how can i get the number BLE TX re transmissions
hello Nordic
i am working with nrf52832 and nrf52840 socs, with ncs v2.1.0
i would like to know how many of the BLE packets i am sending has to be resent (and if it is possible to know the reason of resent, in case there is another reason beside packet missed some bytes/bits on the OTA way, that would be great as well )
any idea how can i get that info ?
also another question, if i move (with BLE 4.2 and above) to extended length packets, to increase throughput, should there be more resent packets since the risk of loosing data in a larger packet is greater ?
hope to read you soon
best regards
Ziv
    ziv123 said:
    what can cause the diff ?
    Based on my testing, if the SDC e.g. dropped a connection event, i.e. it was blocked for some reason(see link below), you will not get the callback. But the connection event counter is still incremented internally. And next time you get the callback, it will show you the updated counter value that matches the current connection event number.
    https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrfxlib/softdevice_controller/doc/scheduling.html#timing-activities-and-priorities
    ziv123 said:
    another question i have - is it possible to have the report start at some point after the connection between end point and node was established and not from the first moment of connection ?
    Yes, you can enable/disable this reporting as needed.
    thanks, for the patient and help :) few more questions
    1. is there some example or place to look for how to enable it after a connection was establish and disable before a connection is terminated ?
    2. i got values when analysing my data transfer connection via different Rssi values while Node is also scanning for another device that is in it's white list. i am trying to understand what can i understand by the type of fails i get.
    when having more then one device in the Node white list with rssi ~40 : i get around 8300 timeouts and ~330 naks but only ~12 crc fails. total connection events count ~11330
    when i have one device in the white list with same rssi, i get around 200 timeouts, ~350 naks and ~8crc. total connection events count ~ 5660
    with more then one device in Node white list but with rssi ~70 : ~8800 timeouts, ~560 naks (in compare to ~330), ~200 crc (in compare to ~12). total ~11820
    i guess crc fail is caused by some bit miss but then what may be the reason to receive naks ?
    also what can i learn on the connection if i get so many timeouts on one state and much less on another state (rssi on both tests was the same), and what is the different causes for timeouts that explains the different values in comparison to the other two reasons ?
    in all cases total data size transmitted is the same.so also when trying to calculate how many re transmission and how many total connection events it seems that there is no "gold" number of connection events to transfer a known size of data it varies a lot from case to case. is there something to learn from looking on how many re  transmissions and total connection events count ?
    best regards
    Ziv
    Just call the enable/disable function in the connected/disconnected callback you get when a device connects/disconnects.
    If you are getting rx_timeout, then the central did not send a packet when it was expected. I'm not sure what you mean by node white list, but if the central device is connected to other devices, then it's maybe skipping connection events, and then the reason for the timeout have to do with scheduling. You can read about how the SDC handles scheduling here: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.3.0/nrfxlib/softdevice_controller/doc/scheduling.html , you could e.g try to change connection interval and see how that affects the behavior. Also a sniffer log can be useful here, maybe it's skipping every x connection events. For nak_count, then the other device did not get your packet last connection event, and a packet needed to be retransmitted.
  • hi Sigurd
    it has been a while since i touched this issue. i am back on it now.
    I am enabling the connection event report and it works ok.
    1. What added values can i get from the channel index if I look at the complete time of connection between central and peripheral ?
    2. Is there some other info I can get from the softdevice that can give insight / statistics on the BLE connection health, noise, density etc. ? (i am also reading RSSI on peripheral side and central side)
    3. i am using the same function as in the ncs example [ enable_qos_conn_evt_report() ] to enable the callback on the connection events
    does it matter if i call it once in my application comm's init function, without disabling it (ever) ?
    can i enable and disable it while a connection is already active between central and peripheral ?
    how can i disable the callback ?
    best regards
    Ziv
  • Hi Ziv,
    Great!
    I don't understand this question.
    We have recently added a new feature on the main branch. https://github.com/nrfconnect/sdk-nrfxlib/blob/main/softdevice_controller/CHANGELOG.rst#id317 that gives you channel_energy.
    "Experimental support for the Quality of Service (QoS) channel survey. See the :c:func:`sdc_hci_cmd_vs_qos_channel_survey_enable` function."
    I don't think there is any limitations here. You disable it in the same way as you enabled, but instead of cmd_enable->enable = true; , you set cmd_enable->enable = false;
    PS: I believe the original question in this case, "how can i get the number BLE TX re transmissions", has been answered. If you have new questions or issues, please open a new case.
