS_ONLY
NRF_DFU_TRANSPORT_BLE=1
BOARD_DWM3001C
CONFIG_GPIO_AS_PINRESET
FLOAT_ABI_HARD
NO_VTOR_CONFIG
INITIALIZE_USER_SECTIONS
NRF52833_XXAA
NRF_SD_BLE_API_VERSION=7
S140
SOFTDEVICE_PRESENT
