nRF5340 DTM Serial Pin Modification Unsuccessful
Dear Nordic,
I have custom nRF5340 board in my hands and I am going to evaluate its RF performance.
I have ncs2.3.0 in use.
In order to do so, I have nRF5340dk (PCA10095) and I have successfully built the default ncs -> samples -> direct_test_mode example and verified that using RealTerm, the transmitter gets active.
However, my custom board has a few GPIOs interfaced outside, no USB, and I would first like to verify with the dk board that I can control the transmitter using the very same GPIOS. Let us assume that the GPIOs are P0.08 (RX) and P0.09 (TX). I tried to add the GPIOs to the nrf5340dk_nrf5340_cpunet.overlay file as attached but building it failed.
Could you advise me little bit that how I am supposed to change the uart pins for the DTM mode?
	chosen {
		ncs,dtm-uart = &uart0;
&uart0 {
	status = "okay";
	compatible = "nordic,nrf-ipc-uart";
	ipc = <&ipc0>;
	ept-name = "remote shell";
	current-speed = <19200>;
	tx-pin = < 8 >;
	rx-pin = < 9 >;
&radio {
	status = "okay";
	/* This is a number of antennas that are available on antenna matrix
	 * designed by Nordic. For more information see README.rst.
	dfe-antenna-num = <12>;
	/* This is a setting that enables antenna 12 (in antenna matrix designed
	 * by Nordic) for PDU. For more information see README.rst.
	dfe-pdu-antenna = <0x0>;
	/* These are GPIO pin numbers that are provided to
	 * Radio peripheral. The pins will be acquired by Radio to
	 * drive antenna switching.
	 * Pin numbers are selected to drive switches on antenna matrix
	 * desinged by Nordic. For more information see README.rst.
	dfegpio0-gpios = <&gpio0 4 0>;
	dfegpio1-gpios = <&gpio0 5 0>;
	dfegpio2-gpios = <&gpio0 6 0>;
	dfegpio3-gpios = <&gpio0 7 0>;
FAILED: build.ninja
C:\ncs\toolchains\v2.3.0\opt\bin\cmake.exe --regenerate-during-build -SC:\ncs\v2.3.0\nrf\samples\bluetooth\direct_test_mode -BC:\ncs\v2.3.0\nrf\samples\bluetooth\direct_test_mode\build
ninja: error: rebuilding 'build.ninja': subcommand failed
FATAL ERROR: command exited with status 1: 'c:\ncs\toolchains\v2.3.0\opt\bin\cmake.EXE' --build 'c:\ncs\v2.3.0\nrf\samples\bluetooth\direct_test_mode\build'
