Programming Thingy:53 with Bluetooth Mesh sensor_server example
I have successfully built the Bluetooth Mesh sensor_server example, using the thingy53_nrf5340_cpuspp_ns build configuration.
But when I come to try and program the Thingy:53, it does not appear in the Connected Devices list, when connected to an nRF5340-DK board with a standard 10-pin cable (I used one from a STLink-V3). The RGB LED on the Thingy:53 illuminates on power up and cycles through the three colours a couple of times before going out, as it does when not connected via the 10-pin cable. When the Thingy:53 is connected via the 10-pin cable to the nRF5340-DK, the LEDs on the latter are not illuminated and neither appear in the Connected Devices list.
When I unplug and replug the USB cable to the nRF5340-DK board without the Thingy:53 connected, then the nRF5340-DK is detected and does appear in the Connected Devices list.
What else do I need to do for the Thingy:53 to be detected please?
I am using nRF Connect SDK v2.3.0 on Windows 11.
  • Hi Hung Bui,
    I added a system path for nrfjprog.exe and tried running it from the c: drive root directory. It did so but with the same result as shown in the above screen capture and did not generate a log file for the non-working board. I was however able obtain the log file for the non-working board by running it from a USB thumb drive labelled E:. Log file attached.
    Al
    [2023-May-11 23:27:45] [ info] --------------------------------------------------------------------------------
    [2023-May-11 23:27:45] [ info] C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.exe --recover --family NRF53 --log
    [2023-May-11 23:27:45] [ info] nrfjprog version 10.16.0 external
    [2023-May-11 23:27:45] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
    [2023-May-11 23:27:45] [ info] Library loaded, loading member functions.
    [2023-May-11 23:27:45] [ info] Member functions succesfully loaded.
    [2023-May-11 23:27:45] [debug] [ Client] - open
    [2023-May-11 23:27:45] [debug] [ Client] - start
    [2023-May-11 23:27:45] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 48088012-4f5f-44a0-81c8-abc47f71cb06.
    [2023-May-11 23:27:45] [trace] [ Client] - Command open executed for 39 milliseconds with result 0
    [2023-May-11 23:27:45] [debug] [ Client] - enum_emu_snr
    [2023-May-11 23:27:45] [trace] [ Client] - Command enum_emu_con_info executed for 9 milliseconds with result 0
    [2023-May-11 23:27:45] [debug] [ Client] - connect_to_emu_with_snr
    [2023-May-11 23:27:45] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2023-May-11 23:27:45] [debug] [  JLink] - Logger sink registered in JLink logger
    [2023-May-11 23:27:45] [debug] [  nRF53] - open
    [2023-May-11 23:27:45] [debug] [  nRF53] - just_check_family
    [2023-May-11 23:27:45] [debug] [SeggerBackend] - open_dll
    [2023-May-11 23:27:45] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2023-May-11 23:27:45] [ info] [SeggerBackend] - Load library at C:\Program Files (x86)\SEGGER\JLink\JLink_x64.dll.
    [2023-May-11 23:27:45] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2023-May-11 23:27:45] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2023-May-11 23:27:45] [debug] [SeggerBackend] - dll_version
    [2023-May-11 23:27:45] [ info] [SeggerBackend] - Segger dll version 7.86.e loaded.
    [2023-May-11 23:27:45] [trace] [ Worker] - Command open executed for 4 milliseconds with result 0
    [2023-May-11 23:27:45] [debug] [  nRF53] - enum_emu_con_info
    [2023-May-11 23:27:45] [debug] [SeggerBackend] - is_connected_to_emu
    [2023-May-11 23:27:45] [debug] [SeggerBackend] - enum_emu_con_info
    [2023-May-11 23:27:45] [trace] [ Worker] - Command enum_emu_con_info executed for 3 milliseconds with result 0
    [2023-May-11 23:27:45] [debug] [  nRF53] - connect_to_emu_with_snr
    [2023-May-11 23:27:45] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2023-May-11 23:27:45] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2023-May-11 23:27:45] [debug] [SeggerBackend] - ---just_get_num_emus
    [2023-May-11 23:27:45] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2023-May-11 23:27:45] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2023-May-11 23:27:45] [debug] [SeggerBackend] - Segger logging enabled.
    [2023-May-11 23:27:45] [trace] [  JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Nov  7 2022 16:22:01
    [2023-May-11 23:27:45] [trace] [  JLink] - Hardware: V1.00
    [2023-May-11 23:27:45] [trace] [  JLink] - S/N: 1050006835
    [2023-May-11 23:27:45] [trace] [  JLink] - OEM: SEGGER
    [2023-May-11 23:27:45] [trace] [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    [2023-May-11 23:27:45] [trace] [  JLink] - USB speed mode: Full speed (12 MBit/s)
    [2023-May-11 23:27:45] [trace] [  JLink] - TELNET listener socket opened on port 19021
    [2023-May-11 23:27:45] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    [2023-May-11 23:27:45] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
    [2023-May-11 23:27:45] [trace] [  JLink] - - 35.915ms returns "O.K."
    [2023-May-11 23:27:45] [trace] [  JLink] - JLINK_HasError()
    [2023-May-11 23:27:45] [trace] [  JLink] - JLINK_Lock()
    [2023-May-11 23:27:45] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2023-May-11 23:27:45] [trace] [  JLink] - - 0.009ms returns 0x01
    [2023-May-11 23:27:45] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2023-May-11 23:27:45] [trace] [  JLink] - - 0.007ms returns 0x00
    [2023-May-11 23:27:45] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2023-May-11 23:27:45] [trace] [  JLink] - - 0.012ms returns 0x00
    [2023-May-11 23:27:45] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
    [2023-May-11 23:27:45] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
    [2023-May-11 23:27:45] [trace] [  JLink] - - 0.092ms returns 0
    [2023-May-11 23:27:45] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2023-May-11 23:27:45] [trace] [  JLink] - - 1.153ms returns 0x00
    [2023-May-11 23:27:45] [trace] [  JLink] - JLINK_GetSpeedInfo()
    [2023-May-11 23:27:45] [trace] [  JLink] - 128000000 Hz / n, n >= 64
    [2023-May-11 23:27:45] [trace] [  JLink] - - 0.026ms
    [2023-May-11 23:27:45] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 2000kHz
    [2023-May-11 23:27:45] [trace] [  JLink] - JLINK_SetSpeed(2000)
    [2023-May-11 23:27:45] [trace] [  JLink] - - 0.164ms
    [2023-May-11 23:27:45] [trace] [  JLink] - JLINK_GetSpeed()
    [2023-May-11 23:27:45] [trace] [  JLink] - - 0.013ms returns 2000
    [2023-May-11 23:27:45] [debug] [SeggerBackend] - SWD clock set to 2000kHz
    [2023-May-11 23:27:45] [trace] [  JLink] - JLINK_GetSN()
    [2023-May-11 23:27:45] [trace] [  JLink] - - 0.015ms returns 1050006835
    [2023-May-11 23:27:45] [debug] [SeggerBackend] - read_debug_port_idr
    [2023-May-11 23:27:45] [debug] [SeggerBackend] - read_debug_port_register
    [2023-May-11 23:27:45] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2023-May-11 23:27:45] [debug] [SeggerBackend] - coresight_configure
    [2023-May-11 23:27:45] [trace] [  JLink] - JLINK_GetHWStatus(...)
    [2023-May-11 23:27:45] [trace] [  JLink] - - 0.299ms returns 0
    [2023-May-11 23:27:45] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
    [2023-May-11 23:27:46] [trace] [  JLink] - - 101.233ms returns 0
    [2023-May-11 23:27:46] [trace] [  JLink] - JLINK_HasError()
    [2023-May-11 23:27:46] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2023-May-11 23:27:46] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2023-May-11 23:27:46] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2023-May-11 23:27:46] [trace] [  JLink] - - 1.437ms returns -1
    [2023-May-11 23:27:46] [error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
    [2023-May-11 23:27:46] [debug] [SeggerBackend] - ---just_abort_debug_action
    [2023-May-11 23:27:46] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
    [2023-May-11 23:27:46] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.990ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.976ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 1.248ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 1.210ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 1.003ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.959ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.940ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 1.288ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 1.266ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.949ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.948ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.890ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.991ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.887ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.929ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.969ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.946ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.907ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.905ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.893ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.815ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.790ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.693ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.789ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.824ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.065ms
    [2023-May-11 23:27:46] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 202 milliseconds with result -102
    [2023-May-11 23:27:46] [trace] [ Client] - Command connect_to_emu_with_snr executed for 217 milliseconds with result -102
    [2023-May-11 23:27:46] [debug] [  nRF53] - close
    [2023-May-11 23:27:46] [debug] [SeggerBackend] - is_connected_to_emu
    [2023-May-11 23:27:46] [trace] [  JLink] - JLINK_IsOpen()
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.021ms returns 0x01
    [2023-May-11 23:27:46] [trace] [  JLink] - JLINK_Lock()
    [2023-May-11 23:27:46] [debug] [SeggerBackend] - close
    [2023-May-11 23:27:46] [debug] [SeggerBackend] - disconnect_from_emu
    [2023-May-11 23:27:46] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2023-May-11 23:27:46] [debug] [SeggerBackend] - is_connected_to_device
    [2023-May-11 23:27:46] [trace] [  JLink] - JLINK_IsConnected()
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.012ms returns FALSE
    [2023-May-11 23:27:46] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2023-May-11 23:27:46] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.720ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.729ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.662ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.707ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.660ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.689ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.683ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.737ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.614ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.680ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.613ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.608ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.628ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.576ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.571ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.654ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.607ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.684ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.648ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.658ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.631ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.611ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.640ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.547ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.537ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.492ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.556ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.604ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.455ms returns -1
    [2023-May-11 23:27:46] [trace] [  JLink] - - 0.013ms
    [2023-May-11 23:27:46] [trace] [  JLink] - JLINK_Close()
    [2023-May-11 23:27:46] [trace] [ Client] - Command close executed for 68 milliseconds with result 0
    [2023-May-11 23:27:46] [debug] [ Client] - terminate
    [2023-May-11 23:27:46] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
    [2023-May-11 23:27:46] [debug] [SeggerBackend] - Segger Backend closed.
    [2023-May-11 23:27:46] [debug] [  nRF53] - nRF family DLL closed
    [2023-May-11 23:27:46] [trace] [ Worker] - Command close executed for 68 milliseconds with result 0
    [2023-May-11 23:27:46] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
    [2023-May-11 23:27:46] [trace] [ Worker] - Executed 5 commands for 277 milliseconds
    [2023-May-11 23:27:46] [debug] [ Client] - Worker process exited with code: 0
    [2023-May-11 23:27:46] [debug] [ Client] - Child process terminated with result 0
    [2023-May-11 23:27:46] [trace] [ Client] - Executed 5 commands for 333 milliseconds
  • Hi Hung Bui,
    I also produced a log file that same way on the E: drive for the working board. Please see attached.
    Al
    230511 Working.log
  • Hi Al,
    I have forwarded the log to our R&D team and they said that it looks like the chip was not powered hence the programmer can not program the chip.
    Could you please check what's the voltage on the VDD pins ? Also please check the voltage on the 5V pin.
    Is there any chance that you were flashing anything that change the VREGHVOUT ?
    With the other board that works, have you managed to program the Thingy 53 with that board (make sure to turn Thingy53 on when you flash) ?
  • Hi Hung Bui,
    I checked the 5V and VDD rails on both working and non-working boards using an oscilloscope, includng when running nrfjprog (with the same results per the supplied log files). There is no difference in the measured voltages between the two baords:
    5V Rail: +5.0V
    VDD Rail: +3.0V
    I am not sure where to measure VREGHVOUT, could you confirm please?
    I have not tried programming the Thingy:53 using another nRF5340DK for the specific reason that I want to understand why the board previously used is now no longer works, and do not want to risk damage to any other nRF5340DK boards without identifying the problem with this non-working board.
    Al
  • Hi Al,
    We running out of idea on why it wouldn't work.
    I think the way to go is that we will send you a replacement board and you can try doing programming the nRF53 again. If you can record your test step by step and if you reproduce the issue, we can start from there and track down what causes the problem.
    We haven't received other reports about this issue and in my test here on my desk it all worked fine.
