out of tree driver; builds, links but not in map
I have an out of tree driver (vl53l1x) building and linking for an out of tree board which works.
However, another driver for bmi088, builds, appears to link but does not appear in the map files
which leads to this error when I try and use the sensor --> undefined reference to `__device_dts_ord_127'
I have a feeling the dts fragment may be the cause but not sure at this point.
source tree looks like this
- project_root
  - boards
  - dts
  - hello_world
    CMakeLists.txt
    KConfig
    prf.conf
    sample.yaml
  - drivers
    CMakeLists.txt
    KConfig
    - sensor
      CMakeLists.txt
      KConfig
      - bmi088
        CMakeLists.txt
        KConfig
        <other code files>
      - vl53l1x (functioning)
  - src
    main.c
Without trying to use the sensor
[172/184] Linking C static library drivers\sensor\bmi088\lib..__..__..__workvob__xqc__bringup_empty__hello_world__drivers__sensor__bmi088.a
[173/184] Linking C static library zephyr\kernel\libkernel.a
[174/184] Linking C executable zephyr\zephyr_pre0.elf
When I try to use the sensor
[174/185] Linking C static library drivers\sensor\bmi088\lib..__..__..__workvob__xqc__bringup_empty__hello_world__drivers__sensor__bmi088.a
[175/185] Linking C executable zephyr\zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
c:/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.exe: app/libapp.a(main.c.obj): in function `get_gyro_device':
C:\workvob\xqc\bringup_empty\hello_world\src\main.c:131: undefined reference to `__device_dts_ord_127'
Other functioning sensors left out
&i2c1 {
    status = "okay";
    clock-frequency = <I2C_BITRATE_FAST>;
    pinctrl-0 = <&i2c1_default>;
    pinctrl-1 = <&i2c1_sleep>;
    gyro: bmi088_gyr@69 {
      compatible = "bosch,bmi088-gyr";
      status = "okay";
      reg = <0x69>;
      // datasheet page 39
      bandwidth = <0x06>; // corner-frequency at 64 Hz
    acc: bmi088_acc@18 {
      compatible = "bosch,bmi088-acc";
      status = "okay";
      reg = <0x18>;
      odr = <0x0B>; // 800 Hz
      osr = <0x08>; // 4 times oversampled
