nrf21540 gain control
Hi All!
Hope you are doing well. I am using NCS 2.0.2 and VSCODE studio. Radio Test example using nrf52833+nrf21540(custom HW) . I want to ask a question how to control the gain of nrf21540 ?
How to enable it in the radio test example and what will be the sequence of commands for that?
I am using a sequence of commands with only nrf52833DK to ensure FW is working. And output RSSI value is increasing.
output_power pos0dB  /3db /8db
 start_channel 20
 end_channel 60
 start_tx_carrier
 start_tx_sweep
Thanks & Regards,
  • Hi Hieu
    Thank you again for your response and help.
    Looking at the error, I guess that you are working with a standalone project you created based on the radio_test sample. However, the radio_test sample does not work that way. You will need to build it from its location within the nRF Connect SDK.
    Thank you I tried your option and it worked for me for "nrf21540_52840".
    Will that option also work for "52833DK"?
    I added the following lines in  prj.conf file
    CONFIG_FEM=y
    CONFIG_MPSL=y
    CONFIG_MPSL_FEM=y
    CONFIG_MPSL_FEM_ONLY=y      #GPIO/ SPI control features
    CONFIG_MPSL_FEM_NRF21540_GPIO_SPI=y
    CONFIG_MPSL_FEM_NRF21540_RUNTIME_PA_GAIN_CONTROL=y
    CONFIG_MPSL_FEM_POWER_MODEL=y
    I tried for 52833DK by selecting the board from add build configuration but got the following warnings.
    warning: MPSL_FEM (defined at C:/ncs/v2.3.0/nrf\subsys\mpsl\fem/Kconfig:37) was assigned the value
    'y' but got the value 'n'. Check these unsatisfied dependencies: MPSL_FEM_ANY_SUPPORT (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MPSL_FEM and/or look up MPSL_FEM in the
    menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values,
    and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
    warning: MPSL_FEM_NRF21540_RUNTIME_PA_GAIN_CONTROL (defined at
    C:/ncs/v2.3.0/nrf\subsys\mpsl\fem/Kconfig:132) was assigned the value 'y' but got the value 'n'.
    Check these unsatisfied dependencies: (MPSL_FEM_NRF21540_GPIO || MPSL_FEM_NRF21540_GPIO_SPI) (=n),
    MPSL_FEM (=n), (MPSL_FEM || MPSL_FEM_PIN_FORWARDER) (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MPSL_FEM_NRF21540_RUNTIME_PA_GAIN_CONTROL
    and/or look up MPSL_FEM_NRF21540_RUNTIME_PA_GAIN_CONTROL in the menuconfig/guiconfig interface. The
    Parsing C:/ncs/v2.3.0/nrf/samples/peripheral/radio_test/Kconfig
    Loaded configuration 'C:/ncs/v2.3.0/zephyr/boards/arm/nrf52833dk_nrf52833/nrf52833dk_nrf52833_defconfig'
    Merged configuration 'c:/ncs/v2.3.0/nrf/samples/peripheral/radio_test/prj.conf'
    Configuration saved to 'C:/ncs/v2.3.0/nrf/samples/peripheral/radio_test/build_1/zephyr/.config'
    Kconfig header saved to 'C:/ncs/v2.3.0/nrf/samples/peripheral/radio_test/build_1/zephyr/include/generated/autoconf.h'
    Application Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices
    warning: MPSL_FEM_POWER_MODEL (defined at C:/ncs/v2.3.0/nrf\subsys\mpsl\fem/Kconfig:154) was
    assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies: MPSL_FEM (=n).
    See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MPSL_FEM_POWER_MODEL and/or look up
    MPSL_FEM_POWER_MODEL in the menuconfig/guiconfig interface. The Application Development Primer,
    Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
    helpful too.
    warning: The choice symbol MPSL_FEM_NRF21540_GPIO_SPI (defined at
    C:/ncs/v2.3.0/nrf\subsys\mpsl\fem/Kconfig:70) was selected (set =y), but no symbol ended up as the
    choice selection. See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MPSL_FEM_NRF21540_GPIO_SPI and/or look up
    MPSL_FEM_NRF21540_GPIO_SPI in the menuconfig/guiconfig interface. The Application Development
    Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
    And CONFIG_FEM is also disabled
    is there any other thing I am missing? Because I have to run the code on custom Hardware nrf52833_nrf21540.
    Or do u have any other option for that?
    Firstly, I don't understand what you mean by the above options being disabled. Do you mean that you cannot set them for some reasons? Or do you mean their values are reset somehow?
     Thank you, now I understand my mistake after your response!
    Thanks & Regards,
    Muhammad Usman
  • Hi Muhammad,
    If you recall what I said in my earlier reply, it would make sense:
    Hieu said:
    Just want to share I understood the reason CONFIG_FEM was not set to y. Its dependency MPSL_FEM_ANY_SUPPORT was not set for boards without FEMs.
    The board nrf52833dk_nrf52833, which you are likely using, does not have a FEM defined in its Device Tree Specification (DTS).
    If you are using the nRF21540 EK as a shield on top of the nRF52833 DK, you can get the FEM defined in the final compiled DTS by building with the -DSHIELD=nrf21540_ek argument.
    You can find that documented in the Radio Test sample documentation.
    In the future, where you have a custom board, you have two options.
    1. Use DTS Overlay to "overlay" the nrf52833dk_nrf52833 board definition into your custom board
    2. Create your custom board.
    To prepare for that, I recommend you read and fully understand the following pages (and their subpages):
    Devicetree HOWTOs — Zephyr Project Documentation (nordicsemi.com)
    Board support — nRF Connect SDK 2.3.99 documentation (nordicsemi.com)
    The two pages above are just on the DTS topic. If possible, I recommend you read the entire application development guide from Zephyr and NCS.
    Application development — nRF Connect SDK 2.3.99 documentation (nordicsemi.com)
    Application Development — Zephyr Project Documentation (nordicsemi.com)
    I understand that they are a lot. However, to realize a complete product with DFU, wireless connectivity, and custom board, you most likely would need a lot of the knowledge in those pages. Of course, some section can be skipped if they are obviously not applicable to you, such as Wi-Fi.
    Hieu
  • Hi Hieu!
    Again thank you so much for your support!
    You are right, I have to read and understand the basic functionality. Thank you for the links and guidance! Definitely, I will go through all these.
    In the last 2 days, I tried to enable the nrf21540 FEM module for nrf52833. I assigned the pins according to the custom board design (nrf21540+nrf52833).I want to share my work with you. Am I in the right direction?
    Here is the image which explains the configuration of the .dts .overlay file and device tree output.Now MP
    Now,
    CONFIG_MPSL=y
    CONFIG_MPSL_FEM=y
    also enabled in the prj.conf file and "fem.h" in radio_cmd.c  and radio_test.c as well.
    The last thing pending is to test on custom HW. Which will be available to me in 4-5 days.
    Thanks & Regards,
    Muhammad Usman
  • Hi Muhammad,
    I am not too confident in review things without test, but the content looks right to me. Just remember to define the SPI IF pins correctly as well.
    Are you modifying the nrf52833dk_nrf52833.dts file directly? You shouldn't do that, and just use the overlay file.
    Finally, as we discussed before, the three Kconfigs you listed should be enabled by default if your DTS work correctly, so please try not setting them explicitly, and run a build to see if they are enabled by default in the zephyr/.config file.
    On second thought, if the DTS setup does not work correctly, the Kconfigs should also just be disabled due to unsatisfied dependencies.
    Hieu
  • Hi Hieu,
    Thank you so much for your support! Sure i will follow all your instructions. yes, I modified the overlay file only. Will take 1-2 days to get the hardware for testing. I will update my findings soon on it.
    Thanks &  Regards,
    Muhammad Usman
