Dynamically assign MQTT subscription topic on AWS
I try to subscribe to a MQTT topic on AWS using the following code which is used to compose a dynamic MQTT topic based on IMEI
char imei[32] = {'\0',};
modem_info_string_get(MODEM_INFO_IMEI, imei, sizeof(imei));
printk("Modem IMEI: %s \n", imei);
static char settingsString[20] =  "/settings\0";
static char topicString[75];
strcpy(topicString, imei);
strcat(topicString, settingsString);
printk("Subscribe string: %s \n", imei);
printk("Subscribe string length: %d \n", strlen(imei));
const struct aws_iot_topic_data topics_list[APP_TOPICS_COUNT] = {
	[0].str = *topicString,
	[0].len = strlen(*topicString)};
err = aws_iot_subscription_topics_add(topics_list, ARRAY_SIZE(topics_list));
if (err)
	printk("aws_iot_subscription_topics_add, error: %d\n", err);
The output is this (*** for security reasons)
Modem IMEI: 351358815046***
Subscribe string: 351358815046***/settings
Subscribe string length: 24
If I now publish a message using AWS MQTT Client the message will not reach the device. The strange thing is if i declare the same variable hard coded using
static char topicString[75] = "351358815046880/settings"
All works as expected and the publish messages get received as expected.
Is there anything wrong using the strcat function?
Thanks!
    What version of the nRF Connect SDK are you using? Could there be an issue with "\0" added to end of settingsString?
    Øyvind
  • I tried with and without the "\0", result is the same.
    I am using  2.1.2
  • Are you able to provide me the project you are working on, in order to reproduce the issue?
  • Below is the aws_iot sample as provided with minimal changes.
    main.c
     * Copyright (c) 2020 Nordic Semiconductor ASA
    #include <zephyr/kernel.h>
    #include <stdio.h>
    #include <stdlib.h>
    #if defined(CONFIG_NRF_MODEM_LIB)
    #include <modem/lte_lc.h>
    #include <modem/nrf_modem_lib.h>
    #include <modem/modem_info.h>
    #include <nrf_modem.h>
    #include <net/aws_iot.h>
    #include <zephyr/sys/reboot.h>
    #include <date_time.h>
    #include <zephyr/dfu/mcuboot.h>
    #include <cJSON.h>
    #include <cJSON_os.h>
    char imei[32] = {
    	'\0',
    LOG_MODULE_REGISTER(aws_iot_sample, CONFIG_AWS_IOT_SAMPLE_LOG_LEVEL);
    BUILD_ASSERT(!IS_ENABLED(CONFIG_LTE_AUTO_INIT_AND_CONNECT),
    	     "This sample does not support LTE auto-init and connect");
    #define APP_TOPICS_COUNT CONFIG_AWS_IOT_APP_SUBSCRIPTION_LIST_COUNT
    static struct k_work_delayable shadow_update_work;
    static struct k_work_delayable connect_work;
    static struct k_work shadow_update_version_work;
    static bool cloud_connected;
    static K_SEM_DEFINE(lte_connected, 0, 1);
    static K_SEM_DEFINE(date_time_obtained, 0, 1);
    NRF_MODEM_LIB_ON_INIT(aws_iot_init_hook, on_modem_lib_init, NULL);
    /* Initialized to value different than success (0) */
    static int modem_lib_init_result = -1;
    static void on_modem_lib_init(int ret, void *ctx)
    	modem_lib_init_result = ret;
    static int json_add_obj(cJSON *parent, const char *str, cJSON *item)
    	cJSON_AddItemToObject(parent, str, item);
    	return 0;
    static int json_add_str(cJSON *parent, const char *str, const char *item)
    	cJSON *json_str;
    	json_str = cJSON_CreateString(item);
    	if (json_str == NULL) {
    		return -ENOMEM;
    	return json_add_obj(parent, str, json_str);
    static int json_add_number(cJSON *parent, const char *str, double item)
    	cJSON *json_num;
    	json_num = cJSON_CreateNumber(item);
    	if (json_num == NULL) {
    		return -ENOMEM;
    	return json_add_obj(parent, str, json_num);
    static int shadow_update(bool version_number_include)
    	int err;
    	char *message;
    	int64_t message_ts = 0;
    	int16_t bat_voltage = 0;
    	err = date_time_now(&message_ts);
    	if (err) {
    		LOG_ERR("date_time_now, error: %d", err);
    		return err;
    	/* Request battery voltage data from the modem. */
    	err = modem_info_short_get(MODEM_INFO_BATTERY, &bat_voltage);
    	if (err != sizeof(bat_voltage)) {
    		LOG_ERR("modem_info_short_get, error: %d", err);
    		return err;
    	cJSON *root_obj = cJSON_CreateObject();
    	cJSON *state_obj = cJSON_CreateObject();
    	cJSON *reported_obj = cJSON_CreateObject();
    	if (root_obj == NULL || state_obj == NULL || reported_obj == NULL) {
    		cJSON_Delete(root_obj);
    		cJSON_Delete(state_obj);
    		cJSON_Delete(reported_obj);
    		err = -ENOMEM;
    		return err;
    	if (version_number_include) {
    		err = json_add_str(reported_obj, "app_version", CONFIG_APP_VERSION);
    	} else {
    		err = 0;
    	err += json_add_number(reported_obj, "batv", bat_voltage);
    	err += json_add_number(reported_obj, "ts", message_ts);
    	err += json_add_obj(state_obj, "reported", reported_obj);
    	err += json_add_obj(root_obj, "state", state_obj);
    	if (err) {
    		LOG_ERR("json_add, error: %d", err);
    		goto cleanup;
    	message = cJSON_Print(root_obj);
    	if (message == NULL) {
    		LOG_ERR("cJSON_Print, error: returned NULL");
    		err = -ENOMEM;
    		goto cleanup;
    	struct aws_iot_data tx_data = { .qos = MQTT_QOS_0_AT_MOST_ONCE,
    					.topic.type = AWS_IOT_SHADOW_TOPIC_UPDATE,
    					.ptr = message,
    					.len = strlen(message) };
    	LOG_INF("Publishing: %s to AWS IoT broker", message);
    	err = aws_iot_send(&tx_data);
    	if (err) {
    		LOG_ERR("aws_iot_send, error: %d", err);
    	cJSON_FreeString(message);
    cleanup:
    	return err;
    static void connect_work_fn(struct k_work *work)
    	int err;
    	if (cloud_connected) {
    		return;
    	err = aws_iot_connect(NULL);
    	if (err) {
    		LOG_ERR("aws_iot_connect, error: %d", err);
    	LOG_INF("Next connection retry in %d seconds", CONFIG_CONNECTION_RETRY_TIMEOUT_SECONDS);
    	k_work_schedule(&connect_work, K_SECONDS(CONFIG_CONNECTION_RETRY_TIMEOUT_SECONDS));
    static void shadow_update_work_fn(struct k_work *work)
    	int err;
    	if (!cloud_connected) {
    		return;
    	err = shadow_update(false);
    	if (err) {
    		LOG_ERR("shadow_update, error: %d", err);
    	LOG_INF("Next data publication in %d seconds", CONFIG_PUBLICATION_INTERVAL_SECONDS);
    	k_work_schedule(&shadow_update_work, K_SECONDS(CONFIG_PUBLICATION_INTERVAL_SECONDS));
    static void shadow_update_version_work_fn(struct k_work *work)
    	int err;
    	err = shadow_update(true);
    	if (err) {
    static void print_received_data(const char *buf, const char *topic, size_t topic_len)
    	char *str = NULL;
    	cJSON *root_obj = NULL;
    	root_obj = cJSON_Parse(buf);
    	if (root_obj == NULL) {
    		LOG_ERR("cJSON Parse failure");
    		return;
    	str = cJSON_Print(root_obj);
    	if (str == NULL) {
    		LOG_ERR("Failed to print JSON object");
    		goto clean_exit;
    	LOG_INF("Data received from AWS IoT console: Topic: %.*s Message: %s", topic_len, topic,
    		str);
    	cJSON_FreeString(str);
    clean_exit:
    void aws_iot_event_handler(const struct aws_iot_evt *const evt)
    	switch (evt->type) {
    	case AWS_IOT_EVT_CONNECTING:
    		LOG_INF("AWS_IOT_EVT_CONNECTING");
    	case AWS_IOT_EVT_CONNECTED:
    		LOG_INF("AWS_IOT_EVT_CONNECTED");
    		cloud_connected = true;
    		/* This may fail if the work item is already being processed,
    		 * but in such case, the next time the work handler is executed,
    		 * it will exit after checking the above flag and the work will
    		 * not be scheduled again.
    		(void)k_work_cancel_delayable(&connect_work);
    		if (evt->data.persistent_session) {
    			LOG_INF("Persistent session enabled");
    		/** Successfully connected to AWS IoT broker, mark image as
    		 *  working to avoid reverting to the former image upon reboot.
    		boot_write_img_confirmed();
    		/** Send version number to AWS IoT broker to verify that the
    		 *  FOTA update worked.
    		k_work_submit(&shadow_update_version_work);
    		/** Start sequential shadow data updates.
    		int err = lte_lc_psm_req(true);
    		if (err) {
    			LOG_ERR("Requesting PSM failed, error: %d", err);
    	case AWS_IOT_EVT_READY:
    		LOG_INF("AWS_IOT_EVT_READY");
    	case AWS_IOT_EVT_DISCONNECTED:
    		LOG_INF("AWS_IOT_EVT_DISCONNECTED");
    		cloud_connected = false;
    		(void)k_work_cancel_delayable(&shadow_update_work);
    		k_work_schedule(&connect_work, K_NO_WAIT);
    	case AWS_IOT_EVT_DATA_RECEIVED:
    		LOG_INF("AWS_IOT_EVT_DATA_RECEIVED");
    		print_received_data(evt->data.msg.ptr, evt->data.msg.topic.str,
    				    evt->data.msg.topic.len);
    	case AWS_IOT_EVT_PUBACK:
    		LOG_INF("AWS_IOT_EVT_PUBACK, message ID: %d", evt->data.message_id);
    	case AWS_IOT_EVT_FOTA_START:
    		LOG_INF("AWS_IOT_EVT_FOTA_START");
    	case AWS_IOT_EVT_FOTA_ERASE_PENDING:
    		LOG_INF("AWS_IOT_EVT_FOTA_ERASE_PENDING");
    		LOG_INF("Disconnect LTE link or reboot");
    		err = lte_lc_offline();
    		if (err) {
    			LOG_ERR("Error disconnecting from LTE");
    	case AWS_IOT_EVT_FOTA_ERASE_DONE:
    		LOG_INF("AWS_FOTA_EVT_ERASE_DONE");
    		LOG_INF("Reconnecting the LTE link");
    		err = lte_lc_connect();
    		if (err) {
    			LOG_ERR("Error connecting to LTE");
    	case AWS_IOT_EVT_FOTA_DONE:
    		LOG_INF("AWS_IOT_EVT_FOTA_DONE");
    		LOG_INF("FOTA done, rebooting device");
    		aws_iot_disconnect();
    		sys_reboot(0);
    	case AWS_IOT_EVT_FOTA_DL_PROGRESS:
    		LOG_INF("AWS_IOT_EVT_FOTA_DL_PROGRESS, (%d%%)", evt->data.fota_progress);
    	case AWS_IOT_EVT_ERROR:
    		LOG_INF("AWS_IOT_EVT_ERROR, %d", evt->data.err);
    	case AWS_IOT_EVT_FOTA_ERROR:
    		LOG_INF("AWS_IOT_EVT_FOTA_ERROR");
    		LOG_WRN("Unknown AWS IoT event type: %d", evt->type);
    static void work_init(void)
    	k_work_init_delayable(&shadow_update_work, shadow_update_work_fn);
    	k_work_init_delayable(&connect_work, connect_work_fn);
    	k_work_init(&shadow_update_version_work, shadow_update_version_work_fn);
    static void lte_handler(const struct lte_lc_evt *const evt)
    	case LTE_LC_EVT_NW_REG_STATUS:
    		if ((evt->nw_reg_status != LTE_LC_NW_REG_REGISTERED_HOME) &&
    		    (evt->nw_reg_status != LTE_LC_NW_REG_REGISTERED_ROAMING)) {
    		LOG_INF("Network registration status: %s",
    			evt->nw_reg_status == LTE_LC_NW_REG_REGISTERED_HOME ?
    				"Connected - home network" :
    				"Connected - roaming");
    		k_sem_give(&lte_connected);
    	case LTE_LC_EVT_PSM_UPDATE:
    		LOG_INF("PSM parameter update: TAU: %d, Active time: %d", evt->psm_cfg.tau,
    			evt->psm_cfg.active_time);
    	case LTE_LC_EVT_EDRX_UPDATE: {
    		char log_buf[60];
    		ssize_t len;
    		len = snprintf(log_buf, sizeof(log_buf), "eDRX parameter update: eDRX: %f, PTW: %f",
    			       evt->edrx_cfg.edrx, evt->edrx_cfg.ptw);
    		if (len > 0) {
    			LOG_INF("%s", log_buf);
    	case LTE_LC_EVT_RRC_UPDATE:
    		LOG_INF("RRC mode: %s",
    			evt->rrc_mode == LTE_LC_RRC_MODE_CONNECTED ? "Connected" : "Idle");
    	case LTE_LC_EVT_CELL_UPDATE:
    		LOG_INF("LTE cell changed: Cell ID: %d, Tracking area: %d", evt->cell.id,
    			evt->cell.tac);
    static void modem_configure(void)
    	int err;
    	if (IS_ENABLED(CONFIG_LTE_AUTO_INIT_AND_CONNECT)) {
    		/* Do nothing, modem is already configured and LTE connected. */
    	} else {
    		err = lte_lc_init_and_connect_async(lte_handler);
    		if (err) {
    			LOG_ERR("Modem could not be configured, error: %d", err);
    			return;
    static void nrf_modem_lib_dfu_handler(void)
    	int err;
    	err = modem_lib_init_result;
    	switch (err)
    	case MODEM_DFU_RESULT_OK:
    		printk("Modem update suceeded, reboot\n");
    		sys_reboot(SYS_REBOOT_COLD);
    	case MODEM_DFU_RESULT_UUID_ERROR:
    	case MODEM_DFU_RESULT_AUTH_ERROR:
    		printk("Modem update failed, error: %d\n", err);
    		printk("Modem will use old firmware\n");
    	case MODEM_DFU_RESULT_HARDWARE_ERROR:
    	case MODEM_DFU_RESULT_INTERNAL_ERROR:
    		printk("Modem update malfunction, error: %d, reboot\n", err);
    static int app_topics_subscribe(void)
    	int err;
    	static char settingsString[20] = "/settings";
    	static char custom_topic_2[75] = "my-custom-topic/example_2";
    		[0].str = topicString,
    		[0].len = strlen(topicString),
    		[1].str = custom_topic_2,
    		[1].len = strlen(custom_topic_2)
    	if (err) {
    		LOG_ERR("aws_iot_subscription_topics_add, error: %d", err);
    	return err;
    static void date_time_event_handler(const struct date_time_evt *evt)
    	case DATE_TIME_OBTAINED_MODEM:
    		/* Fall through */
    	case DATE_TIME_OBTAINED_NTP:
    		/* Fall through */
    	case DATE_TIME_OBTAINED_EXT:
    		LOG_INF("Date time obtained");
    		k_sem_give(&date_time_obtained);
    		/* De-register handler. At this point the sample will have
    		 * date time to depend on indefinitely until a reboot occurs.
    		date_time_register_handler(NULL);
    	case DATE_TIME_NOT_OBTAINED:
    		LOG_INF("DATE_TIME_NOT_OBTAINED");
    		LOG_ERR("Unknown event: %d", evt->type);
    void main(void)
    	int err;
    	LOG_INF("The AWS IoT sample started, version: %s", CONFIG_APP_VERSION);
    	cJSON_Init();
    	nrf_modem_lib_dfu_handler();
    	err = aws_iot_init(NULL, aws_iot_event_handler);
    	if (err) {
    		LOG_ERR("AWS IoT library could not be initialized, error: %d", err);
    	/** Subscribe to customizable non-shadow specific topics
    	 *  to AWS IoT backend.
    	err = app_topics_subscribe();
    	if (err) {
    		LOG_ERR("Adding application specific topics failed, error: %d", err);
    	work_init();
    	modem_configure();
    	err = modem_info_init();
    	if (err) {
    		LOG_ERR("Failed initializing modem info module, error: %d", err);
    	k_sem_take(&lte_connected, K_FOREVER);
    	/* Trigger a date time update. The date_time API is used to timestamp data that is sent
    	 * to AWS IoT.
    	date_time_update_async(date_time_event_handler);
    	/* Postpone connecting to AWS IoT until date time has been obtained. */
    	k_sem_take(&date_time_obtained, K_FOREVER);
    prj.conf (*** changed)
    # Copyright (c) 2020 Nordic Semiconductor ASA
    # General config
    CONFIG_NCS_SAMPLES_DEFAULTS=y
    CONFIG_REBOOT=y
    # NEWLIB C
    CONFIG_NEWLIB_LIBC=y
    # Log
    CONFIG_LOG=y
    # Network
    CONFIG_NETWORKING=y
    CONFIG_NET_NATIVE=n
    # LTE link control
    CONFIG_LTE_LINK_CONTROL=y
    CONFIG_LTE_NETWORK_MODE_LTE_M=y
    CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
    # Modem library
    CONFIG_NRF_MODEM_LIB=y
    # AT Host
    CONFIG_AT_HOST_LIBRARY=n
    # AWS IoT library
    CONFIG_AWS_IOT=y
    CONFIG_AWS_IOT_CLIENT_ID_STATIC="351358815046***"
    CONFIG_AWS_IOT_BROKER_HOST_NAME="***.iot.eu-central-1.amazonaws.com"
    CONFIG_AWS_IOT_SEC_TAG=***
    CONFIG_AWS_IOT_APP_SUBSCRIPTION_LIST_COUNT=2
    CONFIG_AWS_IOT_TOPIC_UPDATE_DELTA_SUBSCRIBE=y
    CONFIG_AWS_IOT_LAST_WILL=y
    CONFIG_AWS_IOT_TOPIC_GET_ACCEPTED_SUBSCRIBE=y
    CONFIG_AWS_IOT_TOPIC_GET_REJECTED_SUBSCRIBE=y
    # MQTT - Maximum MQTT keepalive timeout specified by AWS IoT Core
    CONFIG_MQTT_KEEPALIVE=1200
    # Date Time library
    CONFIG_DATE_TIME=y
    # Modem information
    CONFIG_MODEM_INFO=y
    # Heap and stacks
    CONFIG_HEAP_MEM_POOL_SIZE=8192
    CONFIG_MAIN_STACK_SIZE=4096
    # MCUBOOT
    CONFIG_BOOTLOADER_MCUBOOT=y
    CONFIG_MCUBOOT_IMG_MANAGER=y
    # Image manager
    CONFIG_IMG_MANAGER=y
    CONFIG_FLASH=y
    CONFIG_IMG_ERASE_PROGRESSIVELY=y
    # AWS FOTA
    CONFIG_AWS_FOTA=y
    CONFIG_FOTA_DOWNLOAD=y
    CONFIG_DFU_TARGET=y
    # CJSON
    CONFIG_CJSON_LIB=y
    # Download client (needed by AWS FOTA)
    CONFIG_DOWNLOAD_CLIENT=y
    CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
    ## PSM
    CONFIG_LTE_PSM_REQ_RPTAU="00100001"
    CONFIG_LTE_PSM_REQ_RAT="00000000"
    Seems not to work for me. This is the output:
    13:02:12:301 -> *** Booting Zephyr OS build v3.1.99-ncs1-1  ***
    13:02:12:306 -> I: The AWS IoT sample started, version: v1.0.0
    13:02:12:354 -> Modem IMEI: 351358815046***
    13:02:39:360 -> I: LTE cell changed: Cell ID: 6712589, Tracking area: 34101
    13:02:39:408 -> I: RRC mode: Connected
    13:02:41:089 -> I: Network registration status: Connected - roaming
    13:02:41:096 -> I: PSM parameter update: TAU: 3240, Active time: -1
    13:02:41:101 -> I: Date time obtained
    13:02:41:101 -> I: Next connection retry in 30 seconds
    13:02:41:116 -> I: AWS_IOT_EVT_CONNECTING
    13:02:44:647 -> I: AWS_IOT_EVT_CONNECTED
    13:02:44:647 -> I: Persistent session enabled
    13:02:44:647 -> I: Publishing: {
    13:02:44:652 ->         "state":        {
    13:02:44:652 ->                 "reported":     {
    13:02:44:652 ->                         "app_version":  "v1.0.0",
    13:02:44:658 ->                         "batv": 3316,
    13:02:44:658 ->                         "ts":   1680087764074
    13:02:44:658 ->                 }
    13:02:44:658 ->         }
    13:02:44:658 -> } to AWS IoT broker
    13:02:44:673 -> I: AWS_IOT_EVT_READY
    13:02:44:977 -> I: AWS_IOT_EVT_DATA_RECEIVED
    13:02:45:005 -> E: Failed to print JSON object
    13:02:45:005 -> I: AWS_IOT_EVT_PUBACK, message ID: 30604
    13:02:57:683 -> I: RRC mode: Idle
    13:03:44:651 -> I: Publishing: {
    13:03:44:657 ->         "state":        {
    13:03:44:657 ->                 "reported":     {
    13:03:44:657 ->                         "batv": 3312,
    13:03:44:657 ->                         "ts":   1680087824074
    13:03:44:669 ->                 }
    13:03:44:669 ->         }
    13:03:44:669 -> } to AWS IoT broker
    13:03:44:669 -> I: Next data publication in 60 seconds
    13:03:44:752 -> I: RRC mode: Connected
    This is the AWS console MQTT page
    To be clear, the other (default) topic works fine:
    13:40:33:455 -> I: RRC mode: Connected
    13:40:33:597 -> I: AWS_IOT_EVT_DATA_RECEIVED
    13:40:33:597 -> I: Data received from AWS IoT console: Topic: my-custom-topic/example_2 Message: {
    13:40:33:603 ->         "message":      "Hello from AWS IoT console"
    13:40:33:618 -> }
  • Thanks for sharing. I am able to reproduce with nRF Connect SDK v2.1.2. Had to rearrange some of the calls, i.e. moved the following to after reading IMEI
    if (err) {
    Here is my output:
    *** Booting Zephyr OS build v3.2.99-ncs2 ***
    I: Starting bootloader
    I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Boot source: none
    I: Swap type: none
    I: Bootloader chainload address offset: 0x10000
    I: Jumping to the first image slot
    I: Modem IMEI: 350457791991456
    +CEREG: 2,"08FF","0212410C",7
    I: LTE cell changed: Cell ID: 34750732, Tracking area: 2303
    +CSCON: 1
    +CEREG: 1,"08FF","0212410C",7,,,"11100000","11100000"
    I: Network registration status: Connected - home network
    I: SI: PSM parameter update: TAU: 3240, Active time: -1
    ent 350457791991456/settings
    I: Sent 350457791991456
    I: Sen%XTIME: "80","32300321716380","01"
    t /settings
    I: Sent my-custom-topic/example_2
    I: Publishing: {
    "state":{
    "reported":{
    "app_version":"v1.0.0",
    "batv":5117,
    "ts":1680178660424
    } to AWS IoT broker
    +CEREG: 1,"08FF","0212410C",7,,,"00100001","00000110"
    I: PSM parameter update: TAU: 3600, Active time: 60
    I: Data received from AWS IoT console: Topic: $aws/things/350457791991456/shadow/get/accepted Message: {
    "state":{
    "reported":{
    "batv":5117,
    "ts":1680178660424
    "metadata":{
    "reported":{
    "app_version":{
    "timestamp":1680178660
    "batv":{
    "ts":{
    "version":272,
    I: AWS_IOT_EVT_PUBACK, message ID: 22170
    +CSCON: 0
    I: RRC mode: Idle
    +CEREG: 1,"08FF","0209E216",7,,,"00100001","00000110"
    I: LTE cell changed: Cell ID: 34202134, Tracking area: 2303
    +CSCON: 1
    "message":"Hello from AWS IoT console - my-custom-topic/example_2"
    +CSCON: 0
    I: RRC mode: Idle
    I am able to subscribe to custom_topic_2, but not topicString
