MCP2518 SPI-CAN integration with nrf52840
I am using nrf52840 on a custom board. I have a MCP2518 to which I wish to communicate through the SPI interface. I changed the dts file accordingly and added the bindings and finally got it to build. The problem is I cannot access the SPI bus. My custom driver is based on the mc2518 driver that is part of NRF Connectv2.2.0 . I have modified it and removed everything except the initialization part where it checks if the devices and bus is ready. I have not started using that however. I cannot get an instance of the MCP2518 because the initialization fails. The failure point is where it checks whether the SPI bus is ready. Exactly this same position as described in this post. It seems like that question is inactive now. So I though I would raise this question here. I hope it is alright.
There are a few additional observations too. If i do device_is_ready() on the SPI bus instance from main() of my application, it returns success. However, if I do the same check in my custom driver module, right before the above failure point, I get failure. I dont know if this bit of info helps and I dont know why it behaves differently.
I would very much appreciate it if anyone could help.
device ; nrf52840
NCS v2.2.0
trying to interface mcp2518fd
    I tried that. But i didnt see any change in the behavior. I did not really expect to see much change in the behavior eithe since I am accessing the node like this in main.c
    As far as I can tell, this is fine. right ? Or is there any other module looking for the zzephy_canbus as chosen ?
    Also, can you confirm if I need CONFIG_SPI and CONFIG_CAN enabled in my prj.conf ? Since I am using a custom written kernel module, I am not sure if I should include them. But if I dont include both of them, I run into the previous linking error, even if I add the zephyr,canbus line in dts and make corresponding changes in the main.c
    Thanks
    Yes, those are needed.
    What do you mean by this? Do you mean a custom written application?
    Does any of the can-samples in zephyr work as expected with your .overlay?
    Remember to also include your INIT priority configuration to ensure that the ordering on boot is correct.
    Håkon
  • What do you mean by this? Do you mean a custom written application?
    yes. The nordic samples implement MCP2515 driver. But I am working with MCP2518 and so, I am trying to get my kernel drivers ready for that.
    yes, I confirmed the working with dfrobot CAN shield. The counter example which works on loopback was implemented alright. Later I connected PCAN View too in CAN normal mode and verified the working.
    that is done. I no longer have the problem with initialization it seems. For some reason however, my 2518 does not seem to be responding at all. I try writing and the whole application reboots. I try reading and all I get is 0xFF.
    If the overlay, and SPI connection towards your sensor is verified to work, then it sounds like the MCP25xx integration isn't working for your specific device. Have you tried asking the zephyr community about this?
    Håkon
    Sorry for the late reply. I have not asked the zephyr community about the issue. Before I do that, is there any way I can verify that my SPI bus is active ? When I read from an address of the MCP2518FD on my custom board, all I get is the value 255. I just wanted to know if it is because my SPI bus is not active or because there is something faulty with my device
    Thanks.
