ble stack softdevice vs ncs dbm/rssi/range wise
hi Nordic
i am working with nrf52832
i have a code that works with SDK11.0, softdevice132
i am migrating my application for the same boards to run on zephyr, ncs v2.1.0
i am sure there are some differences between the two BLE stacks
is there some documentation i can read on the differences, and more specific, i see that DBM reads i get on the ncs code are a bit weeker (-42 with sdk vs -53 on ncs) both baords communicate with the same node (not nordic based) and are at the same location
any explanation for the diff in dbm ?
hope to read you soon
best regards
Ziv
    An update. I was playing around with this, and I found that the NCS\zephyr\samples\bluetooth\hci_pwr_ctrl checks the TX power for a certain connection (as it is possible to set them for every connection). Check out that sample. It will fetch the TX power when it connects and print it to the log. I took the liberty to add this to the peripheral_uart sample as well. You just need to add the following configurations to prj.conf:
    CONFIG_BT_CTLR_TX_PWR_PLUS_4=y
    CONFIG_BT_CTLR_CONN_RSSI=y
    CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL=y
    And check out the following main.c file:
     * Copyright (c) 2018 Nordic Semiconductor ASA
    /** @file
     *  @brief Nordic UART Bridge Service (NUS) sample
    #include "uart_async_adapter.h"
    #include <zephyr/types.h>
    #include <zephyr/kernel.h>
    #include <zephyr/drivers/uart.h>
    #include <zephyr/usb/usb_device.h>
    #include <zephyr/device.h>
    #include <soc.h>
    #include <zephyr/bluetooth/uuid.h>
    #include <zephyr/bluetooth/gatt.h>
    #include <zephyr/bluetooth/conn.h>
    #include <zephyr/bluetooth/hci.h>
    #include <zephyr/bluetooth/hci_vs.h>
    #include <stddef.h>
    #include <zephyr/sys/util.h>
    #include <zephyr/sys/byteorder.h>
    #include <bluetooth/services/nus.h>
    #include <dk_buttons_and_leds.h>
    #include <zephyr/settings/settings.h>
    #include <stdio.h>
    #define LOG_MODULE_NAME peripheral_uart
    LOG_MODULE_REGISTER(LOG_MODULE_NAME);
    #define STACKSIZE CONFIG_BT_NUS_THREAD_STACK_SIZE
    #define PRIORITY 7
    #define DEVICE_NAME CONFIG_BT_DEVICE_NAME
    #define DEVICE_NAME_LEN	(sizeof(DEVICE_NAME) - 1)
    #define RUN_STATUS_LED DK_LED1
    #define RUN_LED_BLINK_INTERVAL 1000
    #define CON_STATUS_LED DK_LED2
    #define KEY_PASSKEY_ACCEPT DK_BTN1_MSK
    #define KEY_PASSKEY_REJECT DK_BTN2_MSK
    #define UART_BUF_SIZE CONFIG_BT_NUS_UART_BUFFER_SIZE
    #define UART_WAIT_FOR_BUF_DELAY K_MSEC(50)
    #define UART_WAIT_FOR_RX CONFIG_BT_NUS_UART_RX_WAIT_TIME
    static K_SEM_DEFINE(ble_init_ok, 0, 1);
    static struct bt_conn *current_conn;
    static struct bt_conn *auth_conn;
    static uint16_t default_conn_handle;
    static const struct device *uart = DEVICE_DT_GET(DT_CHOSEN(nordic_nus_uart));
    static struct k_work_delayable uart_work;
    struct uart_data_t {
    	void *fifo_reserved;
    	uint8_t data[UART_BUF_SIZE];
    	uint16_t len;
    static K_FIFO_DEFINE(fifo_uart_tx_data);
    static K_FIFO_DEFINE(fifo_uart_rx_data);
    static const struct bt_data ad[] = {
    	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
    	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
    static const struct bt_data sd[] = {
    	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_NUS_VAL),
    #if CONFIG_BT_NUS_UART_ASYNC_ADAPTER
    UART_ASYNC_ADAPTER_INST_DEFINE(async_adapter);
    #else
    static const struct device *const async_adapter;
    static void get_tx_power(uint8_t handle_type, uint16_t handle, int8_t *tx_pwr_lvl);
    static void read_conn_rssi(uint16_t handle, int8_t *rssi);
    static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
    	ARG_UNUSED(dev);
    	static size_t aborted_len;
    	struct uart_data_t *buf;
    	static uint8_t *aborted_buf;
    	static bool disable_req;
    	switch (evt->type) {
    	case UART_TX_DONE:
    		LOG_DBG("UART_TX_DONE");
    		if ((evt->data.tx.len == 0) ||
    		    (!evt->data.tx.buf)) {
    			return;
    		if (aborted_buf) {
    			buf = CONTAINER_OF(aborted_buf, struct uart_data_t,
    					   data);
    			aborted_buf = NULL;
    			aborted_len = 0;
    		} else {
    			buf = CONTAINER_OF(evt->data.tx.buf, struct uart_data_t,
    					   data);
    		k_free(buf);
    		buf = k_fifo_get(&fifo_uart_tx_data, K_NO_WAIT);
    		if (!buf) {
    			return;
    		if (uart_tx(uart, buf->data, buf->len, SYS_FOREVER_MS)) {
    			LOG_WRN("Failed to send data over UART");
    	case UART_RX_RDY:
    		LOG_DBG("UART_RX_RDY");
    		buf = CONTAINER_OF(evt->data.rx.buf, struct uart_data_t, data);
    		buf->len += evt->data.rx.len;
    		if (disable_req) {
    			return;
    		if ((evt->data.rx.buf[buf->len - 1] == '\n') ||
    		    (evt->data.rx.buf[buf->len - 1] == '\r')) {
    			disable_req = true;
    			uart_rx_disable(uart);
    	case UART_RX_DISABLED:
    		LOG_DBG("UART_RX_DISABLED");
    		disable_req = false;
    		buf = k_malloc(sizeof(*buf));
    		if (buf) {
    			buf->len = 0;
    		} else {
    			LOG_WRN("Not able to allocate UART receive buffer");
    			k_work_reschedule(&uart_work, UART_WAIT_FOR_BUF_DELAY);
    			return;
    		uart_rx_enable(uart, buf->data, sizeof(buf->data),
    			       UART_WAIT_FOR_RX);
    	case UART_RX_BUF_REQUEST:
    		LOG_DBG("UART_RX_BUF_REQUEST");
    		if (buf) {
    			buf->len = 0;
    			uart_rx_buf_rsp(uart, buf->data, sizeof(buf->data));
    		} else {
    	case UART_RX_BUF_RELEASED:
    		LOG_DBG("UART_RX_BUF_RELEASED");
    		buf = CONTAINER_OF(evt->data.rx_buf.buf, struct uart_data_t,
    				   data);
    		if (buf->len > 0) {
    			k_fifo_put(&fifo_uart_rx_data, buf);
    		} else {
    			k_free(buf);
    	case UART_TX_ABORTED:
    		LOG_DBG("UART_TX_ABORTED");
    		if (!aborted_buf) {
    			aborted_buf = (uint8_t *)evt->data.tx.buf;
    		aborted_len += evt->data.tx.len;
    				   data);
    		uart_tx(uart, &buf->data[aborted_len],
    			buf->len - aborted_len, SYS_FOREVER_MS);
    static void uart_work_handler(struct k_work *item)
    	if (buf) {
    		buf->len = 0;
    	} else {
    		return;
    	uart_rx_enable(uart, buf->data, sizeof(buf->data), UART_WAIT_FOR_RX);
    static bool uart_test_async_api(const struct device *dev)
    	const struct uart_driver_api *api =
    			(const struct uart_driver_api *)dev->api;
    	return (api->callback_set != NULL);
    static int uart_init(void)
    	int err;
    	int pos;
    	struct uart_data_t *rx;
    	struct uart_data_t *tx;
    	if (!device_is_ready(uart)) {
    		return -ENODEV;
    	if (IS_ENABLED(CONFIG_USB_DEVICE_STACK)) {
    		err = usb_enable(NULL);
    		if (err && (err != -EALREADY)) {
    			LOG_ERR("Failed to enable USB");
    			return err;
    	rx = k_malloc(sizeof(*rx));
    	if (rx) {
    		rx->len = 0;
    	} else {
    		return -ENOMEM;
    	k_work_init_delayable(&uart_work, uart_work_handler);
    	if (IS_ENABLED(CONFIG_BT_NUS_UART_ASYNC_ADAPTER) && !uart_test_async_api(uart)) {
    		/* Implement API adapter */
    		uart_async_adapter_init(async_adapter, uart);
    		uart = async_adapter;
    	err = uart_callback_set(uart, uart_cb, NULL);
    	if (err) {
    		k_free(rx);
    		LOG_ERR("Cannot initialize UART callback");
    		return err;
    	if (IS_ENABLED(CONFIG_UART_LINE_CTRL)) {
    		LOG_INF("Wait for DTR");
    		while (true) {
    			uint32_t dtr = 0;
    			uart_line_ctrl_get(uart, UART_LINE_CTRL_DTR, &dtr);
    			if (dtr) {
    			/* Give CPU resources to low priority threads. */
    			k_sleep(K_MSEC(100));
    		LOG_INF("DTR set");
    		err = uart_line_ctrl_set(uart, UART_LINE_CTRL_DCD, 1);
    		if (err) {
    			LOG_WRN("Failed to set DCD, ret code %d", err);
    		err = uart_line_ctrl_set(uart, UART_LINE_CTRL_DSR, 1);
    		if (err) {
    			LOG_WRN("Failed to set DSR, ret code %d", err);
    	tx = k_malloc(sizeof(*tx));
    	if (tx) {
    		pos = snprintf(tx->data, sizeof(tx->data),
    			       "Starting Nordic UART service example\r\n");
    		if ((pos < 0) || (pos >= sizeof(tx->data))) {
    			k_free(rx);
    			k_free(tx);
    			LOG_ERR("snprintf returned %d", pos);
    			return -ENOMEM;
    		tx->len = pos;
    	} else {
    		k_free(rx);
    		return -ENOMEM;
    	err = uart_tx(uart, tx->data, tx->len, SYS_FOREVER_MS);
    	if (err) {
    		k_free(rx);
    		k_free(tx);
    		LOG_ERR("Cannot display welcome message (err: %d)", err);
    		return err;
    	err = uart_rx_enable(uart, rx->data, sizeof(rx->data), 50);
    	if (err) {
    		LOG_ERR("Cannot enable uart reception (err: %d)", err);
    		/* Free the rx buffer only because the tx buffer will be handled in the callback */
    		k_free(rx);
    	return err;
    static void connected(struct bt_conn *conn, uint8_t err)
        int ret;
        int8_t txp;
    	if (err) {
    		LOG_ERR("Connection failed (err %u)", err);
    		return;
    	LOG_INF("Connected %s", addr);
    	current_conn = bt_conn_ref(conn);
        ret = bt_hci_get_conn_handle(current_conn, &default_conn_handle);
        if (ret) {
            LOG_ERR("couldn't get conn handle. ret %d", ret);
        else {
            get_tx_power(BT_HCI_VS_LL_HANDLE_TYPE_CONN, default_conn_handle, &txp);
            LOG_INF("connection (%d) - Initial TX power = %d", default_conn_handle, txp);
    	dk_set_led_on(CON_STATUS_LED);
    	LOG_INF("Disconnected: %s (reason %u)", addr, reason);
    	if (auth_conn) {
    		bt_conn_unref(auth_conn);
    		auth_conn = NULL;
    	if (current_conn) {
    		bt_conn_unref(current_conn);
    		current_conn = NULL;
    		dk_set_led_off(CON_STATUS_LED);
    #ifdef CONFIG_BT_NUS_SECURITY_ENABLED
    static void security_changed(struct bt_conn *conn, bt_security_t level,
    			     enum bt_security_err err)
    	if (!err) {
    		LOG_INF("Security changed: %s level %u", addr, level);
    	} else {
    		LOG_WRN("Security failed: %s level %u err %d", addr,
    			level, err);
    BT_CONN_CB_DEFINE(conn_callbacks) = {
    	.connected    = connected,
    	.disconnected = disconnected,
    	.security_changed = security_changed,
    #if defined(CONFIG_BT_NUS_SECURITY_ENABLED)
    static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey)
    	LOG_INF("Passkey for %s: %06u", addr, passkey);
    static void auth_passkey_confirm(struct bt_conn *conn, unsigned int passkey)
    	auth_conn = bt_conn_ref(conn);
    	LOG_INF("Press Button 1 to confirm, Button 2 to reject.");
    static void auth_cancel(struct bt_conn *conn)
    	LOG_INF("Pairing cancelled: %s", addr);
    static void pairing_complete(struct bt_conn *conn, bool bonded)
    	LOG_INF("Pairing completed: %s, bonded: %d", addr, bonded);
    static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
    	LOG_INF("Pairing failed conn: %s, reason %d", addr, reason);
    static struct bt_conn_auth_cb conn_auth_callbacks = {
    	.passkey_display = auth_passkey_display,
    	.passkey_confirm = auth_passkey_confirm,
    	.cancel = auth_cancel,
    static struct bt_conn_auth_info_cb conn_auth_info_callbacks = {
    	.pairing_complete = pairing_complete,
    	.pairing_failed = pairing_failed
    #else
    static struct bt_conn_auth_cb conn_auth_callbacks;
    static struct bt_conn_auth_info_cb conn_auth_info_callbacks;
    static void bt_receive_cb(struct bt_conn *conn, const uint8_t *const data,
    			  uint16_t len)
    	int err;
    	char addr[BT_ADDR_LE_STR_LEN] = {0};
    	bt_addr_le_to_str(bt_conn_get_dst(conn), addr, ARRAY_SIZE(addr));
    	LOG_INF("Received data from: %s", addr);
    	for (uint16_t pos = 0; pos != len;) {
    		struct uart_data_t *tx = k_malloc(sizeof(*tx));
    		if (!tx) {
    			LOG_WRN("Not able to allocate UART send data buffer");
    			return;
    		/* Keep the last byte of TX buffer for potential LF char. */
    		size_t tx_data_size = sizeof(tx->data) - 1;
    		if ((len - pos) > tx_data_size) {
    			tx->len = tx_data_size;
    		} else {
    			tx->len = (len - pos);
    		memcpy(tx->data, &data[pos], tx->len);
    		pos += tx->len;
    		/* Append the LF character when the CR character triggered
    		 * transmission from the peer.
    		if ((pos == len) && (data[len - 1] == '\r')) {
    			tx->data[tx->len] = '\n';
    			tx->len++;
    		if (err) {
    			k_fifo_put(&fifo_uart_tx_data, tx);
    static struct bt_nus_cb nus_cb = {
    	.received = bt_receive_cb,
    void error(void)
    	dk_set_leds_state(DK_ALL_LEDS_MSK, DK_NO_LEDS_MSK);
    	while (true) {
    		/* Spin for ever */
    		k_sleep(K_MSEC(1000));
    static void num_comp_reply(bool accept)
    	if (accept) {
    		bt_conn_auth_passkey_confirm(auth_conn);
    		LOG_INF("Numeric Match, conn %p", (void *)auth_conn);
    	} else {
    		bt_conn_auth_cancel(auth_conn);
    		LOG_INF("Numeric Reject, conn %p", (void *)auth_conn);
    	auth_conn = NULL;
    void button_changed(uint32_t button_state, uint32_t has_changed)
    	uint32_t buttons = button_state & has_changed;
    	if (auth_conn) {
    		if (buttons & KEY_PASSKEY_ACCEPT) {
    			num_comp_reply(true);
    		if (buttons & KEY_PASSKEY_REJECT) {
    			num_comp_reply(false);
    #endif /* CONFIG_BT_NUS_SECURITY_ENABLED */
    static void configure_gpio(void)
    	int err;
    	err = dk_buttons_init(button_changed);
    	if (err) {
    		LOG_ERR("Cannot init buttons (err: %d)", err);
    	err = dk_leds_init();
    	if (err) {
    		LOG_ERR("Cannot init LEDs (err: %d)", err);
    // static void read_conn_rssi(uint16_t handle, int8_t *rssi)
    // 	struct net_buf *buf, *rsp = NULL;
    // 	struct bt_hci_cp_read_rssi *cp;
    // 	struct bt_hci_rp_read_rssi *rp;
    // 	int err;
    // 	buf = bt_hci_cmd_create(BT_HCI_OP_READ_RSSI, sizeof(*cp));
    // 	if (!buf) {
    // 		printk("Unable to allocate command buffer\n");
    // 		return;
    // 	cp = net_buf_add(buf, sizeof(*cp));
    // 	cp->handle = sys_cpu_to_le16(handle);
    // 	err = bt_hci_cmd_send_sync(BT_HCI_OP_READ_RSSI, buf, &rsp);
    // 	if (err) {
    // 		uint8_t reason = rsp ?
    // 			((struct bt_hci_rp_read_rssi *)rsp->data)->status : 0;
    // 		printk("Read RSSI err: %d reason 0x%02x\n", err, reason);
    // 		return;
    // 	rp = (void *)rsp->data;
    // 	*rssi = rp->rssi;
    // 	net_buf_unref(rsp);
    	int err;
    	if (!buf) {
    		return;
    	if (err) {
    		return;
    	*rssi = rp->rssi;
    	net_buf_unref(rsp);
    	struct bt_hci_cp_vs_read_tx_power_level *cp;
    	struct bt_hci_rp_vs_read_tx_power_level *rp;
    	int err;
    	*tx_pwr_lvl = 0xFF;
    	buf = bt_hci_cmd_create(BT_HCI_OP_VS_READ_TX_POWER_LEVEL,
    				sizeof(*cp));
    	if (!buf) {
    		return;
    	cp->handle_type = handle_type;
    	err = bt_hci_cmd_send_sync(BT_HCI_OP_VS_READ_TX_POWER_LEVEL,
    				   buf, &rsp);
    	if (err) {
    			((struct bt_hci_rp_vs_read_tx_power_level *)
    		printk("Read Tx power err: %d reason 0x%02x\n", err, reason);
    		return;
    	*tx_pwr_lvl = rp->tx_power_level;
    	net_buf_unref(rsp);
    void main(void)
    	int blink_status = 0;
    	int err = 0;
        int8_t rssi;
    	configure_gpio();
    	err = uart_init();
    	if (err) {
    		error();
    	if (IS_ENABLED(CONFIG_BT_NUS_SECURITY_ENABLED)) {
    		err = bt_conn_auth_cb_register(&conn_auth_callbacks);
    		if (err) {
    			printk("Failed to register authorization callbacks.\n");
    			return;
    		err = bt_conn_auth_info_cb_register(&conn_auth_info_callbacks);
    		if (err) {
    			printk("Failed to register authorization info callbacks.\n");
    			return;
    	err = bt_enable(NULL);
    	if (err) {
    		error();
    	LOG_INF("Bluetooth initialized");
    	k_sem_give(&ble_init_ok);
    	if (IS_ENABLED(CONFIG_SETTINGS)) {
    		settings_load();
    	err = bt_nus_init(&nus_cb);
    	if (err) {
    		LOG_ERR("Failed to initialize UART service (err: %d)", err);
    		return;
    	err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad), sd,
    			      ARRAY_SIZE(sd));
    	if (err) {
    		LOG_ERR("Advertising failed to start (err %d)", err);
    		return;
    	for (;;) {
    		dk_set_led(RUN_STATUS_LED, (++blink_status) % 2);
            read_conn_rssi(default_conn_handle, &rssi);
            LOG_INF("last RSSI %d", rssi);
    		k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
    void ble_write_thread(void)
    	/* Don't go any further until BLE is initialized */
    	k_sem_take(&ble_init_ok, K_FOREVER);
    	for (;;) {
    		/* Wait indefinitely for data to be sent over bluetooth */
    		struct uart_data_t *buf = k_fifo_get(&fifo_uart_rx_data,
    						     K_FOREVER);
    		if (bt_nus_send(NULL, buf->data, buf->len)) {
    			LOG_WRN("Failed to send data over BLE connection");
    		k_free(buf);
    K_THREAD_DEFINE(ble_write_thread_id, STACKSIZE, ble_write_thread, NULL, NULL,
    		NULL, PRIORITY, 0, 0);
    Edvin
  • hi Edvin
    yes i thought about the 'CONFIG_BT_CTLR_TX_PWR_PLUS_4' later on and actually on the ncs code base we used PLUS_8 cause its a common code base for several boards now but on the SDK code it was set to 4 tx_power
    so i added it in the .conf file of each board after i checked what was in the .config file .. and since nrf52832 apparently does not support tx_power 8, then it defaulted to zero i guess (the other board runs with nrf52840).
    i haven't replayed yet since i wanted to do some checking and see if it explains the difference i saw. and it seems like it does
