How to avoid data collision in a network of NRF devices where only 2 NRF want to communicate with each other and others dont get this data ?
We are using NRF24L01 as a transreceiver. We have a network of NRF devices operating individually and we want one NRF to communicate only with its respective NRF. However the data collision happens during this. The NRFs in the network also receives this data despite keeping the different frequency.
We cant have multiple frequencies for our every product.
So, is there any way to avoid data collision / interference so that only 2 desired NRF will communicate with each other and other NRF devices in the network wpn't get that data ??
Thanks and Regards ,
Harshal
    So basically the mere act of receiving data will cause the device to reset?
    Yes.
    Will receiving the ACK from the correct PRX not cause this to happen?
    Whether from correct PRX or any other PRX, when the PTX receives a payload of ACK/Response its reseted.
    Have you done some measurements with a scope to verify how high the supply voltage is, and how much RF activity you are able to sustain before the voltage drops too low?
    Does the MCU have some kind of low voltage warning that would allow you to prepare for such a situation?
    okay, that's a great suggestion, Need to check with this.
    Are all the PTX's in the area using the same RF addres
    No, every pair is having the unique addressing.
  • Hi
    Then it sounds like you need to make some improvements to the supply architecture, in order to ensure you have the energy available to perform a successful radio transmission.
    How much decoupling capacitance do you have on the supply lines?
    Possibly you can improve the situation by using larger caps, in order to store up more energy before you start a radio transmission.
    Also, if you are using 1M on air bitrate today you could reduce energy consumption by switching to the 2M mode, at the cost of slightly reduced range.
    Using one of our latest nRF devices like the nRF52810 would also help reduce energy consumption considerably, but then you would need to completely redesign your software, so this is not an easy migration. The nRF52810 has less than half the peak current in TX/RX, and also includes an MCU so you don't need to have a separate host MCU.
    Best regards
    Torbjørn
    We are using 250kbps data rate. Range is not a constraint as the PTX and PRX operate closer to each other in a pair.
    In fact it'd be great if we get a reduced range this will stop the signals from PTX to reach to any other PRX.
  • Hi
    Do you know why you picked the 250kbps data rate in the first place, if you don't need long range?
    If you change to 2M mode instead you should reduce the packet on air time by a factor of 8, which will reduce the energy consumption of each packet transmission and reception considerably.
    Best regards
    Torbjørn
  • Do you know why you picked the 250kbps data rate in the first place, if you don't need long range?
    It was for the POC and sadly we sticked to it.
    Yes, thanks a ton !!
