We're using nRF Connect SDK 1.9.1, we have a requirement of getting SNR / PER values in nRF connect SDK.
do we have any provision to get these values from physical layer if possible ?
Thank you,
Hitesh
Thank you,
Hitesh
Hi ovrebekk,
Can you please share how do we get RX_sensitivity from nRF Connect SDK 1.9.1?
I which file we'll get the value of RX_sensitivity?
Thank you,
Hitesh
Hi Hitesh
The RX sensitivity is not defined anywhere in the code, you have to find this in the product specification for the part you are using.
As an example, for the nRF52840 you can find the RX sensitivity numbers here.
Please note that the RX sensitivity is different for different radio modes, and you have to make sure to refer to the correct value for the mode you are using.
Best regards
Torbjørn
We're using nRF52833, I'm attaching the screenshot of datasheet capture for Rx sensitivity,
can you please update which value do I refer to calculate SNR?
Thank you,
Hitesh
Hi Hitesh
If you're running standard Bluetooth mesh then you should refer to the P_SENS,IT,SP,1M,BLE value, meaning the sensitivity is -96dBm.
Best regards
Torbjørn
I have some confusion with regards to the SNR calculation suggested by Nordic in mail trail below. I would like to understand your opinion.
I was going through this site Signal-to-Noise Ratio (SNR) and Wireless Signal Strength - Cisco Meraki
Since the SNR is difference in between the Received signal and the Noise floor , I have one query with respect to the answer received from Nordic.
According to Nordic inputs : SNR is as follows:
If this is so then higher the sensitivity of our antenna higher is the ability to detect weaker signals. Thus if sensitivity is -96dbm at 1mbps with packet size < 37bytes ,as per snap shared by @Shinde, Ramesh T (refer mail below), then for a actual signal (good signal) of -70dbm then SNR is -70 –(-96dbm) = 26dbm which is a very good SNR value. i.e. since the difference between the required signal and the noise signal is big. While it may be so that the other noisy signal in the area are having the signal strength of -80dbm as well, which will intern lead to a SNR of -70-(80)dbm = 10db. Which is not so good SNR.
So my understanding is that the SNR should not be related to sensitivity, but to the overall noise floor of the region.
Thank you,
Hitesh
